Updated on 2026-09-21 GMT+08:00
Hierarchical Queues
In multi-tenant scenarios, queues are a core mechanism for fair scheduling, resource isolation, and job priority control. In real-world applications, different queues usually belong to different departments, and there are hierarchical relationships between departments, which lead to more refined requirements for resource allocation and preemption. However, traditional peer queues cannot meet such requirements. To address this issue, the Volcano scheduler introduces hierarchical queues to implement resource allocation, sharing, and preemption between queues at different levels. With hierarchical queues, you can manage resource quotas at a finer granularity and build a more efficient unified scheduling platform.
Introduction to Hierarchical Queues
Hierarchical queues are used to implement hierarchical resource allocation and isolation in a multi-tenant cluster environment. Queues are organized in a tree structure, with the following functions:
  • The queue hierarchy can be configured. The parent attribute is added to QueueSpec of Volcano Scheduler. When creating a queue, you can use the parent attribute to specify the parent queue that a queue belongs to.
    type QueueSpec struct {
       // Specify the parent queue that a queue belongs to.
        Parent string `json:"parent,omitempty" protobuf:"bytes,8,opt,name=parent"`
    After Volcano Scheduler is started, a root queue is created by default. You can create a hierarchical queue tree based on the root queue.
  • You can configure capability, the upper limit of a queue's resource capacity (pods that exceed this limit cannot be scheduled), deserved (if a queue's allocated resources exceed its configured deserved value, the excess may be reclaimed), and guarantee (resources reserved for a queue and cannot be shared with other queues) for each resource dimension.
  • Resources can be shared and reclaimed across hierarchical queues. When no other queues are submitting tasks, queues in the cluster can use resources beyond their reserved amounts, allowing their workloads to exceed the configured deserved value. When multiple queues submit tasks and cluster resources become insufficient to schedule new pods, the system can reclaim shared resources from queues at other levels.
    In Figure 1, Job A and Job C are submitted first, and both the allocated resources of the queues exceed the deserved value. If the cluster does not have enough resources to run Job B, the system attempts to reclaim resources from Job A and Job C to satisfy Job B's requirements.
    Figure 1 Reclaiming resources of hierarchical queues
Notes and Constraints
  • Queue resource management and scheduling support only CPUs, memory, and native heterogeneous resources (such as nvidia.com/gpu), but not virtualized heterogeneous resources.
Configuring a Hierarchical Queue Policy
After configuring a hierarchical queue policy, you can specify the hierarchical relationships between queues for sharing and reclaiming resources across queues and managing resource quotas at a finer granularity.
  2. In the navigation pane, choose Settings. Then click the Scheduling tab.
  3. In the Volcano Scheduler configuration, hierarchical queues are disabled by default. You need to modify the parameters to enable this feature.
    1. In Default Cluster Scheduler > Expert mode, click Try Now.
      Figure 2 Expert mode > Try Now
    2. Ensure that capacity has been enabled and set enableHierarchy to true. The hierarchical queue capability relies on the capacity plug-in. You also need to enable the reclaim action for resource reclamation between queues. When queue resources are insufficient, resource reclamation is triggered. The system preferentially reclaims resources that exceed the deserved value of the queue and selects an appropriate reclamation object based on the queue/job priority.
      To enable inter-queue sharing and reclamation of GPU resources, set enable_topology_aware_preemption to true to allow for the reclamation and preemption of GPU resources across cards.
      The capacity and proportion plug-ins cannot be used together. When using capacity, make sure that all proportion plug-in settings have been removed. In addition, verify that capacity has been added to the tier referenced in the YAML example below.
      Add the following parameters to the YAML file:
      default_scheduler_conf:
        actions: allocate, backfill, preempt, reclaim     # Enable the reclaim action.
        metrics:
          interval: 30s
          type: ''
        tiers:
          - plugins:
              - name: priority
              - enableJobStarving: false
                enablePreemptable: false
                enableReclaimable: false
              - name: conformance
              - name: capacity             # Confirm whether to enable capacity.
                enableHierarchy: true     # Confirm whether to enable hierarchical queues.
