Node Specifications
Node flavors vary depending on regions, and some flavors may be unavailable due to insufficient resources. To obtain available node flavors, log in to the CCE console and switch to the page for creating nodes.
In CCE Turbo clusters, pods need to occupy network interfaces or supplementary network interfaces of nodes. The number of pods you can create on a node depends on how many network interfaces that node has. You need to evaluate the number of network interfaces that can be attached to each node. For details, see Maximum Number of Pods That Can Be Created on a Node.
| Node Type | Description | Flavors |
| ECS (VM) | ECS running on a KVM or QingTian hypervisor. Multiple flavors are offered to meet your compute and storage needs for various applications. | x86:
Arm (Kunpeng): Heterogeneous: |
| ECS (PM) | ECS running on a QingTian-backed bare-metal hypervisor. PM resources and VM resources of such an ECS are in the same resource pool and can be dynamically scheduled. | |
| BMS | BMS offering high-performance computing at low latency for containers. |
General Computing-plus ECSs
General computing-plus ECSs use dedicated vCPUs and next-generation network acceleration engines to provide powerful compute and network performance.
| ECS Type | Compute | Network | Supported Cluster Type |
| aC9 |
| CCE standard clusters CCE Turbo clusters |
| aC9s |
| C9 |
| aC8 |
| aC7 |
| C7t |
| C7 |
| C6ne |
| C6s |
| CCE standard clusters |
| C6 |
| aC6 |
| C3 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Network Connections (10,000) | Max. NIC Queues | Max. NICs | Max. Supplementary NICs | Max./Assured EVS Disk Bandwidth (Gbit/s) | Max. EVS Disk IOPS (10,000) | Max. EVS Disks | Virtualization |
| ac9.large.2 | 2 | 4 | 20/2.5 | 100 | 75 | 2 | 3 | 8 | 8/0.4 | 11 | 24 | QingTian |
| ac9.xlarge.2 | 4 | 8 | 20/4 | 150 | 150 | 4 | 3 | 16 | 8/0.8 | 11 | 24 | |
| ac9.2xlarge.2 | 8 | 16 | 20/6 | 200 | 200 | 8 | 4 | 32 | 8/1.6 | 11 | 24 | |
| ac9.4xlarge.2 | 16 | 32 | 30/10 | 300 | 300 | 16 | 6 | 64 | 8/3.2 | 11 | 24 | |
| ac9.8xlarge.2 | 32 | 64 | 40/20 | 500 | 400 | 32 | 6 | 128 | 8/6.4 | 11 | 60 | |
| ac9.16xlarge.2 | 64 | 128 | 60/30 | 1,000 | 600 | 64 | 8 | 256 | 16/12.8 | 21 | 60 | |
| ac9.32xlarge.2 | 128 | 256 | 100/60 | 2,000 | 800 | 64 | 10 | 256 | 32/25.6 | 43 | 60 | |
| ac9.48xlarge.2 | 192 | 384 | 120/90 | 3,000 | 1,000 | 64 | 12 | 256 | 48/38.4 | 64 | 60 | |
| ac9.large.4 | 2 | 8 | 20/2.5 | 100 | 75 | 2 | 3 | 8 | 8/0.4 | 11 | 24 | |
| ac9.xlarge.4 | 4 | 16 | 20/4 | 150 | 150 | 4 | 3 | 16 | 8/0.8 | 11 | 24 | |
| ac9.2xlarge.4 | 8 | 32 | 20/6 | 200 | 200 | 8 | 4 | 32 | 8/1.6 | 11 | 24 | |
| ac9.4xlarge.4 | 16 | 64 | 30/10 | 300 | 300 | 16 | 6 | 64 | 8/3.2 | 11 | 24 | |
| ac9.8xlarge.4 | 32 | 128 | 40/20 | 500 | 400 | 32 | 6 | 128 | 8/6.4 | 11 | 60 | |
| ac9.16xlarge.4 | 64 | 256 | 60/30 | 1,000 | 600 | 64 | 8 | 256 | 16/12.8 | 21 | 60 | |
| ac9.32xlarge.4 | 128 | 512 | 100/60 | 2,000 | 800 | 64 | 10 | 256 | 32/25.6 | 43 | 60 | |
| ac9.48xlarge.4 | 192 | 768 | 120/90 | 3,000 | 1,000 | 64 | 12 | 256 | 48/38.4 | 64 | 60 |
| ac9s.large.2 | 2 | 4 | 20/2 | 90 | 75 | 2 | 3 | 8 | 6/0.3 | 7 | 24 | QingTian |
| ac9s.xlarge.2 | 4 | 8 | 20/3 | 100 | 150 | 4 | 3 | 16 | 6/0.5 | 7 | 24 | |
| ac9s.2xlarge.2 | 8 | 16 | 20/5 | 160 | 200 | 8 | 3 | 32 | 6/1.1 | 7 | 24 | |
| ac9s.4xlarge.2 | 16 | 32 | 30/8 | 200 | 300 | 16 | 6 | 64 | 6/2.1 | 7 | 24 | |
| ac9s.8xlarge.2 | 32 | 64 | 40/12 | 350 | 400 | 32 | 6 | 128 | 6/4.3 | 7 | 60 | |
| ac9s.16xlarge.2 | 64 | 128 | 60/25 | 700 | 600 | 64 | 8 | 256 | 11/8.5 | 15 | 60 | |
| ac9s.32xlarge.2 | 128 | 256 | 100/45 | 1,400 | 800 | 64 | 10 | 256 | 21/17 | 28 | 60 | |
| ac9s.large.4 | 2 | 8 | 20/2 | 90 | 75 | 2 | 3 | 8 | 6/0.3 | 7 | 24 | |
| ac9s.xlarge.4 | 4 | 16 | 20/3 | 100 | 150 | 4 | 3 | 16 | 6/0.5 | 7 | 24 | |
| ac9s.2xlarge.4 | 8 | 32 | 20/5 | 160 | 200 | 8 | 3 | 32 | 6/1.1 | 7 | 24 | |
| ac9s.4xlarge.4 | 16 | 64 | 30/8 | 200 | 300 | 16 | 6 | 64 | 6/2.1 | 7 | 24 | |
| ac9s.8xlarge.4 | 32 | 128 | 40/12 | 350 | 400 | 32 | 6 | 128 | 6/4.3 | 7 | 60 | |
| ac9s.16xlarge.4 | 64 | 256 | 60/25 | 700 | 600 | 64 | 8 | 256 | 11/8.5 | 15 | 60 | |
| ac9s.32xlarge.4 | 128 | 512 | 100/45 | 1,400 | 800 | 64 | 10 | 256 | 21/17 | 28 | 60 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Network Connections (10,000) | Max. NIC Queues | Max. NICs | Max. Supplementary NICs | Max. EVS Disk Bandwidth (Gbit/s) | Max. EVS Disk IOPS (10,000) | Max. EVS Disks | Virtualization |
| c9.large.2 | 2 | 4 | 20/3 | 100 | 75 | 2 | 2 | 16 | 11 | 11 | 24 | QingTian |
| c9.xlarge.2 | 4 | 8 | 20/5 | 160 | 200 | 4 | 3 | 32 | 11 | 11 | 24 | |
| c9.2xlarge.2 | 8 | 16 | 20/8 | 200 | 300 | 8 | 6 | 64 | 11 | 11 | 24 | |
| c9.3xlarge.2 | 12 | 24 | 25/10 | 275 | 350 | 12 | 8 | 128 | 11 | 11 | 24 | |
| c9.4xlarge.2 | 16 | 32 | 30/12 | 350 | 400 | 16 | 8 | 128 | 11 | 11 | 24 | |
| c9.6xlarge.2 | 24 | 48 | 35/18 | 400 | 500 | 16 | 8 | 192 | 11 | 11 | 24 | |
| c9.8xlarge.2 | 32 | 64 | 40/25 | 700 | 600 | 32 | 8 | 256 | 11 | 11 | 60 | |
| c9.12xlarge.2 | 48 | 96 | 50/36 | 800 | 650 | 32 | 8 | 256 | 16 | 17 | 60 | |
| c9.16xlarge.2 | 64 | 128 | 60/40 | 1,400 | 700 | 64 | 8 | 256 | 21 | 23 | 60 | |
| c9.24xlarge.2 | 96 | 192 | 80/45 | 1,800 | 800 | 64 | 10 | 256 | 32 | 35 | 60 | |
| c9.32xlarge.2 | 128 | 256 | 100/80 | 2,000 | 1,000 | 64 | 10 | 256 | 43 | 46 | 60 | |
| c9.48xlarge.2 | 192 | 376 | 120/102 | 4,000 | 1,000 | 64 | 12 | 256 | 64 | 70 | 60 | |
| c9.large.4 | 2 | 8 | 20/3 | 100 | 75 | 2 | 2 | 16 | 11 | 11 | 24 | |
| c9.xlarge.4 | 4 | 16 | 20/5 | 160 | 200 | 4 | 3 | 32 | 11 | 11 | 24 | |
| c9.2xlarge.4 | 8 | 32 | 20/8 | 200 | 300 | 8 | 6 | 64 | 11 | 11 | 24 | |
| c9.3xlarge.4 | 12 | 48 | 25/10 | 275 | 350 | 8 | 8 | 128 | 11 | 11 | 24 | |
