Help Center/ Cloud Container Engine/ User Guide/ Networking/ Ingresses/ LoadBalancer Ingresses/ Configuring Multiple Ingresses to Use the Same Load Balancer
Updated on 2026-09-21 GMT+08:00
Multiple Ingresses Accessing the Same External ELB Port
In a cluster, you can configure multiple ingresses to use the same ELB listener, allowing them to use the same port on a single load balancer. If two ingresses have different listener configurations, the listener configuration of the earlier ingress (known as the first route) will be used. For details about how to confirm the first route, see How Can I Determine Which Ingress the Listener Settings Have Been Applied To?
Figure 1 Diagram for multiple ingresses to use the same external ELB port
The following table lists listener parameters.
Listener
Annotation
Helpful Links
Configuring ELB Certificates
kubernetes.io/elb.tls-certificate-ids
kubernetes.io/elb.tls-ciphers-policy
Configuring an HTTPS Certificate for a LoadBalancer Ingress
When you use kubernetes.io/elb.tls-certificate-ids to configure an SNI certificate, the SNI certificate does not comply with the first route effectiveness rule. For details, see SNI Certificate Effectiveness When Multiple Ingresses Share the Same Port.
Using HTTP/2
kubernetes.io/elb.http2-enable
Configuring HTTP/2 for a LoadBalancer Ingress
Configuring Timeout for an Ingress
kubernetes.io/elb.keepalive_timeout
kubernetes.io/elb.client_timeout
kubernetes.io/elb.member_timeout
Configuring Timeout for a LoadBalancer Ingress
Configuring a Blocklist/Trustlist
kubernetes.io/elb.acl-id
kubernetes.io/elb.acl-status
kubernetes.io/elb.acl-type
Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Ingress
Configuring an HTTP/HTTPS Header
kubernetes.io/elb.x-forwarded-port
kubernetes.io/elb.x-forwarded-for-port
kubernetes.io/elb.x-forwarded-host
kubernetes.io/elb.x-real-ip
Configuring an HTTP/HTTPS Header for a LoadBalancer Ingress
Enabling GZIP
kubernetes.io/elb.gzip-enabled
Configuring GZIP Data Compression for a LoadBalancer Ingress
Configuring Mutual Authentication
kubernetes.io/elb.client-ca-cert-id
Ensure that the configurations of different listeners for various ingresses are synchronized. To do so, perform the following operations:
  2. In the navigation pane, choose Services and Ingresses. Click the Ingresses tab and choose More > Update in the Operation column.
  3. Synchronize Configuration is available if the listener configuration of the ingress differs from that of the ELB. Click Update to automatically synchronize listener settings.
Multiple Ingresses Associated with the Same Service Accessing the Same ELB Port
When you create an ingress, CCE automatically adds a backend server group on the ELB based on the associated Service.
In a cluster, if multiple ingresses access the same ELB port and are associated with the same Service and port, only one backend server group will be created on the ELB. The configuration applied to this backend server group will be that of the first ingress created (referred to as the first route). If ingresses use multiple load balancers to access the same Service, multiple backend server groups will be created. In this case, the sequence of ingress configurations does not matter. For details about how to confirm the first route, see How Can I Determine Which Ingress the Listener Settings Have Been Applied To?
Figure 2 Diagram for multiple ingresses associated with the same Service to access the same ELB port
The following table lists backend server settings.
Backend Server Setting
Annotation
Helpful Link
Slow start
kubernetes.io/elb.slowstart
Configuring a Slow Start for a LoadBalancer Ingress
