Updated on 2026-05-26 GMT+08:00
Binding a Security Group to a Pod Using an Annotation
In cloud native network 2.0, pods use VPC network interfaces or supplementary network interfaces for networking, which allow you to configure security groups. You can bind a security group to a pod by adding an annotation to the pod.
You can configure security groups in the following applications.
Application
Annotation
Reference
Configure a pod's network interface security group via an annotation.
yangtse.io/security-group-ids
Create a workload with a security group configured.
Add an additional security group to a pod's network interface via an annotation, while retaining the existing security group.
yangtse.io/additional-security-group-ids
Add an additional security group for the workload.
Security groups can be associated with workloads through multiple methods: annotations, security group policies, node pool settings, or pod network settings. When multiple methods are used, only the highest-priority method applies. For details about priorities, see Comparison of Workload Security Group Configuration Methods.
A CCE Turbo cluster is available and the cluster version meets the following requirements:
  • v1.23: v1.23.16-r0 or later
  • v1.25: v1.25.11-r0 or later
  • v1.27: v1.27.8-r0 or later
  • v1.28: v1.28.6-r0 or later
  • v1.29: v1.29.2-r0 or later
  • Versions later than v1.29
Using kubectl
  • Create a workload with a security group configured. The security group bound to the pod is subject to the one configured using an annotation.
    If the pod has been bound to a security group, the configuration will be overwritten.
    apiVersion: apps/v1
    kind: Deployment
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          annotations:
            yangtse.io/security-group-ids: *****  # Security group ID. Use commas (,) to separate multiple security groups.
          containers:
            - name: container-0
              image: nginx:alpine
              resources:
                limits:
                  cpu: 100m
                  memory: 200Mi
                requests:
                  cpu: 100m
                  memory: 200Mi
          imagePullSecrets:
            - name: default-secret
  • Add an additional security group for the workload.
    apiVersion: apps/v1
    kind: Deployment
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          annotations:
            yangtse.io/additional-security-group-ids: *****  # Security group ID. Use commas (,) to separate multiple security groups.
          containers:
            - name: container-0
              image: nginx:alpine
              resources:
                limits:
                  cpu: 100m
                  memory: 200Mi
                requests:
                  cpu: 100m
                  memory: 200Mi
          imagePullSecrets:
Table 1 Annotations for configuring a security group for a pod
Annotation
Value Range
Configure a security group for a pod. The security group of the pod is subject to the one configured using this annotation. If the pod already has a security group, the original security group will be overwritten.
Security group IDs. Use commas (,) to separate multiple security groups. For better network performance, select no more than five security groups.
If this parameter is left blank, no annotation will be used to configure a security group for the pod.
Add more security groups to a pod.
Security group IDs. Use commas (,) to separate multiple security groups. For better network performance, keep no more than five security groups (existing and new).
