Situation Awareness
Configuring HTTPS Certificates for ELB Ingresses
Updated on 2024-01-04 GMT+08:00
Ingress supports TLS certificate configuration and secures your Services with HTTPS.
Currently, you can use the TLS secret certificate configured in the cluster and the ELB certificate.
If HTTPS is enabled for the same port of the same load balancer of multiple ingresses, you must select the same certificate.
Using a TLS Secret Certificate
  1. Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Ingress supports two TLS secret types: kubernetes.io/tls and IngressTLS. IngressTLS is used as an example. For details, see Creating a Secret. For details about examples of the kubernetes.io/tls secret and its description, see TLS Secret.
    Run the following command to create a YAML file named ingress-test-secret.yaml (the file name can be customized):
    vi ingress-test-secret.yaml
    The YAML file is configured as follows:
    apiVersion: v1
    data:
      tls.crt: LS0******tLS0tCg==
      tls.key: LS0tL******0tLS0K
    kind: Secret
      annotations:
        description: test for ingressTLS secrets
      namespace: default
    type: IngressTLS
    In the preceding information, tls.crt and tls.key are only examples. Replace them with the actual files. The values of tls.crt and tls.key are Base64-encoded.
  3. Create a secret.
    kubectl create -f ingress-test-secret.yaml
    If information similar to the following is displayed, the secret is being created:
    secret/ingress-test-secret created
    View the created secret.
    kubectl get secrets
    If information similar to the following is displayed, the secret has been created:
    NAME                         TYPE                                  DATA      AGE
    ingress-test-secret          IngressTLS                            2         13s
  4. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    Default security policy (kubernetes.io/elb.tls-ciphers-policy) is supported only in clusters of v1.17.17 or later.
    The following uses the automatically created load balancer as an example. The YAML file is configured as follows:
    For clusters of v1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      annotations:
        kubernetes.io/elb.class: performance
        kubernetes.io/ingress.class: cce
        kubernetes.io/elb.port: '443'
        kubernetes.io/elb.autocreate:
              "type": "public",
              "bandwidth_name": "cce-bandwidth-******",
              "bandwidth_chargemode": "bandwidth",
              "bandwidth_size": 5,
              "bandwidth_sharetype": "PER",
              "eip_type": "5_bgp",
              "available_zone": [
                  "ae-ad-1a"
              "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"],
              "l7_flavor_name": "L7_flavor.elb.s1.small"
        kubernetes.io/elb.tls-ciphers-policy: tls-1-2
      tls:
      - secretName: ingress-test-secret
      rules:
      - host: foo.bar.com
        http:
          paths:
          - path: '/'
            backend:
              serviceName: <your_service_name>  # Replace it with the name of your target Service.
              servicePort: 80
            property:
    For clusters of v1.23 or later:
    kind: Ingress
      annotations:
              "type": "public",
              "available_zone": [
                  "ae-ad-1a"
      tls:
      rules:
      - host: foo.bar.com
        http:
          paths:
          - path: '/'
            backend:
              service:
                name: <your_service_name>  # Replace it with the name of your target Service.
                port:
                  number: 8080             # Replace 8080 with the port number of your target Service.
            property:
      ingressClassName: cce
    Table 1 Key parameters
    Mandatory
    Type
    No
    String
    The default value is tls-1-2, which is the default security policy used by the listener and takes effect only when HTTPS is used.
    Options:
    • tls-1-0
    • tls-1-1
    • tls-1-2
    • tls-1-2-strict
    For details of cipher suites for each security policy, see Table 2.
    tls
    No
    Array of strings
    When HTTPS is used, this parameter must be added to specify the secret certificate.
    Multiple independent domain names and certificates can be added. For details, see Configuring the Server Name Indication (SNI) for ELB Ingresses.
    secretName
    No
    String
    This parameter is mandatory if HTTPS is used. Set this parameter to the name of the created secret.
    Table 2 tls_ciphers_policy parameter description
    Security Policy
    TLS Version
    Cipher Suite
    tls-1-0
    TLS 1.2
    TLS 1.1
    TLS 1.0
    ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:AES128-SHA256:AES256-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:AES128-SHA:AES256-SHA
    tls-1-1
    TLS 1.2
    TLS 1.1
    tls-1-2
    TLS 1.2
    tls-1-2-strict
    TLS 1.2
  5. Create an ingress.
    If information similar to the following is displayed, the ingress has been created.
    ingress/ingress-test created
    View the created ingress.
    kubectl get ingress
    If information similar to the following is displayed, the ingress has been created and the workload is accessible.
    NAME             HOSTS     ADDRESS          PORTS   AGE
    ingress-test     *         121.**.**.**     80      10s
  6. Enter https://121.**.**.**:443 in the address box of the browser to access the workload (for example, Nginx workload).
    121.**.**.** indicates the IP address of the unified load balancer.
Using the ELB Certificate
To use the ELB certificate, you can specify the annotations kubernetes.io/elb.tls-certificate-ids.
  1. If you specify both the IngressTLS certificate and the ELB certificate, the latter is used.
  2. CCE does not check whether the ELB certificate is valid. It only checks whether the certificate exists.
  3. Only clusters of v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later support the ELB certificate.
kind: Ingress
  annotations:
    kubernetes.io/elb.id: 0b9a6c4d-bd8b-45cc-bfc8-ff0f9da54e95
    kubernetes.io/elb.class: union
    kubernetes.io/elb.tls-certificate-ids: 058cc023690d48a3867ad69dbe9cd6e5,b98382b1f01c473286653afd1ed9ab63
  rules:
  - host: ''
    http:
      paths:
      - path: '/'
        backend:
          servicePort: 80
        property:
kind: Ingress
  namespace: default
  annotations:
  rules:
    - host: ''
      http:
        paths:
          - path: '/'
            backend:
              service:
                port:
            property:
