Annotations for Configuring LoadBalancer Ingresses
You can add annotations to a YAML file for more advanced ingress functions. This section describes the annotations that can be used when you create a LoadBalancer ingress.
Indexes
Category |
Ingress Annotation |
Load balancer configuration |
Port or protocol configuration |
Advanced features of ELB listeners |
Forwarding policy |
Basic Configurations for Interconnecting with ELB
- Associate an existing load balancer. For details, see Associating an Existing Load Balancer to an Ingress While Creating the Ingress.
- Automatically create a load balancer. For details, see Automatically Creating a Load Balancer While Creating an Ingress.
Parameter |
Type |
Description |
Supported Cluster Version |
kubernetes.io/elb.class |
String |
Select a proper load balancer type.
v1.9 or later |
kubernetes.io/ingress.class |
String |
This parameter is mandatory when an ingress is created by calling the API. For clusters of v1.23 or later, use the parameter ingressClassName. For details, see Creating a LoadBalancer Ingress Using kubectl. |
Only clusters of v1.21 or earlier |
kubernetes.io/elb.port |
String |
This parameter indicates the external port registered with the address of the LoadBalancer Service. The value ranges from 1 to 65535.
Some ports are high-risk ports and are blocked by default, for example, port 21. |
v1.9 or later |
kubernetes.io/elb.id |
String |
Mandatory when an existing load balancer is to be interconnected. ID of a load balancer. How to obtain: On the management console, click Service List, and choose Networking > Elastic Load Balance. Click the name of the target load balancer. On the Summary tab page, find and copy the ID. |
v1.9 or later |
kubernetes.io/elb.ip |
String |
Mandatory when an existing load balancer is to be interconnected. Service address of a load balancer. The value can be the public IP address of a public network load balancer or the private IP address of a private network load balancer. |
v1.9 or later |
kubernetes.io/elb.autocreate |
Table 14 Object |
Mandatory when load balancers are automatically created. Example
v1.9 or later |
kubernetes.io/elb.enterpriseID |
String |
Optional when load balancers are automatically created. Clusters of v1.15 and later versions support this field. In clusters earlier than v1.15, load balancers are created in the default project by default. This parameter indicates the ID of the enterprise project in which the ELB load balancer will be created. If this parameter is not specified or is set to 0, resources will be bound to the default enterprise project. How to obtain: Log in to the management console and choose Enterprise > Project Management on the top menu bar. In the list displayed, click the name of the target enterprise project, and copy the ID on the enterprise project details page. |
v1.15 or later |
kubernetes.io/elb.subnet-id |
String |
Optional when load balancers are automatically created. ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
Mandatory for clusters earlier than v1.11.7-r0 Discarded in clusters of a version later than v1.11.7-r0 |
Configuring ELB Certificates
For details about application scenarios and use cases, see Using kubectl to Configure a Certificate Created on the ELB Console.
