Help Center/ Cloud Container Engine/ User Guide/ Nodes/ Management Nodes/ Synchronizing the Data of Cloud Servers
Updated on 2026-09-21 GMT+08:00
Each node in a cluster is a cloud server. After a cluster node is created, you can change the cloud server name or specifications as required. Modifying node specifications will affect services. Perform the operation on nodes one by one.
Some CCE node information is maintained independently of the cloud server console. After changing a cloud server's name, EIP, billing mode, or specifications on the cloud server console, synchronize it with the target node on the CCE console to ensure consistency.
Common ECS information to be modified:
  • Data, including the statuses, names, number of CPUs, memory, specifications, and public IP addresses of cloud servers, can be synchronized.
    If a cloud server name is specified as the Kubernetes node name, the change of the cloud server name cannot be synchronized to the CCE console. For details, see ECS Names, Node Names, and Kubernetes Node Names.
  • The following data cannot be synchronized: OS, image ID, and disk configuration.
Synchronizing the Data of a Cloud Server
  2. In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab.
  3. Locate the target node and choose More > Sync Server Data in the Operation column.
    Figure 1 Synchronizing server data
    After the synchronization is complete, the "ECS data synchronization requested" message is displayed in the upper right corner.
Synchronizing the Data of All Cloud Servers
  3. Click Synchronize All Cloud Server Modifications and click OK.
    Figure 2 Synchronize All Cloud Server Modifications
