- What's New
- Function Overview
- Product Bulletin
Service Overview
- Infographics
- What Is MRS?
- Advantages
- Application Scenarios
- MRS Cluster Version Overview
- List of MRS Component Versions
- Components
- Functions
- Security
- Constraints
- Technical Support
- Billing
- Permissions Management
- Related Services
- Quota Description
- Common Concepts
- Released Versions
- Billing
Getting Started
- Creating and Using a Hadoop Cluster for Offline Analysis
- Creating and Using a Kafka Cluster for Stream Processing
- Creating and Using an HBase Cluster for Offline Query
- Creating and Using a ClickHouse Cluster for Columnar Store
- Creating and Using an MRS Cluster Requiring Security Authentication
- Best Practices for Beginners
User Guide
- Preparations
- MRS Cluster Planning
- Buying MRS Clusters
- Installing an MRS Cluster Client
- Submitting an MRS Job
Managing Clusters
- Overview
- Introduction to MRS Manager
- Accessing MRS Manager
Managing an MRS Cluster
- Viewing Basic Information About an MRS Cluster
- Checking the Running Status of an MRS Cluster
- Starting and Stopping an MRS Cluster
- Restarting an MRS Cluster
- Exporting MRS Cluster Configuration Parameters
- Synchronizing the MRS Cluster Configuration
- Transforming a Pay-per-Use MRS Cluster to a Yearly/Monthly Cluster
- Deleting an MRS Cluster
- Changing the VPC Subnet of an MRS Cluster
- Replacing the NTP Server for an MRS Cluster
- Modifying the OMS Service Configuration
- Modifying MRS Manager Routing Table
Managing MRS Cluster Components
- Checking the Running Status of an MRS Cluster Component
- Starting and Stopping an MRS Cluster Component
- Restarting an MRS Cluster Component
- Adding and Deleting an MRS Cluster Component
- Modifying the Configuration Parameters of an MRS Cluster Component
- Viewing the Modified Component Configuration Parameters of an MRS Cluster
- Synchronizing MRS Component Configuration Parameters
- Adding Custom MRS Component Parameters
- Managing MRS Role Instances
- Managing MRS Role Instance Groups
- Modifying MRS Role Instance Parameters
- Perform an Active/Standby Switchover for MRS Role Instances
- Decommissioning and Recommissioning an MRS Role Instance
- Enabling and Disabling Ranger Authentication for an MRS Component
- Accessing Web Pages of Open Source Components Managed in MRS Clusters
Managing MRS Cluster Nodes
- Checking the Running Status of an MRS Cluster Node
- Starting and Stopping All Roles on an MRS Cluster Node
- Isolating an MRS Cluster Node
- Modifying the Rack Information of an MRS Cluster Node
- Scaling Up Master Node Specifications in an MRS Cluster
- Synchronizing Disk Information of an MRS Cluster Node
- Adding a Tag to an MRS Cluster/Node
- Configuring Bootstrap Actions for an MRS Cluster Node
- Managing the MRS Cluster Client
- Managing MRS Cluster Jobs
Managing MRS Cluster Tenants
- Introduction to MRS Multi-Tenancy
- Using MRS Multi-Tenancy
- Configuring MRS Tenants
Managing MRS Tenant Resources
- Managing the MRS Tenant Resource Directory
- Managing MRS Tenant Resource Pools
- Clearing the MRS Tenant Queue Configuration
- Restoring MRS Tenant Data After YARN Is Reinstalled
- Deleting an MRS Tenant
- Managing Global User Policies When Using Superior Scheduler
- Clearing Tenant's Non-Associated Queues Using Capacity Scheduler
- Switching the MRS Tenant Resource Scheduler
- Managing MRS Cluster Users
- Managing MRS Cluster Metadata
- Managing Static Service Resources in an MRS Cluster
MRS Cluster O&M
- Cluster O&M
- Logging In to an MRS Cluster
- Viewing MRS Cluster Monitoring Metrics
- Checking MRS Cluster Health
- Adjusting the Capacity of an MRS Cluster
MRS Cluster Data Backup and Restoration
- Backing Up and Restoring MRS Cluster Data
- Enabling MRS Inter-Cluster Replication
- Creating an MRS Cluster Data Backup Task
- Creating an MRS Cluster Data Restoration Task
Backing Up MRS Cluster Component Data
- Backing Up Manager Data (MRS 2.x and Earlier)
- Backing Up Manager Data (MRS 3.x and Later Versions)
- Backing Up CDL Service Data
- Backing Up ClickHouse Metadata
- Backing Up ClickHouse Service Data
- Backing Up DBService Data
- Backing Up Doris Data
- Backing Up Flink Metadata
- Backing Up HBase Metadata
- Backing Up HBase Service Data
- Backing Up HDFS NameNode Data
- Backing Up HDFS Service Data
- Backing Up Hive Service Data
- Backing Up IoTDB Metadata
- Backing Up IoTDB Service Data
- Backing Up Kafka Metadata
Restoring MRS Cluster Component Data
- Restoring Manager Data (MRS2.x and Earlier)
- Restoring Manager Data (MRS 3.x and Later Versions)
- Restoring CDL Service Data
- Restoring ClickHouse Metadata
- Restoring ClickHouse Service Data
- Restoring DBService Metadata
- Restoring Doris Service Data
- Restoring Flink Metadata
- Restoring HBase Metadata
- Restoring HBase Service Data
- Restoring HDFS NameNode Metadata
- Restoring HDFS Service Data
- Restoring Hive Service Data
- Restoring IoTDB Metadata
- Restoring IoTDB Service Data
- Restoring Kafka Metadata
- Managing MRS Cluster Backup and Restoration Tasks
- Using HDFS Snapshots to Quickly Restore Component Service Data
- MRS Cluster Patching
MRS Cluster Patch Description
- MRS 3.0.5.1 Patch Description
- MRS 2.1.0.11 Patch Description
- MRS 2.1.0.10 Patch Description
- MRS 2.1.0.9 Patch Description
- MRS 2.1.0.8 Patch Description
- MRS 2.1.0.7 Patch Description
- MRS 2.1.0.6 Patch Description
- MRS 2.1.0.3 Patch Description
- MRS 2.1.0.2 Patch Description
- MRS 2.1.0.1 Patch Description
- MRS 2.0.6.1 Patch Description
- MRS 2.0.1.3 Patch Description
- MRS 2.0.1.2 Patch Description
- MRS 2.0.1.1 Patch Description
- MRS 1.9.3.3 Patch Description
- MRS 1.9.3.1 Patch Description
- MRS 1.9.2.2 Patch Description
- MRS 1.9.0.8, 1.9.0.9, and 1.9.0.10 Patch Description
- MRS 1.9.0.7 Patch Description
- MRS 1.9.0.6 Patch Description
- MRS 1.9.0.5 Patch Description
- MRS 1.8.10.1 Patch Description
Viewing Logs of an MRS Cluster
- Overview of MRS Cluster Logs
- Viewing MRS Operation Logs
- Viewing MRS Cluster History
- Viewing MRS Cluster Audit Logs
- Viewing Role Instance Logs of MRS Components
- Searching for MRS Cluster Logs Online
- Downloading MRS Cluster Logs
- Collecting MRS Cluster Service Stack Information
- Configuring Default Log Level and Archive File Size for MRS Components
- Configuring the Number of Local Backups of MRS Cluster Audit Logs
- Configuring Dumping for MRS Cluster Audit Logs
MRS Cluster Security Configuration
- Cluster Mutual Trust Management
- Replacing MRS Cluster Certificates
MRS Cluster Security Hardening
- MRS Cluster Security Hardening Policies
- Configuring Hadoop Data Encryption During Transmission
- Configuring Kafka Data Encryption During Transmission
- Configuring HDFS Data Encryption During Transmission
- Configuring Spark Data Encryption During Transmission
- Configuring ZooKeeper Data Encryption During Transmission
- Encrypting Data Transmission Between the Controller and Agent
- Configuring a Trusted IP Address to Access LDAP
- HFile and WAL Encryption
- Configuring the IP Address Whitelist for Modifying Data in an HBase Read-Only Cluster
- Configuring LDAP Output Audit Logs
- Updating Encryption Keys of an MRS Cluster
- Updating the SSH Key of User omm on MRS Cluster Nodes
- Enabling and Disabling Permission Verification on MRS Cluster Components
- Allowing External Users to Access MRS Clusters in Normal Mode
- Configuring Secure Communication Authorization for an MRS Cluster
Changing the Passwords for System Users of an MRS Cluster
- Changing or Resetting the Password for User admin of an MRS Cluster
- Changing the Passwords for OS Users of an MRS Cluster Node
- Changing the Password for the Kerberos Administrator of an MRS Cluster
- Changing the Passwords for Manager Users of an MRS Cluster
- Changing the Password for a Regular LDAP User of an MRS Cluster
- Changing the LDAP Administrator Password for an MRS Cluster
- Changing the Passwords for MRS Cluster Component Running Users
Changing the Passwords for Database Users of an MRS Cluster
- Changing the Password for the OMS Database Administrator
- Changing the Password for an OMS Database Access User
- Changing the Passwords for Database Users of MRS Cluster Components
- Resetting the MRS Component Database User Password
- Resetting the Password for User omm in DBService
- Changing the Password for User compdbuser of the DBService Database
Viewing and Configuring MRS Alarm Events
- Viewing MRS Cluster Events
- Viewing Alarms of an MRS Cluster
- Configuring Alarm Thresholds for an MRS Cluster
- Configuring Alarm Masking for an MRS Cluster
- Connecting an MRS Cluster to SNMP to Report Alarms
- Connecting an MRS Cluster to the Syslog Server to Report Alarms
- Periodically Backing Up Alarm and Audit Information
- Enabling the MRS Cluster Maintenance Mode to Disable Alarm Reporting
- Configuring Notifications for MRS Cluster Alarms and Events
MRS Cluster Alarm Handling Reference
- ALM-12001 Audit Log Dumping Failure
- ALM-12004 OLdap Resource Abnormal
- ALM-12005 OKerberos Resource Abnormal
- ALM-12006 Node Fault
- ALM-12007 Process Fault
- ALM-12010 Manager Heartbeat Interruption Between the Active and Standby Nodes
- ALM-12011 Manager Data Synchronization Exception Between the Active and Standby Nodes
- ALM-12012 NTP Service Is Abnormal
- ALM-12014 Partition Lost
- ALM-12015 Partition Filesystem Readonly
- ALM-12016 CPU Usage Exceeds the Threshold
- ALM-12017 Insufficient Disk Capacity
- ALM-12018 Memory Usage Exceeds the Threshold
- ALM-12027 Host PID Usage Exceeds the Threshold
- ALM-12028 Number of Processes in the D State and Z State on a Host Exceeds the Threshold
- ALM-12033 Slow Disk Fault
- ALM-12034 Periodical Backup Failure
- ALM-12035 Unknown Data Status After Recovery Task Failure
- ALM-12037 NTP Server Abnormal
- ALM-12038 Monitoring Indicator Dumping Failure
- ALM-12039 Active/Standby OMS Databases Not Synchronized
- ALM-12040 Insufficient System Entropy
- ALM-12041 Incorrect Permission on Key Files
- ALM-12042 Incorrect Configuration of Key Files
- ALM-12045 Read Packet Dropped Rate Exceeds the Threshold
- ALM-12046 Write Packet Dropped Rate Exceeds the Threshold
- ALM-12047 Read Packet Error Rate Exceeds the Threshold
