Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
FAQs>
Workload>
Workload Abnormalities>
What Should I Do If a Workload Is Stopped Caused by Pod Deletion?
Updated on 2024-01-04 GMT+08:00
Problem
A workload is in Stopped state.
Cause:
The metadata.enable field in the YAML file of the workload is false. As a result, the pod of the workload is deleted and the workload is in the stopped status.
Solution
Delete the enable field or set it to true.
Parent topic: Workload Abnormalities