| c9.4xlarge.4 | 16 | 64 | 30/12 | 350 | 400 | 16 | 8 | 128 | 11 | 11 | 24 | |
| c9.6xlarge.4 | 24 | 96 | 35/18 | 400 | 500 | 16 | 8 | 192 | 11 | 11 | 24 | |
| c9.8xlarge.4 | 32 | 128 | 40/25 | 700 | 600 | 32 | 8 | 256 | 11 | 11 | 60 | |
| c9.12xlarge.4 | 48 | 192 | 50/36 | 800 | 650 | 32 | 8 | 256 | 16 | 17 | 60 | |
| c9.16xlarge.4 | 64 | 256 | 60/40 | 1,400 | 700 | 64 | 8 | 256 | 21 | 23 | 60 | |
| c9.24xlarge.4 | 96 | 384 | 80/45 | 1,800 | 800 | 64 | 10 | 256 | 32 | 35 | 60 | |
| c9.32xlarge.4 | 128 | 512 | 100/80 | 2,000 | 1,000 | 64 | 10 | 256 | 43 | 46 | 60 | |
| c9.48xlarge.4 | 192 | 752 | 120/102 | 4,000 | 1,000 | 64 | 12 | 256 | 64 | 70 | 60 |
| ac8.large.2 | 2 | 4 | 20/2 | 90 | 75 | 2 | 3 | 8 | 6/0.3 | 5 | 24 | QingTian |
| ac8.xlarge.2 | 4 | 8 | 20/3 | 100 | 150 | 4 | 3 | 16 | 6/0.5 | 5 | 24 | |
| ac8.2xlarge.2 | 8 | 16 | 20/5 | 160 | 200 | 8 | 3 | 32 | 6/1.1 | 5 | 24 | |
| ac8.4xlarge.2 | 16 | 32 | 30/8 | 200 | 300 | 16 | 4 | 64 | 6/2.1 | 5 | 24 | |
| ac8.8xlarge.2 | 32 | 64 | 40/12 | 350 | 400 | 32 | 4 | 128 | 6/4.3 | 5 | 60 | |
| ac8.12xlarge.2 | 48 | 96 | 50/18 | 500 | 500 | 48 | 4 | 256 | 8/6.4 | 7 | 60 | |
| ac8.16xlarge.2 | 64 | 128 | 60/25 | 700 | 600 | 64 | 4 | 256 | 11/8.5 | 10 | 60 | |
| ac8.24xlarge.2 | 96 | 192 | 80/35 | 1,000 | 700 | 64 | 8 | 256 | 16/13 | 13 | 60 | |
| ac8.32xlarge.2 | 128 | 256 | 100/45 | 1,400 | 800 | 64 | 10 | 256 | 21/17 | 17 | 60 | |
| ac8.48xlarge.2 | 192 | 384 | 120/65 | 2,000 | 1,000 | 64 | 12 | 256 | 32/26 | 25 | 60 | |
| ac8.large.4 | 2 | 8 | 20/2 | 90 | 75 | 2 | 3 | 8 | 6/0.3 | 5 | 24 | QingTian |
| ac8.xlarge.4 | 4 | 16 | 20/3 | 100 | 150 | 4 | 3 | 16 | 6/0.5 | 5 | 24 | |
| ac8.2xlarge.4 | 8 | 32 | 20/5 | 160 | 200 | 8 | 3 | 32 | 6/1.1 | 5 | 24 | |
| ac8.4xlarge.4 | 16 | 64 | 30/8 | 200 | 300 | 16 | 4 | 64 | 6/2.1 | 5 | 24 | |
| ac8.8xlarge.4 | 32 | 128 | 40/12 | 350 | 400 | 32 | 4 | 128 | 6/4.3 | 5 | 60 | |
| ac8.12xlarge.4 | 48 | 192 | 50/18 | 500 | 500 | 48 | 4 | 256 | 8/6.4 | 7 | 60 | |
| ac8.16xlarge.4 | 64 | 256 | 60/25 | 700 | 600 | 64 | 4 | 256 | 11/8.5 | 10 | 60 | |
| ac8.24xlarge.4 | 96 | 384 | 80/35 | 800 | 700 | 64 | 8 | 256 | 16/13 | 13 | 60 | |
| ac8.32xlarge.4 | 128 | 512 | 100/45 | 1,400 | 800 | 64 | 10 | 256 | 21/17 | 17 | 60 | |
| ac8.48xlarge.4 | 192 | 768 | 120/65 | 2,000 | 1,000 | 64 | 12 | 256 | 32/26 | 25 | 60 |
| ac7.large.2 | 2 | 4 | 2/1 | 40 | 100 | 2 | 2 | 16 | 5/0.2 | 1 | 60 | KVM |
| ac7.xlarge.2 | 4 | 8 | 3/1.5 | 60 | 150 | 2 | 3 | 32 | 5/0.5 | 1.5 | 60 | |
| ac7.2xlarge.2 | 8 | 16 | 4/2.5 | 100 | 200 | 4 | 4 | 64 | 5/1 | 2 | 60 | |
| ac7.4xlarge.2 | 16 | 32 | 8/5 | 200 | 400 | 8 | 8 | 128 | 5/2 | 3 | 60 | |
| ac7.8xlarge.2 | 32 | 64 | 15/8 | 300 | 600 | 16 | 8 | 256 | 5/4 | 5 | 60 | |
| ac7.12xlarge.2 | 48 | 96 | 22/12 | 400 | 700 | 16 | 8 | 256 | 7.5/6 | 7 | 60 | |
| ac7.16xlarge.2 | 64 | 128 | 28/16 | 550 | 800 | 24 | 12 | 256 | 10/8 | 10 | 60 | |
| ac7.24xlarge.2 | 96 | 192 | 40/25 | 800 | 1,000 | 24 | 12 | 256 | 15/12 | 13 | 60 | |
| ac7.29xlarge.2 | 116 | 216 | 50/30 | 950 | 1,200 | 32 | 16 | 256 | 18/14 | 14 | 60 | |
| ac7.32xlarge.2 | 128 | 256 | 55/35 | 1,000 | 1,300 | 32 | 16 | 256 | 20/16 | 17 | 60 | |
| ac7.48xlarge.2 | 192 | 384 | 100/80 | 1,600 | 1,800 | 32 | 16 | 256 | 30/24 | 25 | 60 | |
| ac7.58xlarge.2 | 232 | 432 | 120/100 | 2,000 | 2,000 | 32 | 16 | 256 | None/36 | 30 | 60 | |
| ac7.large.4 | 2 | 8 | 2/1 | 40 | 100 | 2 | 2 | 16 | 5/0.2 | 1 | 60 | |
| ac7.xlarge.4 | 4 | 16 | 3/1.5 | 60 | 150 | 2 | 3 | 32 | 5/0.5 | 1.5 | 60 | |
| ac7.2xlarge.4 | 8 | 32 | 4/2.5 | 100 | 200 | 4 | 4 | 64 | 5/1 | 2 | 60 | |
| ac7.4xlarge.4 | 16 | 64 | 8/5 | 200 | 400 | 8 | 8 | 128 | 5/2 | 3 | 60 | |
| ac7.8xlarge.4 | 32 | 128 | 15/8 | 300 | 600 | 16 | 8 | 256 | 5/4 | 5 | 60 | |
| ac7.12xlarge.4 | 48 | 192 | 22/12 | 400 | 700 | 16 | 8 | 256 | 7.5/6 | 7 | 60 | |
| ac7.16xlarge.4 | 64 | 256 | 28/16 | 550 | 800 | 24 | 12 | 256 | 10/8 | 10 | 60 | |
| ac7.24xlarge.4 | 96 | 384 | 40/25 | 800 | 1,000 | 24 | 12 | 256 | 15/12 | 13 | 60 | |
| ac7.29xlarge.4 | 116 | 464 | 50/30 | 950 | 1,200 | 32 | 16 | 256 | 18/14 | 14 | 60 | |
| ac7.32xlarge.4 | 128 | 512 | 55/35 | 1,000 | 1,300 | 32 | 16 | 256 | 20/16 | 17 | 60 | |
| ac7.48xlarge.4 | 192 | 768 | 100/80 | 1,600 | 1,800 | 32 | 16 | 256 | 30/24 | 25 | 60 | |
| ac7.58xlarge.4 | 232 | 928 | 120/100 | 2,000 | 2,000 | 32 | 16 | 256 | None/36 | 30 | 60 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Network Connections (10,000) | Max. NIC Queues | Max. NICs | Max. Supplementary NICs | Assured EVS Disk Bandwidth (Gbit/s) | Assured EVS Disk IOPS (10,000) | Max. EVS Disks | Virtualization |
| c7t.large.2 | 2 | 4 | 10/1.28 | 80 | 50 | 2 | 2 | 16 | 1.5 | 1 | 60 | QingTian |
| c7t.xlarge.2 | 4 | 8 | 16/2.56 | 150 | 50 | 2 | 3 | 32 | 2 | 2 | 60 | |
| c7t.2xlarge.2 | 8 | 16 | 20/4 | 200 | 100 | 4 | 4 | 64 | 3 | 2.5 | 60 | |
| c7t.3xlarge.2 | 12 | 24 | 34/6.4 | 300 | 150 | 4 | 6 | 96 | 4 | 3 | 60 | |
| c7t.4xlarge.2 | 16 | 32 | 40/8 | 400 | 150 | 8 | 8 | 128 | 5 | 4 | 60 | |
| c7t.6xlarge.2 | 24 | 48 | 50/14.4 | 600 | 200 | 8 | 8 | 192 | 6 | 6 | 60 | |
| c7t.8xlarge.2 | 32 | 64 | 60/16 | 800 | 300 | 16 | 8 | 256 | 8 | 7.5 | 60 | |
| c7t.12xlarge.2 | 48 | 96 | 70/28.8 | 1,200 | 400 | 16 | 8 | 256 | 10 | 11.25 | 60 | |
| c7t.16xlarge.2 | 64 | 128 | 72/32 | 1,500 | 500 | 28 | 8 | 256 | 16 | 16 | 60 | |
| c7t.24xlarge.2 | 96 | 192 | 80/40 | 2,400 | 800 | 32 | 8 | 256 | 20 | 22.5 | 60 | |
| c7t.32xlarge.2 | 128 | 256 | 90/48 | 3,000 | 1,000 | 32 | 8 | 256 | 24 | 30 | 60 | |
| c7t.large.4 | 2 | 8 | 10/1.28 | 80 | 50 | 2 | 2 | 16 | 1.5 | 1 | 60 | QingTian |
| c7t.xlarge.4 | 4 | 16 | 16/2.56 | 150 | 50 | 2 | 3 | 32 | 2 | 2 | 60 | |
| c7t.2xlarge.4 | 8 | 32 | 20/4 | 200 | 100 | 4 | 4 | 64 | 3 | 2.5 | 60 | |
| c7t.3xlarge.4 | 12 | 48 | 34/6.4 | 300 | 150 | 4 | 6 | 96 | 4 | 3 | 60 | |
