Configuring Time Zone Synchronization
When creating a workload, you can configure containers to use the same time zone as the node. You can enable time zone synchronization when creating a workload.
The time zone synchronization function depends on the local disk (hostPath) mounted to the container. After time zone synchronization is enabled, /etc/localtime of the node is mounted to /etc/localtime of the container in HostPath mode, in this way, the node and container use the same time zone configuration file.
kind: Deployment
apiVersion: apps/v1
  namespace: default
  replicas: 2
  selector:
    matchLabels:
      app: test
  template:
      labels:
        app: test
      volumes:
        - name: vol-162979628557461404
          hostPath:
            path: /etc/localtime
            type: ''
      containers:
        - name: container-0
          image: 'nginx:alpine'
          volumeMounts:
              readOnly: true
              mountPath: /etc/localtime
          imagePullPolicy: IfNotPresent
      imagePullSecrets:
        - name: default-secret