- ALM-12048 Write Packet Error Rate Exceeds the Threshold
- ALM-12049 Network Read Throughput Rate Exceeds the Threshold
- ALM-12050 Network Write Throughput Rate Exceeds the Threshold
- ALM-12051 Disk Inode Usage Exceeds the Threshold
- ALM-12052 TCP Temporary Port Usage Exceeds the Threshold
- ALM-12053 Host File Handle Usage Exceeds the Threshold
- ALM-12054 Invalid Certificate File
- ALM-12055 Certificate File Is About to Expire
- ALM-12057 Metadata Not Configured with the Task to Periodically Back Up Data to a Third-Party Server
- ALM-12061 Process Usage Exceeds the Threshold
- ALM-12062 OMS Parameter Configurations Mismatch with the Cluster Scale
- ALM-12063 Unavailable Disk
- ALM-12064 Host Random Port Range Conflicts with Cluster Used Port
- ALM-12066 Trust Relationships Between Nodes Become Invalid
- ALM-12067 Tomcat Resource Is Abnormal
- ALM-12068 ACS Resource Exception
- ALM-12069 AOS Resource Exception
- ALM-12070 Controller Resource Is Abnormal
- ALM-12071 Httpd Resource Is Abnormal
- ALM-12072 FloatIP Resource Is Abnormal
- ALM-12073 CEP Resource Is Abnormal
- ALM-12074 FMS Resource Is Abnormal
- ALM-12075 PMS Resource Is Abnormal
- ALM-12076 GaussDB Resource Is Abnormal
- ALM-12077 User omm Expired
- ALM-12078 Password of User omm Expired
- ALM-12079 User omm Is About to Expire
- ALM-12080 Password of User omm Is About to Expire
- ALM-12081User ommdba Expired
- ALM-12082 User ommdba Is About to Expire
- ALM-12083 Password of User ommdba Is About to Expire
- ALM-12084 Password of User ommdba Expired
- ALM-12085 Service Audit Log Dump Failure
- ALM-12087 System Is in the Upgrade Observation Period
- ALM-12089 Inter-Node Network Is Abnormal
- ALM-12091 Abnormal disaster Resources
- ALM-12099 core dump Occurred
- ALM-12100 AD Service Connection Failed
- ALM-12101 AZ Unhealthy
- ALM-12102 AZ HA Component Is Not Deployed Based on DR Requirements
- ALM-12103 Executor Resource Exception
- ALM-12104 Abnormal Knox Resources
- ALM-12110 Failed to get ECS temporary AK/SK
- ALM-12172 Failed to Report Metrics to Cloud Eye
- ALM-12180 Suspended Disk I/O
- ALM-12186 CGroup Task Usage Exceeds the Threshold
- ALM-12187 Failed to Expand Disk Partition Capacity
- ALM-12188 diskmgt Disk Monitoring Unavailable
- ALM-12190 Number of Knox Connections Exceeds the Threshold
- ALM-12191 Disk I/O Usage Exceeds the Threshold
- ALM-12192 Host Load Exceeds the Threshold
- ALM-12200 Password Is About to Expire
- ALM-12201 Process CPU Usage Exceeds the Threshold
- ALM-12202 Process Memory Usage Exceeds the Threshold
- ALM-12203 Process Full GC Duration Exceeds the Threshold
- ALM-12204 Wait Duration of a Disk Read Exceeds the Threshold
- ALM-12205 Wait Duration of a Disk Write Exceeds the Threshold
- ALM-12206 Password Has Expired
- ALM-12207 Slow Disk Processing Timeout
- ALM-13000 ZooKeeper Service Unavailable
- ALM-13001 Available ZooKeeper Connections Are Insufficient
- ALM-13002 ZooKeeper Direct Memory Usage Exceeds the Threshold
- ALM-13003 GC Duration of the ZooKeeper Process Exceeds the Threshold
- ALM-13004 ZooKeeper Heap Memory Usage Exceeds the Threshold
- ALM-13005 Failed to Set the Quota of Top Directories of ZooKeeper Components
- ALM-13006 Znode Number or Capacity Exceeds the Threshold
- ALM-13007 Available ZooKeeper Client Connections Are Insufficient
- ALM-13008 ZooKeeper Znode Usage Exceeds the Threshold
- ALM-13009 ZooKeeper Znode Capacity Usage Exceeds the Threshold
- ALM-13010 Znode Usage of a Directory with Quota Configured Exceeds the Threshold
- ALM-14000 HDFS Service Unavailable
- ALM-14001 HDFS Disk Usage Exceeds the Threshold
- ALM-14002 DataNode Disk Usage Exceeds the Threshold
- ALM-14003 Number of Lost HDFS Blocks Exceeds the Threshold
- ALM-14006 Number of HDFS Files Exceeds the Threshold
- ALM-14007 NameNode Heap Memory Usage Exceeds the Threshold
- ALM-14008 DataNode Heap Memory Usage Exceeds the Threshold
- ALM-14009 Number of Dead DataNodes Exceeds the Threshold
- ALM-14010 NameService Service Is Abnormal
- ALM-14011 DataNode Data Directory Is Not Configured Properly
- ALM-14012 JournalNode Is Out of Synchronization
- ALM-14013 Failed to Update the NameNode FsImage File
- ALM-14014 NameNode GC Time Exceeds the Threshold
- ALM-14015 DataNode GC Time Exceeds the Threshold
- ALM-14016 DataNode Direct Memory Usage Exceeds the Threshold
- ALM-14017 NameNode Direct Memory Usage Exceeds the Threshold
- ALM-14018 NameNode Non-heap Memory Usage Exceeds the Threshold
- ALM-14019 DataNode Non-heap Memory Usage Exceeds the Threshold
- ALM-14020 Number of Entries in the HDFS Directory Exceeds the Threshold
- ALM-14021 NameNode Average RPC Processing Time Exceeds the Threshold
- ALM-14022 NameNode Average RPC Queuing Time Exceeds the Threshold
- ALM-14023 Percentage of Total Reserved Disk Space for Replicas Exceeds the Threshold
- ALM-14024 Tenant Space Usage Exceeds the Threshold
- ALM-14025 Tenant File Object Usage Exceeds the Threshold
- ALM-14026 Blocks on DataNode Exceed the Threshold
- ALM-14027 DataNode Disk Fault
- ALM-14028 Number of Blocks to Be Supplemented Exceeds the Threshold
- ALM-14029 Number of Blocks in a Replica Exceeds the Threshold
- ALM-14030 HDFS Allows Write of Single-Replica Data
- ALM-14031 DataNode Process Is Abnormal
- ALM-14032 JournalNode Process Is Abnormal
- ALM-14033 ZKFC Process Is Abnormal
- ALM-14034 Router Process Is Abnormal
- ALM-14035 HttpFS Process Is Abnormal
- ALM-14036 NameNode Is In Safe Mode
- ALM-14037 DataNodes Outside the Cluster
- ALM-14038 Router Heap Memory Usage Exceeds the Threshold
- ALM-14039 Slow DataNodes Exist in the Cluster
- ALM-16000 Percentage of Sessions Connected to the HiveServer to Maximum Number Allowed Exceeds the Threshold
- ALM-16001 Hive Warehouse Space Usage Exceeds the Threshold
- ALM-16002 Hive SQL Execution Success Rate Is Lower Than the Threshold
- ALM-16003 Background Thread Usage Exceeds the Threshold
- ALM-16004 Hive Service Unavailable
- ALM-16005 The Heap Memory Usage of the Hive Process Exceeds the Threshold
- ALM-16006 The Direct Memory Usage of the Hive Process Exceeds the Threshold
- ALM-16007 Hive GC Time Exceeds the Threshold
- ALM-16008 Non-Heap Memory Usage of the Hive Process Exceeds the Threshold
- ALM-16009 Map Number Exceeds the Threshold
- ALM-16045 Hive Data Warehouse Is Deleted
- ALM-16046 Hive Data Warehouse Permission Is Modified
- ALM-16047 HiveServer Has Been Deregistered from ZooKeeper
- ALM-16048 Tez or Spark Library Path Does Not Exist
- ALM-16051 Percentage of Sessions Connected to MetaStore Exceeds the Threshold
- ALM-16052 Latency for MetaStore to Access the Meta Database During Table Creation Exceeds the Threshold
- ALM-16053 Average HQL Submission Time of Hive in the Last 5 Minutes Exceeds the Threshold
- ALM-17003 Oozie Service Unavailable
- ALM-17004 Oozie Heap Memory Usage Exceeds the Threshold
- ALM-17005 Oozie Non Heap Memory Usage Exceeds the Threshold
- ALM-17006 Oozie Direct Memory Usage Exceeds the Threshold
- ALM-17007 Garbage Collection (GC) Time of the Oozie Process Exceeds the Threshold
- ALM-17008 Abnormal Connection Between Oozie and ZooKeeper
- ALM-17009 Abnormal Connection Between Oozie and DBService
- ALM-17010 Abnormal Connection Between Oozie and HDFS
- ALM-17011 Abnormal Connection Between Oozie and Yarn
- ALM-18000 Yarn Service Unavailable
- ALM-18002 NodeManager Heartbeat Lost
- ALM-18003 NodeManager Unhealthy
- ALM-18008 Heap Memory Usage of ResourceManager Exceeds the Threshold
- ALM-18009 Heap Memory Usage of JobHistoryServer Exceeds the Threshold
- ALM-18010 ResourceManager GC Time Exceeds the Threshold
- ALM-18011 NodeManager GC Time Exceeds the Threshold
- ALM-18012 JobHistoryServer GC Time Exceeds the Threshold
- ALM-18013 ResourceManager Direct Memory Usage Exceeds the Threshold
- ALM-18014 NodeManager Direct Memory Usage Exceeds the Threshold
- ALM-18015 JobHistoryServer Direct Memory Usage Exceeds the Threshold
- ALM-18016 Non Heap Memory Usage of ResourceManager Exceeds the Threshold
- ALM-18017 Non Heap Memory Usage of NodeManager Exceeds the Threshold
- ALM-18018 NodeManager Heap Memory Usage Exceeds the Threshold
- ALM-18019 Non Heap Memory Usage of JobHistoryServer Exceeds the Threshold
- ALM-18020 Yarn Task Execution Timeout
- ALM-18021 Mapreduce Service Unavailable
- ALM-18022 Insufficient Yarn Queue Resources
- ALM-18023 Number of Pending Yarn Tasks Exceeds the Threshold
- ALM-18024 Pending Yarn Memory Usage Exceeds the Threshold
- ALM-18025 Number of Terminated Yarn Tasks Exceeds the Threshold
- ALM-18026 Number of Failed Yarn Tasks Exceeds the Threshold
- ALM-18027 JobHistoryServer Process Is Abnormal
- ALM-18028 TimeLineServer Process Is Abnormal
- ALM-19000 HBase Service Unavailable
- ALM-19006 HBase Replication Sync Failed
- ALM-19007 HBase GC Time Exceeds the Threshold
- ALM-19008 Heap Memory Usage of the HBase Process Exceeds the Threshold
- ALM-19009 Direct Memory Usage of the HBase Process Exceeds the Threshold
- ALM-19011 RegionServer Region Number Exceeds the Threshold
- ALM-19012 HBase System Table Directory or File Lost
- ALM-19013 Duration of Regions in transaction State Exceeds the Threshold
- ALM-19014 Capacity Quota Usage on ZooKeeper Exceeds the Threshold Severely
- ALM-19015 Quantity Quota Usage on ZooKeeper Exceeds the Threshold
- ALM-19016 Quantity Quota Usage on ZooKeeper Exceeds the Threshold Severely
- ALM-19017 Capacity Quota Usage on ZooKeeper Exceeds the Threshold
- ALM-19018 HBase Compaction Queue Size Exceeds the Threshold
- ALM-19019 Number of HBase HFiles to Be Synchronized Exceeds the Threshold
- ALM-19020 Number of HBase WAL Files to Be Synchronized Exceeds the Threshold
- ALM-19021 Handler Usage of RegionServer Exceeds the Threshold
- ALM-19022 HBase Hotspot Detection Is Unavailable
- ALM-19023 Region Traffic Restriction for HBase
- ALM-19024 RPC Requests P99 Latency on RegionServer Exceeds the Threshold
- ALM-19025 Damaged StoreFile in HBase
- ALM-19026 Damaged WAL Files in HBase
- ALM-19030 P99 Latency of RegionServer RPC Request Exceeds the Threshold
- ALM-19031 Number of RegionServer RPC Connections Exceeds the Threshold
- ALM-19032 Number of Tasks in the RegionServer RPC Write Queue Exceeds the Threshold
