Updated on 2026-09-21 GMT+08:00
LoadBalancer Ingress Annotations
You can add annotations to a YAML file for more advanced ingress functions. This section describes the annotations that can be used when you create a LoadBalancer ingress.
Indexes
In a cluster, multiple ingresses can share a listener, allowing them to use the same port on a single load balancer. If two ingresses have different listener configurations, the listener configuration of the earlier ingress (known as the first route) will be used. For details about how to confirm the first route, see How Can I Determine Which Ingress the Listener Settings Have Been Applied To?
This case involves the following scenarios:
Ensure that the configurations of different listeners for various ingresses are synchronized.
Load Balancer Settings
Basic Configurations for Interconnecting with ELB
Application scenarios and use cases:
Table 1 Annotations for interconnecting with ELB
Type
Supported Cluster Version
kubernetes.io/elb.class
String
Select a proper load balancer type. This parameter cannot be modified after the ingress is created.
Options:
Default: union
v1.9 or later
kubernetes.io/ingress.class
String
  • cce: A proprietary LoadBalancer ingress is used.
  • nginx: indicates that Nginx Ingress is used. This option is available only after NGINX Ingress Controller is installed. For details, see Creating an Nginx Ingress Using kubectl.
    Multiple NGINX Ingress Controller add-ons can be installed in a single cluster if the add-on version is 2.5.4 or later. In this case, the value of this parameter must be the controller name customized during controller installation, indicating that the ingress is managed by that specific controller.
This parameter is mandatory when you create an ingress. The default value is cce.
For clusters v1.23 or later, use the parameter ingressClassName. For details, see Creating a LoadBalancer Ingress Using kubectl.
Only clusters v1.21 or earlier
kubernetes.io/elb.port
String
External port registered with the LoadBalancer Service address.
The value ranges from 1 to 65535. The default value is 80 for HTTP and 443 for HTTPS.
Some ports on a shared load balancer are highly risky and blocked by default, for example, port 21.
v1.9 or later
kubernetes.io/elb.id
String
When associating only existing load balancers, you can use either this parameter or kubernetes.io/elb.ip. If they conflict, kubernetes.io/elb.id will take precedence. This parameter cannot be modified after the ingress is created.
This parameter indicates the ID of a load balancer.
How to obtain:
Log in to the ELB console and click the load balancer name. On the Summary tab of the load balancer details page, find the ID field and copy it.
v1.9 or later
String
When associating only existing load balancers, you can use either this parameter or kubernetes.io/elb.id. If they conflict, kubernetes.io/elb.id will take precedence. This parameter cannot be modified after the ingress is created.
This parameter indicates the IP address of a load balancer.
When creating an ingress, specify a public or private IP address for a shared load balancer. For a dedicated load balancer, only a private IP address can be specified.
v1.9 or later
kubernetes.io/elb.autocreate
Table 2 object
Mandatory when load balancers are automatically created. This parameter cannot be modified after the ingress is created.
CAUTION:
kubernetes.io/elb.id and kubernetes.io/elb.autocreate cannot be specified concurrently.
If both annotations are specified in a Service, CCE will use an existing load balancer instead of automatically creating one. If this Service is deleted, the existing load balancer is considered as an automatically created one. If no other resources are associated with the load balancer, the load balancer will also be deleted.
Example:
  • Automatically created dedicated load balancer with an EIP bound:
    '{"type":"public","bandwidth_name":"cce-bandwidth-1741230802502","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","available_zone":["*****"],"elb_virsubnet_ids":["*****"],"l7_flavor_name":"L7_flavor.elb.pro.max","l4_flavor_name":"","vip_subnet_cidr_id":"*****"}'
  • Automatically created dedicated load balancer with no EIP bound:
    '{"type":"inner","available_zone":["*****"],"elb_virsubnet_ids":["*****"],"l7_flavor_name":"L7_flavor.elb.pro.max","l4_flavor_name":"","vip_subnet_cidr_id":"*****"}'
  • Automatically created shared load balancer with an EIP bound:
    '{"type":"public","bandwidth_name":"cce-bandwidth-1551163379627","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","name":"james"}'
  • Automatically created shared load balancer with no EIP bound:
    '{"type":"inner", "name": "A-location-d-test"}'
v1.9 or later
kubernetes.io/elb.enterpriseID
String
Optional when load balancers are automatically created.