Parameter |
Type |
Description |
kubernetes.io/elb.tls-certificate-ids |
String |
ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained. To obtain the certificate, log in to the CCE console, choose Service List > Networking > Elastic Load Balance, and click Certificates in the navigation pane. In the load balancer list, copy the ID under the target certificate name. |
v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later |
Adding Resource Tags
For details about application scenarios and use cases, see Automatically Creating a Load Balancer While Creating an Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.tags |
String |
Add resource tags to a load balancer. This parameter can be configured only when a load balancer is automatically created. A tag is in the format of "key=value". Use commas (,) to separate multiple tags. |
v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later |
Using HTTP/2
For details about application scenarios and use cases, see Configuring HTTP/2 for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.http2-enable |
String |
Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves the access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server. Options:
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP. |
v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
Interconnecting with HTTPS Backend Services
For details about application scenarios and use cases, see Configuring HTTPS Backend Services for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.pool-protocol |
String |
To interconnect with HTTPS backend services, set this parameter to https. |
v1.23.8, v1.25.3, or later |
Configuring Timeout for an Ingress
For details about application scenarios and use cases, see Configuring Timeout for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.keepalive_timeout |
String |
Timeout for client connections. If there are no requests reaching the load balancer during the timeout duration, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request. Value:
For UDP listeners, this parameter does not take effect. |
Dedicated load balancers: v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, or later Shared load balancers: v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
kubernetes.io/elb.client_timeout |
String |
Timeout for waiting for a request from a client. There are two cases:
The value ranges from 1 to 300 (in seconds). The default value is 60. This parameter is available only for HTTP and HTTPS listeners. Minimum value: 1 Maximum value: 300 Default value: 60 |
kubernetes.io/elb.member_timeout |
String |
Timeout for waiting for a response from a backend server. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout. The value ranges from 1 to 300 (in seconds). The default value is 60. This parameter is available only for HTTP and HTTPS listeners. Minimum value: 1 Maximum value: 300 Default value: 60 |
Configuring a Slow Start
For details about application scenarios and use cases, see Configuring a Slow Start for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.slowstart |
String |
Duration of slow start, in seconds. The slow start duration ranges from 30 to 1200.
The load balancer linearly increases the proportion of requests to backend servers in slow start mode. When the configured slow start duration elapses, the load balancer sends full share of requests to backend servers and exits the slow start mode. |
v1.23 or later |
Configuring a Range of Listening Ports
A custom listening port can be configured for an ingress. In this way, both ports 80 and 443 can be exposed.
Parameter |
Type |
Description |
kubernetes.io/elb.listen-ports |
String |
Configure multiple listening ports for an ingress. The port number ranges from 1 to 65535. The following is an example for JSON characters: kubernetes.io/elb.listen-ports: '[{"HTTP":80},{"HTTPS":443}]'
v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
Configuring the Priorities of Forwarding Rules
When ingresses use the same load balancer listener, forwarding rules can be prioritized based on the following rules:
- Forwarding rules of different ingresses: The rules are sorted based on the priorities (ranging from 1 to 1000) of the kubernetes.io/elb.ingress-order annotation. A smaller value indicates a higher priority.
- Forwarding rules of an ingress: If the kubernetes.io/elb.rule-priority-enabled annotation is set to true, the forwarding rules are sorted based on the sequence in which they are added during ingress creation. A forwarding rule added earlier indicates a higher priority. If the kubernetes.io/elb.rule-priority-enabled annotation is not configured, the default sorting of the forwarding rules on the load balancer will be used.
If the preceding annotations are not configured, the default sorting of the forwarding rules on the load balancer will be used, regardless of whether the forwarding rules are of the same ingress or different ingresses under the same load balancer listener.
For details about application scenarios and use cases, see Configuring the Priorities of Forwarding Rules for LoadBalancer Ingresses.
Parameter |
Type |
Description |
kubernetes.io/elb.ingress-order |
String |
Specifies the sequence of forwarding rules of different ingresses. The value ranges from 1 to 1000. A smaller value indicates a higher priority. The priority of a forwarding rule must be unique under the same load balancer listener. This parameter is available only for dedicated load balancers.