- ALM-19033 Number of Tasks in the RegionServer RPC Read Queue Exceeds the Threshold
- ALM-19034 Number of RegionServer WAL Write Timeouts Exceeds the Threshold
- ALM-19035 Size of the RegionServer Call Queue Exceeds the Threshold
- ALM-19036 Bad Blocks Exist in HBase Key Directory Data
- ALM-20002 Hue Service Unavailable
- ALM-23001 Loader Service Unavailable
- ALM-23003 Loader Task Execution Failure
- ALM-23004 Loader Heap Memory Usage Exceeds the Threshold
- ALM-23005 Loader Non-Heap Memory Usage Exceeds the Threshold
- ALM-23006 Loader Direct Memory Usage Exceeds the Threshold
- ALM-23007 Garbage Collection (GC) Time of the Loader Process Exceeds the Threshold
- ALM-24000 Flume Service Unavailable
- ALM-24001 Flume Agent Exception
- ALM-24003 Flume Client Connection Interrupted
- ALM-24004 Exception Occurs When Flume Reads Data
- ALM-24005 Exception Occurs When Flume Transmits Data
- ALM-24006 Heap Memory Usage of Flume Server Exceeds the Threshold
- ALM-24007 Flume Server Direct Memory Usage Exceeds the Threshold
- ALM-24008 Flume Server Non Heap Memory Usage Exceeds the Threshold
- ALM-24009 Flume Server Garbage Collection (GC) Time Exceeds the Threshold
- ALM-24010 Flume Certificate File Is Invalid or Damaged
- ALM-24011 Flume Certificate File Is About to Expire
- ALM-24012 Flume Certificate File Has Expired
- ALM-24013 Flume MonitorServer Certificate File Is Invalid or Damaged
- ALM-24014 Flume MonitorServer Certificate Is About to Expire
- ALM-24015 Flume MonitorServer Certificate File Has Expired
- ALM-25000 LdapServer Service Unavailable
- ALM-25004 Abnormal LdapServer Data Synchronization
- ALM-25005 nscd Service Exception
- ALM-25006 Sssd Service Exception
- ALM-25007 Number of SlapdServer Connections Exceeds the Threshold
- ALM-25008 SlapdServer CPU Usage Exceeds the Threshold
- ALM-25500 KrbServer Service Unavailable
- ALM-25501 Too Many KerberosServer Requests
- ALM-26051 Storm Service Unavailable
- ALM-26052 Number of Available Supervisors of the Storm Service Is Less Than the Threshold
- ALM-26053 Storm Slot Usage Exceeds the Threshold
- ALM-26054 Nimbus Heap Memory Usage Exceeds the Threshold
- ALM-27001 DBService Service Unavailable
- ALM-27003 DBService Heartbeat Interruption Between the Active and Standby Nodes
- ALM-27004 Data Inconsistency Between Active and Standby DBServices
- ALM-27005 Database Connections Usage Exceeds the Threshold
- ALM-27006 Disk Space Usage of the Data Directory Exceeds the Threshold
- ALM-27007 Database Enters the Read-Only Mode
- ALM-29000 Impala Service Unavailable
- ALM-29004 Impalad Process Memory Usage Exceeds the Threshold
- ALM-29005 Number of JDBC Connections to Impalad Exceeds the Threshold
- ALM-29006 Number of ODBC Connections to Impalad Exceeds the Threshold
- ALM-29010 Number of Queries Being Submitted by Impalad Exceeds the Threshold
- ALM-29011 Number of Queries Being Executed by Impalad Exceeds the Threshold
- ALM-29012 Number of Queries Being Waited by Impalad Exceeds the Threshold
- ALM-29013 Impalad FGC Time Exceeds the Threshold
- ALM-29014 Catalog FGC Time Exceeds the Threshold
- ALM-29015 Catalog Process Memory Usage Exceeds the Threshold
- ALM-29016 Impalad Instance in the Sub-healthy State
- ALM-29100 Kudu Service Unavailable
- ALM-29104 Tserver Process Memory Usage Exceeds the Threshold
- ALM-29106 Tserver Process CPU Usage Exceeds the Threshold
- ALM-29107 Tserver Process Memory Usage Exceeds the Threshold
- ALM-38000 Kafka Service Unavailable
- ALM-38001 Insufficient Kafka Disk Capacity
- ALM-38002 Kafka Heap Memory Usage Exceeds the Threshold
- ALM-38004 Kafka Direct Memory Usage Exceeds the Threshold
- ALM-38005 GC Duration of the Broker Process Exceeds the Threshold
- ALM-38006 Percentage of Kafka Partitions That Are Not Completely Synchronized Exceeds the Threshold
- ALM-38007 Status of Kafka Default User Is Abnormal
- ALM-38008 Abnormal Kafka Data Directory Status
- ALM-38009 Busy Broker Disk I/Os (Applicable to Versions Later Than MRS 3.1.0)
- ALM-38009 Kafka Topic Overload (Applicable to MRS 3.1.0 and Earlier Versions)
- ALM-38010 Topics with Single Replica
- ALM-38011 User Connection Usage on Broker Exceeds the Threshold
- ALM-38012 Number of Broker Partitions Exceeds the Threshold
- ALM-38013 Produce Request Latency in the Request Queue Exceeds the Threshold
- ALM-38014 Total Produce Request Latency Exceeds the Threshold
- ALM-38015 Fetch Request Latency in the Request Queue Exceeds the Threshold
- ALM-38016 Total Fetch Request Latency Exceeds the Threshold
- ALM-38017 Partition Reassignment Duration Exceeds the Threshold
- ALM-38018 Kafka Consumer Lag
- ALM-43001 Spark2x Service Unavailable
- ALM-43006 Heap Memory Usage of the JobHistory2x Process Exceeds the Threshold
- ALM-43007 Non-Heap Memory Usage of the JobHistory2x Process Exceeds the Threshold
- ALM-43008 The Direct Memory Usage of the JobHistory2x Process Exceeds the Threshold
- ALM-43009 JobHistory2x Process GC Time Exceeds the Threshold
- ALM-43010 Heap Memory Usage of the JDBCServer2x Process Exceeds the Threshold
- ALM-43011 Non-Heap Memory Usage of the JDBCServer2x Process Exceeds the Threshold
- ALM-43012 Direct Heap Memory Usage of the JDBCServer2x Process Exceeds the Threshold
- ALM-43013 JDBCServer2x Process GC Time Exceeds the Threshold
- ALM-43017 JDBCServer2x Process Full GC Number Exceeds the Threshold
- ALM-43018 JobHistory2x Process Full GC Number Exceeds the Threshold
- ALM-43019 Heap Memory Usage of the IndexServer2x Process Exceeds the Threshold
- ALM-43020 Non-Heap Memory Usage of the IndexServer2x Process Exceeds the Threshold
- ALM-43021 Direct Memory Usage of the IndexServer2x Process Exceeds the Threshold
- ALM-43022 IndexServer2x Process GC Time Exceeds the Threshold
- ALM-43023 IndexServer2x Process Full GC Number Exceeds the Threshold
- ALM-43028 JDBCServer Session Overflow
- ALM-43029 JDBCServer Job Submission Timed Out
- ALM-44000 Presto Service Unavailable
- ALM-44004 Presto Coordinator Resource Group Queuing Tasks Exceed the Threshold
- ALM-44005 Presto Coordinator Process GC Time Exceeds the Threshold
- ALM-44006 Presto Worker Process GC Time Exceeds the Threshold
- ALM-45000 HetuEngine Service Unavailable
- ALM-45001 Faulty HetuEngine Compute Instances
- ALM-45003 HetuEngine QAS Disk Capacity Is Insufficient
- ALM-45004 Tasks Stacked on HetuEngine Compute Instance
- ALM-45005 CPU Usage of HetuEngine Compute Instance Exceeded the Threshold
- ALM-45006 Memory Usage of a HetuEngine Compute Instance Exceeded the Threshold
- ALM-45007 Number of Workers of a HetuEngine Compute Instance Is Less Than the Threshold
- ALM-45008 Query Latency of HetuEngine Compute Instances Exceeds the Threshold
- ALM-45009 Task Failure Rate of HetuEngine Compute Instances Exceeds the Threshold
- ALM-45175 Average Time for Calling OBS Metadata APIs Is Greater than the Threshold
- ALM-45176 Success Rate of Calling OBS Metadata APIs Is Lower than the Threshold
- ALM-45177 Success Rate of Calling OBS Data Read APIs Is Lower than the Threshold
- ALM-45178 Success Rate of Calling OBS Data Write APIs Is Lower Than the Threshold
- ALM-45179 Number of Failed OBS readFully API Calls Exceeds the Threshold
- ALM-45180 Number of Failed OBS read API Calls Exceeds the Threshold
- ALM-45181 Number of Failed OBS write API Calls Exceeds the Threshold
- ALM-45182 Number of Throttled OBS Operations Exceeds the Threshold
- ALM-45275 Ranger Service Unavailable
- ALM-45276 Abnormal RangerAdmin Status
- ALM-45277 RangerAdmin Heap Memory Usage Exceeds the Threshold
- ALM-45278 RangerAdmin Direct Memory Usage Exceeds the Threshold
- ALM-45279 RangerAdmin Non Heap Memory Usage Exceeds the Threshold
- ALM-45280 RangerAdmin GC Duration Exceeds the Threshold
- ALM-45281 UserSync Heap Memory Usage Exceeds the Threshold
- ALM-45282 UserSync Direct Memory Usage Exceeds the Threshold
- ALM-45283 UserSync Non Heap Memory Usage Exceeds the Threshold
- ALM-45284 UserSync Garbage Collection (GC) Time Exceeds the Threshold
- ALM-45285 TagSync Heap Memory Usage Exceeds the Threshold
- ALM-45286 TagSync Direct Memory Usage Exceeds the Threshold
- ALM-45287 TagSync Non Heap Memory Usage Exceeds the Threshold
- ALM-45288 TagSync Garbage Collection (GC) Time Exceeds the Threshold
- ALM-45289 PolicySync Heap Memory Usage Exceeds the Threshold
- ALM-45290 PolicySync Direct Memory Usage Exceeds the Threshold
- ALM-45291 PolicySync Non-Heap Memory Usage Exceeds the Threshold
- ALM-45292 PolicySync GC Duration Exceeds the Threshold
- ALM-45293 Ranger User Synchronization Exception
- ALM-45294 RangerKMS Process Is Abnormal
- ALM-45325 Presto Service Unavailable
- ALM-45326 Number of Presto Coordinator Threads Exceeds the Threshold
- ALM-45327 Presto Coordinator Process GC Time Exceeds the Threshold
- ALM-45328 Presto Worker Process GC Time Exceeds the Threshold
- ALM-45329 Presto Coordinator Resource Group Queuing Tasks Exceed the Threshold
- ALM-45330 Number of Presto Worker Threads Exceeds the Threshold
- ALM-45331 Number of Presto Worker1 Threads Exceeds the Threshold
- ALM-45332 Number of Presto Worker2 Threads Exceeds the Threshold
- ALM-45333 Number of Presto Worker3 Threads Exceeds the Threshold
- ALM-45334 Number of Presto Worker4 Threads Exceeds the Threshold
- ALM-45335 Presto Worker1 Process GC Time Exceeds the Threshold
- ALM-45336 Presto Worker2 Process GC Time Exceeds the Threshold
- ALM-45337 Presto Worker3 Process GC Time Exceeds the Threshold
- ALM-45338 Presto Worker4 Process GC Time Exceeds the Threshold
- ALM-45425 ClickHouse Service Unavailable
- ALM-45426 ClickHouse Service Quantity Quota Usage in ZooKeeper Exceeds the Threshold
- ALM-45427 ClickHouse Service Capacity Quota Usage in ZooKeeper Exceeds the Threshold
- ALM-45428 ClickHouse Disk I/O Exception
- ALM-45429 Table Metadata Synchronization Failed on the Added ClickHouse Node
- ALM-45430 Permission Metadata Synchronization Failed on the Added ClickHouse Node
- ALM-45431 Improper ClickHouse Instance Distribution for Topology Allocation
- ALM-45432 ClickHouse User Synchronization Process Fails
- ALM-45433 ClickHouse AZ Topology Exception
- ALM-45434 A Single Replica Exists in the ClickHouse Data Table
- ALM-45435 Inconsistent Metadata of ClickHouse Tables