This parameter is available in clusters v1.15 or later. In clusters earlier than v1.15, load balancers are created in the default project by default.
This parameter indicates the ID of the enterprise project in which the ELB load balancer will be created.
If this parameter is not specified or is set to 0, resources will be bound to the default enterprise project.
How to obtain:
Log in to the EPS console. Click the enterprise project name. On the details page, copy the ID.
v1.15 or later
kubernetes.io/elb.subnet-id
String
ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
  • Mandatory when a cluster v1.11.7-r0 or earlier will be automatically created.
  • Optional for clusters of a version later than v1.11.7-r0.
Mandatory for clusters of a version earlier than v1.11.7-r0
Discarded in clusters of a version later than v1.11.7-r0
Adding Resource Tags
For details about applications and use cases, see Automatically Creating a Load Balancer While Creating an Ingress.
Table 3 Annotations
Type
kubernetes.io/elb.tags
String
Add resource tags to a load balancer. This parameter can be configured only when a load balancer is automatically created.
A tag is in the format of "key=value". Use commas (,) to separate multiple tags.
v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, v1.23.8-r1, v1.25.3-r1, or later
Configuring a Reclaim Policy for an Auto-created Load Balancer
Table 4 Annotation for configuring a reclaim policy for an auto-created load balancer
Type
kubernetes.io/elb.instance-reclaim-policy
String
Configure a reclaim policy for an auto-created load balancer. The options are as follows:
  • (Default) Absence of the parameter or presence as blank: The auto-created load balancer is deleted along with the Service/ingress. However, if the load balancer is associated with multiple Services/ingresses and the Service/ingress that is created along with the load balancer is deleted first, the load balancer may be retained even after all its associated Services/ingresses are deleted.
  • retain: The auto-created load balancer is retained when the Service/ingress is deleted.
  • alwaysDelete: The auto-created load balancer is deleted along with the Service/ingress. If the load balancer is associated with multiple Services/ingresses, it will be deleted only after all its associated Services/ingresses are deleted.
  • If an auto-created load balancer is associated with other resources or its billing mode is changed to yearly/monthly, it will be retained even if the reclaim policy is not set to retain.
  • If an auto-created load balancer is associated with multiple Services/ingresses, this parameter applies only to the Service/ingress that is created along with the load balancer.
v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later
The following shows how to use the preceding annotation:
kind: Ingress
  namespace: default
  annotations:
    kubernetes.io/elb.port: '80'
    kubernetes.io/elb.class: performance
    kubernetes.io/elb.autocreate: '{"type":"inner","available_zone":["******"],"elb_virsubnet_ids":["*****"],"ipv6_vip_virsubnet_id":"******","l7_flavor_name":"L7_flavor.elb.pro.max","l4_flavor_name":"","vip_subnet_cidr_id":"******"}'
    kubernetes.io/elb.enterpriseID: '0'
    kubernetes.io/elb.instance-reclaim-policy: retain   # Configure a reclaim policy for an auto-created load balancer.
  rules:
    - host: ''
      http:
        paths:
          - path: /
            backend:
              service:
                port:
                  number: 80
            property:
  ingressClassName: cce
Certificate and Security Management
Configuring ELB Certificates
For details about applications and use cases, see Configuring an HTTPS Certificate for a LoadBalancer Ingress.
Table 5 ELB certificate annotations
Type
kubernetes.io/elb.tls-certificate-ids
String
ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained. A dedicated load balancer supports a maximum of 50 SNI certificates. A shared load balancer supports a maximum of 30 SNI certificates.
