Updated on 2026-09-21 GMT+08:00
Migrating a Node
You can migrate nodes between node pools within a cluster. Table 1 lists migration scenarios.
Table 1 Migration scenarios
Migration Scenario
Operation
Source Node Pool
Target Node Pool
Custom node pool
Default node pool (DefaultPool)
Supported
Migrating Nodes from a Custom Node Pool to the Default Node Pool
Custom node pool
Supported by clusters of v1.23 or later
Migrating Nodes from the Default Node Pool to a Custom Node Pool
Custom node pool
Custom node pool
Not supported for direct migration
In certain scenarios, you may need to remove a node from management and later re-add it. Note that removing and re-adding nodes are subject to specific restrictions. Migration may not be supported in some scenarios.
  2. In the navigation pane, choose Nodes and click the Node Pools tab.
  3. Click View Node in the Operation column of the node pool to be migrated.
  4. Choose More > Migrate Node in the Operation column of the target node to migrate the node.
    Figure 1 Migrating nodes to the default node pool
  5. In the Migrate Node dialog box, confirm the information.
    • The migration does not affect custom resource tags, and Kubernetes labels and taints of the node.
    • The migration does not affect the kubelet, kube-proxy, container runtime, and node OS settings of the node.
    • After the migration, system labels cce.cloud.com and cce-nodepool on the node will be deleted. If an existing workload uses these labels for affinity or anti-affinity scheduling, the existing pods on the node will be stopped and rescheduled when kubelet is restarted.
Nodes cannot be migrated to spot pricing node pools.
  3. Locate the target node pool and choose More > Migrate Node.
    Figure 2 Migrating nodes to a custom node pool
  4. In the Migrate Node dialog box, select the nodes that meet the following conditions:
    • The nodes and the current node pool are deployed in the same VPC and subnet.
    • The nodes and the current node pool belong to the same enterprise project.
    • The nodes and the current node pool are in the same cloud server group.
    • The nodes are running and they are from the default node pool.
    • The flavor, AZ, container runtime, OS, and resource reservation settings of the nodes must match those of the node pool.
  5. Click OK.
    • After migration, node pool configurations (including resource tags, Kubernetes labels, taints, and Kubernetes component settings) will overwrite conflicting node settings.
    • After the migration, the pool's security group will take over the nodes' original security group.
    • After the migration, the pool's agency will take over the nodes' original agency.
    • After the migration, the nodes' original login mode will remain unchanged.
    • Nodes migrated to a node pool after acceptance may be removed during scale-in.
Helpful Links
Node migration refers to moving nodes between different node pools within the same cluster. To add an external cloud server to a cluster node pool, see Accepting Nodes in a Node Pool.