| c7t.4xlarge.4 | 16 | 64 | 40/8 | 400 | 150 | 8 | 8 | 128 | 5 | 4 | 60 | |
| c7t.6xlarge.4 | 24 | 96 | 50/14.4 | 600 | 200 | 8 | 8 | 192 | 6 | 6 | 60 | |
| c7t.8xlarge.4 | 32 | 128 | 60/16 | 800 | 300 | 16 | 8 | 256 | 8 | 7.5 | 60 | |
| c7t.12xlarge.4 | 48 | 192 | 70/28.8 | 1,200 | 400 | 16 | 8 | 256 | 10 | 11.25 | 60 | |
| c7t.16xlarge.4 | 64 | 256 | 72/32 | 1,500 | 500 | 28 | 8 | 256 | 16 | 16 | 60 | |
| c7t.24xlarge.4 | 96 | 384 | 80/40 | 2,400 | 800 | 32 | 8 | 256 | 20 | 22.5 | 60 | |
| c7t.32xlarge.4 | 128 | 512 | 90/48 | 3,000 | 1,000 | 32 | 8 | 256 | 24 | 30 | 60 |
| c7.large.2 | 2 | 4 | 4/0.64 | 40 | 50 | 2 | 2 | 16 | 1 | 1 | 60 | QingTian |
| c7.xlarge.2 | 4 | 8 | 8/1.28 | 80 | 50 | 2 | 3 | 32 | 1.5 | 2 | 60 | |
| c7.2xlarge.2 | 8 | 16 | 15/2.4 | 150 | 100 | 4 | 4 | 64 | 2 | 2.5 | 60 | |
| c7.3xlarge.2 | 12 | 24 | 17/4 | 200 | 150 | 4 | 6 | 96 | 3 | 3 | 60 | |
| c7.4xlarge.2 | 16 | 32 | 20/4.8 | 280 | 150 | 8 | 8 | 128 | 4 | 4 | 60 | |
| c7.6xlarge.2 | 24 | 48 | 25/7.2 | 400 | 200 | 8 | 8 | 192 | 5 | 6 | 60 | |
| c7.8xlarge.2 | 32 | 64 | 30/9.6 | 550 | 300 | 16 | 8 | 256 | 6 | 7.5 | 60 | |
| c7.12xlarge.2 | 48 | 96 | 35/14.4 | 750 | 400 | 16 | 8 | 256 | 8 | 11.25 | 60 | |
| c7.16xlarge.2 | 64 | 128 | 36/19.2 | 1,000 | 500 | 28 | 8 | 256 | 12 | 16 | 60 | |
| c7.24xlarge.2 | 96 | 192 | 40/28.8 | 1,100 | 800 | 32 | 8 | 256 | 16 | 22.5 | 60 | |
| c7.32xlarge.2 | 128 | 256 | 42/32 | 1,200 | 1,000 | 32 | 8 | 256 | 24 | 30 | 60 | |
| c7.large.4 | 2 | 8 | 4/0.64 | 40 | 50 | 2 | 2 | 16 | 1 | 1 | 60 | |
| c7.xlarge.4 | 4 | 16 | 8/1.28 | 80 | 50 | 2 | 3 | 32 | 1.5 | 2 | 60 | |
| c7.2xlarge.4 | 8 | 32 | 15/2.4 | 150 | 100 | 4 | 4 | 64 | 2 | 2.5 | 60 | |
| c7.3xlarge.4 | 12 | 48 | 17/4 | 200 | 150 | 4 | 6 | 96 | 3 | 3 | 60 | |
| c7.4xlarge.4 | 16 | 64 | 20/4.8 | 280 | 150 | 8 | 8 | 128 | 4 | 4 | 60 | |
| c7.6xlarge.4 | 24 | 96 | 25/7.2 | 400 | 200 | 8 | 8 | 192 | 5 | 6 | 60 | |
| c7.8xlarge.4 | 32 | 128 | 30/9.6 | 550 | 300 | 16 | 8 | 256 | 6 | 7.5 | 60 | |
| c7.12xlarge.4 | 48 | 192 | 35/14.4 | 750 | 400 | 16 | 8 | 256 | 8 | 11.25 | 60 | |
| c7.16xlarge.4 | 64 | 256 | 36/19.2 | 1,000 | 500 | 28 | 8 | 256 | 12 | 16 | 60 | |
| c7.24xlarge.4 | 96 | 384 | 40/28.8 | 1,100 | 800 | 32 | 8 | 256 | 16 | 22.5 | 60 | |
| c7.32xlarge.4 | 128 | 512 | 42/32 | 1,200 | 1,000 | 32 | 8 | 256 | 24 | 30 | 60 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Bandwidth (Gbit/s) | Max. PPS (10,000) | Max. Network Interface Queues | Max. Network Interfaces | Max. Supplementary Network Interfaces |
| c6ne.large.2 | 2 | 4 | 4/1.2 | 40 | 2 | 2 | 16 |
| c6ne.large.4 | 2 | 8 | 4/1.2 | 40 | 2 | 2 | 16 |
| c6ne.xlarge.2 | 4 | 8 | 8/2.4 | 80 | 2 | 3 | 32 |
| c6ne.xlarge.4 | 4 | 16 | 8/2.4 | 80 | 2 | 3 | 32 |
| c6ne.2xlarge.2 | 8 | 16 | 15/4.5 | 150 | 4 | 4 | 64 |
| c6ne.2xlarge.4 | 8 | 32 | 15/4.5 | 150 | 4 | 4 | 64 |
| c6ne.3xlarge.2 | 12 | 24 | 17/7 | 200 | 4 | 6 | 96 |
| c6ne.3xlarge.4 | 12 | 48 | 17/7 | 200 | 4 | 6 | 96 |
| c6ne.4xlarge.2 | 16 | 32 | 20/9 | 280 | 8 | 8 | 128 |
| c6ne.4xlarge.4 | 16 | 64 | 20/9 | 280 | 8 | 8 | 128 |
| c6ne.6xlarge.2 | 24 | 48 | 25/14 | 400 | 8 | 8 | 192 |
| c6ne.6xlarge.4 | 24 | 96 | 25/14 | 400 | 8 | 8 | 192 |
| c6ne.8xlarge.2 | 32 | 64 | 30/18 | 550 | 16 | 8 | 256 |
| c6ne.8xlarge.4 | 32 | 128 | 30/18 | 550 | 16 | 8 | 256 |
| c6ne.12xlarge.2 | 48 | 96 | 35/27 | 750 | 16 | 8 | 256 |
| c6ne.12xlarge.4 | 48 | 192 | 35/27 | 750 | 16 | 8 | 256 |
| c6ne.16xlarge.2 | 64 | 128 | 40/36 | 1,000 | 32 | 8 | 256 |
| c6ne.16xlarge.4 | 64 | 256 | 40/36 | 1,000 | 32 | 8 | 256 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Network Connections (10,000) | Max. NIC Queues | Max. NICs | Assured EVS Disk Bandwidth (Gbit/s) | Assured EVS Disk IOPS (10,000) | Max. EVS Disks | Virtualization |
| c6s.large.2 | 2 | 4 | 1/1 | 30 | 50 | 2 | 2 | 1.5 | 1 | 60 | KVM |
| c6s.xlarge.2 | 4 | 8 | 2/2 | 60 | 50 | 2 | 3 | 2 | 2 | 60 | KVM |
| c6s.2xlarge.2 | 8 | 16 | 4/4 | 120 | 100 | 4 | 4 | 3 | 2.5 | 60 | KVM |
| c6s.3xlarge.2 | 12 | 24 | 5.5/5.5 | 180 | 150 | 4 | 6 | 4 | 3 | 60 | KVM |
| c6s.4xlarge.2 | 16 | 32 | 7.5/7.5 | 240 | 150 | 8 | 8 | 5 | 4 | 60 | KVM |
| c6s.6xlarge.2 | 24 | 48 | 11/11 | 350 | 200 | 8 | 8 | 7.5 | 5 | 60 | KVM |
| c6s.8xlarge.2 | 32 | 64 | 15/15 | 450 | 300 | 16 | 8 | 10 | 6 | 60 | KVM |
| c6s.12xlarge.2 | 48 | 96 | 22/22 | 650 | 400 | 16 | 8 | 15 | 10 | 60 | KVM |
| c6s.16xlarge.2 | 64 | 128 | 30/30 | 850 | 500 | 32 | 8 | 20 | 15 | 60 | KVM |
| c6s.large.4 | 2 | 8 | 1/1 | 30 | 50 | 2 | 2 | 1.5 | 1 | 60 | KVM |
| c6s.xlarge.4 | 4 | 16 | 2/2 | 60 | 50 | 2 | 3 | 2 | 2 | 60 | KVM |
| c6s.2xlarge.4 | 8 | 32 | 4/4 | 120 | 100 | 4 | 4 | 3 | 2.5 | 60 | KVM |
| c6s.3xlarge.4 | 12 | 48 | 5.5/5.5 | 180 | 150 | 4 | 6 | 4 | 3 | 60 | KVM |
| c6s.4xlarge.4 | 16 | 64 | 7.5/7.5 | 240 | 150 | 8 | 8 | 5 | 4 | 60 | KVM |
| c6s.6xlarge.4 | 24 | 96 | 11/11 | 350 | 200 | 8 | 8 | 7.5 | 5 | 60 | KVM |
| c6s.8xlarge.4 | 32 | 128 | 15/15 | 450 | 300 | 16 | 8 | 10 | 6 | 60 | KVM |
| c6s.12xlarge.4 | 48 | 192 | 22/22 | 650 | 400 | 16 | 8 | 15 | 10 | 60 | KVM |
| c6s.16xlarge.4 | 64 | 256 | 30/30 | 850 | 500 | 32 | 8 | 20 | 15 | 60 | KVM |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Bandwidth (Gbit/s) | Max. PPS (10,000) | Max. Network Interface Queues | Max. Network Interfaces | Virtualization |
| ac6.2xlarge.1 | 8 | 8 | 4.0/1.4 | 80 | 4 | 4 | KVM |
| ac6.2xlarge.2 | 8 | 16 | 4.0/1.4 | 80 | 4 | 4 | KVM |
| ac6.2xlarge.4 | 8 | 32 | 4.0/1.4 | 80 | 4 | 4 | KVM |
| ac6.4xlarge.1 | 16 | 16 | 7.5/2.8 | 100 | 8 | 8 | KVM |
| ac6.4xlarge.2 | 16 | 32 | 7.5/2.8 | 100 | 8 | 8 | KVM |
| ac6.4xlarge.4 | 16 | 64 | 7.5/2.8 | 100 | 8 | 8 | KVM |
| ac6.6xlarge.2 | 24 | 48 | 11.0/4.2 | 150 | 8 | 8 | KVM |
| ac6.6xlarge.4 | 24 | 96 | 11.0/4.2 | 150 | 8 | 8 | KVM |