How to obtain: Log in to the ELB console and choose Certificates. In the certificate list, copy the ID under the target certificate name.
v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later
kubernetes.io/elb.tls-ciphers-policy
String
The default value is tls-1-2, which is the default security policy used by the listener and takes effect only when HTTPS is used.
Options:
  • tls-1-0
  • tls-1-1
  • tls-1-2
  • tls-1-2-strict
  • tls-1-0-with-1-3 (dedicated load balancer)
  • tls-1-2-fs (dedicated load balancer)
  • tls-1-2-fs-with-1-3 (dedicated load balancer)
For details of cipher suites for each security policy, see Table 3.
Clusters v1.17.17 or later
kubernetes.io/elb.security_policy_id
String
The ID of the custom security group policy on ELB. Obtain it on the ELB console. This field takes effect only when HTTPS is used and has a higher priority than the default security policy.
For details about how to create and update a custom security policy, see TLS Security Policy.
Configuring Mutual Authentication
Table 6 Annotation for configuring mutual authentication
Type
kubernetes.io/elb.client-ca-cert-id
String
Required only for mutual authentication. The ELB certificate ID serves as the CA certificate.
Clusters v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later support this configuration.
kind: Ingress
  namespace: default
  annotations:
    kubernetes.io/elb.port: '443'
    kubernetes.io/elb.id: *****
    kubernetes.io/elb.tls-certificate-ids: *****
    kubernetes.io/elb.client-ca-cert-id: *****   # Configure mutual authentication.
  rules:
    - host: ''
      http:
        paths:
          - path: /
            backend:
              service:
                port:
                  number: 80
            property:
Blocklist/Trustlist
For details about applications and use cases, see Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Ingress.
Table 7 Annotations for ELB access control
Type
kubernetes.io/elb.acl-id
String
  • If this parameter is not specified, CCE does not modify access control on the ELB.
  • If this parameter is left empty, all IP addresses are allowed to access the load balancer.
  • If this parameter is set to the IP address group ID of the load balancer, access control is enabled and you need to configure an IP address blocklist or trustlist for the load balancer. Additionally, you need to configure both kubernetes.io/elb.acl-status and kubernetes.io/elb.acl-type.
    For clusters v1.25.16-r10, v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, v1.31.1-r0, or later, when using a dedicated load balancer, you can select a maximum of five IP address groups at a time, separated by commas (,).
    How to obtain:
    Log in to the ELB console, choose Elastic Load Balance > IP Address Groups, and copy the ID of the target IP address group. For details, see Creating an IP Address Group.
v1.23.12-r0, v1.25.7-r0, v1.27.4-r0, v1.28.2-r0, or later
String
This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
  • on or true: Access control is enabled.
  • off or false: Access control is disabled.
String
  • black: indicates a blocklist. The selected IP address group cannot access the load balancer.
  • white: indicates a trustlist. Only the selected IP address group can access the load balancer.
Protocol and Listener Configuration
Using HTTP/2
For details about applications and use cases, see Configuring HTTP/2 for a LoadBalancer Ingress.
Table 8 Annotations for using HTTP/2
Type
kubernetes.io/elb.http2-enable
String
Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server.
Options:
  • true: enabled
  • false: disabled (default value)
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP.
v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later
Interconnecting with HTTPS/gRPC Backend Services
For details about applications and use cases, see Configuring HTTPS Backend Services for a LoadBalancer Ingress and Configuring gRPC Backend Services for a LoadBalancer Ingress.
Table 9 Annotations for interconnecting with HTTPS backend services
Type
kubernetes.io/elb.pool-protocol
String
To interconnect with HTTPS backend services, set this parameter to https.
v1.23.8, v1.25.3, or later
To interconnect with gRPC backend services, set this parameter to grpc.
v1.23.10-r20, v1.25.5-r20, v1.27.2-r20, v1.28.1-r0, or later
Configuring a Range of Listening Ports
A custom listening port can be configured for an ingress. In this way, both ports 80 and 443 can be exposed.
