Situation Awareness
Software Repository for Container
On this page
Show all
How Does Spark2x Access External Cluster Components?
Updated on 2024-12-13 GMT+08:00
Question
How can I use Spark2x in cluster 1 to connect with HDFS, Hive, HBase, and Kafka components in cluster 2?
Answer
  1. Components in two clusters can access each other. However, there are the following restrictions:
    • Only one Hive MetaStore can be accessed. Specifically, Hive MetaStore in cluster 1 and Hive MetaStore in cluster 2 cannot be accessed at the same time.
    • User systems in different clusters are not synchronized. When users access components in another cluster, user permission is determined by the user configuration of the peer cluster. For example, if user A of cluster 1 does not have the permissions to access the HBase meta table in cluster 1 but user A of cluster 2 can access the HBase meta table in cluster 2, user A of cluster 1 can access the HBase meta table in cluster 2.
    • To enable components in a security cluster to communicate with each other across Manager, you need to configure mutual trust.
  2. The following describes how to access Hive, HBase, and Kafka components in cluster 2 as user A.
    The following operations are based on the scenario where a user uses the FusionInsight client to submit the Spark2x application. If the user uses the configuration file directory, the user needs to modify the corresponding file in the configuration directory of the application and upload the configuration file to the executor.
    When the HDFS and HBase clients access the server, hostname is used to configure the server address. Therefore, the hosts configuration of all nodes to be accessed must be saved in the /etc/hosts file on the client. You can add the host of the peer cluster node to the /etc/hosts file of the client node in advance.
    • Access Hive metastore: Replace the hive-site.xml file in the conf directory of the Spark2x client in cluster 1 with the hive-site.xml file in the conf directory of the Spark2x client in cluster 2.
      After the preceding operations are performed, you can use Spark SQL to access Hive MetaStore. To access Hive table data, you need to perform the operations in • Access HDFS of two clusters at the same time: and set nameservice of the peer cluster to LOCATION.
    • Access HBase of the peer cluster.
      1. Configure the IP addresses and host names of all ZooKeeper nodes and HBase nodes in cluster 2 in the /etc/hosts file on the client node of cluster 1.
      2. Replace the hbase-site.xml file in the conf directory of the Spark2x client in cluster 1 with the hbase-site.xml file in the conf directory of the Spark2x client in cluster 2.
    • Access Kafka: Set the address of the Kafka Broker to be accessed to the Kafka Broker address in cluster 2.
      • Two tokens with the same NameService cannot be obtained. The NameServices of the HDFS in two clusters must be different. For example, one is hacluster, and the other is test.
        1. Obtain the following configurations from the hdfs-site.xml file of cluster2 and add them to the hdfs-site.xml file in the conf directory of the Spark2x client in cluster1:
          dfs.nameservices.mappings, dfs.nameservices, dfs.namenode.rpc-address.test.*, dfs.ha.namenodes.test, and dfs.client.failover.proxy.provider.test
          The following is an example:
          <property>
          <name>dfs.nameservices.mappings</name>
          <value>[{"name":"hacluster","roleInstances":["14","15"]},{"name":"test","roleInstances":["16","17"]}]</value>
          </property>
          <property>
          <name>dfs.nameservices</name>
          <value>hacluster,test</value>
          </property>
          <property>
          <name>dfs.namenode.rpc-address.test.16</name>
          <value>192.168.0.1:8020</value>
          </property>
          <property>
          <name>dfs.namenode.rpc-address.test.17</name>
          <value>192.168.0.2:8020</value>
          </property>
          <property>
          <name>dfs.ha.namenodes.test</name>
          <value>16,17</value>
          </property>
          <property>
          <name>dfs.client.failover.proxy.provider.test</name>
          <value>org.apache.hadoop.hdfs.server.namenode.ha.ConfiguredFailoverProxyProvider</value>
          </property>
        1. Modify spark.yarn.extra.hadoopFileSystems = hdfs://test and spark.hadoop.hdfs.externalToken.enable = true in the spark-defaults.conf configuration file under the conf directory on the Spark client of cluster 1.
        1. In the application submission command, add the --keytab and --principal parameters and set them to the user who submits the task in cluster1.
        2. Use the Spark client of cluster1 to submit the application. Then, both HDFS services can be accessed.
    • Access HBase of two clusters at the same time:
      1. Modify spark.hadoop.hbase.externalToken.enable = true in the spark-defaults.conf configuration file under the conf directory on the Spark client of cluster 1.
      2. When accessing HBase, you need to use the configuration file of the corresponding cluster to create a Configuration object for creating a Connection object.
      3. In an MRS cluster, tokens of multiple HBase services can be obtained at the same time to solve the problem that the executor cannot access HBase. The method is as follows:
        Assume that you need to access HBase of the current cluster and HBase of cluster2. Save the hbase-site.xml file of cluster2 in a compressed package named external_hbase_conf***, and use --archives to specify the compressed package when submitting the command.
