Creating a Kubernetes Cluster
Context
This section describes how to quickly create a CCE cluster. In this example, the default or simple configurations are in use.
Creating a Cluster
- Log in to the CCE console.
- If you have not created a cluster, a wizard page is displayed. Click Create under CCE cluster.
- If you have created a cluster, choose Clusters from the navigation pane and click Buy Cluster.
- On the Configure Cluster page, configure cluster parameters.
In this example, a majority of parameters retain default values. Only mandatory parameters are described. For details, see Table 1.
Table 1 Parameters for creating a cluster Parameter
Basic Settings
*Cluster Name
Name of the cluster to be created. A cluster name contains 4 to 128 characters starting with a lowercase letter and not ending with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
* Enterprise Project
This parameter is displayed only for enterprise users who have enabled Enterprise Project Management.
* Cluster Version
Choose the latest version.
* Cluster Scale
Maximum number of worker nodes that can be managed by the cluster. If you select 50 nodes, the cluster can manage a maximum of 50 worker nodes.
*High Availability
The default value is Yes.
Network Settings
* Network Model
Retain the default settings.
*VPC
VPC where the cluster will be located.
If no VPC is available, click Create VPC to create one. After the VPC is created, click refresh.
* Master Node Subnet
Subnet where master nodes of the cluster are located.
* Container CIDR Block
Retain the default value.
* IPv4 Service CIDR Block
CIDR block for Services used by containers in the same cluster to access each other. The value determines the maximum number of Services you can create. The value cannot be changed after creation.
- Click Next: Add-on Configuration. Retain the default settings.
- Click Next: Confirm. After confirming that the cluster configuration information is correct, select I have read and understand the preceding instructions and click Submit.
It takes about 6 to 10 minutes to create a cluster.
The created cluster will be displayed on the Clusters page, and the number of nodes in the cluster is 0.
Creating a Node
After a cluster is created, you need to create nodes in the cluster to run workloads.
- Click the created cluster.
- In the navigation pane, choose Nodes. Click Create Node in the upper right corner and set node parameters.
The following describes only important parameters. For other parameters, retain the defaults.
Compute Settings
- AZ: Retain the default value.
- Node Type: Select Elastic Cloud Server (VM).
- Specifications: Select node specifications that fit your business needs.
- Container Engine: Select a container engine as required.
- OS: Select the operating system (OS) of the nodes to be created.
- Node Name: Enter a node name.
- Login Mode:
- If the login mode is Password: The default username is root. Enter the password for logging to the node and confirm the password.
Please remember the node login password. If you forget the password, the system is unable to retrieve your password and you will have to reset the password.
- If the login mode is Key pair, select a key pair for logging to the node and select the check box to acknowledge that you have obtained the key file and without this file you will not be able to log in to the node.
A key pair is used for identity authentication when you remotely log in to a node. If no key pair is available, click Create Key Pair..
Storage Settings
- System Disk: Configure disk type and capacity based on your requirements. The default disk capacity is 50 GiB.
- Data Disk: Configure disk type and capacity based on your requirements. The default disk capacity is 100 GiB.
Network Settings
- VPC: Use the default value, that is, the subnet selected during cluster creation.
- Node Subnet: Select a subnet in which the node runs.
- Node IP: IP address of the specified node.
- EIP: The default value is Do not use. You can select Use existing and Auto create.
- At the bottom of the page, select the node quantity, and click Next: Confirm.
- Review the node specifications, read the instructions, select I have read and understand the preceding instructions, and click Submit.
It takes about 6 to 10 minutes to add a node.
The created node will be displayed on the Nodes page.
