Configuring an HTTP or HTTPS Service
Notes and Constraints
- Only clusters of v1.19.16 or later support HTTP or HTTPS.
Table 1 Scenarios where a load balancer supports HTTP or HTTPS ELB Type
Application scenario
Whether to Support HTTP or HTTPS
Shared load balancer
Interconnecting with an existing load balancer
Yes
None
Automatically creating a load balancer
Yes
None
Dedicated load balancer
Yes (A YAML file is required.)
- For versions earlier than v1.19.16-r50, v1.21.11-r10, v1.23.9-r10, v1.25.4-r10 and v1.27.1-r10, the load balancer flavor must support both the layer-4 and layer-7 routing.
- For v1.19.16-r50, v1.21.11-r10, v1.23.9-r10, v1.25.4-r10, v1.27.1-r10, and later versions, the load balancer flavor must support layer-7 routing.
- Do not connect an ingress and a Service that uses HTTP or HTTPS to the same listener of the same load balancer. Otherwise, a port conflict occurs.
Using the CCE Console
- In the navigation pane, choose Services & Ingresses. In the upper right corner, click Create Service.
- Configure Service parameters. In this example, only mandatory parameters required for using HTTP/HTTPS are listed. For details about how to configure other parameters, see Creating a LoadBalancer Service.
- Service Name: Specify a Service name, which can be the same as the workload name.
- Service Type: Select LoadBalancer.
- Selector: Add a label and click Confirm. The Service will use this label to select pods. You can also click Reference Workload Label to use the label of an existing workload. In the dialog box that is displayed, select a workload and click OK.
- Load Balancer: Select a load balancer type and creation mode.
- A load balancer can be dedicated or shared. To enable HTTP/HTTPS on the listener port of a dedicated load balancer, the type of the load balancer must be Application (HTTP/HTTPS) or Network (TCP/UDP) & Application (HTTP/HTTPS).
- This section uses an existing load balancer as an example. For details about the parameters for automatically creating a load balancer, see Table 1.
- Ports
- Protocol: Select TCP. If you select UDP, HTTP and HTTPS will be unavailable.
- Service Port: port used by the Service. The port number ranges from 1 to 65535.
- Container Port: listener port of the workload. For example, Nginx uses port 80 by default.
- Frontend Protocol: specifies whether to enable HTTP/HTTPS on the listener port. For a dedicated load balancer, to use HTTP/HTTPS, the type of the load balancer must be Application (HTTP/HTTPS).
- Listener
- SSL Authentication: Select this option if HTTPS is enabled on the listener port.
- One-way authentication: Only the backend server is authenticated. If you also need to authenticate the identity of the client, select mutual authentication.
- Mutual authentication: If you want the clients and the load balancer to authenticate each other, select this option. Only authenticated clients will be allowed to access the load balancer.
- CA Certificate: If SSL Authentication is set to Mutual authentication, add a CA certificate to authenticate the client. A CA certificate is issued by a certificate authority (CA) and used to verify the certificate issuer. If HTTPS mutual authentication is required, HTTPS connections can be established only when the client provides a certificate issued by a specific CA.
- Server Certificate: If HTTPS is enabled on the listener port, you must select a server certificate.
- SNI: If HTTPS is enabled on the listener port, you must determine whether to add an SNI certificate. Before adding an SNI certificate, ensure the certificate contains a domain name.
If multiple HTTPS Services are released, all listeners will use the same certificate configuration.
- Click OK.
Using kubectl
If a Service is HTTP/HTTPS-compliant, add the following annotations:
- kubernetes.io/elb.protocol-port: "https:443,http:80"
The value of protocol-port must be the same as the port in the spec.ports field of the Service. The format is Protocol:Port. The port matches the one in the service.spec.ports field and is released as the corresponding protocol.
- kubernetes.io/elb.cert-id: "17e3b4f4bc40471c86741dc3aa211379"
cert-id indicates the certificate ID in ELB certificate management. When https is configured for protocol-port, the certificate of the ELB listener will be set to the server certificate. When multiple HTTPS Services are released, they will use the same certificate.
The following is a configuration example for automatically creating a dedicated load balancer, in which key configurations are marked in red:
- Different ELB types and cluster versions have different requirements on flavors. For details, see Table 1.
- The two ports in spec.ports must correspond to those in kubernetes.io/elb.protocol-port. In this example, ports 443 and 80 are enabled with HTTPS and HTTP, respectively.
apiVersion: v1 kind: Service metadata: annotations: # Specify the Layer 4 and Layer 7 flavors in the parameters for automatically creating a load balancer. kubernetes.io/elb.autocreate: ' { "type": "public", "bandwidth_name": "cce-bandwidth-1634816602057", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", "available_zone": [ "" ], "l7_flavor_name": "L7_flavor.elb.s2.small", "l4_flavor_name": "L4_flavor.elb.s1.medium" }' kubernetes.io/elb.class: performance # Dedicated load balancer kubernetes.io/elb.protocol-port: "https:443,http:80" # HTTP/HTTPS and port number, which must be the same as the port numbers in spec.ports kubernetes.io/elb.cert-id: "17e3b4f4bc40471c86741dc3aa211379" # Certificate ID of the LoadBalancer Service labels: app: nginx name: test name: test namespace: default spec: ports: - name: cce-service-0 port: 443 protocol: TCP targetPort: 80 - name: cce-service-1 port: 80 protocol: TCP targetPort: 80 selector: app: nginx version: v1 sessionAffinity: None type: LoadBalancer
Use the preceding example configurations to create a Service. In the new ELB load balancer, you can see that the listeners on ports 443 and 80 are created.