For details about applications and use cases, see Configuring a Range of Listening Ports for a LoadBalancer Ingress.
Table 10 Annotations for a custom listening port
Type
kubernetes.io/elb.listen-ports
String
Configure multiple listening ports for an ingress. The port number ranges from 1 to 65535.
The following is an example for JSON characters:
kubernetes.io/elb.listen-ports: '[{"HTTP":80},{"HTTPS":443}]'
  • Only the listening ports that comply with both HTTP and HTTPS are allowed.
  • This function is available only for newly created ingresses in clusters earlier than v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, or v1.30.4-r0. After you configure multiple listening ports, the annotations cannot be modified or deleted. In clusters v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later, the annotations can be modified and deleted.
  • If both kubernetes.io/elb.listen-ports and kubernetes.io/elb.port are configured, kubernetes.io/elb.listen-ports takes a higher priority.
  • Ingress configuration items such as the blocklist, trustlist, and timeout concurrently take effect on multiple listening ports. When HTTP/2 is enabled for an ingress, HTTP/2 takes effect only on the HTTPS port.
v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later
Configuring a QUIC Listener
For details about applications and use cases, see Configuring a QUIC Listener for a LoadBalancer Ingress.
Table 11 Annotation for configuring a QUIC listener
Type
kubernetes.io/elb.protocol
String
Frontend protocol of the load balancer listener. When configuring the QUIC frontend, set this parameter to QUIC.
v1.28.15-r80, v1.29.15-r40, v1.30.14-r40, v1.31.14-r0, v1.32.9-r0, v1.33.7-r0, v1.34.2-r0, or later
Routing and Forwarding Policies
Configuring Advanced Forwarding Rules
For details about applications and use cases, see Configuring an Advanced Forwarding Policy for a LoadBalancer Ingress.
Table 12 Annotation for advanced forwarding rules
Type
kubernetes.io/elb.conditions.${svc_name}
String
Configure advanced forwarding rules. ${svc_name} indicates the Service name, which can contain a maximum of 51 characters.
If the annotation value is set to [], the advanced forwarding rule will be deleted.
The annotation value is a JSON array. For details, see Table 4.
NOTICE:
  • Due to ELB API restrictions, a kubernetes.io/elb.conditions.{svcName} can contain a maximum of 10 key-value pairs.
  • The rules in a conditions array are connected by an AND relationship, while the values in the same rule block are connected by an OR relationship. For example, if both Method and QueryString are configured, the target traffic can be distributed only when both rules are met. However, if the Method value is GET or POST, the target traffic can be distributed only when both rules are met and the Method value must be GET or POST.
Configuring Advanced Forwarding Actions
Table 13 Annotation for configuring advanced forwarding actions
Type
kubernetes.io/elb.actions.${svc_name}
String
Advanced forwarding action of the Service associated with an ingress. ${svc_name} indicates the Service name, which can contain a maximum of 51 characters.
The annotation value is a JSON array. If it is set to [], the advanced forwarding action will be deleted.
The following advanced forwarding actions are supported:
The forwarding actions supported by clusters vary depending on the cluster version. For details, see Table 2.
Configuring URL Redirection
For details about applications and use cases, see Configuring URL Redirection for a LoadBalancer Ingress.
Table 14 Annotations for configuring URL redirection
Type
kubernetes.io/elb.redirect-url
String
URL for redirection.
Format:
  • HTTPS ingresses: valid URLs starting with https://, for example, https://example.com/
  • HTTP ingresses: valid URLs starting with http:// or https://, for example, https://example.com/
Parameter: This configuration takes effect on all forwarding rules of a single ingress. After the configuration is deleted, the target URL redirection rule will be automatically cleared.
