Updated on 2026-09-21 GMT+08:00
AI Data Acceleration Engine
There are several key challenges that need to be addressed when using Kubernetes for AI and big data tasks, including excessive latency, inefficient bandwidth usage, insufficient data management, fragmented storage interfaces, and a lack of intelligent data awareness and scheduling resulting from the decoupling of storage and compute. To overcome these issues, CCE standard and Turbo clusters integrate the AI Data Acceleration Engine add-on, built on Fluid. This add-on enables functions like dataset abstraction, data orchestration, and application orchestration. It empowers AI and big data applications to efficiently use stored data without altering existing applications, thanks to transparent data management and optimized scheduling.
Fluid Overview
Fluid is a cloud-native distributed dataset orchestration and acceleration engine designed for big data and AI applications. Through transparent data management and optimized scheduling, it enables AI and big data workloads to access stored data efficiently without requiring modifications to existing applications. Fluid supports automatic data scheduling, cache acceleration, and auto scaling to improve data access efficiency and promote efficient storage-compute collaboration in large-scale distributed environments.
  • This add-on uses templates and images from the open-source community. Since it is based on community versions, there may be defects. CCE periodically synchronizes with updated community versions to address known issues. Check whether your service requirements can be met.
  • This add-on only supports data caching via the JuiceFS storage engine. JuiceFS is a cloud native distributed file system that transforms object storage (like OBS) into high-performance local disks. It provides multi-level cache acceleration and integrates seamlessly into CCE, making it ideal for the massive data scenarios such as AI training and big data analytics.
  • This add-on is being deployed. To view the regions where this add-on is available, see the console.
  • This add-on is in the OBT phase. You can experience the latest add-on features. However, the stability of this add-on version has not been fully verified, and the CCE SLA is not valid for this version.
Billing
Installing the Add-on
  2. In the navigation pane, choose Add-ons. Locate AI Data Acceleration Engine on the right and click Install.
  3. In the lower right corner of the Install Add-on page, click Install. If the status of the AI Data Acceleration Engine add-on changes to Running, the add-on has been installed.
Components
Table 2 Add-on components
Component
Resource Type
application-controller
Schedules and runs application pods that use datasets. It retrieves cache from the runtime and preferentially schedules the pods that use datasets to nodes with cached data.
Deployment
csi-nodeplugin-fluid
A storage component of the add-on, which runs in containers. It is decoupled from service containers and provides observability for storage resources.
DaemonSet
dataset-controller
Manages the lifecycle of datasets, including binding cache engines.
Deployment
fluid-crd-upgrader
A CRD upgrade component of the add-on. It updates CRDs in add-on upgrade scenarios based on the add-on versions.
Job
fluid-webhook
Replaces the PVC with a FUSE sidecar and ensures the FUSE pod starts first in environments where CSI plugins cannot be used.
Deployment
juicefsruntime-controller
Manages and schedules JuiceFS runtime-related resources like computing tasks and configurations. It can, for example, dynamically scale cache nodes based on system loads.
Deployment
Use Case
JuiceFS has an architecture where service data and metadata are stored separately. In this use case, the data used by the service pod is stored in OBS, and the metadata generated by JuiceFS is stored in DCS for Redis. This use case shows how to use JuiceFS to abstract data stored in OBS into a dataset and provide the dataset for workloads through a JuiceFSRuntime.
Table 3 Operation process
Create an OBS bucket.
The OBS bucket functions as an underlying data source. It stores service data to be used by pods.
Create a DCS Redis instance.
The DCS Redis instance stores the metadata generated by JuiceFS.
Create a secret.
The secret is used as the identity credential for JuiceFS to access the OBS bucket and DCS Redis instance to read and store related data.
Create a dataset.
The dataset defines and manages data sources and access policies, ensuring workloads in the cluster use stored data appropriately and efficiently.
After the dataset is created, the system will create a worker pod to initialize OBS data and convert the data into the JuiceFS directory format.
Create a JuiceFSRuntime.
The JuiceFSRuntime integrates the JuiceFS storage volumes into the cluster in an efficient, scalable manner; provides data caching, access acceleration, and automatic management; and ensures that applications can access and use data stored in the dataset efficiently.
