Situation Awareness
Creating a CCE Standard Cluster
Updated on 2024-12-18 GMT+08:00
On the CCE console, you can easily create Kubernetes clusters. After a cluster is created, the master node is hosted by CCE. You only need to create worker nodes. In this way, you can implement cost-effective O&M and efficient service deployment.
Notes and Constraints
  • During the node creation, software packages are downloaded from OBS using the domain name. A private DNS server must be used to resolve the OBS domain name. Therefore, the DNS server address of the subnet where the node resides must be set to the private DNS server address so that the node can access the private DNS server. When you create a subnet, the private DNS server is used by default. If you change the subnet DNS, ensure that the DNS server in use can resolve the OBS domain name.
  • You can create a maximum of 50 clusters in a single region.
  • After a cluster is created, the following items cannot be changed:
    • Cluster type
    • Number of master nodes in the cluster
    • AZ of a master node
    • Network configurations of the cluster, such as the VPC, subnet, Service CIDR block, and kube-proxy (service forwarding) settings.
    • Network model. For example, change Tunnel network to VPC network.
Step 1: Log In to the CCE Console
  1. Log in to the CCE console.
  2. On the Clusters page, click Create Cluster in the upper right corner.
Step 2: Configure the Cluster
On the Create Cluster page, configure the parameters.
Basic Settings
Cluster Name
Enter a cluster name. Cluster names under the same account must be unique.
Cluster Version
Select the Kubernetes version used by the cluster.
Cluster Scale
Select a cluster scale for your cluster as required. These values specify the maximum number of nodes that can be managed by the cluster.
Master Nodes
Select the number of master nodes. The master nodes are automatically hosted by CCE and deployed with Kubernetes cluster management components such as kube-apiserver, kube-controller-manager, and kube-scheduler.
  • 3 Masters: Three master nodes will be created for high cluster availability.
  • Single: Only one master node will be created in your cluster.
You can also select AZs for the master nodes. By default, AZs are allocated automatically for the master nodes.
  • Automatic: Master nodes are randomly distributed in different AZs for cluster DR. If the number of available AZs is less than the number of nodes to be created, CCE will create the nodes in the AZs with sufficient resources to preferentially ensure cluster creation. In this case, AZ-level DR may not be ensured.
  • Custom: Master nodes are deployed in specific AZs.
    If there is one master node in your cluster, you can select one AZ for the master node. If there are multiple master nodes in your cluster, you can select multiple AZs for the master nodes.
    • Host: Master nodes are deployed on different hosts in the same AZ for cluster DR.
    • Custom: Master nodes are deployed in the AZs you specified.
Network Settings
The network settings cover nodes, containers, and Services. For details about the cluster networking and container network models, see Overview.
Table 1 Cluster network settings
VPC
Select the VPC to which the cluster belongs. If no VPC is available, click Create VPC to create one. The value cannot be changed after the cluster is created.
Subnet
Select the subnet to which the master nodes belong. If no subnet is available, click Create Subnet to create one. The value cannot be changed after the cluster is created.
Default Security Group
Select the security group automatically generated by CCE or use the existing one as the default security group of the node.
NOTICE:
The default security group must allow traffic from certain ports to ensure normal communication. Otherwise, the node cannot be created.
IPv6
If enabled, cluster resources, including nodes and workloads, can be accessed through IPv6 CIDR blocks.
  • IPv4/IPv6 dual stack is not supported by clusters using the VPC networks.
Table 2 Container network settings
Network Model
Select VPC network or Tunnel network for your CCE standard cluster.
For more information about their differences, see Overview.
Container CIDR Block (configured for CCE standard clusters)
Configure the CIDR block used by containers. The value determines the maximum number of containers in your cluster.
Table 3 Service network settings
Service CIDR Block
Configure the Service CIDR blocks for containers in the same cluster to access each other. The value determines the maximum number of Services you can create. The value cannot be changed after the cluster is created.
