Help Center>
Cloud Container Engine>
User Guide (Kuala Lumpur Region)>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
Health of Worker Node Components
Updated on 2024-01-24 GMT+08:00
Check Item
Check whether the container runtime and network components on the worker nodes are healthy.
Solution
If a worker node component malfunctions, log in to the node to check the status of the component and rectify the fault.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
