How Can I Achieve Compatibility Between ExtendPathMode and Kubernetes client-go?
The Kubernetes pod structure does not contain ExtendPathMode. Therefore, when a user calls the API for creating a pod or deployment by using client-go, the created pod does not contain ExtendPathMode. CCE provides a solution to ensure compatibility with the Kubernetes client-go.
Solution
![](https://support.huaweicloud.com/intl/en-us/my-kualalumpur-1-usermanual-cce/public_sys-resources/notice_3.0-en-us.png)
- When creating a pod, you need to add kubernetes.io/extend-path-mode to annotation of the pod.
- When creating a Deployment, you need to add kubernetes.io/extend-path-mode to kubernetes.io/extend-path-mode in the template.
The following is an example YAML of creating a pod. After the kubernetes.io/extend-path-mode keyword is added to annotation, the containername, name, and mountpath fields are matched, and the corresponding extendpathmode is added to volumeMount.
apiVersion: v1 kind: Pod metadata: name: test-8b59d5884-96vdz generateName: test-8b59d5884- namespace: default selfLink: /api/v1/namespaces/default/pods/test-8b59d5884-96vdz labels: app: test pod-template-hash: 8b59d5884 annotations: kubernetes.io/extend-path-mode: '[{"containername":"container-0","name":"vol-156738843032165499","mountpath":"/tmp","extendpathmode":"PodUID"}]' metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]' ownerReferences: - apiVersion: apps/v1 kind: ReplicaSet name: test-8b59d5884 uid: 2633020b-cd23-11e9-8f83-fa163e592534 controller: true blockOwnerDeletion: true spec: volumes: - name: vol-156738843032165499 hostPath: path: /tmp type: '' - name: default-token-4s959 secret: secretName: default-token-4s959 defaultMode: 420 containers: - name: container-0 image: 'nginx:latest' env: - name: PAAS_APP_NAME value: test - name: PAAS_NAMESPACE value: default - name: PAAS_PROJECT_ID value: b6315dd3d0ff4be5b31a963256794989 resources: limits: cpu: 250m memory: 512Mi requests: cpu: 250m memory: 512Mi volumeMounts: - name: vol-156738843032165499 mountPath: /tmp extendPathMode: PodUID - name: default-token-4s959 readOnly: true mountPath: /var/run/secrets/kubernetes.io/serviceaccount terminationMessagePath: /dev/termination-log terminationMessagePolicy: File imagePullPolicy: Always restartPolicy: Always terminationGracePeriodSeconds: 30 dnsPolicy: ClusterFirst serviceAccountName: default serviceAccount: default nodeName: 192.168.0.24 securityContext: {} imagePullSecrets: - name: default-secret - name: default-secret affinity: {} schedulerName: default-scheduler tolerations: - key: node.kubernetes.io/not-ready operator: Exists effect: NoExecute tolerationSeconds: 300 - key: node.kubernetes.io/unreachable operator: Exists effect: NoExecute tolerationSeconds: 300 priority: 0 dnsConfig: options: - name: timeout value: '' - name: ndots value: '5' - name: single-request-reopen enableServiceLinks: true
Parameter |
Type |
Description |
containername |
String |
Name of a container. |
name |
String |
Name of a volume. |
mountpath |
String |
Mount path. |
extendpathmode |
String |
A third-level directory is added to the created volume directory/subdirectory to facilitate the obtaining of a single pod output file. The following types are supported.
