Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ FAQs/ Workload/ Others/ What Can I Do If a Layer Is Missing During Image Pull?
Symptom
When containerd is used as the container engine, there is a possibility that the image layer is missing when an image is pulled to a node. As a result, the workload container fails to be created.
Possible Causes
Docker earlier than v1.10 supports the layer whose mediaType is application/octet-stream. However, containerd does not support application/octet-stream. As a result, the image is not pulled.
Solution
You can use either of the following methods to solve this problem:
  • Use Docker v1.11 or later to repackage the image.
  • Manually pull the image.
    1. Log in to the node.
    2. Run the following command to pull the image:
      ctr -n k8s.io images pull --user u:p images
    3. Use the newly pulled image to create a workload.
