Situation Awareness
Custom Storage Classes
Updated on 2024-01-04 GMT+08:00
Background
When using storage resources in CCE, the most common method is to specify storageClassName to define the type of storage resources to be created when creating a PVC. The following configuration shows how to use a PVC to apply for an SAS (high I/O) EVS disk (block storage).
apiVersion: v1
kind: PersistentVolumeClaim
  namespace: default
  annotations:
    everest.io/disk-volume-type: SAS
  accessModes:
  - ReadWriteOnce
  resources:
    requests:
      storage: 10Gi
  storageClassName: csi-disk
To specify the EVS disk type, you can set the everest.io/disk-volume-type field. The value SAS is used as an example here, indicating the high I/O EVS disk type. Or you can choose SSD (ultra-high I/O).
This configuration method may not work if you want to:
  • Set storageClassName only, which is simpler than specifying the EVS disk type by using everest.io/disk-volume-type.
  • Avoid modifying YAML files or Helm charts. Some users switch from self-built or other Kubernetes services to CCE and have written YAML files of many applications. In these YAML files, different types of storage resources are specified by different StorageClassNames. When using CCE, they need to modify a large number of YAML files or Helm charts to use storage resources, which is labor-consuming and error-prone.
  • Set the default storageClassName for all applications to use the default storage class. In this way, you can create storage resources of the default type without needing to specify storageClassName in the YAML file.
Solution
This section describes how to set a custom storage class in CCE and how to set the default storage class. You can specify different types of storage resources by setting storageClassName.
  • For the first scenario, you can define custom storageClassNames for SAS and SSD EVS disks. For example, define a storage class named csi-disk-sas for creating SAS disks. The following figure shows the differences before and after you use a custom storage class.
  • For the second scenario, you can define a storage class with the same name as that in the existing YAML file without needing to modify storageClassName in the YAML file.
  • For the third scenario, you can set the default storage class as described below to create storage resources without specifying storageClassName in YAML files.
    apiVersion: v1
      namespace: default
      accessModes:
      - ReadWriteOnce
      resources:
        requests:
          storage: 10Gi
Default Storage Classes in CCE
Run the following command to query the supported storage classes.
# kubectl get sc
NAME                PROVISIONER                     AGE
csi-disk            everest-csi-provisioner         17d          # Storage class for EVS disks
csi-disk-topology   everest-csi-provisioner         17d          # Storage class for EVS disks with delayed association
csi-nas             everest-csi-provisioner         17d          # Storage class for SFS file systems
csi-obs             everest-csi-provisioner         17d          # Storage Class for OBS buckets
csi-sfsturbo        everest-csi-provisioner         17d          # Storage class for SFS Turbo file systems
Check the details of csi-disk. You can see that the type of the disk created by csi-disk is SAS by default.
# kubectl get sc csi-disk -oyaml
allowVolumeExpansion: true
apiVersion: storage.k8s.io/v1
kind: StorageClass
  creationTimestamp: "2021-03-17T02:10:32Z"
  resourceVersion: "760"
  selfLink: /apis/storage.k8s.io/v1/storageclasses/csi-disk
  uid: 4db97b6c-853b-443d-b0dc-41cdcb8140f2
parameters:
  csi.storage.k8s.io/csi-driver-name: disk.csi.everest.io
  csi.storage.k8s.io/fstype: ext4
  everest.io/passthrough: "true"
provisioner: everest-csi-provisioner
reclaimPolicy: Delete
volumeBindingMode: Immediate
You can customize a high I/O storage class in a YAML file. For example, the name csi-disk-sas indicates that the disk type is SAS (high I/O).
kind: StorageClass
  name: csi-disk-sas                          # Name of the high I/O storage class, which can be customized.
parameters:
  everest.io/disk-volume-type: SAS            # High I/O EVS disk type, which cannot be customized.
allowVolumeExpansion: true                    # true indicates that capacity expansion is allowed.
For an ultra-high I/O storage class, you can set the class name to csi-disk-ssd to create SSD EVS disk (ultra-high I/O).
kind: StorageClass
  name: csi-disk-ssd                       # Name of the ultra-high I/O storage class, which can be customized.
parameters:
  everest.io/disk-volume-type: SSD         # Ultra-high I/O EVS disk type, which cannot be customized.
reclaimPolicy: indicates the recycling policies of the underlying cloud storage. The value can be Delete or Retain.
  • Delete: When a PVC is deleted, both the PV and the EVS disk are deleted.
  • Retain: When a PVC is deleted, the PV and underlying storage resources are not deleted. Instead, you must manually delete these resources. After that, the PV resource is in the Released state and cannot be bound to the PVC again.
The reclamation policy set here has no impact on the SFS Turbo storage.
If high data security is required, you are advised to select Retain to prevent data from being deleted by mistake.
After the definition is complete, run the kubectl create commands to create storage resources.
# kubectl create -f sas.yaml
storageclass.storage.k8s.io/csi-disk-sas created
# kubectl create -f ssd.yaml
storageclass.storage.k8s.io/csi-disk-ssd created
Query the storage class again. Two more types of storage classes are displayed in the command output, as shown below.