| ac6.8xlarge.2 | 32 | 64 | 15.5/5.5 | 200 | 16 | 8 | KVM |
| ac6.8xlarge.4 | 32 | 128 | 15.5/5.5 | 200 | 16 | 8 | KVM |
| ac6.12xlarge.2 | 48 | 96 | 24.0/8.0 | 250 | 16 | 8 | KVM |
| ac6.12xlarge.4 | 48 | 192 | 24.0/8.0 | 250 | 16 | 8 | KVM |
| ac6.16xlarge.2 | 64 | 128 | 28.0/11.0 | 300 | 16 | 8 | KVM |
| ac6.16xlarge.4 | 64 | 256 | 28.0/11.0 | 300 | 16 | 8 | KVM |
| ac6.24xlarge.2 | 96 | 192 | 30.0/16.0 | 400 | 32 | 16 | KVM |
| ac6.24xlarge.4 | 96 | 384 | 30.0/16.0 | 400 | 32 | 16 | KVM |
| ac6.32xlarge.2 | 128 | 256 | 35.0/22.0 | 600 | 32 | 16 | KVM |
| ac6.32xlarge.4 | 128 | 256 | 35.0/22.0 | 600 | 32 | 16 | KVM |
| ac6.48xlarge.2 | 192 | 384 | 38.0/30.0 | 700 | 32 | 16 | KVM |
| ac6.48xlarge.4 | 192 | 768 | 38.0/30.0 | 700 | 32 | 16 | KVM |
| ac6.56xlarge.2 | 224 | 432 | 40.0/35.0 | 800 | 32 | 16 | KVM |
| ac6.56xlarge.2 | 224 | 924 | 40.0/35.0 | 800 | 32 | 16 | KVM |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Max. NIC Queues | Assured EVS Disk Bandwidth (Gbit/s) | Assured EVS Disk IOPS (10,000) | Max. EVS Disks | Virtualization |
| c3.large.2 | 2 | 4 | 1.5/0.6 | 30 | 2 | 0.5 | 1 | 60 | KVM |
| c3.xlarge.2 | 4 | 8 | 3/1 | 50 | 2 | 1 | 1.5 | 60 | KVM |
| c3.2xlarge.2 | 8 | 16 | 5/2 | 90 | 4 | 1.5 | 2.5 | 60 | KVM |
| c3.3xlarge.2 | 12 | 24 | 7/3 | 110 | 4 | 2 | 4 | 60 | KVM |
| c3.4xlarge.2 | 16 | 32 | 10/4 | 130 | 4 | 2.5 | 5 | 60 | KVM |
| c3.6xlarge.2 | 24 | 48 | 12/6 | 200 | 8 | 3 | 8 | 60 | KVM |
| c3.8xlarge.2 | 32 | 64 | 15/8 | 260 | 8 | 4 | 10 | 60 | KVM |
| c3.15xlarge.2 | 60 | 128 | 16/16 | 500 | 16 | 8 | 20 | 60 | KVM |
| c3.large.4 | 2 | 8 | 1.5/0.6 | 30 | 2 | 0.5 | 1 | 60 | KVM |
| c3.xlarge.4 | 4 | 16 | 3/1 | 50 | 2 | 1 | 1.5 | 60 | KVM |
| c3.2xlarge.4 | 8 | 32 | 5/2 | 90 | 4 | 1.5 | 2.5 | 60 | KVM |
| c3.3xlarge.4 | 12 | 48 | 7/3 | 110 | 4 | 2 | 4 | 60 | KVM |
| c3.4xlarge.4 | 16 | 64 | 10/4 | 130 | 4 | 2.5 | 5 | 60 | KVM |
| c3.6xlarge.4 | 24 | 96 | 12/6 | 200 | 8 | 3 | 8 | 60 | KVM |
| c3.8xlarge.4 | 32 | 128 | 15/8 | 260 | 8 | 4 | 10 | 60 | KVM |
| c3.15xlarge.4 | 60 | 256 | 16/16 | 500 | 16 | 8 | 20 | 60 | KVM |
General Computing ECSs
General computing ECSs provide a balance of compute, memory, and networking resources and a baseline level of vCPU performance with the ability to burst above the baseline.
| S7n |
| S7 |
| aS7 |
| S6 |
| Sn3 |
| S3 |
| S2 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Bandwidth (Gbit/s) | Max. PPS (10,000) | Network Connections (10,000) | Max. Network Interface Queues | Max. Network Interfaces | Max. Supplementary Network Interfaces | Virtualization |
| s7n.large.2 | 2 | 4 | 1.5/0.2 | 15 | 30 | 1 | 2 | 8 | KVM |
| s7n.xlarge.2 | 4 | 8 | 2/0.35 | 25 | 30 | 1 | 2 | 16 | KVM |
| s7n.2xlarge.2 | 8 | 16 | 3/0.75 | 50 | 30 | 2 | 2 | 32 | KVM |
| s7n.large.4 | 2 | 8 | 1.5/0.2 | 15 | 30 | 1 | 2 | 8 | KVM |
| s7n.xlarge.4 | 4 | 16 | 2/0.35 | 25 | 30 | 1 | 2 | 16 | KVM |
| s7n.2xlarge.4 | 8 | 32 | 3/0.75 | 50 | 30 | 2 | 2 | 32 | KVM |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Bandwidth (Gbit/s) | Max. PPS (10,000) | Max. Network Interface Queues | Max. Network Interfaces | Max. Supplementary Network Interfaces | Virtualization |
| s7.large.2 | 2 | 4 | 1.5/0.2 | 15 | 1 | 2 | 8 | KVM |
| s7.xlarge.2 | 4 | 8 | 2/0.35 | 25 | 1 | 2 | 16 | KVM |
| s7.2xlarge.2 | 8 | 16 | 3/0.75 | 50 | 2 | 2 | 32 | KVM |
| s7.large.4 | 2 | 8 | 1.5/0.2 | 15 | 1 | 2 | 8 | KVM |
| s7.xlarge.4 | 4 | 16 | 2/0.35 | 25 | 1 | 2 | 16 | KVM |
| s7.2xlarge.4 | 8 | 32 | 3/0.75 | 50 | 2 | 2 | 32 | KVM |
| as7.large.2 | 2 | 4 | 1.5/0.3 | 15 | 1 | 2 | 8 | KVM |
| as7.xlarge.2 | 4 | 8 | 2/0.5 | 25 | 1 | 2 | 16 | KVM |
| as7.2xlarge.2 | 8 | 16 | 4/1 | 40 | 2 | 2 | 32 | KVM |
| as7.3xlarge.2 | 12 | 24 | 6/1.5 | 60 | 2 | 2 | 64 | KVM |
| as7.4xlarge.2 | 16 | 32 | 8/2 | 80 | 4 | 2 | 64 | KVM |
| s6.large.2 | 2 | 4 | 1.5/0.2 | 15 | 1 | 2 | KVM |
| s6.xlarge.2 | 4 | 8 | 2/0.35 | 25 | 1 | 2 | KVM |
| s6.2xlarge.2 | 8 | 16 | 3/0.75 | 50 | 2 | 2 | KVM |
| s6.large.4 | 2 | 8 | 1.5/0.2 | 15 | 1 | 2 | KVM |
| s6.xlarge.4 | 4 | 16 | 2/0.35 | 25 | 1 | 2 | KVM |
| s6.2xlarge.4 | 8 | 32 | 3/0.75 | 50 | 2 | 2 | KVM |
| sn3.large.2 | 2 | 4 | 1.5/0.35 | 15 | 1 | 2 | KVM |
| sn3.xlarge.2 | 4 | 8 | 2/0.7 | 25 | 1 | 2 | KVM |
| sn3.2xlarge.2 | 8 | 16 | 3/1.3 | 50 | 2 | 2 | KVM |
| sn3.4xlarge.2 | 16 | 32 | 6/2.5 | 100 | 4 | 2 | KVM |
| sn3.large.4 | 2 | 8 | 1.5/0.35 | 15 | 1 | 2 | KVM |
| sn3.xlarge.4 | 4 | 16 | 2/0.7 | 25 | 1 | 2 | KVM |
| sn3.2xlarge.4 | 8 | 32 | 3/1.3 | 50 | 2 | 2 | KVM |
| sn3.4xlarge.4 | 16 | 64 | 6/2.5 | 100 | 4 | 2 | KVM |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Bandwidth (Gbit/s) | Max. PPS (10,000) | Max. Network Interface Queues | Virtualization |
| s3.large.2 | 2 | 4 | 0.8/0.2 | 10 | 1 | KVM |
| s3.xlarge.2 | 4 | 8 | 1.5/0.4 | 15 | 1 | KVM |
| s3.2xlarge.2 | 8 | 16 | 3/0.8 | 20 | 2 | KVM |
| s3.4xlarge.2 | 16 | 32 | 4/1.5 | 30 | 4 | KVM |
| s3.large.4 | 2 | 8 | 0.8/0.2 | 10 | 1 | KVM |
| s3.xlarge.4 | 4 | 16 | 1.5/0.4 | 15 | 1 | KVM |
| s3.2xlarge.4 | 8 | 32 | 3/0.8 | 20 | 2 | KVM |
| s3.4xlarge.4 | 16 | 64 | 4/1.5 | 30 | 4 | KVM |
| s2.large.2 | 2 | 4 | 0.8/0.2 | 10 | 1 | KVM |
| s2.xlarge.2 | 4 | 8 | 1.5/0.4 | 15 | 1 | KVM |
| s2.2xlarge.2 | 8 | 16 | 3/0.8 | 20 | 2 | KVM |
| s2.4xlarge.2 | 16 | 32 | 4/1.5 | 30 | 4 | KVM |
| s2.8xlarge.2 | 32 | 64 | 6/3 | 50 | 8 | KVM |
| s2.large.4 | 2 | 8 | 0.8/0.2 | 10 | 1 | KVM |
| s2.xlarge.4 | 4 | 16 | 1.5/0.4 | 15 | 1 | KVM |
| s2.2xlarge.4 | 8 | 32 | 3/0.8 | 20 | 2 | KVM |
| s2.4xlarge.4 | 16 | 64 | 4/1.5 | 30 | 4 | KVM |
| s2.8xlarge.4 | 32 | 128 | 6/3 | 50 | 8 | KVM |
Memory-optimized ECSs
Memory-optimized ECSs have a large memory and provide high memory performance. They are designed for memory-intensive applications that process a large amount of data.