When this annotation is configured, the kubernetes.io/elb.rule-priority-enabled annotation is enabled by default. The forwarding rules of each ingress will be sorted. |
v1.23.15-r0, v1.25.10-r0, v1.27.7-r0, v1.28.5-r0, v1.29.1-r10, or later |
kubernetes.io/elb.rule-priority-enabled |
String |
This parameter can only be set to true, indicating to sort the forwarding rules of an ingress. The priorities of the forwarding rules are determined based on the sequence in which they are added during ingress creation. A forwarding rule added earlier indicates a higher priority. If this parameter is not configured, the default sorting of the forwarding rules on the load balancer will be used. After this parameter is enabled, it cannot be disabled. This parameter is available only for dedicated load balancers. |
Configuring a Custom Header Forwarding Policy
For details about application scenarios and use cases, see Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.headers.${svc_name} |
String |
Custom header of the Service associated with an ingress. ${svc_name} is the Service name. Format: a JSON string, for example, {"key": "test", "values": ["value1", "value2"]}
v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later |
Configuring a Custom EIP
For details about application scenarios and use cases, see Configuring a Custom EIP for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.custom-eip-id |
String |
ID of the custom EIP, which can be seen on the EIP console The EIP must be bindable. |
v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later |
Writing or Deleting a Header
For details about application scenarios and use cases, see Configuring Header Writing or Deletion for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.actions.${svc_name} |
String |
Rewrite the header of the Service associated with an ingress. ${svc_name} indicates the Service name, which contains a maximum of 51 characters. If the annotation value is set to [], the header rewriting policy is deleted. An annotation value is a JSON string array. For example: [{"type":"InsertHeader","InsertHeaderConfig":{"key":"aa","value_type":"USER_DEFINED","value":"aa"}}]
A maximum of five configurations are allowed for writing or deleting a header. |
v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later |
Configuring Advanced Forwarding Rules
For details about application scenarios and use cases, see Configuring Advanced Forwarding Rules for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.conditions.${svc_name} |
String |
Configure an advanced forwarding rule. ${svc_name} indicates the Service name, which contains a maximum of 51 characters. If the annotation value is set to [], the advanced forwarding rule is deleted. The annotation value is in the form of a JSON array. For details, see Table 2.
NOTICE:
Parameters for Automatically Creating a Load Balancer
Parameter |
Mandatory |
Type |
Description |
name |
No |
String |
Name of the automatically created load balancer. The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed. Default: cce-lb+service.UID |
type |
No |
String |
Network type of the load balancer.
Default: inner |
bandwidth_name |
Yes for public network load balancers |
String |
Bandwidth name. The default value is cce-bandwidth-******. The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed. |
bandwidth_chargemode |
No |
String |
Bandwidth mode.
Default: bandwidth |
bandwidth_size |
Integer |
Bandwidth size. The value ranges from 1 Mbit/s to 2000 Mbit/s by default. Configure this parameter based on the bandwidth range allowed in your region.
The minimum increment for bandwidth adjustment varies depending on the bandwidth range.
bandwidth_sharetype |
String |
Bandwidth sharing mode.
eip_type |
String |
EIP type.
The specific type varies with regions. For details, see the EIP console. |
vip_subnet_cidr_id |
No |
String |
Subnet where a load balancer is located. The subnet must belong to the VPC where the cluster resides. If this parameter is not specified, the ELB load balancer and the cluster are in the same subnet. This field can be specified only for clusters of v1.21 or later. |
vip_address |
No |
String |
Private IP address of the load balancer. Only IPv4 addresses are supported. The IP address must be in the ELB CIDR block. If this parameter is not specified, an IP address will be automatically assigned from the ELB CIDR block. This parameter is available only in clusters of v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later versions. |
available_zone |
Yes |
Array of strings |
AZ where the load balancer is located. This parameter is available only for dedicated load balancers. |
l4_flavor_name |
Yes |
String |
Flavor name of the layer-4 load balancer. This parameter is available only for dedicated load balancers. |
l7_flavor_name |
No |
String |
Flavor name of the layer-7 load balancer. This parameter is available only for dedicated load balancers. The value of this parameter must be the same as that of l4_flavor_name, that is, both are elastic specifications or fixed specifications. |
elb_virsubnet_ids |
No |
Array of strings |
Subnet where the backend server of the load balancer is located. If this parameter is left blank, the default cluster subnet is used. Load balancers occupy different number of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters and nodes) as the load balancer CIDR block. This parameter is available only for dedicated load balancers. Example: "elb_virsubnet_ids": [ "14567f27-8ae4-42b8-ae47-9f847a4690dd" ] |
