Modifying Cluster Properties
FusionInsight Manager allows you to view basic attributes after the cluster is installed.
 - Choose Cluster > Name of the desired cluster > Cluster Properties.
You can view the cluster name, cluster description, product type, cluster ID, authentication mode, cluster creation time and installed component by default.
 - Change the cluster name.
- Click
 and enter a new name.
      The following naming rules are as follows: Enter 2 to 199 characters, including letters, digits, underscores (_), hyphens (-), and spaces. Spaces can be placed only between characters.
 - Click OK for the new cluster name to take effect.
 - Click
 - Modify the cluster description.
- Click
 and enter a new description.
      Contains a maximum of 199 characters, including letters, digits, commas (,), periods(.), underscores(_), spaces, or newline characters.
 - Click OK for the new description to take effect.
 - Click