| aM9 |
| M9 |
| aM8 |
| M7 |
| aM7 |
| M7n |
| M6ne |
| M6 |
| M6s |
| M3 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Network Connections (10,000) | Max. NIC Queues | Max. NICs | Max./Assured EVS Disk Bandwidth (Gbit/s) | Max. EVS Disk IOPS (10,000) | Max. EVS Disks | Virtualization |
| am9.large.8 | 2 | 16 | 20/2.5 | 100 | 75 | 2 | 3 | 8/0.4 | 11 | 24 | QingTian |
| am9.xlarge.8 | 4 | 32 | 20/4 | 150 | 150 | 4 | 3 | 8/0.8 | 11 | 24 | |
| am9.2xlarge.8 | 8 | 64 | 20/6 | 200 | 200 | 8 | 4 | 8/1.6 | 11 | 24 | |
| am9.4xlarge.8 | 16 | 128 | 30/10 | 300 | 300 | 16 | 6 | 8/3.2 | 11 | 24 | |
| am9.8xlarge.8 | 32 | 256 | 40/20 | 500 | 400 | 32 | 6 | 8/6.4 | 11 | 60 | |
| am9.16xlarge.8 | 64 | 512 | 60/30 | 1,000 | 600 | 64 | 8 | 16/12.8 | 21 | 60 | |
| am9.32xlarge.8 | 128 | 1,024 | 100/60 | 2,000 | 800 | 64 | 10 | 32/25.6 | 43 | 60 |
| m9.large.8 | 2 | 16 | 20/3 | 100 | 75 | 2 | 2 | 16 | 11 | 11 | 24 | QingTian |
| m9.xlarge.8 | 4 | 32 | 20/5 | 160 | 200 | 4 | 3 | 32 | 11 | 11 | 24 | |
| m9.2xlarge.8 | 8 | 64 | 20/8 | 200 | 300 | 8 | 6 | 64 | 11 | 11 | 24 | |
| m9.4xlarge.8 | 16 | 128 | 30/12 | 350 | 400 | 16 | 8 | 128 | 11 | 11 | 24 | |
| m9.8xlarge.8 | 32 | 256 | 40/25 | 700 | 600 | 32 | 8 | 256 | 11 | 11 | 60 | |
| m9.16xlarge.8 | 64 | 512 | 60/40 | 1,400 | 700 | 64 | 8 | 256 | 21 | 23 | 60 | |
| m9.24xlarge.8 | 96 | 768 | 80/45 | 1,800 | 800 | 64 | 10 | 256 | 32 | 35 | 60 | |
| m9.32xlarge.8 | 128 | 1,024 | 100/80 | 2,000 | 1,000 | 64 | 10 | 256 | 43 | 46 | 60 | |
| m9.48xlarge.8 | 192 | 1,504 | 120/102 | 4,000 | 1,000 | 64 | 12 | 256 | 64 | 70 | 60 |
| am8.large.8 | 2 | 16 | 20/2 | 90 | 75 | 2 | 3 | 8 | 6/0.3 | 5 | 24 | QingTian |
| am8.xlarge.8 | 4 | 32 | 20/3 | 100 | 150 | 4 | 3 | 16 | 6/0.5 | 5 | 24 | |
| am8.2xlarge.8 | 8 | 64 | 20/5 | 160 | 200 | 8 | 3 | 32 | 6/1.1 | 5 | 24 | |
| am8.4xlarge.8 | 16 | 128 | 30/8 | 200 | 300 | 16 | 4 | 64 | 6/2.1 | 5 | 24 | |
| am8.8xlarge.8 | 32 | 256 | 40/12 | 350 | 400 | 32 | 4 | 128 | 6/4.3 | 5 | 60 | |
| am8.12xlarge.8 | 48 | 384 | 50/18 | 500 | 500 | 48 | 4 | 256 | 8/6.4 | 7 | 60 | |
| am8.16xlarge.8 | 64 | 512 | 60/25 | 700 | 600 | 64 | 4 | 256 | 11/8.5 | 10 | 60 | |
| am8.24xlarge.8 | 96 | 768 | 80/35 | 1,000 | 700 | 64 | 8 | 256 | 16/13 | 13 | 60 | |
| am8.32xlarge.8 | 128 | 1,024 | 100/45 | 1,400 | 800 | 64 | 10 | 256 | 21/17 | 17 | 60 | |
| am8.48xlarge.8 | 192 | 1,536 | 120/65 | 2,000 | 1,000 | 64 | 12 | 256 | 32/26 | 25 | 60 |
| m7.large.8 | 2 | 16 | 4/0.8 | 40 | 2 | 2 | 16 | QingTian-backed simplified, proprietary virtualization |
| m7.xlarge.8 | 4 | 32 | 8/1.6 | 80 | 2 | 3 | 32 | |
| m7.2xlarge.8 | 8 | 64 | 15/3 | 150 | 4 | 4 | 64 | |
| m7.3xlarge.8 | 12 | 96 | 17/5 | 200 | 4 | 6 | 96 | |
| m7.4xlarge.8 | 16 | 128 | 20/6 | 280 | 8 | 8 | 128 | |
| m7.6xlarge.8 | 24 | 192 | 25/9 | 400 | 8 | 8 | 192 | |
| m7.8xlarge.8 | 32 | 256 | 30/12 | 550 | 16 | 8 | 256 | |
| m7.12xlarge.8 | 48 | 384 | 35/18 | 750 | 16 | 8 | 256 | |
| m7.16xlarge.8 | 64 | 512 | 36/24 | 1,000 | 28 | 8 | 256 | |
| m7.24xlarge.8 | 96 | 768 | 40/36 | 1,100 | 32 | 8 | 256 | |
| m7.32xlarge.8 | 128 | 1,024 | 42/40 | 1,200 | 32 | 8 | 256 |
| am7.large.8 | 2 | 16 | 2/1 | 40 | 75 | 2 | 2 | 16 | KVM |
| am7.xlarge.8 | 4 | 32 | 3/1.5 | 60 | 150 | 2 | 3 | 32 | |
| am7.2xlarge.8 | 8 | 64 | 4/2.5 | 100 | 200 | 4 | 4 | 64 | |
| am7.4xlarge.8 | 16 | 128 | 8/5 | 200 | 300 | 8 | 8 | 128 | |
| am7.8xlarge.8 | 32 | 256 | 15/8 | 300 | 400 | 16 | 8 | 256 | |
| am7.12xlarge.8 | 48 | 384 | 22/12 | 400 | 500 | 16 | 8 | 256 | |
| am7.16xlarge.8 | 64 | 512 | 28/16 | 550 | 800 | 24 | 12 | 256 | |
| am7.24xlarge.8 | 96 | 768 | 40/25 | 800 | 1,000 | 24 | 12 | 256 | |
| am7.29xlarge.8 | 116 | 934 | 50/30 | 950 | 1,200 | 32 | 16 | 256 | |
| am7.32xlarge.8 | 128 | 1,024 | 55/35 | 1,000 | 1,300 | 32 | 16 | 256 | |
| am7.48xlarge.8 | 192 | 1,536 | 100/80 | 1,600 | 1,800 | 32 | 16 | 256 | |
| am7.58xlarge.8 | 232 | 1,868 | 120/100 | 2,000 | 2,000 | 32 | 16 | 256 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Bandwidth (Gbit/s) | Max. PPS (10,000) | Network Connections (10,000) | Max. Network Interface Queues | Max. Network Interfaces | EVS Basic Bandwidth/Burst Bandwidth (Gbit/s) | Virtualization |
| m7n.large.8 | 2 | 16 | 4/0.8 | 40 | 50 | 2 | 2 | 1.5/6 | KVM |
| m7n.xlarge.8 | 4 | 32 | 8/1.6 | 80 | 50 | 2 | 3 | 2/6 | KVM |
| m7n.2xlarge.8 | 8 | 64 | 15/3 | 150 | 100 | 4 | 4 | 3/6 | KVM |
| m7n.3xlarge.8 | 12 | 96 | 17/5 | 200 | 150 | 4 | 6 | 4/6 | KVM |
| m7n.4xlarge.8 | 16 | 128 | 20/6 | 280 | 150 | 8 | 8 | 5/6 | KVM |
| m7n.6xlarge.8 | 24 | 192 | 25/9 | 400 | 200 | 8 | 8 | 6/None | KVM |
| m7n.8xlarge.8 | 32 | 256 | 30/12 | 550 | 300 | 16 | 8 | 8/None | KVM |
| m7n.12xlarge.8 | 48 | 384 | 35/18 | 750 | 400 | 16 | 8 | 12/None | KVM |
| m7n.16xlarge.8 | 64 | 512 | 36/24 | 800 | 500 | 28 | 8 | 16/None | KVM |
| m7n.24xlarge.8 | 96 | 768 | 40/36 | 850 | 800 | 32 | 8 | 24/None | KVM |
| m6ne.large.8 | 2 | 16 | 4/1.2 | 40 | 2 | 2 | 16 |
| m6ne.xlarge.8 | 4 | 32 | 8/2.4 | 80 | 2 | 3 | 32 |
| m6ne.2xlarge.8 | 8 | 64 | 15/4.5 | 150 | 4 | 4 | 64 |
| m6ne.3xlarge.8 | 12 | 96 | 17/7 | 200 | 4 | 6 | 96 |
| m6ne.4xlarge.8 | 16 | 128 | 20/9 | 280 | 8 | 8 | 128 |
| m6ne.6xlarge.8 | 24 | 192 | 25/14 | 400 | 8 | 8 | 192 |
| m6ne.8xlarge.8 | 32 | 256 | 30/18 | 550 | 16 | 8 | 256 |
| m6ne.16xlarge.8 | 64 | 512 | 40/36 | 1,000 | 32 | 8 | 256 |
| m6.large.8 | 2 | 16 | 4/1.2 | 40 | 50 | 2 | 2 | 1 | 1 | 60 | KVM |
| m6.xlarge.8 | 4 | 32 | 8/2.4 | 80 | 50 | 2 | 3 | 1.5 | 2 | 60 | KVM |
| m6.2xlarge.8 | 8 | 64 | 15/4.5 | 150 | 100 | 4 | 4 | 2 | 2.5 | 60 | KVM |
| m6.3xlarge.8 | 12 | 96 | 17/7 | 200 | 150 | 4 | 6 | 2.5 | 3 | 60 | KVM |