CCE only supports the CSI mode. In this mode, the dataset is cached in a FUSE pod, which is then mounted to a service pod as a PVC. Typically, after you create a JuiceFSRuntime, the FUSE pod, PV, and PVC are generated automatically. The FUSE pod uses lazy startup by default and is launched alongside the service pod.
Create a service pod and use an automatically created PVC and PV.
A FUSE pod is created alongside the service pod. The internal data of the FUSE pod can be used by the service pod via a PVC.
  1. Create an OBS bucket to store service data.
    1. Log in to the OBS console. In the navigation pane, choose Object Storage.
    2. In the upper right corner of the page, click Create Bucket and configure related parameters as required. The following is an example.
      Figure 3 Creating a bucket
      Table 4 Parameters
      Example Value
      Bucket Name
      juicefs-data
      The name of a bucket, which must be unique across all users. After a bucket is created, its name cannot be changed.
      Naming rules:
      • Each OBS bucket name must be 3 to 63 characters long. Only lowercase letters, digits, hyphens (-), and periods (.) are allowed.
      • An OBS bucket name cannot start or end with a period (.) or hyphen (-), and cannot contain two consecutive periods (..) or contain a period (.) and a hyphen (-) adjacent to each other.
      • An OBS bucket name cannot be an IP address.
      Data Redundancy Policy
      Multi-AZ storage
      The data redundancy policy of a bucket. The policy cannot be modified after the bucket is created.
      • Multi-AZ storage: Data is stored in multiple AZs to achieve higher reliability.
      • Single-AZ storage: Data is stored in a single AZ, which costs less.
      For details about the performance comparison between multi-AZ and single-AZ storage, see Comparison of Storage Classes.
      Storage Class
      Standard
      The storage class of a bucket. Different storage classes meet different needs for performance and costs.
      • Standard: For storing a large number of hot files or small files that are frequently accessed (multiple times per month on average) and require fast access.
      • Infrequent Access: For storing data that is less frequently accessed (less than 12 times per year on average), but when needed, the access has to be fast.
      • Archive: For archiving data that is rarely accessed (once a year on average) and does not require fast access.
      • Deep Archive: For storing data that is very rarely accessed and does not require fast access.
      For details, see Storage Class.
      Bucket Policy
      Private
      The read and write permissions of a bucket.
      • Private: Only users granted permissions by the bucket ACL can access the bucket.
      • Public Read: Anyone can read objects in the bucket.
      • Public Read/Write: Anyone can read, write, or delete objects in the bucket.
      • Replicate Bucket Policy: The policy of the selected source bucket will be applied to the bucket you are creating. This option is only available if you have selected a bucket as the replication source.
    3. After configuring the parameters, click Create Now in the lower right corner.
    4. After creating the bucket, click the bucket name in the bucket list. On the page displayed, choose Overview in the navigation pane. In the Domain Name Details area, you can see the access domain name of the bucket. The access domain name will be used to configure the secret that allows access from JuiceFS.
      Figure 4 Checking the access domain name of a bucket
  2. Create a DCS Redis instance to store metadata generated by JuiceFS, such as file or directory attributes and data block mapping.
    1. On the Buy DCS Instance page, click the Quick Config tab and configure parameters as required. An example is shown below. This example describes only mandatory parameters. For details about more parameters, see Buying a DCS Redis Instance.
      Figure 5 Creating a DCS Redis instance
      Table 5 Parameters
      Example Value
      Specifications Settings
      Basic - 16GB
      Select an edition with the specifications you require. Each edition includes the product type, memory specifications, version, and instance type. For details about the differences between these specifications, see Buying a DCS Redis Instance.
      VPC
      vpc-default
      Select the same VPC as the CCE cluster.
      Subnet
      subnet-observe
      Select an existing subnet.
    2. After the configuration is complete, click Pay Now in the lower right corner. After confirming the specifications, click Submit in the lower right corner. If the status of the DCS Redis instance changes to Running, the instance has been created.
    3. Click the name of the created DCS Redis instance. In the Connection area on the right of the Basic Information page, check the IP address of the instance. This IP address will be used to configure the secret that allows access from JuiceFS.
