Help Center/ Cloud Container Engine/ User Guide/ Storage/ EVS/ Expanding the Capacity of an EVS Disk
Updated on 2026-09-21 GMT+08:00
If the EVS disk attached to a workload does not have enough space, you can increase its capacity by expanding it. This section describes how to expand the capacity of an EVS disk through the console.
When you increase the size of the EVS disk through the EVS console and the new capacity outgrows the PVC, resize the PVC capacity on the CCE console to match the new size.
Procedure: In the navigation pane of the cluster, choose Storage. On the right, click the PVCs tab. Locate the target PVC and click Synchronize in the Capacity column to make the PVC capacity consistent with the underlying storage capacity.
  2. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Locate the target PVC and choose More > Scale-out in the Operation column.
    Figure 1 Expanding an EVS disk capacity
  3. Enter the capacity to be added and click OK.
    Disk sizes can only be increased, not decreased.
    Figure 2 Configuring the capacity to be expanded
  4. Wait until the scale-out is complete and verify that the total capacity of the PVC has been expanded.