          - plugins:
              - enablePreemptable: false
              - name: predicates
              - name: nodeorder
              - arguments:
                  binpack.cpu: 1
                  binpack.memory: 1
                  binpack.resources: nvidia.com/gpu
                  binpack.resources.nvidia.com/gpu: 2
                  binpack.weight: 10
      descheduler_enable: 'false'
      deschedulingInterval: 10m
      enable_scale_in_score: true
      enable_topology_aware_preemption: true # To share and reclaim GPU resources among queues, enable topology-aware preemption.
      enable_workload_balancer: false
      oversubscription_method: nodeResource
    3. Click Save in the lower right corner.
  4. Click Confirm Settings in the lower right corner. In the displayed dialog box, confirm the modification and click Save.
Use Case
Assume that the cluster has 8 CPU cores and 16 GiB of memory remaining. First, create a hierarchical queue tree. Second, create two Volcano jobs (job-a and job-c) to exhaust cluster resources. Finally, create a Volcano job (job-b) and check the resource reclamation in hierarchical queues. Figure 3 shows the overall structure of this example.
Figure 3 Hierarchical queues
  1. Create a YAML file for the hierarchical queue tree.
    vim hierarchical_queue.yaml
    The file content is as follows:
    # The parent queue of child-queue-a is the root queue.
    apiVersion: scheduling.volcano.sh/v1beta1
    kind: Queue
      reclaimable: true
      parent: root
      capability:
        cpu: "5"
        memory: "10Gi"
      deserved:
        cpu: "4"
        memory: "8Gi"
      guarantee:
        resource:
          cpu: "2"
          memory: "4Gi"
    # The parent queue of child-queue-b is the root queue.
    kind: Queue
      reclaimable: true
      parent: root
      deserved:
        cpu: "2"
        memory: "4Gi"
    # The parent queue of subchild-queue-a1 is child-queue-a.
    kind: Queue
      reclaimable: true
      parent: child-queue-a
      # Set deserved as required. If the allocated resources of a queue exceed the value of deserved, resources used by the queue may be reclaimed.
      deserved:
        cpu: "2"
        memory: "4Gi"
    # The parent queue of subchild-queue-a2 is child-queue-a.
    kind: Queue
      reclaimable: true
      deserved:
        cpu: "2"
        memory: "4Gi"
    The following uses the YAML file of child-queue-a as an example to describe the parameters of hierarchical queues. For more parameter information, see Queue.
    Table 1 Hierarchical queue parameters
    Example Value
    reclaimable
    true
    (Optional) Specifies whether to enable the resource reclamation policy.
    • true (default): If the resource usage of a queue exceeds the value of deserved, other queues can reclaim the resources that are overused by the queue.
    • false: Other queues cannot reclaim the resources that are overused by the queue.
    parent
    root
    (Optional) Specifies the parent queue. The queues are hierarchical, and the total resources of a child queue are limited by the parent queue. If no parent queue is specified, the root queue is used by default.
    capability
    cpu: "5"
    memory: "10Gi"
    (Optional) Specifies the upper limit of resources for the queue. The value cannot exceed the capability value of the parent queue. Pods that exceed the upper limit cannot be scheduled.
    If a queue does not specify a capability value for a particular resource dimension, it automatically inherits the value from its parent queue. If neither the parent queue nor any of its ancestor queues defines this value, the setting of the root queue is used. By default, the root queue's capability is infinite.
    deserved
    cpu: "4"
    memory: "8Gi"
    Specifies the deserved resources of the queue. Each value must be less than or equal to the corresponding capability. In a single-layer queue scenario, the total deserved values of all queues should ideally not exceed the total resources available in the cluster. In a multi-layer queue scenario, the total deserved values of all child queues must not exceed the deserved value configured for their parent queues.
    If the resources already allocated to a queue exceed its deserved value, the queue is not allowed to reclaim resources from other queues. Instead, other queues may reclaim its resources, which can result in pod eviction. If the queue's allocated resources, after subtracting the resources requested by a pod being considered for eviction, fall below the queue's deserved value, the pod will not be evicted. This means that only the portion of resources exceeding the deserved value is reclaimable. If a queue does not define a deserved value, the default is 0, meaning all resources used by that queue may be reclaimed.
    guarantee
    cpu: "2"
    memory: "4Gi"
    (Optional) Specifies the reserved resources for the queue. The resources are reserved for this queue and cannot be borrowed by any other queue.
    The total guarantee value of all child queues cannot exceed the guarantee value configured for their parent queues, and each queue's guarantee value must be less than or equal to its deserved value. If a queue does not specify a guarantee value, the default is 0.