| m6.4xlarge.8 | 16 | 128 | 20/9 | 280 | 150 | 8 | 8 | 3.5 | 4 | 60 | KVM |
| m6.6xlarge.8 | 24 | 192 | 25/14 | 400 | 200 | 8 | 8 | 4 | 5 | 60 | KVM |
| m6.8xlarge.8 | 32 | 256 | 30/18 | 550 | 300 | 16 | 8 | 7 | 6 | 60 | KVM |
| m6.12xlarge.8 | 48 | 384 | 35/27 | 750 | 400 | 16 | 8 | 10 | 10 | 60 | KVM |
| m6.16xlarge.8 | 64 | 512 | 40/36 | 1,000 | 500 | 32 | 8 | 20 | 15 | 60 | KVM |
| m6.22xlarge.8.physical | 88 | 768 | 40/40 | 1,000 | 1,000 | 16 | 33 | 20 | 20 | 60 | Bare metal |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Network Connections (10,000) | Max. NIC Queues | Max. NICs | Virtualization |
| m6s.large.8 | 2 | 16 | 3/1 | 30 | 50 | 2 | 2 | KVM |
| m6s.xlarge.8 | 4 | 32 | 6/2 | 60 | 50 | 2 | 3 | KVM |
| m6s.2xlarge.8 | 8 | 64 | 12/4 | 120 | 100 | 4 | 4 | KVM |
| m6s.3xlarge.8 | 12 | 96 | 14/5.5 | 160 | 150 | 4 | 6 | KVM |
| m6s.4xlarge.8 | 16 | 128 | 16/7.5 | 220 | 150 | 8 | 8 | KVM |
| m6s.6xlarge.8 | 24 | 192 | 20/11 | 320 | 200 | 8 | 8 | KVM |
| m6s.8xlarge.8 | 32 | 256 | 25/15 | 450 | 300 | 16 | 8 | KVM |
| m6s.16xlarge.8 | 64 | 512 | 34/30 | 850 | 500 | 32 | 8 | KVM |
| m3.large.8 | 2 | 16 | 1.5/0.6 | 30 | 2 | 0.5 | 1 | 60 | KVM |
| m3.xlarge.8 | 4 | 32 | 3/1.1 | 50 | 2 | 1 | 1.5 | 60 | KVM |
| m3.2xlarge.8 | 8 | 64 | 5/2 | 90 | 4 | 1.5 | 2.5 | 60 | KVM |
| m3.3xlarge.8 | 12 | 96 | 8/3.5 | 110 | 4 | 2 | 4 | 60 | KVM |
| m3.4xlarge.8 | 16 | 128 | 10/4.5 | 130 | 4 | 2.5 | 5 | 60 | KVM |
| m3.6xlarge.8 | 24 | 192 | 12/6.5 | 200 | 8 | 3 | 8 | 60 | KVM |
| m3.8xlarge.8 | 32 | 256 | 15/9 | 260 | 8 | 4 | 10 | 60 | KVM |
| m3.15xlarge.8 | 60 | 512 | 17/17 | 500 | 16 | 8 | 20 | 60 | KVM |
General Computing-Basic ECSs
General computing-basic ECSs are suitable for scenarios that require moderate CPU performance generally but burstable high performance occasionally while keeping costs low. The performance of such ECSs is constrained by the baseline performance and CPU credits. There are no additional charges for using CPU credits. For details, see CPU Credits.
| T6 |
| Flavor | vCPUs | Memory (GiB) | CPU Baseline (%) | Average CPU Baseline (%) | Max./Assured Bandwidth (Gbit/s) | Max. PPS (10,000) | Max. Network Interfaces | Virtualization |
| t6.xlarge.1 | 4 | 4 | 80 | 20 | 1/0.2 | 20 | 2 | KVM |
| t6.2xlarge.1 | 8 | 8 | 120 | 15 | 2/0.4 | 40 | 2 | KVM |
| t6.4xlarge.1 | 16 | 16 | 240 | 15 | 3/0.8 | 60 | 2 | KVM |
| t6.large.2 | 2 | 4 | 40 | 20 | 0.5/0.1 | 10 | 1 | KVM |
| t6.xlarge.2 | 4 | 8 | 80 | 20 | 1/0.2 | 20 | 2 | KVM |
| t6.2xlarge.2 | 8 | 16 | 120 | 15 | 2/0.4 | 40 | 2 | KVM |
| t6.4xlarge.2 | 16 | 32 | 240 | 15 | 3/0.8 | 60 | 2 | KVM |
| t6.large.4 | 2 | 8 | 40 | 20 | 0.5/0.1 | 10 | 1 | KVM |
| t6.xlarge.4 | 4 | 16 | 80 | 20 | 1/0.2 | 20 | 2 | KVM |
| t6.2xlarge.4 | 8 | 32 | 120 | 15 | 2/0.4 | 40 | 2 | KVM |
GPU-accelerated ECSs
GPU-accelerated ECSs provide outstanding floating-point computing capabilities. They are suitable for applications that require real-time, highly concurrent massive computing.
GPU-accelerated ECSs are classified as G series and P series.
- G series: Graphics-accelerated ECSs, which are suitable for 3D animation rendering and CAD
- P series: Computing-accelerated or inference-accelerated ECSs, which are suitable for deep learning, scientific computing, and CAE
| Classification | ECS Type | GPU | CUDA Cores per GPU | Single-GPU Performance | Application | Supported Cluster Type |
| Graphics-accelerated | G6ne | NVIDIA T4 (GPU passthrough) | 2560 |
| Cloud desktop, image rendering, 3D visualization, and heavy-load graphics design | CCE Turbo clusters |
| Graphics-accelerated | G6 | NVIDIA T4 (GPU passthrough) | 2560 |
| Cloud desktop, image rendering, 3D visualization, and heavy-load graphics design | CCE standard clusters |
| Graphics-accelerated | G5 | NVIDIA V100 (GPU passthrough) | 5120 |
| Computing-accelerated | P2s | NVIDIA V100 | 5120 |
| AI deep learning training, scientific computing, computational fluid dynamics, computational finance, seismic analysis, molecular modeling, and genomics | CCE standard clusters |
| Computing-accelerated | P2v | NVIDIA V100 NVLink (GPU passthrough) | 5120 |
| Machine learning, deep learning, inference training, scientific computing, seismic analysis, computational finance, rendering, multimedia encoding and decoding | CCE standard clusters |
| Inference-accelerated | Pi2ne | NVIDIA T4 (GPU passthrough) | 2560 |
| Machine learning, deep learning, inference training, scientific computing, seismic analysis, computational finance, rendering, multimedia encoding and decoding | CCE Turbo clusters |
| Inference-accelerated | Pi2 | NVIDIA T4 (GPU passthrough) | 2560 |
| Inference-accelerated | Pi1 | NVIDIA P4 (GPU passthrough) | 2560 | 5.5 TFLOPS of single-precision floating-point computing | Machine learning, deep learning, inference training, scientific computing, seismic analysis, computational finance, rendering, multimedia encoding and decoding | CCE standard clusters |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Max. NIC Queues | Max. NICs | GPUs | GPU Connection | GPU Memory (GiB) | Virtualization |
| p2v.2xlarge.8 | 8 | 64 | 10/4 | 50 | 4 | 4 | 1 × V100 | - | 1 × 16 GiB | KVM |
| p2v.4xlarge.8 | 16 | 128 | 15/8 | 100 | 8 | 8 | 2 × V100 | NVLink | 2 × 16 GiB | KVM |
| p2v.8xlarge.8 | 32 | 256 | 25/15 | 200 | 16 | 8 | 4 × V100 | NVLink | 4 × 16 GiB | KVM |
| p2v.16xlarge.8 | 64 | 512 | 30/30 | 400 | 32 | 8 | 8 × V100 | NVLink | 8 × 16 GiB | KVM |
Disk-intensive ECSs
Disk-intensive ECSs are delivered with local disks for high storage bandwidth and IOPS. Local disks are more cost-effective in massive data storage scenarios.