- ALM-45436 Skew ClickHouse Table Data
- ALM-45437 Excessive Parts in the ClickHouse Table
- ALM-45438 ClickHouse Disk Usage Exceeds 80%
- ALM-45439 ClickHouse Node Enters the Read-Only Mode
- ALM-45440 Inconsistency Between ClickHouse Replicas
- ALM-45441 Zookeeper Disconnected
- ALM-45442 Too Many Concurrent SQL Statements
- ALM-45443 Slow SQL Queries in the Cluster
- ALM-45444 Abnormal ClickHouse Process
- ALM-45445 Failed to Send Data Files to Remote Shards When ClickHouse Writes Data to a Distributed Table
- ALM-45446 Mutation Task of ClickHouse Is Not Complete for a Long Time
- ALM-45447 ClickHouse Table Read-Only
- ALM-45448 Rapid Increase of Znodes Used by ClickHouse
- ALM-45449 The Counter Number of zxid Used by ClickHouse Exceeds the Threshold
- ALM-45450 ClickHouse Failed to Obtain a Temporary Agency Credential
- ALM-45451 ClickHouse Failed to Access OBS
- ALM-45452 ClickHouse's Local Disk Space Is Below the Cold-Hot Separation Threshold
- ALM-45585 IoTDB Service Unavailable
- ALM-45586 IoTDBServer Heap Memory Usage Exceeds the Threshold
- ALM-45587 IoTDBServer GC Duration Exceeds the Threshold
- ALM-45588 IoTDBServer Direct Memory Usage Exceeds the Threshold
- ALM-45589 ConfigNode Heap Memory Usage Exceeds the Threshold
- ALM-45590 ConfigNode GC Duration Exceeds the Threshold
- ALM-45591 ConfigNode Direct Memory Usage Exceeds the Threshold
- ALM-45592 IoTDBServer RPC Execution Duration Exceeds the Threshold
- ALM-45593 IoTDBServer Flush Execution Duration Exceeds the Threshold
- ALM-45594 IoTDBServer Intra-Space Merge Duration Exceeds the Threshold
- ALM-45595 IoTDBServer Cross-Space Merge Duration Exceeds the Threshold
- ALM-45596 Procedure Execution Failed
- ALM-45615 CDL Service Unavailable
- ALM-45616 CDL Job Execution Exception
- ALM-45617 Data Queued in the CDL Replication Slot Exceeds the Threshold
- ALM-45635 FlinkServer Job Execution Failure
- ALM-45636 Flink Job Checkpoints Keep Failing
- ALM-45636 Number of Consecutive Checkpoint Failures of a Flink Job Exceeds the Threshold
- ALM-45637 FlinkServer Task Is Continuously Under Back Pressure
- ALM-45638 Number of Restarts After FlinkServer Job Failures Exceeds the Threshold
- ALM-45638 Number of Restarts After Flink Job Failures Exceeds the Threshold
- ALM-45639 Checkpointing of a Flink Job Times Out
- ALM-45640 FlinkServer Heartbeat Interruption Between the Active and Standby Nodes
- ALM-45641 Data Synchronization Exception Between the Active and Standby FlinkServer Nodes
- ALM-45642 RocksDB Continuously Triggers Write Traffic Limiting
- ALM-45643 MemTable Size of RocksDB Continuously Exceeds the Threshold
- ALM-45644 Number of SST Files at Level 0 of RocksDB Continuously Exceeds the Threshold
- ALM-45645 Pending Flush Size of RocksDB Continuously Exceeds the Threshold
- ALM-45646 Pending Compaction Size of RocksDB Continuously Exceeds the Threshold
- ALM-45647 Estimated Pending Compaction Size of RocksDB Continuously Exceeds the Threshold
- ALM-45648 RocksDB Frequently Encounters Write-Stopped
- ALM-45649 P95 Latency of RocksDB Get Requests Continuously Exceeds the Threshold
- ALM-45650 P95 Latency of RocksDB Write Requests Continuously Exceeds the Threshold
- ALM-45652 Flink Service Unavailable
- ALM-45653 Invalid Flink HA Certificate File
- ALM-45654 Flink HA Certificate Is About to Expire
- ALM-45655 Flink HA Certificate File Has Expired
- ALM-45736 Guardian Service Unavailable
- ALM-45737 TokenServer Heap Memory Usage Exceeds the Threshold
- ALM-45738 TokenServer Direct Memory Usage Exceeds the Threshold
- ALM-45739 TokenServer Non-Heap Memory Usage Exceeds the Threshold
- ALM-45740 TokenServer GC Duration Exceeds the Threshold
- ALM-45741 Failed to Call the ECS securitykey API
- ALM-45742 Failed to Call the ECS Metadata API
- ALM-45743 Failed to Call the IAM API
- ALM-45744 Average RPC Processing Time of the Guardian TokenServer Exceeds the Threshold
- ALM-45745 Average RPC Queuing Time of the Guardian TokenServer Exceeds the Threshold
- ALM-47001 MemArtsCC Service Unavailable
- ALM-47002 MemArtsCC Disk Fault
- ALM-47003 Memory Usage of the MemArtsCC Worker Process Exceeds the Threshold
- ALM-47004 Average Latency of MemArtsCC Worker Read Requests Exceeds the Threshold
- ALM-50201 Doris Service Unavailable
- ALM-50202 FE CPU Usage Exceeds the Threshold
- ALM-50203 FE Memory Usage Exceeds the Threshold
- ALM-50205 BE CPU Usage Exceeds the Threshold
- ALM-50206 BE Memory Usage Exceeds the Threshold
- ALM-50207 Ratio of Connections to the FE MySQL Port to the Maximum Connections Allowed Exceeds the Threshold
- ALM-50208 Failures to Clear Historical Metadata Image Files Exceed the Threshold
- ALM-50209 Failures to Generate Metadata Image Files Exceed the Threshold
- ALM-50210 Maximum Compaction Score of All BE Nodes Exceeds the Threshold
- ALM-50211 FE Queue Length of BE Periodic Report Tasks Exceeds the Threshold
- ALM-50212 Accumulated Old-Generation GC Duration of the FE Process Exceeds the Threshold
- ALM-50213 Number of Tasks Queuing in the FE Thread Pool for Interacting with BE Exceeds the Threshold
- ALM-50214 Number of Tasks Queuing in the FE Thread Pool for Task Processing Exceeds the Threshold
- ALM-50215 Longest Duration of RPC Requests Received by Each FE Thrift Method Exceeds the Threshold
- ALM-50216 Memory Usage of the FE Node Exceeds the Threshold
- ALM-50217 Heap Memory Usage of the FE Node Exceeds the Threshold
- ALM-50219 Length of the Queue in the Thread Pool for Query Execution Exceeds the Threshold
- ALM-50220 Error Rate of TCP Packet Receiving Exceeds the Threshold
- ALM-50221 BE Data Disk Usage Exceeds the Threshold
- ALM-50222 Disk Status of a Specified Data Directory on BE Is Abnormal
- ALM-50223 Maximum Memory Required by BE Is Greater Than the Remaining Memory of the Machine
- ALM-50224 Failures a Certain Task Type on BE Are Increasing
- ALM-50225 FE Instance Fault
- ALM-50226 BE Instance Fault
- ALM-50227 Concurrent Doris Tenant Queries Exceeds the Threshold
- ALM-50228 Memory Usage of a Doris Tenant Exceeds the Threshold
- ALM-50229 Doris FE Failed to Connect to OBS
- ALM-50230 Doris BE Cannot Connect to OBS
- ALM-50231 Abnormal Tablets Exist in Doris
- ALM-50232 Large Tablets in Doris
- ALM-50401 Number of JobServer Jobs Waiting to Be Executed Exceeds the Threshold
- ALM-50402 JobGateway Service Unavailable
- ALM-50406 Failure Rate of the JobServer Job Submission API Exceeds the Threshold
- ALM-50407 Failure Rate of the JobServer Job Query API Exceeds the Threshold
- ALM-50408 Failure Rate of the JobServer Job Termination API Exceeds the Threshold
- ALM-12001 Audit Log Dump Failure (For MRS 2.x or Earlier)
- ALM-12002 HA Resource Abnormal (For MRS 2.x or Earlier)
- ALM-12004 OLdap Resource Abnormal (For MRS 2.x or Earlier)
- ALM-12005 OKerberos Resource Abnormal (For MRS 2.x or Earlier)
- ALM-12006 Node Fault (For MRS 2.x or Earlier)
- ALM-12007 Process Fault (For MRS 2.x or Earlier)
- ALM-12010 Manager Heartbeat Interruption Between the Active and Standby Nodes (For MRS 2.x or Earlier)
- ALM-12011 Data Synchronization Exception Between the Active and Standby Manager Nodes (For MRS 2.x or Earlier)
- ALM-12012 NTP Service Abnormal (For MRS 2.x or Earlier)
- ALM-12014 Device Partition Lost (For MRS 2.x or Earlier)
- ALM-12015 Device Partition File System Read-Only (For MRS 2.x or Earlier)
- ALM-12016 CPU Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12017 Insufficient Disk Capacity (For MRS 2.x or Earlier)
- ALM-12018 Memory Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12027 Host PID Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12028 Number of Processes in the D State on the Host Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12031 User omm or Password Is About to Expire (For MRS 2.x or Earlier)
- ALM-12032 User ommdba or Password Is About to Expire (For MRS 2.x or Earlier)
- ALM-12033 Slow Disk Fault (For MRS 2.x or Earlier)
- ALM-12034 Periodic Backup Failure (For MRS 2.x or Earlier)
- ALM-12035 Unknown Data Status After Recovery Task Failure (For MRS 2.x or Earlier)
- ALM-12037 NTP Server Abnormal (For MRS 2.x or Earlier)
- ALM-12038 Monitoring Indicator Dump Failure (For MRS 2.x or Earlier)
- ALM-12039 GaussDB Data Is Not Synchronized (For MRS 2.x or Earlier)
- ALM-12040 Insufficient System Entropy (For MRS 2.x or Earlier)
- ALM-12041 Permission of Key Files Is Abnormal (For MRS 2.x or Earlier)
- ALM-12042 Key File Configurations Are Abnormal (For MRS 2.x or Earlier)
- ALM-12043 DNS Parsing Duration Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12045 Read Packet Dropped Rate Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12046 Write Packet Dropped Rate Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12047 Read Packet Error Rate Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12048 Write Packet Error Rate Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12049 Read Throughput Rate Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12050 Write Throughput Rate Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12051 Disk Inode Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12052 Usage of Temporary TCP Ports Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12053 File Handle Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-12054 Invalid Certificate File (For MRS 2.x or Earlier)
- ALM-12055 Certificate File Is About to Expire (For MRS 2.x or Earlier)
- ALM-12180 Disk Card I/O (For MRS 2.x or Earlier)
- ALM-12357 Failed to Export Audit Logs to OBS (For MRS 2.x or Earlier)
- ALM-13000 ZooKeeper Service Unavailable (For MRS 2.x or Earlier)
- ALM-13001 Available ZooKeeper Connections Are Insufficient (For MRS 2.x or Earlier)
- ALM-13002 ZooKeeper Memory Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-14000 HDFS Service Unavailable (For MRS 2.x or Earlier)
- ALM-14001 HDFS Disk Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-14002 DataNode Disk Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-14003 Number of Lost HDFS Blocks Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-14004 Number of Damaged HDFS Blocks Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-14006 Number of HDFS Files Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-14007 HDFS NameNode Memory Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-14008 HDFS DataNode Memory Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-14009 Number of Faulty DataNodes Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-14010 NameService Is Abnormal (For MRS 2.x or Earlier)
