Querying the FusionInsight Manager Version
Before performing system upgrade and routine maintenance operations, you need to query the current FusionInsight Manager version.
- Using the GUI
On the Homepage interface, click
on the upper right corner and choose About from the shortcut menu. In the displayed interface, view the version number of FusionInsight Manager. - Using the CLI
- Log in to the active management node using the IP address of this node as user root.
- Run the following command to check the FusionInsight_Manager version and platform information:
cd ${BIGDATA_HOME}/om-server/om/sbin/pack
./queryManager.sh
Information similar to the following is displayed:
Version Package Cputype 8.0.2.1 FusionInsight_Manager_8.0.2.1 x86_64
In this document, 8.0.2.1 is used as an example.