| D7 |
Maximum intranet bandwidth: 42 Gbit/s | CCE standard clusters CCE Turbo clusters |
| D6 |
| D3 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Network Connections (10,000) | Max. NIC Queues | Max. NICs | Max. Supplementary NICs | Local Disks (GiB) | Max. EVS Disks | Virtualization |
| d7.xlarge.4 | 4 | 16 | 5/1.7 | 60 | 50 | 2 | 3 | 32 | 2 × 3,600 | 60 | KVM |
| d7.2xlarge.4 | 8 | 32 | 10/3.5 | 120 | 100 | 4 | 4 | 64 | 4 × 3,600 | 60 | KVM |
| d7.4xlarge.4 | 16 | 64 | 20/6.7 | 240 | 150 | 4 | 6 | 96 | 8 × 3,600 | 60 | KVM |
| d7.6xlarge.4 | 24 | 96 | 25/10 | 350 | 200 | 8 | 8 | 128 | 12 × 3,600 | 60 | KVM |
| d7.8xlarge.4 | 32 | 128 | 30/13.5 | 450 | 300 | 8 | 8 | 192 | 16 × 3,600 | 60 | KVM |
| d7.12xlarge.4 | 48 | 192 | 40/20 | 650 | 400 | 16 | 8 | 256 | 24 × 3,600 | 60 | KVM |
| d7.16xlarge.4 | 64 | 256 | 42/27 | 850 | 500 | 16 | 8 | 256 | 32 × 3,600 | 52 | KVM |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Network Connections (10,000) | Max. NIC Queues | Max. NICs | Local Disks (GiB) | Max. EVS Disks | Virtualization |
| d6.xlarge.4 | 4 | 16 | 5/2 | 60 | 50 | 2 | 3 | 2 × 3,600 | 54 | KVM |
| d6.2xlarge.4 | 8 | 32 | 10/4 | 120 | 100 | 4 | 4 | 4 × 3,600 | 54 | KVM |
| d6.4xlarge.4 | 16 | 64 | 20/7.5 | 240 | 150 | 8 | 8 | 8 × 3,600 | 54 | KVM |
| d6.6xlarge.4 | 24 | 96 | 25/11 | 350 | 200 | 8 | 8 | 12 × 3,600 | 54 | KVM |
| d6.8xlarge.4 | 32 | 128 | 30/15 | 450 | 300 | 16 | 8 | 16 × 3,600 | 54 | KVM |
| d6.12xlarge.4 | 48 | 192 | 40/22 | 650 | 400 | 16 | 8 | 24 × 3,600 | 54 | KVM |
| d6.16xlarge.4 | 64 | 256 | 42/30 | 850 | 500 | 32 | 8 | 32 × 3,600 | 52 | KVM |
| d6.18xlarge.4 | 72 | 288 | 44/34 | 900 | 700 | 32 | 8 | 36 × 3,600 | 48 | KVM |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Max. NIC Queues | Max. NICs | Local Disks (GiB) | Max. EVS Disks | Virtualization |
| d3.xlarge.8 | 4 | 32 | 2.5/2.5 | 50 | 2 | 3 | 2 × 1,675 | 54 | KVM |
| d3.2xlarge.8 | 8 | 64 | 5/5 | 100 | 2 | 4 | 4 × 1,675 | 54 | KVM |
| d3.4xlarge.8 | 16 | 128 | 10/10 | 120 | 4 | 8 | 8 × 1,675 | 54 | KVM |
| d3.6xlarge.8 | 24 | 192 | 15/15 | 160 | 6 | 8 | 12 × 1,675 | 54 | KVM |
| d3.8xlarge.8 | 32 | 256 | 20/20 | 200 | 8 | 8 | 16 × 1,675 | 54 | KVM |
| d3.12xlarge.8 | 48 | 384 | 32/32 | 220 | 16 | 8 | 24 × 1,675 | 54 | KVM |
| d3.14xlarge.10 | 56 | 560 | 40/40 | 500 | 16 | 8 | 28 × 1,675 | 54 | KVM |
Kunpeng General Computing-plus ECSs
Kunpeng general computing-plus ECSs use Kunpeng processors to provide powerful compute and high-performance network, meeting enterprise requirements for cost-effective, secure, reliable cloud services.
| kC2 |
| kC1 |
| kC1n |
| kc2.large.2 | 2 | 4 | 10/2 | 90 | 2 | 3 | 16 | QingTian-backed simplified, proprietary virtualization |
| kc2.xlarge.2 | 4 | 8 | 10/4 | 100 | 4 | 3 | 32 | |
| kc2.2xlarge.2 | 8 | 16 | 15/8 | 200 | 8 | 4 | 64 | |
| kc2.3xlarge.2 | 12 | 24 | 20/10 | 300 | 12 | 4 | 96 | |
| kc2.4xlarge.2 | 16 | 32 | 30/15 | 400 | 16 | 6 | 128 | |
| kc2.6xlarge.2 | 24 | 48 | 40/20 | 600 | 24 | 6 | 192 | |
| kc2.8xlarge.2 | 32 | 64 | 50/25 | 800 | 32 | 6 | 256 | |
| kc2.10xlarge.2 | 40 | 80 | 60/30 | 1,000 | 40 | 6 | 256 | |
| kc2.12xlarge.2 | 48 | 96 | 80/40 | 1,200 | 48 | 6 | 256 | |
| kc2.16xlarge.2 | 64 | 128 | 90/50 | 1,600 | 64 | 6 | 256 | |
| kc2.20xlarge.2 | 80 | 160 | 102/60 | 2,000 | 64 | 8 | 256 | |
| kc2.24xlarge.2 | 96 | 192 | 102/80 | 2,400 | 64 | 8 | 256 | |
| kc2.32xlarge.2 | 128 | 256 | 102/90 | 3,200 | 64 | 8 | 256 | |
| kc2.40xlarge.2 | 160 | 320 | 102/102 | 4,000 | 64 | 15 | 256 | |
| kc2.large.4 | 2 | 8 | 10/2 | 90 | 2 | 3 | 16 | QingTian-backed simplified, proprietary virtualization |
| kc2.xlarge.4 | 4 | 16 | 10/4 | 100 | 4 | 3 | 32 | |
| kc2.2xlarge.4 | 8 | 32 | 15/8 | 200 | 8 | 4 | 64 | |
| kc2.3xlarge.4 | 12 | 48 | 20/10 | 300 | 12 | 4 | 96 | |
| kc2.4xlarge.4 | 16 | 64 | 30/15 | 400 | 16 | 6 | 128 | |
| kc2.6xlarge.4 | 24 | 96 | 40/20 | 600 | 24 | 6 | 192 | |
| kc2.8xlarge.4 | 32 | 128 | 50/25 | 800 | 32 | 6 | 256 | |
| kc2.10xlarge.4 | 40 | 160 | 60/30 | 1,000 | 40 | 6 | 256 | |
| kc2.12xlarge.4 | 48 | 192 | 80/40 | 1,200 | 48 | 6 | 256 | |
| kc2.16xlarge.4 | 64 | 256 | 90/50 | 1,600 | 64 | 6 | 256 | |
| kc2.20xlarge.4 | 80 | 320 | 102/60 | 2,000 | 64 | 8 | 256 | |
| kc2.24xlarge.4 | 96 | 384 | 102/80 | 2,400 | 64 | 8 | 256 | |
| kc2.32xlarge.4 | 128 | 512 | 102/90 | 3,200 | 64 | 8 | 256 | |
| kc2.40xlarge.4 | 160 | 640 | 102/102 | 4,000 | 64 | 15 | 256 |
Kunpeng Memory-optimized ECSs
Kunpeng memory-optimized ECSs use Kunpeng 920 processors and 25GE high-speed intelligent network interfaces to provide up to 480-GiB DDR4 memory with high network performance for large in-memory datasets.
| kM2 |
| kM1 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Max. NIC Queues | Max. NICs | Max. EVS Disks | Virtualization |
| km1.large.8 | 2 | 16 | 3/0.8 | 30 | 2 | 2 | 23 | KVM |
| km1.xlarge.8 | 4 | 32 | 5/1.5 | 50 | 2 | 3 | 23 | KVM |
| km1.2xlarge.8 | 8 | 64 | 7/3 | 80 | 4 | 4 | 23 | KVM |
| km1.3xlarge.8 | 12 | 96 | 9/4.5 | 110 | 4 | 5 | 23 | KVM |
| km1.4xlarge.8 | 16 | 128 | 12/6 | 140 | 4 | 6 | 23 | KVM |
| km1.6xlarge.8 | 24 | 192 | 15/8 | 200 | 8 | 6 | 23 | KVM |
| km1.8xlarge.8 | 32 | 256 | 18/10 | 260 | 8 | 6 | 23 | KVM |
| km1.12xlarge.8 | 48 | 384 | 25/16 | 350 | 16 | 8 | 23 | KVM |
| km1.15xlarge.8 | 60 | 480 | 30/20 | 400 | 16 | 8 | 23 | KVM |
Kunpeng Ultra-high I/O ECSs
Kunpeng ultra-high I/O ECSs use Kunpeng 920 processors and 25GE high-speed intelligent network interfaces to provide up to 480-GiB DDR4 memory with high network performance for large in-memory datasets.
| kI1 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Max. NICs | Max. NIC Queues | Local Disks | Max. EVS Disks | Virtualization |
| ki1.2xlarge.4 | 8 | 32 | 7/3 | 80 | 4 | 4 | 1 × 3,200 GiB | 15 | KVM |
| ki1.4xlarge.4 | 16 | 64 | 12/6 | 140 | 6 | 4 | 2 × 3,200 GiB | 15 | KVM |
| ki1.6xlarge.4 | 24 | 96 | 15/8.5 | 200 | 6 | 8 | 3 × 3,200 GiB | 15 | KVM |
| ki1.8xlarge.4 | 32 | 128 | 18/10 | 260 | 6 | 8 | 4 × 3,200 GiB | 15 | KVM |
| ki1.12xlarge.4 | 48 | 192 | 25/16 | 350 | 6 | 16 | 6 × 3,200 GiB | 15 | KVM |
| ki1.16xlarge.4 | 64 | 228 | 30/20 | 400 | 6 | 16 | 8 × 3,200 GiB | 15 | KVM |
Ultra-high I/O ECSs
Ultra-high I/O ECSs use high-performance local NVMe SSDs to provide high storage IOPS and low read/write latency.
