Creating an HPA Policy with Custom Metrics
Kubernetes' default HPA policy only allows for auto scaling based on CPU and memory usage. However, in more complex service scenarios, this may not be sufficient to meet routine O&M requirements. To resolve this issue, you can configure HPA policies with custom metrics, allowing for flexible workload scaling.
This section uses an example to describe how to deploy an Nginx application, which uses the container_cpu_usage_core_per_second metric exposed by Prometheus to identify the number of CPU cores used by a container on a per-second basis. For more information about Prometheus metrics, see METRIC TYPES.
Step 1: Install Cloud Native Cluster Monitoring
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Add-ons.
  2. Locate the Cloud Native Cluster Monitoring add-on and click Install.
    Prioritize the configurations listed below and adjust any other configurations as needed. For details, see Cloud Native Cluster Monitoring.
    • Data Storage Configuration: Local data storage is mandatory, and other configurations are optional.
    • Custom Metric Collection: Enable this option in this example. If this option is not enabled, custom metrics cannot be collected.
  3. Click Install.
Step 2: Create a Workload
  2. In the navigation pane of the cluster console, choose Workloads. Then, click Create Workload in the upper right corner. Create an Nginx workload. For details, see Creating a Deployment.
Step 3: Modify the Configuration File
  1. In the navigation pane of the cluster console, choose ConfigMaps and Secrets and switch to the monitoring namespace.
  2. Update user-adapter-config. You can modify the rules field in user-adapter-config to convert the metrics exposed by Prometheus to metrics that can be associated with HPA.
    Add the following example rule:
    rules:
        - seriesQuery: 'container_cpu_usage_seconds_total{namespace!="",pod!=""}'
          seriesFilters: []
          resources:
            overrides:
              namespace:
                resource: namespace
              pod:
                resource: pod
          name:
            matches: "^(.*)_seconds_total"
            as: "${1}_core_per_second"
          metricsQuery: 'sum(rate(<<.Series>>{<<.LabelMatchers>>}[1m])) by (<<.GroupBy>>)'
    In this example, the existing container_cpu_usage_seconds_total metrics are aggregated into the container_cpu_usage_core_per_second metric, which is then used for HPA policies. For details, see Metrics Discovery and Presentation Configuration.
    • seriesQuery: PromQL request data, which specifies the metrics to be obtained by users. You can configure this parameter as needed.
    • metricsQuery: aggregates the PromQL query data in seriesQuery.
    • resources: data labels in PromQL, which are used to match resources. The resources here refer to api-resource such as pods, namespaces, and nodes in a cluster. You can run kubectl api-resources -o wide to check the resources. The key corresponds to LabelName in the Prometheus data. Ensure that the Prometheus metric data contains LabelName.
    • name: indicates that Prometheus metric names are converted to readable metric names based on regular expression matching. In this example, container_cpu_usage_seconds_total is converted to container_cpu_usage_core_per_second.
  3. Redeploy the custom-metrics-apiserver workload in the monitoring namespace.
  4. Run the following command to check whether the metric has been added:
    kubectl get --raw  "/apis/custom.metrics.k8s.io/v1beta1/namespaces/default/pods/*/container_cpu_usage_core_per_second"
Step 4: Verify HPA Scaling
  1. Choose Workloads in the navigation pane. Locate the target workload and choose More > Auto Scaling in the Operation column.
  2. Set Policy Type to HPA+CronHPA and enable an HPA policy. You can use the custom metrics configured in rules to create the HPA policy.
  3. Click the workload name and switch to the Auto Scaling tab page. You can find that the HPA policy has been triggered.