- ALM-14011 HDFS DataNode Data Directory Is Not Configured Properly (For MRS 2.x or Earlier)
- ALM-14012 HDFS Journalnode Data Is Not Synchronized (For MRS 2.x or Earlier)
- ALM-16000 Percentage of Sessions Connected to the HiveServer to the Maximum Number Allowed Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-16001 Hive Warehouse Space Usage Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-16002 Hive SQL Execution Success Rate Is Lower Than the Threshold (For MRS 2.x or Earlier)
- ALM-16004 Hive Service Unavailable (For MRS 2.x or Earlier)
- ALM-16005 Number of Failed Hive SQL Executions in the Last Period Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-18000 Yarn Service Unavailable (For MRS 2.x or Earlier)
- ALM-18002 NodeManager Heartbeat Lost (For MRS 2.x or Earlier)
- ALM-18003 NodeManager Unhealthy (For MRS 2.x or Earlier)
- ALM-18004 NodeManager Disk Usability Ratio Is Lower Than the Threshold (For MRS 2.x or Earlier)
- ALM-18006 MapReduce Job Execution Timeout (For MRS 2.x or Earlier)
- ALM-18008 Heap Memory Usage of Yarn ResourceManager Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-18009 Heap Memory Usage of MapReduce JobHistoryServer Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-18010 Number of Pending Yarn Tasks Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-18011 Memory of Pending Yarn Tasks Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-18012 Number of Terminated Yarn Tasks in the Last Period Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-18013 Number of Failed Yarn Tasks in the Last Period Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-19000 HBase Service Unavailable (For MRS 2.x or Earlier)
- ALM-19006 HBase Replication Sync Failed (For MRS 2.x or Earlier)
- ALM-19007 HBase Merge Queue Exceeds the Threshold (for 2.x and Earlier Versions)
- ALM-20002 Hue Service Unavailable (For MRS 2.x or Earlier)
- ALM-23001 Loader Service Unavailable (For MRS 2.x or Earlier)
- ALM-24000 Flume Service Unavailable (For MRS 2.x or Earlier)
- ALM-24001 Flume Agent Is Abnormal (For MRS 2.x or Earlier)
- ALM-24003 Flume Client Connection Interrupted (For MRS 2.x or Earlier)
- ALM-24004 Flume Fails to Read Data (For MRS 2.x or Earlier)
- ALM-24005 Data Transmission by Flume Is Abnormal (For MRS 2.x or Earlier)
- ALM-25000 LdapServer Service Unavailable (For MRS 2.x or Earlier)
- ALM-25004 Abnormal LdapServer Data Synchronization (For MRS 2.x or Earlier)
- ALM-25500 KrbServer Service Unavailable (For MRS 2.x or Earlier)
- ALM-26051 Storm Service Unavailable (For MRS 2.x or Earlier)
- ALM-26052 Number of Available Supervisors in Storm Is Lower Than the Threshold (For MRS 2.x or Earlier)
- ALM-26053 Slot Usage of Storm Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-26054 Heap Memory Usage of Storm Nimbus Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-27001 DBService Unavailable (For MRS 2.x or Earlier)
- ALM-27003 DBService Heartbeat Interruption Between the Active and Standby Nodes (For MRS 2.x or Earlier)
- ALM-27004 Data Inconsistency Between Active and Standby DBServices (For MRS 2.x or Earlier)
- ALM-28001 Spark Service Unavailable (For MRS 2.x or Earlier)
- ALM-38000 Kafka Service Unavailable (For MRS 2.x or Earlier)
- ALM-38001 Insufficient Kafka Disk Capacity (For MRS 2.x or Earlier)
- ALM-38002 Heap Memory Usage of Kafka Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-43001 Spark Service Unavailable (For MRS 2.x or Earlier)
- ALM-43006 Heap Memory Usage of the JobHistory Process Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-43007 Non-Heap Memory Usage of the JobHistory Process Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-43008 Direct Memory Usage of the JobHistory Process Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-43009 JobHistory GC Time Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-43010 Heap Memory Usage of the JDBCServer Process Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-43011 Non-Heap Memory Usage of the JDBCServer Process Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-43012 Direct Memory Usage of the JDBCServer Process Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-43013 JDBCServer GC Time Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-44004 Presto Coordinator Resource Group Queuing Tasks Exceed the Threshold (For MRS 2.x or Earlier)
- ALM-44005 Presto Coordinator Process GC Time Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-44006 Presto Worker Process GC Time Exceeds the Threshold (For MRS 2.x or Earlier)
- ALM-45325 Presto Service Unavailable (For MRS 2.x or Earlier)
- Configuring Remote O&M for an MRS Cluster
- Common Ports for MRS Cluster Services
Configuring Storage-Compute Decoupling for an MRS Cluster
- Configuration Process
Interconnecting an MRS Cluster with OBS Using an IAM Agency
- Interconnecting an MRS Cluster with OBS Using an IAM Agency
- Configuring the Policy for Clearing Recycle Bin Directories of MRS Cluster Components
Example for Interconnecting a Cluster Service with OBS
- Interconnecting Flink with OBS Using an IAM Agency
- Interconnecting Flume with OBS Using an IAM Agency
- Interconnecting HDFS with OBS Using an IAM Agency
- Interconnecting Hive with OBS Using an IAM Agency
- Interconnecting Hudi with OBS Using an IAM Agency
- Interconnecting MapReduce with OBS Using an IAM Agency
- Interconnecting Presto with OBS Using an IAM Agency
- Interconnecting Spark with OBS Using an IAM Agency
- Interconnecting Sqoop with OBS Using an IAM Agency
- Configuring Fine-Grained OBS Access Permissions for MRS Cluster Users
FAQ About Decoupled Storage and Compute
- How Do I Read Encrypted OBS Data When Running an MRS Job?
- Example Application Development for Interconnecting HDFS with OBS
- How Do I Connect an MRS Cluster Client to OBS Using an AK/SK Pair?
- How Do I Access OBS Using an MRS Client Installed Outside a Cluster?
- Accessing an MRS Cluster's Manager (Version 2.x or Earlier)
- How Do I Handle Abnormal Status of Core Nodes in an MRS Cluster After Successful Expansion?
Component Operation Guide (LTS)
Using CarbonData
- CarbonData Data Types
- CarbonData Table User Permissions
- Creating a CarbonData Table Using the Spark Client
- CarbonData Data Analytics
- CarbonData Performance Tuning
- Typical CarbonData Configuration Parameters
CarbonData Syntax Reference
- CREATE TABLE
- CREATE TABLE As SELECT
- DROP TABLE
- SHOW TABLES
- ALTER TABLE COMPACTION
- TABLE RENAME
- ADD COLUMNS
- DROP COLUMNS
- CHANGE DATA TYPE
- REFRESH TABLE
- REGISTER INDEX TABLE
- LOAD DATA
- UPDATE CARBON TABLE
- DELETE RECORDS from CARBON TABLE
- INSERT INTO CARBON TABLE
- DELETE SEGMENT by ID
- DELETE SEGMENT by DATE
- SHOW SEGMENTS
- CREATE SECONDARY INDEX
- SHOW SECONDARY INDEXES
- DROP SECONDARY INDEX
- CLEAN FILES
- SET/RESET
- Concurrent CarbonData Table Operations
- CarbonData Segment API
- CarbonData Tablespace Index
Common Issues About CarbonData
- Why Is Incorrect Output Displayed When I Perform Query with Filter on Decimal Data Type Values?
- How to Avoid Minor Compaction for Historical Data?
- How to Change the Default Group Name for CarbonData Data Loading?
- Why Does INSERT INTO CARBON TABLE Command Fail?
- Why Is the Data Logged in Bad Records Different from the Original Input Data with Escape Characters?
- Why Data Load Performance Decreases due to Bad Records?
- Why Data loading Fails During off heap?
- Why Do I Fail to Create a Hive Table?
- How Do I Logically Split Data Across Different Namespaces?
- Why the UPDATE Command Cannot Be Executed in Spark Shell?
- How Do I Configure Unsafe Memory in CarbonData?
- Why Does CarbonData Become Abnormal After the Disk Space Quota of the HDFS Storage Directory Is Set?
- Why Do Files of a Carbon Table Exist in the Recycle Bin Even If the drop table Command Is Not Executed When Mis-deletion Prevention Is Enabled?
- How Do I Restore the Latest tablestatus File That Has Been Lost or Damaged When TableStatus Versioning Is Enabled?
CarbonData Troubleshooting
- Filter Result Is not Consistent with Hive when a Big Double Type Value Is Used in Filter
- Query Performance Deteriorated Due to Insufficient Executor Memory
- Data Query or Loading Failed, and "org.apache.carbondata.core.memory.MemoryException: Not enough memory" Was Reported
- Why INSERT INTO/LOAD DATA Task Distribution Is Incorrect and the Opened Tasks Are Less Than the Available Executors when the Number of Initial ExecutorsIs Zero?
- Why Does CarbonData Require Additional Executors Even Though the Parallelism Is Greater Than the Number of Blocks to Be Processed?
Using CDL
- Integrating CDL Data
- CDL User Permission Management
- Creating a Data Synchronization Job with CDL
- Preparing for Creating a CDL Job
Creating a CDL Job
- Creating a CDL Data Synchronization Job
- Creating a CDL Data Comparison Job
- Synchronizing Data from PgSQL to Kafka Using CDL
- Synchronizing Data from PgSQL to Hudi Using CDL
- Synchronizing Data from openGauss to Hudi Using CDL
- Synchronizing Data from Hudi to DWS Using CDL
- Synchronizing Data from Hudi to ClickHouse Using CDL
- Synchronizing openGauss Data to Hudi Using CDL (ThirdKafka)
- Synchronizing drs-oracle-json Database to Hudi Using CDL (ThirdKafka)
- Synchronizing drs-oracle-avro Database to Hudi Using CDL (ThirdKafka)
- CDL Job DDL Changes
- CDL Log Overview
- Common Issues About CDL
CDL Troubleshooting
- Error 403 Is Reported When a CDL Job Is Stopped
- Error 104 or 143 Is Reported After a CDL Job Runs for a Period of Time
- Why Is the Value of Task configured for the OGG Source Different from the Actual Number of Running Tasks When Data Is Synchronized from OGG to Hudi?
- Why Are There Too Many Topic Partitions Corresponding to the CDL Synchronization Task Names?
- What Should I When a CDL Task Is Executed to Synchronize Data to the Hudi, an Error Message Indicating that the Current User Does Not Have the Permission to Create Tables?