| Ir7 |
| I7 |
| Ir3 |
| I3 |
| d7i.2xlarge.4 | 8 | 32 | 10/3 | 120 | 100 | 4 | 4 | 64 | 1 × 15,360 GiB NVMe | 60 | KVM |
| d7i.4xlarge.4 | 16 | 64 | 15/6 | 200 | 150 | 4 | 6 | 96 | 2 × 15,360 GiB NVMe | 60 | KVM |
| d7i.8xlarge.4 | 32 | 128 | 25/12 | 400 | 300 | 8 | 8 | 192 | 4 × 15,360 GiB NVMe | 60 | KVM |
| d7i.12xlarge.4 | 48 | 192 | 30/18 | 500 | 400 | 16 | 8 | 256 | 6 × 15,360 GiB NVMe | 60 | KVM |
| d7i.16xlarge.4 | 64 | 256 | 35/24 | 600 | 500 | 16 | 8 | 256 | 8 × 15,360 GiB NVMe | 60 | KVM |
| d7i.24xlarge.4 | 96 | 384 | 44/36 | 800 | 800 | 32 | 8 | 256 | 12 × 15,360 GiB NVMe | 60 | KVM |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Max. NIC Queues | Max. NICs | Max. Supplementary NICs | Local Disks (GiB) | Max. EVS Disks | Virtualization |
| ai7.2xlarge.8 | 8 | 64 | 4/2.5 | 100 | 8 | 8 | 64 | 1 × 1,600 GiB NVMe | 60 | KVM |
| ai7.4xlarge.8 | 16 | 128 | 8/5 | 200 | 16 | 8 | 128 | 2 × 1,600 GiB NVMe | 60 | KVM |
| ai7.8xlarge.8 | 32 | 256 | 15/8 | 300 | 16 | 8 | 256 | 4 × 1,600 GiB NVMe | 60 | KVM |
| ai7.12xlarge.8 | 48 | 384 | 22/12 | 400 | 16 | 8 | 256 | 6 × 1,600 GiB NVMe | 60 | KVM |
| ai7.16xlarge.8 | 64 | 512 | 28/16 | 550 | 24 | 12 | 256 | 8 × 1,600 GiB NVMe | 60 | KVM |
| ai7.24xlarge.8 | 96 | 768 | 40/25 | 800 | 24 | 12 | 256 | 12 × 1,600 GiB NVMe | 60 | KVM |
| i7.2xlarge.4 | 8 | 32 | 10/3 | 120 | 100 | 4 | 4 | 64 | 1 × 1,600 GiB NVMe | 60 | KVM |
| i7.4xlarge.4 | 16 | 64 | 15/6 | 200 | 150 | 4 | 6 | 96 | 2 × 1,600 GiB NVMe | 60 | KVM |
| i7.8xlarge.4 | 32 | 128 | 25/12 | 400 | 300 | 8 | 8 | 192 | 4 × 1,600 GiB NVMe | 60 | KVM |
| i7.12xlarge.4 | 48 | 192 | 30/18 | 500 | 400 | 16 | 8 | 256 | 6 × 1,600 GiB NVMe | 60 | KVM |
| i7.16xlarge.4 | 64 | 256 | 35/24 | 600 | 500 | 16 | 8 | 256 | 8 × 1,600 GiB NVMe | 60 | KVM |
| i7.24xlarge.4 | 96 | 384 | 44/36 | 800 | 800 | 32 | 8 | 256 | 12 × 1,600 GiB NVMe | 60 | KVM |
| i7.2xlarge.8 | 8 | 64 | 10/3 | 120 | 100 | 4 | 4 | 64 | 1 × 1,600 GiB NVMe | 60 | KVM |
| i7.4xlarge.8 | 16 | 128 | 15/6 | 200 | 150 | 4 | 6 | 96 | 2 × 1,600 GiB NVMe | 60 | KVM |
| i7.8xlarge.8 | 32 | 256 | 25/12 | 400 | 300 | 8 | 8 | 192 | 4 × 1,600 GiB NVMe | 60 | KVM |
| i7.12xlarge.8 | 48 | 384 | 30/18 | 500 | 400 | 16 | 8 | 256 | 6 × 1,600 GiB NVMe | 60 | KVM |
| i7.16xlarge.8 | 64 | 512 | 35/24 | 600 | 500 | 16 | 8 | 256 | 8 × 1,600 GiB NVMe | 60 | KVM |
| i7.24xlarge.8 | 96 | 768 | 44/36 | 800 | 800 | 32 | 8 | 256 | 12 × 1,600 GiB NVMe | 60 | KVM |
FlexusX Instances
FlexusX instances are next-generation cloud servers that offer flexible computing for small and medium-sized enterprises and developers. They allow for flexible configuration of vCPU-to-memory ratios, so you can choose the appropriate flavors based on your service resource needs to minimize resource overhead.
| Flavor | Compute | Network | Supported Cluster Type |
| FlexusX1 |
| FlexusX1e |
| FlexusX2e |
| vCPU | Max./Assured Bandwidth (Gbit/s) | Max. PPS (10,000) | Network Connections (10,000) | Max. Network Interface Queues | Max. Network Interfaces | Max. Supplementary Network Interfaces | Virtualization |
| 2 | 2/0.2 | 30 | 50 | 2 | 2 | 8 | KVM |
| 3 | 2/0.2 | 30 | 50 | 2 | 2 | 8 | KVM |
| 4 | 3/0.4 | 50 | 50 | 2 | 2 | 16 | KVM |
| 5 | 3/0.4 | 50 | 50 | 2 | 2 | 16 | KVM |
| 6 | 4/0.6 | 60 | 50 | 2 | 2 | 24 | KVM |
| 7 | 4/0.6 | 60 | 50 | 2 | 2 | 24 | KVM |
| 8 | 6/0.8 | 80 | 100 | 2 | 2 | 32 | KVM |
| 9 | 6/0.8 | 80 | 100 | 2 | 2 | 32 | KVM |
| 12 | 8/1.2 | 90 | 100 | 4 | 3 | 48 | KVM |
| 16 | 12/1.6 | 100 | 100 | 4 | 3 | 64 | KVM |
| vCPU | Max./Assured Bandwidth (Gbit/s) | Max. PPS (10,000) | Max. Network Interface Queues | Max. Network Interfaces | Max. Supplementary Network Interfaces | Virtualization |
| 2 | 2/1 | 40 | 2 | 2 | 16 | KVM |
| 4 | 3/1.5 | 60 | 2 | 3 | 32 | KVM |
| 8 | 6/2.5 | 100 | 4 | 4 | 64 | KVM |
| 12 | 8/4 | 150 | 4 | 6 | 96 | KVM |
| 16 | 12/5 | 200 | 8 | 8 | 128 | KVM |
| 20 | 13/5 | 220 | 8 | 8 | 128 | KVM |
| 24 | 14/6 | 250 | 8 | 8 | 192 | KVM |
| 28 | 15/6 | 280 | 8 | 8 | 192 | KVM |
| 32 | 16/8 | 300 | 16 | 8 | 256 | KVM |
| 2 | 2/1 | 40 | 2 | 2 | 8 | QingTian-backed simplified, proprietary virtualization |
| 4 | 3/1.5 | 60 | 2 | 3 | 16 | |
| 8 | 6/2.5 | 100 | 4 | 4 | 32 | |
| 16 | 12/5 | 200 | 8 | 4 | 64 | |
| 32 | 16/8 | 300 | 16 | 4 | 128 | |
| 48 | 22/12 | 400 | 16 | 4 | 256 | |
| 64 | 28/16 | 550 | 28 | 4 | 256 | |
| 96 | 40/25 | 800 | 32 | 8 | 256 | |
| 128 | 55/35 | 1,000 | 32 | 10 | 256 |
AI-accelerated ECSs
AI-accelerated ECSs are dedicated for accelerating AI applications. These ECSs use Ascend processors that feature low power consumption, high compute capabilities, and significantly improved energy efficiency for AI inference and video encoding and decoding.
AI-accelerated ECSs are classified as kAi series and Ai series ECSs.
- kAi series: Arm ECSs, which use Kunpeng 920 processors
- AI series: x86 ECSs, which use Intel Xeon processors
| kAi1s |
| Ai1s |
| Ai2 |
| Ai1 |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Bandwidth | Max. PPS (10,000) | Max. Network Interface Queues | Max. Network Interfaces | Ascend 310 | Virtualization |
| kai1s.xlarge.1 | 4 | 4 | 3/0.8 | 20 | 2 | 2 | 1 | KVM |
| kai1s.2xlarge.1 | 8 | 8 | 4/1.5 | 40 | 2 | 3 | 2 | KVM |
| kai1s.4xlarge.1 | 16 | 16 | 6/3 | 80 | 4 | 4 | 4 | KVM |
| kai1s.3xlarge.2 | 12 | 24 | 8/4 | 100 | 4 | 4 | 4 | KVM |
| kai1s.4xlarge.2 | 16 | 32 | 10/6 | 140 | 4 | 5 | 6 | KVM |
| kai1s.6xlarge.2 | 24 | 48 | 12/8 | 200 | 8 | 6 | 8 | KVM |
| kai1s.9xlarge.2 | 36 | 72 | 16/12 | 280 | 8 | 6 | 12 | KVM |
| kai1s.12xlarge.2 | 48 | 96 | 20/16 | 400 | 16 | 6 | 12 | KVM |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Network Bandwidth (Gbit/s) | Max. Network PPS (10,000) | Ascend 310 Processors | Ascend RAM (GiB) | Max. NIC Queues | Max. NICs | Virtualization |
| ai1s.large.4 | 2 | 8 | 4/1.3 | 20 | 1 | 8 | 2 | 2 | KVM |
| ai1s.xlarge.4 | 4 | 16 | 6/2 | 35 | 2 | 16 | 2 | 3 | KVM |
| ai1s.2xlarge.4 | 8 | 32 | 10/4 | 50 | 4 | 32 | 4 | 4 | KVM |
| ai1s.4xlarge.4 | 16 | 64 | 15/8 | 100 | 8 | 64 | 8 | 8 | KVM |
| ai1s.8xlarge.4 | 32 | 128 | 25/15 | 200 | 16 | 128 | 8 | 8 | KVM |
| Flavor | vCPUs | Memory (GiB) | Max./Assured Bandwidth | Max. PPS (10,000) | Ascend Chip | Ascend RAM (GiB) | Max. Network Interface Queues | Max. Network Interfaces | Virtualization |
| ai2.xlarge.4 | 4 | 16 | 8/1.6 | 80 | 1 | 24 | 3 | 3 | KVM |
| ai2.2xlarge.4 | 8 | 32 | 15/3 | 150 | 1 | 24 | 4 | 4 | KVM |
| ai2.4xlarge.4 | 16 | 64 | 20/6 | 280 | 1 | 24 | 8 | 8 | KVM |
| ai2.8xlarge.4 | 32 | 128 | 30/12 | 550 | 2 | 48 | 8 | 8 | KVM |
| ai2.16xlarge.4 | 64 | 256 | 36/24 | 800 | 4 | 96 | 16 | 8 | KVM |
| ai2.24xlarge.4 | 96 | 384 | 40/36 | 850 | 6 | 144 | 32 | 8 | KVM |
| ai1.large.4 | 2 | 8 | 4/1.3 | 20 | 1 | 8 | 2 | 2 | KVM |
| ai1.xlarge.4 | 4 | 16 | 6/2 | 35 | 2 | 16 | 2 | 3 | KVM |
| ai1.2xlarge.4 | 8 | 32 | 10/4 | 50 | 4 | 32 | 4 | 4 | KVM |
| ai1.4xlarge.4 | 16 | 64 | 15/8 | 100 | 8 | 64 | 8 | 8 | KVM |
| ai1.8xlarge.4 | 32 | 128 | 25/15 | 200 | 16 | 128 | 8 | 8 | KVM |
