Adding a Container CIDR Block for a Cluster
If the container CIDR block configured during CCE cluster creation cannot meet service expansion requirements, you can add a container CIDR block for the cluster.
Notes and Constraints
- This function is available only for clusters of v1.19 or later using a VPC network.
 - An added container CIDR block cannot be deleted.
Adding a Container CIDR Block for a CCE Standard Cluster
 - On the Overview page, locate the Networking Configuration area and click Add.
 - Configure the container CIDR block to be added. You can click
 to add multiple container CIDR blocks at a time.
     New container CIDR blocks cannot conflict with service CIDR blocks, VPC CIDR blocks, and existing container CIDR blocks.
 - Click OK.