- Error Is Reported When the Job of Capturing Data From PgSQL to Hudi Is Started
Using ClickHouse
- ClickHouse Overview
- ClickHouse User Permission Management
- ClickHouse Client Practices
ClickHouse Data Import
- Interconnecting ClickHouse with RDS for MySQL
- Interconnecting ClickHouse with OBS
- Interconnecting ClickHouse with HDFS (MRS 3.2.0-LTS)
- Interconnecting ClickHouse with HDFS (MRS 3.3.0-LTS or later)
- Configuring Interconnection Between ClickHouse and Kafka
- Synchronizing Kafka Data to ClickHouse
- Importing DWS Table Data to ClickHouse
- Importing ClickHouse Data in Batches
- Using ClickHouse to Import and Export Data
Enterprise-Class Enhancements of ClickHouse
- ClickHouse Multi-Tenancy
- Checking Slow SQL Statements in ClickHouse
- Checking Monitoring Metrics of ClickHouse Replication Table Data Synchronization
- Configuring Strong Data Consistency Between ClickHouse Replicas
- Configuring the Support for Transactions on ClickHouse
- Accessing ClickHouse Through ELB
- Storing ClickHouse Cold and Hot Data Separately
- Configuring the Connection Between ClickHouse and Open-Source ClickHouse
- Pre-Caching ClickHouse Metadata to the Memory
- ClickHouse Performance Tuning
ClickHouse O&M Management
- ClickHouse Log Overview
- Collecting Dumping Logs of the ClickHouse System Tables
- Enabling the Read-Only Mode for ClickHouse Tables
- Migrating Data Between ClickHouseServer Nodes in a Cluster
- Migrating ClickHouse Data from One MRS Cluster to Another
- Expanding the Disk Capacity of the ClickHouse Node
- Backing Up and Restoring ClickHouse Data Using a Data File
- Configuring the Default ClickHouse User Password (MRS 3.1.2-LTS)
- Configuring the Default ClickHouse User Password (MRS 3.3.0-LTS or later)
- Clearing the Passwords of Default ClickHouse Users
Common ClickHouse SQL Syntax
- CREATE DATABASE: Creating a Database
- CREATE TABLE: Creating a Table
- INSERT INTO: Inserting Data into a Table
- DELETE: Lightweight Deleting Table Data
- SELECT: Querying Table Data
- ALTER TABLE: Modifying a Table Structure
- ALTER TABLE: Modifying Table Data
- DESC: Querying a Table Structure
- DROP: Deleting a Table
- SHOW: Displaying Information About Databases and Tables
- UPSERT: Writing Data
Common Issues About ClickHouse
- How Do I Do If the Disk Status Displayed in the System.disks Table Is fault or abnormal?
- How Do I Migrate Data from Hive/HDFS to ClickHouse?
- How Do I Migrate Data from OBS/S3 to ClickHouse?
- An Error Is Reported in Logs When the Auxiliary ZooKeeper or Replica Data Is Used to Synchronize Table Data
- How Do I Grant the Select Permission at the Database Level to ClickHouse Users?
- How Do I Quickly Restore ClickHouse When Concurrent Requests Are Stacked for a Long Time?
- Using DBService
Using Doris
- Overview of the Doris Data Model
- Managing Doris User Permissions
- Using the MySQL Client to Connect to Doris
- Getting Started with Doris
- Importing Doris Data
- Analyzing Doris Data
- Enterprise-Class Enhancements of Doris
- Doris O&M Management
- Typical SQL Syntax of Doris
Common Issues About Doris
- What Should I Do If Occasionally Occurs During Table Creation Due to the Configuration of the SSD and HDD Data Directories?
- What Should I Do If RPC Timeout Error Is Reported When Stream Load Is Used?
- What Do I Do If the Error Message "plugin not enabled" Is Displayed When the MySQL Client Is Used to Connect to the Doris Database?
- How Do I Handle the FE Startup Failure?
- How Do I Handle the Startup Failure Due to Incorrect IP Address Matching for the BE Instance?
- What Should I Do If Error Message "Read timed out" Is Displayed When the MySQL Client Connects to the Doris?
- What Should I Do If an Error Is Reported When the BE Runs a Data Import or Query Task?
- What Should I Do If a Timeout Error Is Reported When Broker Load Imports Data?
- What Should I Do If an Error Message Is Displayed When Broker Load Is Used to Import Data?
- Doris Troubleshooting
Using Flink
- Flink Job Engine
- Flink User Permission Management
- Using the Flink Client
- Preparing for Creating a FlinkServer Job
- Creating a FlinkServer Job and Writing Data to a ClickHouse Table
- Creating a FlinkServer Job to Interconnect with a Doris Table
- Creating a FlinkServer Job to Interconnect with a GaussDB(DWS) Table
- Creating a FlinkServer Job to Interconnect with JDBC
- Creating a FlinkServer Job to Write Data to a DWS
- Creating a FlinkServer Job to Write Data to an HBase Table
- Creating a FlinkServer Job to Write Data to an HDFS
- Creating a FlinkServer Job to Write Data to a Hive Table
- Creating a FlinkServer Job to Write Data to a Hudi Table
- Creating a FlinkServer Job to Write Data to a Kafka Message Queue
Managing FlinkServer Jobs
- Viewing the Health Status of FlinkServer Jobs
- Importing and Exporting FlinkServer Job Information
- Configuring Automatic Clearing of FlinkServer Job Residuals
- Configuring the FlinkServer Job Restart Policy
- Adding Third-Party Dependency JAR Packages to a FlinkServer Job
- Using UDFs in FlinkServer Jobs
- Configuring the FlinkServer UDF Sandbox
Enterprise-Class Enhancements of Flink
- Flink SQL Syntax Enhancement
- Table-Level TTL for Stream Joins
- Configuring Flink SQL Client to Support SQL Verification
- Enhancing the Joins of Large and Small Tables in Flink Jobs
- Exiting FlinkSQL OVER Window Upon Expiration
- Limiting Read Rate for Flink SQL Kafka and Upsert-Kafka Connector
- Consuming Data in drs-json Format with FlinkSQL Kafka Connector
- Using ignoreDelete in JDBC Data Writes
- Join-To-Live
- Row Filter
- FlinkSQL Operator Parallelism
- Optimizing FlinkSQL JSON_VALUE Performance
- Reusing FlinkSQL Lookup Operator
- FlinkSQL Function Enhancements
- Using the MultiJoin Operator in Flink SQL
- Flink O&M Management
- Flink Performance Tuning
- Typical Commands of the Flink Client
- Common Flink SQL Syntax
- Common Issues About Flink
- Flink Troubleshooting
Using Flume
- Flume Log Collection Overview
- Flume Service Model Configuration
- Installing the Flume Client
- Quickly Using Flume to Collect Node Logs
Configuring a Non-Encrypted Flume Data Collection Task
- Generating Configuration Files for the Flume Server and Client
- Using Flume Server to Collect Static Logs from Local Host to Kafka
- Using Flume Server to Collect Static Logs from Local Host to HDFS
- Using Flume Server to Collect Dynamic Logs from Local Host to HDFS
- Using Flume Server to Collect Logs from Kafka to HDFS
- Using Flume Client to Collect Logs from Kafka to HDFS
- Using Cascaded Agents to Collect Static Logs from Local Host to HBase
- Configuring an Encrypted Flume Data Collection Task
- Enterprise-Class Enhancements of Flume
- Flume O&M Management
- Common Issues About Flume
- Using Guardian
Using HBase
- Creating an HBase Permission Role
- Using the HBase Client
- Using HBase for Offline Data Analysis
- Migrating Data to HBase Using BulkLoad
- HBase Data Operations
Enterprise-Class Enhancements of HBase
Configuring HBase Global Secondary Indexes for Faster Queries
- Introduction to HBase Global Secondary Indexes
- Creating an HBase Global Secondary Index
- Querying an HBase Global Secondary Index
- Changing Status of HBase Global Secondary Indexes
- Creating HBase Global Secondary Indexes in Batches
- Checking HBase Global Secondary Index Data Consistency
- Querying HBase Table Data with Global Secondary Indexes
- Configuring HBase Local Secondary Indexes for Faster Queries
- Improving HBase BulkLoad Data Migration
- Using the Spark BulkLoad Tool to Synchronize Data to HBase Tables
- Configuring Hot-Cold Data Separate in HBase
- Configuring RSGroup to Manage RegionServer Resource
- Checking Slow and Oversized HBase Requests
- Configuring HBase Table-Level Overload Control
- Enabling the HBase Multicast Function
HBase Performance Tuning
- Improving the Batch Loading Efficiency of HBase BulkLoad
- Improving HBase Continuous Put Performance
- Improving HBase Put and Scan Performance
- Improving HBase Real-Time Write Efficiency
- Improving HBase Real-Time Read Efficiency
- Accelerating HBase Compaction During Off-Peak Hours
- Tuning HBase JVM Parameters
- Optimization for HBase Overload
- Enabling CCSMap Functions
- Enabling Succinct Trie
- HBase O&M Management
Common Issues About HBase
- Operation Failures Occur in Stopping BulkLoad On the Client
- How Do I Restore a Region in the RIT State for a Long Time?
- Why Does HMaster Exits Due to Timeout When Waiting for the NameSpace Table to Go Online?
- Why Does SocketTimeoutException Occur When a Client Queries HBase?
- Why "java.lang.UnsatisfiedLinkError: Permission denied" exception thrown while starting HBase shell?
- When does the RegionServers listed under "Dead Region Servers" on HMaster WebUI gets cleared?
- Insufficient Rights When Accessing Phoenix
- Insufficient Rights When Useing the HBase Bulkload Function
- How Do I Fix Region Overlapping?
- Restrictions on using the Phoenix BulkLoad Tool
- Why a Message Is Displayed Indicating that the Permission is Insufficient When CTBase Connects to the Ranger Plug-ins?
- Introduction to HBase Global Secondary Index APIs
- How Do I Disable HDFS Hedged Read on HBase?
HBase Troubleshooting
- Why Does a Client Keep Failing to Connect to a Server for a Long Time?
- Why May a Table Creation Exception Occur When HBase Deletes or Creates the Same Table Consecutively?
- Why Other Services Become Unstable If HBase Sets up A Large Number of Connections over the Network Port?
- Why Does the HBase BulkLoad Task Consisting of 210,000 Map Tasks and 10,000 Reduce Tasks Fail?
- Why Modified and Deleted Data Can Still Be Queried by Using the Scan Command?
- What Should I Do If I Fail to Create Tables Due to the FAILED_OPEN State of Regions?
- How Do I Delete Residual Table Names in the table-lock Directory of ZooKeeper?
- Why Does HBase Become Faulty When I Set a Quota for the Directory Used by HBase in HDFS?
- HMaster Fails to Be Started After the OfflineMetaRepair Tool Is Used to Rebuild Metadata
- Why Messages Containing FileNotFoundException Frequently Displayed in the HMaster Logs?
- Why Does the ImportTsv Tool Display "Permission denied"
- Why Are Different Query Results Returned After I Use Same Query Criteria to Query Data Successfully Imported by HBase bulkload?
- HBase Fails to Recover a Task
- Why Does RegionServer Fail to Be Started When GC Parameters Xms and Xmx of HBase RegionServer Are Set to 31 GB?
- Why Does the LoadIncrementalHFiles Tool Fail to Be Executed and "Permission denied" Is Displayed?
- Why Is the Error Message "import argparse" Displayed When the Phoenix sqlline Script Is Used?
- How Do I View Regions in the CLOSED State in an ENABLED Table?
- How Can I Quickly Recover the Service When HBase Files Are Damaged Due to a Cluster Power-Off?
- How Do I Quickly Restore HBase After HDFS Enters the Safe Mode and the HBase Service Is Abnormal?
