Situation Awareness
On this page
Configuring a Node Pool
Updated on 2024-01-04 GMT+08:00
The default node pool DefaultPool does not support the following management operations.
Configuration Management
CCE allows you to highly customize Kubernetes parameter settings on core components in a cluster. For more information, see kubelet.
This function is supported only in clusters of v1.15 and later. It is not displayed for clusters earlier than v1.15.
  1. Log in to the CCE console.
  2. Click the cluster name to access the cluster console. Choose Nodes in the navigation pane and click the Node Pools tab on the right.
  3. Click Manage in the Operation column of the target node pool
  4. On the Manage Components page on the right, change the values of the following Kubernetes parameters:
    Table 1 kubelet
    Default Value
    Modification
    Remarks
    cpu-manager-policy
    CPU management policy configuration. For details, see CPU Scheduling.
    • none: disables pods from exclusively occupying CPUs. Select this value if you want a large pool of shareable CPU cores.
    • static: enables pods to exclusively occupy CPUs. Select this value if your workload is sensitive to latency in CPU cache and scheduling.
    none
    None
    None
    kube-api-qps
    Query per second (QPS) for communicating with kube-apiserver.
    100
    None
    None
    kube-api-burst
    Burst to use while talking with kube-apiserver.
    100
    None
    None
    max-pods
    Maximum number of pods managed by kubelet.
    None
    None
    pod-pids-limit
    Limited number of PIDs in Kubernetes
    -1
    None
    None
    with-local-dns
    Whether to use the local IP address as the ClusterDNS of the node.
    false
    None
    None
    event-qps
    QPS limit for event creation
    5
    None
    None
    allowed-unsafe-sysctls
    Insecure system configuration allowed.
    Starting from v1.17.17, CCE enables pod security policies for kube-apiserver. Add corresponding configurations to allowedUnsafeSysctls of a pod security policy to make the policy take effect. (This configuration is not required for clusters earlier than v1.17.17.) For details, see Example of Enabling Unsafe Sysctls in Pod Security Policy.
    None
    None
    over-subscription-resource
    Whether to enable node oversubscription.
    If this parameter is set to true, node oversubscription is enabled.
    false
    None
    None
    colocation
    Whether to enable hybrid deployment on nodes.
    If this parameter is set to true, hybrid deployment is enabled on nodes.
    false
    None
    None
    kube-reserved-mem
    system-reserved-mem
    Reserved node memory.
    Depends on node specifications. For details, see Node Resource Reservation Policy.
    None
    The sum of kube-reserved-mem and system-reserved-mem is less than half of the memory.
    topology-manager-policy
    Set the topology management policy.
    Valid values are as follows:
    • restricted: kubelet accepts only pods that achieve optimal NUMA alignment on the requested resources.
    • best-effort: kubelet preferentially selects pods that implement NUMA alignment on CPU and device resources.
    • none (default): The topology management policy is disabled.
    • single-numa-node: kubelet allows only pods that are aligned to the same NUMA node in terms of CPU and device resources.
    none
    None
    NOTICE:
    Modifying topology-manager-policy and topology-manager-scope will restart kubelet, and the resource allocation of pods will be recalculated based on the modified policy. In this case, running pods may restart or even fail to receive any resources.
    Set the resource alignment granularity of the topology management policy. Valid values are as follows:
    • container (default)
    • pod
    container
    resolv-conf
    DNS resolution configuration file specified by the container
    Null
    None
    None
    runtime-request-timeout
    Timeout interval of all runtime requests except long-running requests (pull, logs, exec, and attach).
    2m0s
    None
    This parameter is available only in clusters v1.21.10-r0, v1.23.8-r0, v1.25.3-r0 and later versions.
    registry-pull-qps
    Maximum number of image pulls per second.
    5
    The value ranges from 1 to 50.
    registry-burst
    Maximum number of burst image pulls.
    10
    The value ranges from 1 to 100 and must be greater than or equal to the value of registry-pull-qps.
    serialize-image-pulls
    When this function is enabled, kubelet is notified to pull only one image at a time.
    true
    None
    evictionHard: memory.available
    A hard eviction signal. The threshold is memory.available.
    The value is fixed at 100 MiB.
    None
    For details, see Node-pressure Eviction.
