Updated on 2026-09-21 GMT+08:00
New Pods
Check Items
  • Check whether pods can be created on the existing nodes after the cluster is upgraded.
  • Check whether pods can be created on new nodes after the cluster is upgraded.
After creating a node based on New Nodes, create a DaemonSet workload to create pods on each node.
  2. In the navigation pane, choose Workloads. On the displayed page, click Create from YAML or Create Workload in the upper right corner. For details about how to create a DaemonSet, see Creating a DaemonSet.
    Figure 1 Creating a DaemonSet
    It is a good practice to use the image for routine tests as the base image. You can deploy minimum pods for an application by referring to the following YAML file.
    In this test, a DaemonSet is deployed in the default namespace using YAML. It uses the nginx:perl base image and specifies a request of 10m CPU and 10 MiB of memory. The resource limits for this DaemonSet are set to 100m CPU and 50 MiB of memory.
    apiVersion: apps/v1
    kind: DaemonSet
      namespace: default
      selector:
        matchLabels:
          app: post-upgrade-check
          version: v1
      template:
          labels:
            version: v1
          containers:
            - name: container-1
              image: nginx:perl
              imagePullPolicy: IfNotPresent
              resources:
                requests:
                  cpu: 10m
                  memory: 10Mi
                limits:
                  cpu: 100m
                  memory: 50Mi
  3. Check whether the pods of the workload are running properly.
  4. After the check is complete, choose Workloads in the navigation pane. On the displayed page, click the DaemonSets tab, locate the post-upgrade-check workload, and choose More > Delete in the Operation column to delete the test workload.
If the pod cannot be created or the pod status is abnormal, contact technical support and specify whether the exception occurs on new nodes or existing nodes.
