Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
Memory Resource Limit of Kubernetes Components
Updated on 2024-01-04 GMT+08:00
Check Items
Check whether the resources of Kubernetes components, such as etcd and kube-controller-manager, exceed the upper limit.
Solution
- Solution 1: Reduce Kubernetes resources that are needed.
- Solution 2: Modify cluster specifications. For details, see Changing Cluster Scale.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