Either this annotation or the annotation of a grayscale release can be configured.
kubernetes.io/elb.redirect-url-code
String
Code returned after an ingress is redirected to a URL.
Format: The return code can be 301, 302, 303, 307, or 308.
Parameter: The default value is 301.
Configuring URL Rewriting
For details about applications and use cases, see Configuring URL Rewriting for a LoadBalancer Ingress.
Table 15 Annotations for configuring URL rewriting
Type
kubernetes.io/elb.rewrite-target
String
Information about the rewritten path.
Format: A proper rule matching a regular expression must start with a slash (/).
Parameter: This configuration takes effect on the URL of a single ingress matching the regular expression. After the configuration is deleted, the target URL rewriting rule will be automatically cleared.
Redirecting HTTP to HTTPS
For details about applications and use cases, see Redirecting HTTP to HTTPS for a LoadBalancer Ingress.
Table 16 Annotations for redirecting HTTP to HTTPS
Type
kubernetes.io/elb.ssl-redirect
String
Whether to enable redirection from HTTP to HTTPS.
Format: The value can be true or false.
Parameter: true indicates that redirection is enabled. If the value is false or the parameter is unavailable, redirection is disabled.
If a dedicated load balancer is used, the cluster version must be v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later.
If a shared load balancer is used, the cluster version must be v1.27.16-r50, v1.28.15-r40, v1.29.15-r0, v1.30.14-r0, v1.31.10-r0, v1.32.6-r0, v1.33.1-r0, or later.
Configuring the Priorities of Forwarding Rules
When ingresses use the same load balancer listener, forwarding rules can be prioritized based on the following rules:
  • Forwarding rules of different ingresses: The rules are sorted based on the priorities (ranging from 1 to 1000) of the kubernetes.io/elb.ingress-order annotation. A smaller value indicates a higher priority.
  • Forwarding rules of an ingress: If the kubernetes.io/elb.rule-priority-enabled annotation is set to true, the forwarding rules are sorted based on the sequence in which they are added during ingress creation. A forwarding rule added earlier indicates a higher priority. If the kubernetes.io/elb.rule-priority-enabled annotation is not configured, the default sorting of the forwarding rules on the load balancer will be used.
If the preceding annotations are not configured, the default sorting of the forwarding rules on the load balancer will be used, regardless of whether the forwarding rules are of the same ingress or different ingresses under the same load balancer listener.
For details about applications and use cases, see Configuring Forwarding Rule Priorities for LoadBalancer Ingresses.
Table 17 Annotations for configuring the priorities of forwarding rules
Type
String
Specifies the sequence of forwarding rules of different ingresses. The value ranges from 1 to 1000. A smaller value indicates a higher priority. The priority of a forwarding rule must be unique under the same load balancer listener.
This parameter is available only for dedicated load balancers.
  • When this annotation is configured, the kubernetes.io/elb.rule-priority-enabled annotation is enabled by default. The forwarding rules of each ingress will be sorted.
  • CCE sorts all forwarding policies for a given listener based on the order of the ingresses and the forwarding policy settings within those ingresses. The configured value does not correspond to the priority of the load balancer forwarding policy.
v1.23.15-r0, v1.25.10-r0, v1.27.7-r0, v1.28.5-r0, v1.29.1-r10, or later
String
This parameter can only be set to true, indicating to sort the forwarding rules of an ingress. The priorities of the forwarding rules are determined based on the sequence in which they are added during ingress creation. A forwarding rule added earlier indicates a higher priority.
If this parameter is not configured, the default sorting of the forwarding rules on the load balancer will be used. After this parameter is enabled, it cannot be disabled.
Configuring a Custom Header Forwarding Policy
For details about applications and use cases, see Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress.
Table 18 Annotations for configuring a custom header forwarding policy
Type
kubernetes.io/elb.headers.${svc_name}
String
Custom header of the Service associated with an ingress. ${svc_name} is the Service name.