      Figure 6 Checking the IP address of a DCS Redis instance
  3. Install kubectl on an existing ECS and access a cluster using kubectl. For details, see Accessing a Cluster Using kubectl.
  4. Create a secret for JuiceFS to access the OBS bucket and DCS Redis instance.
    1. Create a YAML file for a secret.
      vim juicefs-secret.yaml
      The file content is as follows:
      apiVersion: v1
      kind: Secret
      type: Opaque
      stringData:
        metaurl: "redis://192.168.0.137:6379/0"
        storage: obs
        bucket: "https://<OBS bucket access address>"
        access-key: <Access key ID>
        secret-key: <Secret access key>
        envs: "{TZ: Asia/Shanghai}"    # Set the time zone of the mount pod. The default time zone is UTC.
      Table 6 Parameters
      Example Value
      metaurl
      Specifies the metadata storage location. For details about how to obtain the IP address of a DCS Redis instance, see 2.c.
      storage
      obs
      Specifies the storage type used by a file system. The value is fixed at obs in Huawei Cloud.
      bucket
      Specifies the storage access address of an OBS bucket. For details, see 1.d.
      access-key
      <Access key ID>
      Specifies the access key ID of an IAM user. It is used as the identity authentication information for accessing the storage. For details, see My Credentials
      secret-key
      <Secret access key>
      Specifies the secret access key of an IAM user. It is used as the identity authentication information for accessing the storage. For details, see My Credentials.
    2. Create the secret.
      kubectl create -f juicefs-secret.yaml
      If information similar to the following is displayed, the resource has been created:
      secret/juicefs-secret-test3 created
  5. Create a dataset for defining the data source.
    1. Create a YAML file for a dataset.
      vim dataset.yaml
      The file content is shown below. This example describes only some parameters.
      apiVersion: data.fluid.io/v1alpha1
      kind: Dataset
        mounts:  # Only one mount can be defined per dataset. If multiple mounts are required, separate datasets must be created.
          - name: juicefs-obs-test3
            mountPoint: "juicefs:///demo"
            options:
              bucket: "https://<OBS access domain name>"
              storage: "obs"    # The value is fixed at obs.
            encryptOptions:     #  Configure a storage access credential for a dataset.
              - name: metaurl
                valueFrom:
                  secretKeyRef:
                    key: metaurl
              - name: access-key
                valueFrom:
                  secretKeyRef:
                    key: access-key
              - name: secret-key
                valueFrom:
                  secretKeyRef:
                    key: secret-key
      Table 7 Parameters
      Example Value
      mounts.name
      juicefs-obs-test3
      The name of an object used to store a dataset in an OBS bucket
      mountPoint
      "juicefs:///demo"
      A subdirectory in JuiceFS where data will be stored. The value must start with juicefs://, for example, juicefs:///demo. In this example, /demo refers to a subdirectory within JuiceFS, and juicefs:/// represents the root directory of JuiceFS.
      encryptOptions
      N/A
      The JuiceFS authentication information, which must be the same as the key in the secret created previously
    2. Create the dataset.
      kubectl create -f dataset.yaml
      dataset.data.fluid.io/jfsdemo created
    3. Check whether the worker pod has been created. After the dataset is created, AI Data Acceleration Engine creates the worker pod to initialize OBS data and convert the data into the JuiceFS directory format.
      kubectl get pod
      If information similar to the following is displayed, the worker pod has been created:
      NAME                               READY   STATUS    RESTARTS   AGE
      jfsdemo-worker-0                   1/1     Running   0          15h
  6. Create a JuiceFSRuntime to ensure that applications can efficiently access and use data stored in the dataset. A JuiceFSRuntime can only be bound to one dataset, and both must share the same name for proper functionality. If multiple underlying data sources are needed, separate JuiceFSRuntimes and corresponding datasets must be created.
    1. Create a YAML file for a JuiceFSRuntime.
      vim runtime.yaml
      kind: JuiceFSRuntime
        replicas: 1
        tieredstore:
          levels:
            - mediumtype: SSD
              path: /cache
              quota: 40960
              low: "0.1"
      Table 8 Parameters
      Example Value
      mediumtype
      SSD
      Specifies the type of the storage device used by the cache directory. The value can be MEM, SSD, or HDD.