Using HDFS
- Overview of HDFS File System Directories
- HDFS User Permission Management
- Using the HDFS Client
- Using Hadoop from Scratch
- Configuring the Recycle Bin Mechanism
- Configuring HDFS DataNode Data Balancing
- Configuring HDFS DiskBalancer
- Configuring HDFS Mover
- Configuring HDFS NodeLabel
- Configuring Memory Management
- Configuring ulimit for HBase and HDFS
- Configuring the Number of Files in a Single HDFS Directory
Enterprise-Class Enhancements of HDFS
- Configuring the HDFS Quick File Close Function
- Configuring Replica Replacement Policy for Heterogeneous Capacity Among DataNodes
- Configuring Reserved Percentage of Disk Usage on DataNodes
- Configuring the NameNode Blacklist
- Configuring Encrypted Channels
- Configuring HDFS Hedged Read
- Configuring Fine-Grained Locks of HDFS
- HDFS Auto Recovery from Cluster Power-off
HDFS Performance Tuning
- Improving Write Performance
- Improving Read Performance Using Client Metadata Cache
- Improving the Connection Between the Client and NameNode Using Current Active Cache
- Reducing the Probability of Abnormal Client Application Operation When the Network Is Not Stable
- Optimizing HDFS NameNode RPC QoS
- Optimizing HDFS DataNode RPC QoS
- Performing Concurrent Operations on HDFS Files
- Configuring LZC Compression
- Asynchronously Deleting HDFS Data
- HDFS O&M Management
- Common commands of the HDFS client
Common Issues About HDFS
- Why Does the Distcp Command Fail in the Secure Cluster, Causing an Exception?
- When Does a Balance Process in HDFS, Shut Down and Fail to be Executed Again?
- "This page can't be displayed" Is Displayed When Internet Explorer Fails to Access the Native HDFS UI
- HDFS WebUI Cannot Properly Update Information About Damaged Data
- The HDFS Client Is Unresponsive When the NameNode Is Overloaded for a Long Time
- Why are There Two Standby NameNodes After the active NameNode Is Restarted?
- DataNode Is Normal but Cannot Report Data Blocks
- Can I Delete or Modify the Data Storage Directory in DataNode?
- Failed to Calculate the Capacity of a DataNode when Multiple data.dir Directories Are Configured in a Disk Partition
- Why Data in the Buffer Is Lost If a Power Outage Occurs During Storage of Small Files
- Why Is the Storage Type of File Copies DISK When the Tiered Storage Policy Is LAZY_PERSIST?
- Blocks Miss on the NameNode UI After the Successful Rollback
HDFS Troubleshooting
- Why Is "java.net.SocketException: No buffer space available" Reported When Data Is Written to HDFS
- NameNode Startup Is Slow
- NameNode Fails to Be Restarted Due to EditLog Discontinuity
- Standby NameNode Fails to Be Restarted When the System Is Powered off During Metadata (Namespace) Storage
- Why Does DataNode Fail to Start When the Number of Disks Specified by dfs.datanode.data.dir Equals dfs.datanode.failed.volumes.tolerated?
- Why Does Array Border-crossing Occur During FileInputFormat Split?
- The Standby NameNode Fails to Be Started Because It Is Not Started for a Long Time
Using HetuEngine
- Overview of HetuEngine Interactive Query
- HetuEngine User Permission Management
- Quickly Using HetuEngine to Access Hive Data Source
- Creating a HetuEngine Compute Instance
Adding a HetuEngine Data Source
- Using HetuEngine to Access Data Sources Across Sources and Domains
- Adding a Hive Data Source
- Adding a Hudi Data Source
- Adding a ClickHouse Data Source
- Adding a GaussDB Data Source
- Adding an HBase Data Source
- Adding a Cross-Cluster HetuEngine Data Source
- Adding an IoTDB Data Source
- Adding a MySQL Data Source
- Adding an Oracle Data Source
- Adding a GBase Data Source
Configuring HetuEngine Materialized Views
- Overview of HetuEngine Materialized Views
- SQL Examples of HetuEngine Materialized Views
- Rewriting of HetuEngine Materialized Views
- HetuEngine Materialized View Recommendation
- HetuEngine Materialized View Caching
- Validity Period and Data Update of HetuEngine Materialized Views
- HetuEngine Intelligent Materialized Views
- Automatic Tasks of HetuEngine Materialized Views
- HetuEngine SQL Diagnosis
- Developing and Deploying HetuEngine UDFs
- Managing a HetuEngine Data Source
Managing HetuEngine Compute Instances
- Configuring HetuEngine Resource Groups
- Configuring the Number of HetuEngine Worker Nodes
- Configuring a HetuEngine Maintenance Instance
- Configuring the Nodes on Which HetuEngine Coordinator Is Running
- Importing and Exporting HetuEngine Compute Instance Configurations
- Viewing the HetuEngine Instance Monitoring Page
- Viewing HetuEngine Coordinator and Worker Logs
- Configuring HetuEngine Query Fault Tolerance
HetuEngine Performance Tuning
- Adjusting YARN Resource Allocation
- Adjusting HetuEngine Cluster Node Resource Configurations
- Optimizing HetuEngine INSERT Statements
- Adjusting HetuEngine Metadata Caching
- Enabling Dynamic Filtering in HetuEngine
- Adjusting the Execution of Adaptive Queries in HetuEngine
- Adjusting Timeout for Hive Metadata Loading
- Tuning Hudi Data Source Performance
- HetuEngine Log Overview
Common HetuEngine SQL Syntax
- HetuEngine Data Type
HetuEngine DDL SQL Syntax
- CREATE SCHEMA
- CREATE VIRTUAL SCHEMA
- CREATE TABLE
- CREATE TABLE AS
- CREATE TABLE LIKE
- CREATE VIEW
- CREATE FUNCTION
- CREATE MATERIALIZED VIEW
- ALTER MATERIALIZED VIEW STATUS
- ALTER TABLE
- ALTER VIEW
- ALTER SCHEMA
- DROP SCHEMA
- DROP TABLE
- DROP VIEW
- DROP FUNCTION
- DROP MATERIALIZED VIEW
- REFRESH MATERIALIZED VIEW
- TRUNCATE TABLE
- COMMENT
- VALUES
- SHOW Syntax Overview
- SHOW CATALOGS
- SHOW SCHEMAS (DATABASES)
- SHOW TABLES
- SHOW TBLPROPERTIES TABLE|VIEW
- SHOW TABLE/PARTITION EXTENDED
- SHOW STATS
- SHOW FUNCTIONS
- SHOW SESSION
- SHOW PARTITIONS
- SHOW COLUMNS
- SHOW CREATE TABLE
- SHOW VIEWS
- SHOW CREATE VIEW
- SHOW MATERIALIZED VIEWS
- SHOW CREATE MATERIALIZED VIEW
- HetuEngine DML SQL Syntax
- HetuEngine TCL SQL Syntax
- HetuEngine DQL SQL Syntax
HetuEngine SQL Functions and Operators
- Logical Operators
- Comparison Functions and Operators
- Condition Expression
- Lambda Expression
- Conversion Functions
- Mathematical Functions and Operators
- Bitwise Functions
- Decimal Functions and Operators
- String Functions and Operators
- Regular Expressions
- Binary Functions and Operators
- JSON Functions and Operators
- Date and Time Functions and Operators
- Aggregate Functions
- Window Functions
- Array Functions and Operators
- Map Functions and Operators
- URL Function
- Geospatial Function
- HyperLogLog Functions
- UUID Function
- Color Function
- Session Information
- Teradata Function
- Data Masking Functions
- IP Address Functions
- Quantile Digest Functions
- T-Digest Functions
- Set Digest Functions
- HetuEngine Auxiliary Command Syntax
- HetuEngine Reserved Keywords
- HetuEngine Implicit Data Type Conversion
- Data Preparation for the Sample Table
- HetuEngine Syntax Compatibility with Common Data Sources
Common Issues About HetuEngine
- What Should I Do After the HetuEngine Domain Name Is Changed?
- What Can I Do If Starting the HetuEngine Cluster on the Client Times Out?
- How Do I Handle Data Loss in a HetuEngine Data Source?
- What Do I Do If the View Owner Does Not Have the Permission on Functions?
- What Do I Do If Error "Encountered too many errors" Is Reported During HetuEngine SQL Execution?
- HetuEngine Troubleshooting
Using Hive
- Hive User Permission Management
- Using the Hive Client
- Using Hive for Data Analysis
- Configuring Hive Data Storage and Encryption
- Hive on HBase
- Using Hive to Read Data in a Relational Database
- Hive Supporting Reading Hudi Tables
Enterprise-Class Enhancements of Hive
- Storing Hive Table Partitions to OBS and HDFS
- Configuring Automatic Removal of Old Data in the Hive Directory to the Recycle Bin
- Configuring Hive to Insert Data to a Directory That Does Not Exist
- Forbidding Location Specification When Hive Internal Tables Are Created
- Creating a Foreign Table in a Directory (Read and Execute Permission Granted)
- Configuring HTTPS/HTTP-based REST APIs
- Configuring Hive Transform
- Switching the Hive Execution Engine to Tez
- Hive Load Balancing
- Configuring Access Control Permission for the Dynamic View of a Hive Single Table
- Allowing Users without ADMIN Permission to Create Temporary Functions
- Allowing Users with Select Permission to View the Table Structure
- Allowing Only the Hive Administrator to Create Databases and Tables in the Default Database
- Configuring Hive to Support More Than 32 Roles
- Creating User-Defined Hive Functions
- Configuring High Reliability for Hive Beeline
- Detecting Statements That Overwrite a Table with Its Own Data
- Configuring Hive Dynamic Data Masking
- Hive Performance Tuning
- Hive O&M Management
- Common Hive SQL Syntax
Common Issues About Hive
- How Do I Delete UDFs on Multiple HiveServers?
- Why Cannot the DROP operation Be Performed on a Backed-up Hive Table?
- How to Perform Operations on Local Files with Hive User-Defined Functions
- How Do I Forcibly Stop MapReduce Jobs Executed by Hive?
- Which special characters are not supported by Hive in complex field names
- How Do I Monitor the Hive Table Size?
- How Do I Prevent Data Loss Caused by Misoperations of the insert overwrite Statement?
- Why Is Hive on Spark Task Freezing When HBase Is Not Installed?
- Error Reported When the WHERE Condition Is Used to Query Tables with Excessive Partitions in FusionInsight Hive
- Why Cannot I Connect to HiveServer When I Use IBM JDK to Access the Beeline Client?
- Description of Hive Table Location (Either Be an OBS or HDFS Path)
- Why Cannot Data Be Queried After the MapReduce Engine Is Switched After the Tez Engine Is Used to Execute Union-related Statements?
- Why Does Hive Not Support Concurrent Data Writing to the Same Table or Partition?
- Does Hive Support Vectorized Query?
- Why Does Metadata Still Exist When the HDFS Data Directory of the Hive Table Is Deleted by Mistake?
- How Do I Disable the Logging Function of Hive?
- Why Hive Tables in the OBS Directory Fail to Be Deleted?
- Why Does an OBS Quickly Deleted Directory Not Take Effect After Being Added to the Customized Hive Configuration?
- Hive Troubleshooting
Using Hudi
- Hudi Table Overview
- Creating a Hudi Table Using Spark Shell
- Operating a Hudi Table Using spark-sql
- Operating a Hudi Table Using hudi-cli.sh
- Hudi Write Operation
- Hudi Read Operation
- Hudi Data Management and Maintenance
- Hudi SQL Syntax Reference
- Hudi Schema Evolution
- Configuring Default Values for Hudi Data Columns
- Partial Update
- Aggregate Functions in Hudi
- Typical Hudi Configuration Parameters
- Hudi Performance Tuning
Common Issues About Hudi
- "Parquet/Avro schema" Is Reported When Updated Data Is Written
- UnsupportedOperationException Is Reported When Updated Data Is Written
- SchemaCompatabilityException Is Reported When Updated Data Is Written
- What Should I Do If Hudi Consumes Much Space in a Temporary Folder During Upsert?
