Help Center/ Cloud Container Engine/ User Guide/ Storage/ DSS/ Dynamically Mounting a DSS Disk to a StatefulSet
Updated on 2026-08-13 GMT+08:00
Dynamic mounting is available only for creating a StatefulSet. It is implemented through a PVC template (the volumeClaimTemplates field) and depends on dynamic creation of PVs through StorageClass. In this mode, each pod in a StatefulSet is associated with a unique PVC and PV. After a pod is rescheduled, the original data can still be mounted to it based on the PVC name. In the common mounting mode for a Deployment, if ReadWriteMany is supported, multiple pods of the Deployment will be mounted to the same underlying storage.
When updating a StatefulSet in Kubernetes, it is not allowed to add or delete the volumeClaimTemplates field. This field can only be configured during the creation of the StatefulSet.
Dynamically Attaching a DSS Disk
CCE allows you to dynamically attach DSS disks to workloads via the console or kubectl.
  2. Choose Workloads in the navigation pane. In the right pane, click the StatefulSets tab.
  3. Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Information area under Container Settings and choose Add Volume > VCT.
  4. Click Create PVC. On the slide-out panel, configure PVC parameters.
    Click Create.
    PVC Type
    In this example, select DSS.
    PVC Name
    Enter the name of the PVC. After a PVC is created, a suffix is automatically added based on the number of pods. The format is <Custom PVC name>-<Serial number>, for example, example-0.
    Creation Method
    You can select Dynamically provision to create a PVC, PV, and underlying storage on the console in cascading mode.
    Storage Classes
    The default StorageClass for DSS disks is csi-disk-dss.
    You can customize a StorageClass and configure its reclaim policy and binding mode. For details, see Basic StorageClass Settings.
    (Optional) Storage Volume Name Prefix
    Available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest v2.4.15 or later is installed in the cluster.
    This parameter specifies the name of the underlying storage that is automatically created. The actual underlying storage name is in the format of "Storage volume name prefix + PVC UID". If this parameter is left blank, the default prefix pvc will be used.
    For example, if the storage volume name prefix is set to test, the actual underlying storage name is test-{UID}.
    DSS Pool
    Select an existing DSS pool.
    Capacity (GiB)
    Capacity of the requested storage volume.
    Access Mode
    DSS volumes support only ReadWriteOnce, indicating that a storage volume can be mounted to one node in read/write mode. For details, see Volume Access Modes.
    Encryption
    Configure whether to encrypt the underlying storage. If you select Enabled (key), an encryption key must be configured.
    Enterprise Project
    An enterprise project manages multiple resources by category. Resources and projects across cloud service regions can be grouped into a single enterprise project. For example, an enterprise can classify resources by department or project group, and place relevant resources in the same enterprise project for unified management.
    This parameter is available only for enterprise accounts with enterprise projects enabled.
    Resource Tag
    You can add resource tags to classify resources. This is supported only when the Everest version in the cluster is v2.1.39 or later.
    You can create predefined tags on the TMS console. These tags are available to all resources that support tags. You can use these tags to improve the tag creation and resource migration efficiency. For details, see Creating Predefined Tags.
    CCE automatically creates system tags CCE-Cluster-ID={cluster-ID}, CCE-Cluster-Name={cluster-name}, and CCE-Namespace={namespace-name}. These tags cannot be modified.
    After a dynamic PV of the DSS type is created, the resource tags cannot be updated on the CCE console. To update DSS resource tags, go to the DSS console.
  5. Enter the path to which the volume is mounted.
    Table 1 Mounting a storage volume
    Mount Path
    Enter a mount path, for example, /tmp.
    This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.
    NOTICE:
    If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
    Subpath
    Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path will be used by default.
    Permission
    • Read-only: You can only read the data in the mounted volumes.
    • Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
    In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the DSS disk.
  6. Dynamically mount and use storage volumes. For details about other parameters, see Creating a StatefulSet. After the configuration, click Create Workload.
    After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence.
  1. Use kubectl to access the cluster.
  2. Create a file named statefulset-dss.yaml. In this example, the disk is mounted to the /data path.
    apiVersion: apps/v1
    kind: StatefulSet
      namespace: default
      selector:
        matchLabels:
          app: statefulset-dss
      template:
          labels:
          containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
                - name: pvc-disk           # The value must be the same as that in the volumeClaimTemplates field.
                  mountPath: /data         # Location where the storage volume is mounted
          imagePullSecrets:
            - name: default-secret
      serviceName: statefulset-dss         # Headless Service name
      replicas: 2
      volumeClaimTemplates:
        - apiVersion: v1
          kind: PersistentVolumeClaim
            namespace: default
            annotations:
              everest.io/disk-volume-type: SAS    # Disk type
              everest.io/csi.dedicated-storage-id: <dss_id>     # ID of the DSS storage pool
              everest.io/crypt-key-id: <your_key_id>    # (Optional) Encryption key ID. Mandatory for an encrypted disk.