Request Forwarding
Select IPVS or iptables for your cluster. For details, see Comparing iptables and IPVS.
  • iptables is the traditional kube-proxy mode. This mode applies to the scenario where the number of Services is small or a large number of short connections are concurrently sent on the client. IPv6 clusters do not support iptables.
  • IPVS allows higher throughput and faster forwarding. This mode applies to scenarios where the cluster scale is large or the number of Services is large.
(Optional) Advanced Settings
Certificate Authentication
  • If Automatically generated is selected, the X509-based authentication mode will be enabled by default. X509 is a commonly used certificate format.
  • If Bring your own is selected, the cluster can identify users based on the header in the request body for authentication.
    Upload your CA root certificate, client certificate, and private key.
    CAUTION:
    • Upload a file smaller than 1 MB. The CA certificate and client certificate can be in .crt or .cer format. The private key of the client certificate can only be uploaded unencrypted.
    • The validity period of the client certificate must be longer than five years.
    • The uploaded CA root certificate is used by the authentication proxy and for configuring the kube-apiserver aggregation layer. If any of the uploaded certificates is invalid, the cluster cannot be created.
    • Starting from v1.25, Kubernetes no longer supports certificate authentication generated using the SHA1WithRSA or ECDSAWithSHA1 algorithm. The certificate authentication generated using the SHA256 algorithm is supported instead.
CPU Management
If enabled, exclusive CPU cores can be allocated to workload pods. For details, see CPU Policy.
Overload Control
After this function is enabled, concurrent requests will be dynamically controlled based on the resource demands received by master nodes to ensure the stable running of the master nodes and the cluster. For details, see Cluster Overload Control.
You can enter description for the cluster. A maximum of 200 characters are allowed.
Step 3: Select Add-ons
Click Next: Select Add-on. On the page displayed, select the add-ons to be installed during cluster creation.
Basic capabilities
Add-on Name
CCE Container Network (Yangtse CNI)
This is the basic cluster add-on. It provides network connectivity, Internet access, and security isolation for pods in your cluster.
CCE Container Storage (Everest)
This add-on (CCE Container Storage (Everest)) is installed by default. It is a cloud native container storage system based on CSI and supports cloud storage services such as EVS.
CoreDNS
This add-on (CoreDNS) is installed by default. It provides DNS resolution for your cluster and can be used to access the in-cloud DNS server.
NodeLocal DNSCache
(Optional) If selected, this add-on (NodeLocal DNSCache) will be automatically installed. NodeLocal DNSCache improves cluster DNS performance by running a DNS caching agent on cluster nodes.
Observability
Add-on Name
Cloud Native Cluster Monitoring
(Optional) If selected, this add-on (Cloud Native Cluster Monitoring) will be automatically installed. Cloud Native Cluster Monitoring collects monitoring metrics for your cluster and reports the metrics to AOM. The agent mode does not support HPA based on custom Prometheus statements. If related functions are required, install this add-on manually after the cluster is created.
CCE Node Problem Detector
(Optional) If selected, this add-on (CCE Node Problem Detector) will be automatically installed to detect faults and isolate nodes for prompt cluster troubleshooting.
Step 4: Configure Add-ons
Click Next: Add-on Configuration.
Basic capabilities
Add-on Name
This add-on is unconfigurable.
This add-on is unconfigurable. After the cluster is created, choose Add-ons in the navigation pane of the cluster console and modify the configuration.
CoreDNS
NodeLocal DNSCache
Observability
Add-on Name
Select an AOM instance for Cloud Native Cluster Monitoring to report metrics. If no AOM instance is available, click Creating Instance to create one.
Step 5: Confirm the Configuration
After the parameters are specified, click Next: Confirm configuration. The cluster resource list is displayed. Confirm the information and click Submit.
It takes about 5 to 10 minutes to create a cluster. You can click Back to Cluster List to perform other operations on the cluster or click Go to Cluster Events to view the cluster details.
Related Operations
