Updated on 2026-09-21 GMT+08:00
(kubectl) Creating a StatefulSet Mounted with an SFS Volume
CCE allows you to use an existing SFS volume to create a StatefulSet through a PersistentVolumeClaim (PVC).
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Create an SFS volume by referring to Automatically Creating an SFS Volume Through kubectl and record the volume name.
  2. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  3. Create a YAML file for creating the workload. Assume that the file name is sfs-statefulset-example.yaml.
    touch sfs-statefulset-example.yaml
    vi sfs-statefulset-example.yaml
    Example YAML:
    apiVersion: apps/v1
    kind: StatefulSet
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: sfs-statefulset-example
      serviceName: qwqq
      template:
          annotations:
            metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]'
            pod.alpha.kubernetes.io/initialized: "true"
          labels:
          affinity: {}
          containers:
          - image: nginx:latest
            volumeMounts:
            - mountPath: /tmp
          imagePullSecrets:
          - name: default-secret
          volumes:
            - name: pvc-sfs-example
              persistentVolumeClaim:
                claimName: cce-sfs-demo
    Table 1 Key parameters
    Parent Parameter
    spec
    replicas
    Number of pods.
    metadata
    name
    Name of the created workload.
    spec.template.spec.containers
    Image used by the workload.
    spec.template.spec.containers.volumeMounts
    mountPath
    Mount path in the container.
    spec
    serviceName
    Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
    spec.template.spec.volumes.persistentVolumeClaim
    claimName
    Name of an existing PVC.
    spec.template.spec.containers.volumeMounts.name and spec.template.spec.volumes.name must be consistent because they have a mapping relationship.
  4. Create the StatefulSet.
    kubectl create -f sfs-statefulset-example .yaml