Format: a JSON string, for example, {"key": "test", "values": ["value1", "value2"]}
  • A key-value pair represents the key and value of a custom header. You can configure up to nine values. However, if a header with the key host is specified, only eight values can be configured.
    Enter 1 to 40 characters for a key. Only letters, digits, hyphens (-), and underscores (_) are allowed.
    Enter 1 to 128 characters for a value. Asterisks (*) and question marks (?) are allowed, but spaces and double quotation marks are not allowed. An asterisk can match zero or more characters, and a question mark can match one character.
  • Either a custom header or grayscale release can be configured.
  • Enter 1 to 51 characters for ${svc_name}.
v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later
Configuring an HTTP/HTTPS Header
For details about applications and use cases, see Configuring an HTTP/HTTPS Header for a LoadBalancer Ingress.
Table 19 Annotations for configuring an HTTP/HTTPS header
Type
kubernetes.io/elb.x-forwarded-port
String
A load balancer can obtain the port number of a listener using X-Forwarded-Port and include the port number into the packets sent to the backend server.
  • true: Enable the function of obtaining a listener port number.
  • false: Disable the function of obtaining a listener port number.
kubernetes.io/elb.x-forwarded-for-port
String
A load balancer can obtain a client port number for requests using X-Forwarded-For-Port and include the port number into the packets sent to the backend server.
  • true: Enable the function of obtaining a client port number for requests.
  • false: Disable the function of obtaining a client port number for requests.
kubernetes.io/elb.x-forwarded-host
String
  • true: Enable the function of rewriting X-Forwarded-Host. Then, the X-Forwarded-Host header will be rewritten using the Host header of the client request and transmitted to backend servers.
  • false: Disable the function of rewriting X-Forwarded-Host. Then, the X-Forwarded-Host header of the client will be transmitted to backend servers.
kubernetes.io/elb.x-real-ip
String
  • true: Enable the function of rewriting X-Real-IP. The source IP address of the client will be written into the X-Real-IP header and transmitted to the backend servers.
  • false: Disable the function of rewriting X-Real-IP. The X-Real-IP header of the client will be transmitted to the backend servers.
v1.25.16-r30, v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, v1.32.1-r0, or later
Traffic and Performance Optimization
Configuring Grayscale Release
For details about applications and use cases, see Configuring Grayscale Release for a LoadBalancer Ingress.
Table 20 Annotations for configuring grayscale release
Type
kubernetes.io/elb.canary
String
Grayscale release status for an ingress. If this parameter is set to true, the implementation of grayscale release varies depending on annotation configurations.
Option: true
  • This configuration applies only to dedicated load balancers.
  • If this parameter is set to true, the configuration cannot be deleted or modified.
kubernetes.io/elb.canary-weight
String
Weight of a grayscale release. After this parameter is configured, the ingress will be grayscale released based on the weight.
  • The value is an integer from 0 to 100. It is a percentage of traffic for routing.
  • This parameter is mandatory when an ingress is grayscale released by weight.
  • Do not configure this parameter with other grayscale release functions.
kubernetes.io/elb.session-affinity-mode
String
After weight-based grayscale release is enabled, configure sticky sessions.
This parameter can only be set to HTTP_COOKIE for grayscale releases.
kubernetes.io/
elb.session-affinity-option
String
Sticky session timeout after sticky sessions are enabled for weight-based grayscale releases.
The parameter value is a JSON string in the following format:
{"persistence_timeout": "1440"}
Parameters:
  • Timeout range: 1 to 1440
  • Default value: 1440
kubernetes.io/elb.canary-by-header
String
Key of an ingress header used for grayscale release, indicating the name of a request header. This parameter must be used with kubernetes.io/elb.canary-by-header-value.
Parameters:
Enter 1 to 40 characters. Only letters, digits, hyphens (-), and underscores (_) are allowed.