# kubectl get sc
csi-disk-sas        everest-csi-provisioner         2m28s
csi-disk-ssd        everest-csi-provisioner         16s
Other types of storage resources can be defined in the similar way. You can use kubectl to obtain the YAML file and modify it as required.
  • File storage
    # kubectl get sc csi-nas -oyaml
    kind: StorageClass
    parameters:
      csi.storage.k8s.io/csi-driver-name: nas.csi.everest.io
      csi.storage.k8s.io/fstype: nfs
      everest.io/share-access-level: rw
      everest.io/share-access-to: 5e3864c6-e78d-4d00-b6fd-de09d432c632   # ID of the VPC to which the cluster belongs
      everest.io/share-is-public: 'false'
      everest.io/zone: xxxxx          # AZ
  • Object storage
    # kubectl get sc csi-obs -oyaml
    kind: StorageClass
    parameters:
      csi.storage.k8s.io/csi-driver-name: obs.csi.everest.io
      csi.storage.k8s.io/fstype: s3fs           # Object storage type. s3fs indicates an object bucket, and obsfs indicates a parallel file system.
      everest.io/obs-volume-type: STANDARD      # Storage class of the OBS bucket
Specifying an Enterprise Project for Storage Classes
CCE allows you to specify an enterprise project when creating EVS disks and OBS PVCs. The created storage resources (EVS disks and OBS) belong to the specified enterprise project. The enterprise project can be the enterprise project to which the cluster belongs or the default enterprise project.
If you do no specify any enterprise project, the enterprise project in StorageClass is used by default. The created storage resources by using the csi-disk and csi-obs storage classes of CCE belong to the default enterprise project.
If you want the storage resources created from the storage classes to be in the same enterprise project as the cluster, you can customize a storage class and specify the enterprise project ID, as shown below.
To use this function, the everest add-on must be upgraded to 1.2.33 or later.
kind: StorageClass
  name: csi-disk-epid      #Customize a storage class name.
parameters:
  everest.io/enterprise-project-id: 86bfc701-9d9e-4871-a318-6385aa368183  #Specify the enterprise project ID.
  everest.io/passthrough: 'true'
Specifying a Default StorageClass
You can specify a storage class as the default class. In this way, if you do not specify storageClassName when creating a PVC, the PVC is created using the default storage class.
For example, to specify csi-disk-ssd as the default storage class, edit your YAML file as follows:
kind: StorageClass
  annotations:
    storageclass.kubernetes.io/is-default-class: "true"   # Specifies the default storage class in a cluster. A cluster can have only one default storage class.
parameters:
Delete the created csi-disk-ssd disk, run the kubectl create command to create a csi-disk-ssd disk again, and then query the storage class. The following information is displayed.
# kubectl delete sc csi-disk-ssd
storageclass.storage.k8s.io "csi-disk-ssd" deleted
# kubectl get sc
csi-disk-sas             everest-csi-provisioner         114m
csi-disk-ssd (default)   everest-csi-provisioner         9s
Verification
  • Use csi-disk-sas to create a PVC.
    apiVersion: v1
      accessModes:
      - ReadWriteOnce
      resources:
        requests:
          storage: 10Gi
      storageClassName: csi-disk-sas
    Create a storage class and view its details. As shown below, the object can be created and the value of STORAGECLASS is csi-disk-sas.
    # kubectl create -f sas-disk.yaml
    persistentvolumeclaim/sas-disk created
    # kubectl get pvc
    NAME       STATUS   VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS   AGE
    sas-disk   Bound    pvc-6e2f37f9-7346-4419-82f7-b42e79f7964c   10Gi       RWO            csi-disk-sas   24s
    # kubectl get pv
    NAME                                       CAPACITY   ACCESS MODES   RECLAIM POLICY   STATUS      CLAIM                     STORAGECLASS   REASON   AGE
    pvc-6e2f37f9-7346-4419-82f7-b42e79f7964c   10Gi       RWO            Delete           Bound       default/sas-disk          csi-disk-sas            30s
    View the PVC details on the CCE console. On the PV details page, you can see that the disk type is high I/O.
  • If storageClassName is not specified, the default configuration is used, as shown below.
    apiVersion: v1
      accessModes:
      - ReadWriteOnce
      resources:
        requests:
          storage: 10Gi
    Create and view the storage resource. You can see that the storage class of PVC ssd-disk is csi-disk-ssd, indicating that csi-disk-ssd is used by default.
    # kubectl create -f ssd-disk.yaml
    persistentvolumeclaim/ssd-disk created
    # kubectl get pvc
    sas-disk   Bound    pvc-6e2f37f9-7346-4419-82f7-b42e79f7964c   10Gi       RWO            csi-disk-sas   16m
    ssd-disk   Bound    pvc-4d2b059c-0d6c-44af-9994-f74d01c78731   10Gi       RWO            csi-disk-ssd   10s
    # kubectl get pv
    pvc-4d2b059c-0d6c-44af-9994-f74d01c78731   10Gi       RWO            Delete           Bound       default/ssd-disk          csi-disk-ssd            15s
    pvc-6e2f37f9-7346-4419-82f7-b42e79f7964c   10Gi       RWO            Delete           Bound       default/sas-disk          csi-disk-sas            17m
    View the PVC details on the CCE console. On the PV details page, you can see that the disk type is ultra-high I/O.