      This field is only a flag and does not necessarily indicate that the underlying storage is memory, SSD, or HDD. The actual storage medium depends on the path setting.
      If the value is MEM, the AI Data Acceleration Engine add-on automatically configures the memory requests and limits of containers based on the quota setting to ensure that the containers have proper memory requests.
      path
      /cache
      A path for storing the local cache.
      If multiple disks are used for caching, multiple directories can be specified using colons (:). To use a storage device, set this parameter to /dev/shm.
      quota
      40960
      The maximum cache capacity per worker pod (cache cluster member), in MiB. The total available space in a cache cluster is obtained by multiplying this value by the number of replicas.
      low
      "0.1"
      The minimum percentage of the space that can be left in a cache disk. The default value is 0.2. The example value is 0.1, which means that up to 90% of the space can be used in a cache disk.
    2. Create the JuiceFSRuntime.
      kubectl create -f runtime.yaml
      juicefsruntime.data.fluid.io/jfsdemo created
  7. Check whether the created dataset and JuiceFSRuntime are functioning properly.
    1. Check the status of the JuiceFSRuntime.
      kubectl get juicefs
      If information similar to the following is displayed and the worker phase of the JuiceFSRuntime is in the Ready state, jfsdemo is functioning properly:
      The FUSE pod of JuiceFS is in lazy startup mode and is only created when needed.
      NAME      WORKER PHASE   FUSE PHASE   AGE
      jfsdemo   Ready          Ready        25h
    2. Check the status of the dataset.
      kubectl get dataset
      If information similar to the following is displayed and the dataset is in the Bound state, the dataset is functioning properly:
      NAME      UFS TOTAL SIZE   CACHED   CACHE CAPACITY   CACHED PERCENTAGE   PHASE   AGE
      jfsdemo   0.00B            0.00B    40.00KiB         0.0%                Bound   25h
  8. After the dataset and JuiceFSRuntime are ready, view the related information of the PV and PVC that are automatically created by the AI Data Acceleration Engine add-on for the dataset.
    1. Check the PVC information.
      kubectl get pvc
      Information similar to the following is displayed:
      NAME      STATUS   VOLUME            CAPACITY   ACCESS MODES   STORAGECLASS   VOLUMEATTRIBUTESCLASS   AGE
      jfsdemo   Bound    default-jfsdemo   100Pi      RWX            fluid          <unset>                 25h
    2. Check the PV information.
      kubectl get pv
      NAME              CAPACITY   ACCESS MODES   RECLAIM POLICY   STATUS   CLAIM             STORAGECLASS   VOLUMEATTRIBUTESCLASS   REASON   AGE
      default-jfsdemo   100Pi      RWX            Retain           Bound    default/jfsdemo   fluid          <unset>                          25h
    The preceding command output indicates that the PVC and PV have been automatically bound, meaning the storage is ready for direct mounting to the pod.
  9. Create a service pod and associate the preceding PVC and PV with it.
    1. Create a YAML file for a workload.
      vim pod.yaml
      apiVersion: v1
      kind: Pod
        containers:
          - name: demo
            image: nginx
            volumeMounts:
              - mountPath: /data
                name: demo  # The name of the volume to be mounted
        volumes:
          - name: demo
            persistentVolumeClaim:
              claimName: jfsdemo   # The PVC that has been automatically created
    2. Create the pod.
      kubectl create -f pod.yaml
      pod/demo-app created
  10. Check the statuses of the service pod and FUSE pod.
    kubectl get pod
    If information similar to the following is displayed, the service pod and FUSE pod are started and the PVC is mounted properly to the pod.
    demo-app                           1/1     Running   0          3s
    jfsdemo-fuse-twwdh                 1/1     Running   0          3s
    jfsdemo-worker-0                   1/1     Running   0          17h
Release History
Table 9 AI Data Acceleration Engine add-on
Add-on Version
Supported Cluster Version
New Feature
Community Version
1.0.5
v1.28
v1.29
v1.30
v1.31
CCE standard and Turbo clusters support the AI Data Acceleration Engine add-on.
1.0.5
