Help Center/
      Cloud Container Engine/
        User Guide (ME-Abu Dhabi Region)/
        Clusters/
        Managing a Cluster/
      Hibernating or Waking Up a Cluster
If a cluster is not needed temporarily, hibernate it to reduce costs.
After a cluster is hibernated, resources such as workloads cannot be created or managed in the cluster.
Precautions
- During cluster wakeup, the master node may fail to start due to insufficient resources, which leads to a cluster wakeup failure. In this case, wait for a while and try again.
 - After a cluster is woken up, it takes 3 to 5 minutes to initialize data. Deliver services after the cluster runs properly.
Hibernating a Cluster
- Log in to the CCE console. In the navigation pane, choose Clusters.
 - Locate the cluster to be hibernated, click ... to view more operations on the cluster, and choose Hibernate.
 - In the dialog box displayed, check the precautions and click Yes. Wait until the cluster is hibernated.
Waking Up a Cluster
You can wake up a hibernated cluster as needed.
 - Click Wake Up in the row of the target cluster.
 - When the cluster status changes from Waking up to Running, the cluster is woken up. It takes about 3 to 5 minutes to wake up the cluster.
   Parent topic: Managing a Cluster