              everest.io/enterprise-project-id: <your_enterprise_project_id>  # (Optional) Enterprise project ID
              everest.io/disk-volume-tags: '{"key1":"value1","key2":"value2"}' # (Optional) Custom resource tags
              everest.io/csi.volume-name-prefix: test  # (Optional) Volume name prefix of the automatically-created underlying storage
            labels:
              failure-domain.beta.kubernetes.io/region: <your_region>   # Region of the node where the application is to be deployed
              failure-domain.beta.kubernetes.io/zone: <your_zone>       # AZ of the node where the application is to be deployed
            accessModes:
              - ReadWriteOnce               # The value must be ReadWriteOnce for DSS.
            resources:
              requests:
                storage: 10Gi               # Disk capacity, ranging from 1 to 32768
            storageClassName: csi-disk-dss      # The StorageClass is DSS.
    apiVersion: v1
    kind: Service
      name: statefulset-dss   # Headless Service name
      namespace: default
      labels:
      selector:
      clusterIP: None
      ports:
        - name: statefulset-dss
          targetPort: 80
          nodePort: 0
          port: 80
          protocol: TCP
      type: ClusterIP
    Table 2 Key parameters
    Mandatory
    Yes
    Region where the cluster is located.
    For details about its value, see Regions and Endpoints.
    Yes
    AZ where the DSS volume is created. It must be the same as the AZ planned for the workload.
    Yes
    Disk type. All letters are in uppercase.
    • SAS: High I/O
    • SSD: Ultra-high I/O
    Yes
    ID of the DSS storage pool where the DSS disk resides.
    To obtain a DSS storage pool ID, log in to the Cloud Server Console. In the navigation pane, choose Dedicated Distributed Storage Service > Storage Pools and click the name of the target storage pool. On the resource pool details page, copy the pool ID.
    No
    Mandatory when the DSS disk is encrypted. Enter the encryption key ID selected during disk creation.
    To obtain a key ID, log in to the DEW console, locate the key to be encrypted, and copy the key ID.
    No
    This parameter specifies the ID of the enterprise project where a DSS disk is created. It is applicable only to enterprise accounts with enterprise projects enabled. For more details, see Enterprise Center Overview.
    To obtain an enterprise project ID, log in to the EPS console, click the name of the target enterprise project, and copy the enterprise project ID.
    No
    (Optional) This parameter is supported when the Everest version in the cluster is v2.1.39 or later.
    No
    (Optional) This parameter is available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest v2.4.15 or later is installed in the cluster.
    Enter 1 to 26 characters that cannot start or end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
    storage
    Yes
    Requested PVC capacity, in Gi. The value ranges from 1 to 32768.
    storageClassName
    Yes
    StorageClass name, which is csi-disk-dss for a DSS disk.
  3. Run the following command to create a workload to which the DSS volume is mounted:
    kubectl apply -f statefulset-dss.yaml
  1. View the deployed application and DSS volume files.
    1. Run the following command to view the created pod:
      kubectl get pod | grep statefulset-dss
      Expected output:
      statefulset-dss-0          1/1     Running   0             45s
      statefulset-dss-1          1/1     Running   0             28s
    2. Run the following command to check whether the DSS volume has been mounted to the /data path:
      kubectl exec statefulset-dss-0 -- df | grep data
      Expected output:
      /dev/sdd              10255636     36888  10202364   0% /data
    3. Run the following command to check the files in the /data path:
      kubectl exec statefulset-dss-0 -- ls /data
      Expected output:
      lost+found
  2. Run the following command to create a file named static in the /data path:
    kubectl exec statefulset-dss-0 --  touch /data/static
    Expected output:
    lost+found
    static
  4. Run the following command to delete the pod named web-dss-auto-0:
    kubectl delete pod statefulset-dss-0
    Expected output:
    pod "statefulset-dss-0" deleted
  5. After the deletion, the StatefulSet controller automatically creates a replica with the same name. Run the following command to check whether the files in the /data path have been modified:
    Expected output:
    lost+found
    static
    The static file is retained, indicating that the data in the DSS volume can be stored persistently.
Related Operations
You can also perform the operations listed in Table 3.
Table 3 Related operations
Operation
Expanding the capacity of DSS storage
Quickly expand the capacity of a mounted DSS volume on the CCE console.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Locate the target PVC and choose More > Scale-out in the Operation column.
  2. Enter the capacity to be added and click OK.
Viewing events
View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs or PVs tab.
  2. Click View Events in the Operation column of the target PVC or PV to view events generated within one hour (events are retained for one hour).
Viewing a YAML file
View, copy, or download the YAML file of a PVC or PV.
  2. Locate the target PVC or PV and click View YAML in the Operation column to view, copy, or download the YAML.
Editing Reclaim Policy
Modify the reclaim policy of a PV.
  1. Choose Storage in the navigation pane. In the right pane, click the PVs tab.
  2. Locate the target PV and choose More > Edit Reclaim Policy in the Operation column.