String
Value of an ingress header used for grayscale release. This parameter must be used with kubernetes.io/elb.canary-by-header.
The parameter value is an array in JSON format, for example:
'{"values":["a","b"]}'
Parameters:
  • Array length: At least one value must be configured.
    • If domain names and paths are configured for an ingress forwarding policy, a maximum of eight values can be configured.
    • If only paths are configured for an ingress forwarding policy, a maximum of nine values can be configured.
  • Enter 1 to 128 characters. Asterisks (*) and question marks (?) are allowed, but spaces and double quotation marks are not allowed. An asterisk can match zero or more characters, and a question mark can match one character.
kubernetes.io/elb.canary-by-cookie
String
Key of cookie-based grayscale release, indicating the name of a request cookie. This parameter must be used with kubernetes.io/elb.canary-by-cookie-value.
Parameters:
Enter 1 to 100 characters, including letters, digits, and other characters (!%'"()*+,./:=?@^\\-_`~).
String
Value of cookie-based grayscale release. This parameter must be used with kubernetes.io/elb.canary-by-cookie.
Parameters:
  • Enter 1 to 100 characters, including letters, digits, and other characters (!%'"()*+,./:=?@^\\-_`~). Spaces are not allowed.
kubernetes.io/elb.canary-related-ingress-uid
String
UID of the original ingress associated with the grayscale release ingress, which is used to display the association between the original ingress and the grayscale release ingress.
● Format: character string
● Value: metadata.uid of the original ingress
Configuring Timeout for an Ingress
For details about applications and use cases, see Configuring Timeout for a LoadBalancer Ingress.
Table 21 Annotations for configuring timeout of an ingress
Type
kubernetes.io/elb.keepalive_timeout
String
Timeout for client connections. If there are no requests reaching the load balancer during this period, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request.
The value ranges from 0 to 4000 (in seconds). The default value is 60.
Dedicated load balancers: v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, or later
Shared load balancers: v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later
kubernetes.io/elb.client_timeout
String
Timeout for waiting for a request from a client. There are two cases:
  • If the client fails to send a request header to the load balancer during this period, the request will be interrupted.
  • If the interval between two consecutive request bodies reaching the load balancer exceeds this period, the connection will be disconnected.
The value ranges from 1 to 300 (in seconds). The default value is 60.
kubernetes.io/elb.member_timeout
String
Timeout for backend server response. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout.
Configuring a Slow Start
For details about applications and use cases, see Configuring a Slow Start for a LoadBalancer Ingress.
Table 22 Annotations for configuring a slow start
Type
kubernetes.io/elb.slowstart
String
Duration of slow start, in seconds.
The slow start duration ranges from 30 to 1200.
  • This parameter is valid only when the allocation policy of the target Service is weighted round robin (WRR) and sticky session is disabled.
The load balancer linearly increases the proportion of requests to backend servers in slow start mode. When the configured slow start duration elapses, the load balancer sends full share of requests to backend servers and exits the slow start mode.
v1.23 or later
Enabling GZIP
For details about applications and use cases, see Configuring GZIP Data Compression for a LoadBalancer Ingress.
Table 23 Annotations for enabling GZIP
Type
kubernetes.io/elb.gzip-enabled
String
LoadBalancer ingresses support data compression, which reduces the size of files to be transferred, improves file transfer efficiency, and reduces the bandwidth needed for the transmission.
If this function is enabled, specific files will be compressed. If it is not enabled, files will not be compressed. By default, data compression is disabled.
The files in the following format can be compressed:
  • Brotli can compress all file formats.
  • GZIP can compress the files of the following types: text/xml, text/plain, text/css, application/javascript, application/x-javascript, application/rss+xml, application/atom+xml, application/xml, and application/json
This function is available only for HTTP/HTTPS listeners of dedicated load balancers. Deleting the advanced configuration for data compression or the target annotation will not modify the existing ELB settings.