    NOTICE:
    Exercise caution when modifying the eviction threshold configuration. Improper configuration may cause pods to be frequently evicted or fail to be evicted when the node is overloaded.
    nodefs and imagefs correspond to the file system partitions used by kubelet and container engines, respectively.
    evictionHard: nodefs.available
    A hard eviction signal. The threshold is nodefs.available.
    10%
    The value ranges from 1% to 99%.
    evictionHard: nodefs.inodesFree
    A hard eviction signal. The threshold is nodefs.inodesFree.
    5%
    evictionHard: imagefs.available
    A hard eviction signal. The threshold is imagefs.available.
    10%
    evictionHard: imagefs.inodesFree
    A hard eviction signal. The threshold is imagefs.inodesFree.
    This parameter is left blank by default.
    evictionHard: pid.available
    A hard eviction signal. The threshold is pid.available.
    10%
    evictionSoft: memory.available
    A soft eviction signal. The threshold is memory.available.
    The value ranges from 100 MiB to 1,000,000 MiB. Configure evictionSoftGracePeriod of the corresponding eviction signal to configure the eviction grace period. This value must be greater than the threshold of the corresponding hard eviction signal.
    evictionSoft: nodefs.available
    A soft eviction signal. The threshold is nodefs.available.
    The value ranges from 1% to 99%. Configure evictionSoftGracePeriod of the corresponding eviction signal to configure the eviction grace period. This value must be greater than the threshold of the corresponding hard eviction signal.
    evictionSoft: nodefs.inodesFree
    A soft eviction signal. The threshold is nodefs.inodesFree.
    evictionSoft: imagefs.available
    A soft eviction signal. The threshold is imagefs.available.
    evictionSoft: imagefs.inodesFree
    A soft eviction signal. The threshold is imagefs.inodesFree.
    evictionSoft: pid.available
    A soft eviction signal. The threshold is pid.available.
    Table 2 kube-proxy
    Default Value
    Modification
    conntrack-min
    Maximum number of connection tracking entries
    To obtain the value, run the following command:
    sysctl -w net.nf_conntrack_max
    131072
    None
    conntrack-tcp-timeout-close-wait
    Wait time of a closed TCP connection
    sysctl -w net.netfilter.nf_conntrack_tcp_timeout_close_wait
    1h0m0s
    None
    Table 3 Network components (available only for CCE Turbo clusters)
    Default Value
    Modification
    nic-minimum-target
    Minimum number of ENIs bound to the nodes in the node pool
    10
    None
    nic-maximum-target
    Maximum number of ENIs pre-bound to a node at the node pool level
    0
    None
    nic-warm-target
    Number of ENIs pre-bound to a node at the node pool level
    2
    None
    nic-max-above-warm-target
    Reclaim number of ENIs pre-bound to a node at the node pool level
    2
    None
    Table 4 Pod security group in a node pool (available only for CCE Turbo clusters)
    Default Value
    Modification
    security_groups_for_nodepool
    • Default security group used by pods in a node pool. You can enter the security group ID. If this parameter is not set, the default security group of the cluster container network is used. A maximum of five security group IDs can be specified at the same time, separated by semicolons (;).
    • The priority of the security group is lower than that of the security group configured for Security Groups.
    None
    None
    Table 5 Docker (available only for node pools that use Docker)
    Default Value
    Modification
    native-umask
    `--exec-opt native.umask
    normal
    Cannot be changed.
    docker-base-size
    `--storage-opts dm.basesize
    0
    Cannot be changed.
    insecure-registry
    Address of an insecure image registry
    false
    Cannot be changed.
    limitcore
    Maximum size of a core file in a container. The unit is byte.
    If not specified, the value is infinity.
    5368709120
    None
    default-ulimit-nofile
    Limit on the number of handles in a container
    {soft}:{hard}
    The value cannot exceed the value of the kernel parameter nr_open and cannot be a negative number.
    You can run the following command to obtain the kernel parameter nr_open:
    sysctl -a | grep nr_open
    image-pull-progress-timeout
    If the image fails to be pulled before time outs, the image pull will be canceled.
    1m0s
    This parameter is supported in v1.25.3-r0 and later.
    Table 6 containerd (available only for node pools that use containerd)
    Default Value
    Modification
    devmapper-base-size
    Available data space of a single container
    0
    Cannot be changed.
    limitcore
    5368709120
    None
    1048576
    1m0s
  5. Click OK.