  2. Create a hierarchical queue tree.
    kubectl apply -f hierarchical_queue.yaml
    Information similar to the following is displayed:
    queue.scheduling.volcano.sh/child-queue-a created
    queue.scheduling.volcano.sh/child-queue-b created
    queue.scheduling.volcano.sh/subchild-queue-a1 created
    queue.scheduling.volcano.sh/subchild-queue-a2 created
  3. Create YAML files for Volcano jobs (job-a and job-b). job-a is submitted to subchild-queue-a1, and job-b to child-queue-b.
    vim vcjob.yaml
    # Submit job-a to the leaf queue subchild-queue-a1.
    apiVersion: batch.volcano.sh/v1alpha1
    kind: Job
      queue: subchild-queue-a1
      schedulerName: volcano
      minAvailable: 1
      tasks:
        - replicas: 3
          template:
              containers:
                - image: nginx
                  imagePullPolicy: IfNotPresent
                  resources:
                    requests:
                      cpu: "1"
                      memory: "2Gi"
    # Submit job-c to the leaf queue child-queue-b.
    kind: Job
      queue: child-queue-b
      minAvailable: 1
      tasks:
        - replicas: 5
          template:
              containers:
                - image: nginx
                  resources:
                    requests:
                      cpu: "1"
                      memory: "2Gi"
  4. Create job-a and job-c.
    kubectl apply -f vcjob.yaml
    job.batch.volcano.sh/job-a created
    job.batch.volcano.sh/job-c created
  5. Check the pod statuses.
    kubectl get pod
    If the following information is displayed and the status of each pod is Running, the cluster CPU and memory are used up.
    NAME           READY        STATUS        RESTARTS       AGE
    job-a-test-0   1/1          Running       0              3h21m
    job-a-test-1   1/1          Running       0              3h31m
    job-a-test-2   1/1          Running       0              3h31m
    job-c-test-0   1/1          Running       0              24m
    job-c-test-1   1/1          Running       0              24m
    job-c-test-2   1/1          Running       0              24m
    job-c-test-3   1/1          Running       0              24m
    job-c-test-4   1/1          Running       0              24m
  6. Create a YAML file for job-b.
    vim vcjob1.yaml
    # Submit job-b to the leaf queue subchild-queue-a2.
    kind: Job
      queue: subchild-queue-a2
      minAvailable: 1
      tasks:
        - replicas: 2
          template:
              containers:
                - image: nginx
                  resources:
                    requests:
                      cpu: "1"
                      memory: "2Gi"
  7. Create job-b.
    kubectl apply -f vcjob1.yaml
    job.batch.volcano.sh/job-b created
    Resource reclamation is triggered because the cluster CPU and memory are used up.
    • job-a is using 3 CPU cores and 6 GiB of memory in its sibling queue, which exceeds the deserved value of subchild-queue-a1 (2 CPU cores and 4 GiB of memory). The excess 1 CPU core and 2 GiB of memory can be reclaimed, but this amount is still insufficient to meet the resource requirements of job-b.
    • Because the reclaimable resources within subchild-queue-a1 are not enough, job-b continues searching upward through the queue hierarchy and eventually identifies job-c in child-queue-b as a candidate for cross-queue resource reclamation.
  8. Check the pod statuses and verify that resources have been reclaimed.
    kubectl get pod
    If the following information is displayed, the system is reclaiming resources:
    job-a-test-0   1/1          Running           0              3h33m
    job-a-test-1   1/1          Running           0              3h33m
    job-a-test-2   1/1          Terminating       0              3h33m
    job-b-test-0   0/1          Pending           0              1m
    job-b-test-1   0/1          Pending           0              1m
    job-c-test-0   1/1          Running           0              26m
    job-c-test-1   1/1          Running           0              26m
    job-c-test-2   1/1          Running           0              26m
    job-c-test-3   1/1          Running           0              26m
    job-c-test-4   1/1          Terminating       0              26m
    Wait for several minutes and run the preceding command again to check the pod statuses. If the following information is displayed, job-b has been executed.
    job-a-test-0   1/1          Running           0              3h35m
    job-a-test-1   1/1          Running           0              3h35m
    job-a-test-2   0/1          Pending           0              3h35m
    job-b-test-0   1/1          Running           0              2m
    job-b-test-1   1/1          Running           0              2m
    job-c-test-0   1/1          Running           0              28m
    job-c-test-1   1/1          Running           0              28m
    job-c-test-2   1/1          Running           0              28m
    job-c-test-3   1/1          Running           0              28m
    job-c-test-4   0/1          Pending           0              28m
Helpful Links