Network and Backend Configuration
Configuring a Custom EIP
For details about applications and use cases, see Configuring a Custom EIP for a LoadBalancer Ingress.
Table 24 Annotations of custom EIP configurations
Type
kubernetes.io/elb.custom-eip-id
String
ID of the custom EIP, which can be seen on the EIP console.
The EIP must not already be bound.
v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later
Configuring Cross-Origin Access
For details about applications and use cases, see Configuring Cross-Origin Access for LoadBalancer Ingresses.
Table 25 Annotations for configuring cross-origin access
Type
kubernetes.io/elb.cors-allow-origin
Array[string]
Specify Access-Control-Allow-Origin for the origin that can be accessed.
Options:
  • Wildcard (*): indicates that all domain names can be accessed.
  • Domain names: start with http:// or https://. Level-1 wildcard domain names are supported. The format is http(s)://example.com or http(s)://example.com:port, where the port number ranges from 1 to 65535.
    You can enter multiple values by separating them with commas (,).
kubernetes.io/elb.cors-allow-headers
Array[string]
Specify Access-Control-Allow-Headers for allowed request headers. You can enter multiple values by separating them with commas (,).
kubernetes.io/elb.cors-expose-headers
Array[string]
Specify Access-Control-Expose-Headers for custom response headers that can be accessed by a cross-origin request. This allows you to retrieve non-standard response headers using client-side JavaScript code. You can enter multiple values by separating them with commas (,).
kubernetes.io/elb.cors-allow-methods
Array[string]
Specify Access-Control-Allow-Methods for allowed HTTP request methods.
kubernetes.io/elb.cors-allow-credentials
String
Specify Access-Control-Allow-Credentials to control the sending of credentials (such as cookies).
Options:
  • true: Credentials can be sent.
  • false: Credentials cannot be sent.
Once configured, the settings cannot be deleted. To remove the configuration, use kubernetes.io/elb.cors-disabled to delete all cross-origin settings.
kubernetes.io/elb.cors-max-age
String
Specify Access-Control-Max-Age for the cache duration of a CORS pre-check request. Unit: second. Value range: -1 to 172800
Properly configure this parameter based on service requirements. If the value is too low, pre-check requests may happen frequently. If the value is too high, the CORS policy may not take effect immediately.
String
Specify whether to disable all cross-origin settings. Options:
  • true: disables all cross-origin settings. The parameter values in the YAML file will not be deleted, but all cross-origin settings will not take effect.
  • false: default value, indicating that the cross-origin settings take effect based on your settings.
Configuring IP Addresses as Backend Servers
For details about applications and use cases, see Configuring IP Addresses as Backend Servers for LoadBalancer Ingresses.
Table 26 Annotation for configuring IP addresses as backend servers
Type
kubernetes.io/elb.ip-target-enabled
String
Enable IP addresses as backend servers for a load balancer. After this function is enabled, the backend IP addresses added to the associated Service or ingress are all IP addresses in VPC subnets. For a CCE Turbo cluster, the backend is <pod-IP-address>:<target-port>. For a CCE standard cluster, the backend is <node-IP-address>:<NodePort>.
  • true: Enable IP addresses as backend servers.
  • Other values are not supported.
CAUTION:
  • Only dedicated load balancers support this function.
  • This function can only be enabled during Service or ingress creation. Annotations cannot be added to or removed from existing resources. To use this function, recreate the Service or ingress.
  • If the load balancer associated with a Service or ingress does not have IP as a backend enabled, CCE will automatically enable it when the annotation is applied. This setting cannot be disabled once enabled.
  • Ensure that the backend subnets of the load balancer associated with the Service or ingress have sufficient IP addresses, or this function cannot be used. If the IP addresses are not enough, you can add more backend subnets on the Summary page of the load balancer.
  • For more details, see Using IP as a Backend to Route Traffic Across Backend Servers.