- Hudi Fails to Write Decimal Data with Lower Precision
- Data in ro and rt Tables Cannot Be Synchronized to a MOR Table Recreated After Being Deleted Using Spark SQL
- IllegalArgumentException Is Reported When Kafka Is Used to Collect Data
- SQLException Is Reported During Hive Data Synchronization
- HoodieHiveSyncException Is Reported During Hive Data Synchronization
- SemanticException Is Reported During Hive Data Synchronization
Using Hue
- Accessing the Hue Web UI
- Creating a Hue Job
- Configuring HDFS Cold and Hot Data Migration
- Typical Hue Parameters
- Hue Log Overview
- Common Issues About Hue
Hue Troubleshooting
- Why Does the use database Statement Become Invalid in Hive?
- Why Do HDFS Files Fail to Access Through the Hue Web UI?
- Why Do Large Files Fail to Upload on the Hue Page
- Why Is the Hue Native Page Cannot Be Properly Displayed If the Hive Service Is Not Installed in a Cluster?
- What Should I Do If It Takes a Long Time to Access the Native Hue UI and the File Browser Reports "Read timed out"?
- Using Impala
- Using IoTDB
- Using JobGateway
- Using Kafka
- Using Kudu
Using Loader
- Overview of Importing and Exporting Loader Data
- Loader User Permission Management
- Uploading the MySQL Database Connection Driver
Creating a Loader Data Import Job
- Using Loader to Import Data to an MRS Cluster
- Using Loader to Import Data from an SFTP Server to HDFS or OBS
- Using Loader to Import Data from an SFTP Server to HBase
- Using Loader to Import Data from an SFTP Server to Hive
- Using Loader to Import Data from an FTP Server to HBase
- Using Loader to Import Data from a Relational Database to HDFS or OBS
- Using Loader to Import Data from a Relational Database to HBase
- Using Loader to Import Data from a Relational Database to Hive
- Using Loader to Import Data from HDFS or OBS to HBase
- Using Loader to Import Data from a Relational Database to ClickHouse
- Using Loader to Import Data from HDFS to ClickHouse
Creating a Loader Data Export Job
- Using Loader to Export Data from an MRS Cluster
- Using Loader to Export Data from HDFS or OBS to an SFTP Server
- Using Loader to Export Data from HBase to an SFTP Server
- Using Loader to Export Data from Hive to an SFTP Server
- Using Loader to Export Data from HDFS or OBS to a Relational Database
- Using Loader to Export Data from HDFS to MOTService
- Using Loader to Export Data from HBase to a Relational Database
- Using Loader to Export Data from Hive to a Relational Database
- Using Loader to Export Data from HBase to HDFS or OBS
- Using Loader to Export Data from HDFS to ClickHouse
- Managing Loader Jobs
- Loader O&M Management
- Loader Operator Help
Loader Client Tools
- Running a Loader Job by Using Commands
- loader-tool Usage Guide
- loader-tool Usage Example
- schedule-tool Usage Guide
- schedule-tool Usage Example
- Using loader-backup to Back Up Job Data
- Open Source sqoop-shell Tool Usage Guide
- Importing Data to HDFS Using sqoop-shell
Common Issues About Loader
- Data Cannot Be Saved When Loader Jobs Are Configured
- Differences Among Connectors Used During the Process of Importing Data from the Oracle Database to HDFS
- Why Data Is Not Imported to HDFS After All Data Types of SQL Server Are Selected?
- An Error Is Reported When a Large Amount of Data Is Written to HDFS
- Failed to Run Jobs Related to the sftp-connector Connector
Using MapReduce
- Configuring the Distributed Cache
- Configuring the MapReduce Shuffle Address
- Configuring the MapReduce Cluster Administrator List
- Transmitting MapReduce Tasks from Windows to Linux
- Configuring the Archiving and Clearing Mechanism for MapReduce Task Logs
- MapReduce Performance Tuning
- Mapreduce Log Overview
Common Issues About MapReduce
- After an Active/Standby Switchover of ResourceManager Occurs, a Task Is Interrupted and Runs for a Long Time
- Why Does a MapReduce Task Stay Unchanged for a Long Time?
- Why the Client Hangs During Job Running?
- Why Cannot HDFS_DELEGATION_TOKEN Be Found in the Cache?
- How Do I Set the Task Priority When Submitting a MapReduce Task?
- Why Physical Memory Overflow Occurs If a MapReduce Task Fails?
- After the Address of MapReduce JobHistoryServer Is Changed, Why the Wrong Page is Displayed When I Click the Tracking URL on the ResourceManager WebUI?
- MapReduce Job Failed in Multiple NameService Environment
- Why a Fault MapReduce Node Is Not Blacklisted?
Using Oozie
- Submitting a Job Using the Oozie Client
Using Hue to Submit an Oozie Job
- Creating a Workflow Using Hue
- Submitting an Oozie Hive2 Job Using Hue
- Submitting an Oozie HQL Script Using Hue
- Submitting an Oozie Spark2x Job Using Hue
- Submitting an Oozie Java Job Using Hue
- Submitting an Oozie Loader Job Using Hue
- Submitting an Oozie MapReduce Job Using Hue
- Submitting an Oozie Sub-workflow Job Using Hue
- Submitting an Oozie Shell Job Using Hue
- Submitting an Oozie HDFS Job Using Hue
- Submitting an Oozie Streaming Job Using Hue
- Submitting an Oozie DistCp Job Using Hue
- Submitting an Oozie SSH Job Using Hue
- Submitting a Coordinator Periodic Scheduling Job Using Hue
- Submitting a Bundle Batch Processing Job Using Hue
- Querying Oozie Job Results on the Hue Page
- Configuring Mutual Trust Between Oozie Nodes
- Enterprise-Class Enhancements of Oozie
- Oozie Log Overview
- Common Issues About Oozie
Using Ranger
- Enabling Ranger Authentication for MRS Cluster Services
- Logging In to the Ranger Web UI
- Adding a Ranger Permission Policy
Configuration Examples for Ranger Permission Policy
- Adding a Ranger Access Permission Policy for CDL
- Adding a Ranger Access Permission Policy for HDFS
- Adding a Ranger Access Permission Policy for HBase
- Adding a Ranger Access Permission Policy for Hive
- Adding a Ranger Access Permission Policy for Yarn
- Adding a Ranger Access Permission Policy for Spark2x
- Adding a Ranger Access Permission Policy for Kafka
- Adding a Ranger Access Permission Policy for HetuEngine
- Adding a Ranger Access Permission Policy for OBS
- Hive Tables Supporting Cascading Authorization
- Viewing Ranger Audit Information
- Configuring Ranger Security Zone
- Viewing Ranger User Permission Synchronization Information
- Ranger Performance Tuning
- Ranger Log Overview
Common Issues About Ranger
- How Do I Determine Whether the Ranger Authentication Is Used for a Service?
- Why Cannot a New User Log In to Ranger After Changing the Password?
- What Should I Do If I Cannot View the Created MRS User on the Ranger Management Page?
- What Should I Do If MRS Users Failed to Be Synchronized to the Ranger Web UI
- Ranger Troubleshooting
Using Spark/Spark2x
- Spark Usage Instruction
- Spark User Permission Management
- Using the Spark Client
- Accessing the Spark Web UI
- Submitting a Spark Job as a Proxy User
- Configuring Spark to Read HBase Data
- Configuring Spark Tasks Not to Obtain HBase Token Information
Spark Core Enterprise-Class Enhancements
- Configuring Spark HA to Enhance HA
- Configuring the Spark Native Engine
- Configuring the Size of the Spark Event Queue
- Configuring the Compression Format of a Parquet Table
- Adapting to the Third-party JDK When Ranger Is Used
- Using the Spark Small File Combination Tool
- Configuring Streaming Reading of Spark Driver Execution Results
- Enabling a Spark Executor to Execute Custom Code When Exiting
- Configuring Spark Dynamic Masking
- Configuring Distinct Aggregation Optimization
- Clearing Residual Files When a Spark Job Fails to Be Configured
- Configuring Spark to Load Third-Party JAR Packages for UDF Registration or SparkSQL Extension
Spark SQL Enterprise-Class Enhancements
- Configuring Vector-based ORC Data Reading
- Filtering Partitions Without Paths in a Partitioned Table
- Configuring the Drop Partition Command to Support Batch Deletion
- Configuring Dynamic Overwriting for Hive Table Partitions
- Configuring Spark SQL to Enable the Adaptive Execution Feature
- Using Spark SQL Statements Without Aggregate Functions for Correlated Subqueries
- Spark Streaming Enterprise-Class Enhancements
Spark Core Performance Tuning
- Spark Core Data Serialization
- Spark Core Memory Tuning
- Setting Spark Core DOP
- Configuring Spark Core Broadcasting Variables
- Configuring Heap Memory Parameters for Spark Executor
- Using the External Shuffle Service to Improve Spark Core Performance
- Configuring Spark Dynamic Resource Scheduling in YARN Mode
- Adjusting Spark Core Process Parameters
- Spark DAG Design Specifications
- Experience Summary
Spark SQL Performance Tuning
- Optimizing the Spark SQL Join Operation
- Improving Spark SQL Calculation Performance Under Data Skew
- Optimizing Spark SQL Performance in the Small File Scenario
- Optimizing the Spark INSERT SELECT Statement
- Configuring Multiple Concurrent Clients to Connect to JDBCServer
- Configuring the Default Number of Data Blocks Divided by SparkSQL
- Optimizing Memory When Data Is Inserted into Spark Dynamic Partitioned Tables
- Optimizing Small Files
- Optimizing the Aggregate Algorithms
- Optimizing Datasource Tables
- Merging CBO
- SQL Optimization for Multi-level Nesting and Hybrid Join
- Spark Streaming Performance Tuning
- Spark on OBS Performance Tuning
Spark O&M Management
- Configuring Spark Parameters Rapidly
- Spark Common Configuration Parameters
- Spark Log Overview
- Obtaining Container Logs of a Running Spark Application
- Changing Spark Log Levels
- Viewing Container Logs on the Web UI
- Configuring the Number of Lost Executors Displayed on the Web UI
- Configuring Local Disk Cache for JobHistory
- Configuring Spark Event Log Rollback
- Enhancing Stability in a Limited Memory Condition
- Configuring Environment Variables in Yarn-Client and Yarn-Cluster Modes
- Broaden Support for Hive Partition Pruning Predicate Pushdown
- Configuring the Column Statistics Histogram for Higher CBO Accuracy
- Using CarbonData for First Query
Common Issues About Spark
Spark Core
- How Do I View Aggregated Spark Application Logs?
- Why Is the Return Code of Driver Inconsistent with Application State Displayed on ResourceManager WebUI?
- Why Cannot Exit the Driver Process?
- Why Does FetchFailedException Occur When the Network Connection Is Timed out
- How to Configure Event Queue Size If Event Queue Overflows?
- What Can I Do If the getApplicationReport Exception Is Recorded in Logs During Spark Application Execution and the Application Does Not Exit for a Long Time?
- What Can I Do If "Connection to ip:port has been quiet for xxx ms while there are outstanding requests" Is Reported When Spark Executes an Application and the Application Ends?
- Why Do Executors Fail to be Removed After the NodeManeger Is Shut Down?
- What Can I Do If the Message "Password cannot be null if SASL is enabled" Is Displayed?
- "Failed to CREATE_FILE" Is Displayed When Data Is Inserted into the Dynamic Partitioned Table Again
- Why Tasks Fail When Hash Shuffle Is Used?
- What Can I Do If the Error Message "DNS query failed" Is Displayed When I Access the Aggregated Logs Page of Spark Applications?
- What Can I Do If Shuffle Fetch Fails Due to the "Timeout Waiting for Task" Exception?
- Why Does the Stage Retry due to the Crash of the Executor?
- Why Do the Executors Fail to Register Shuffle Services During the Shuffle of a Large Amount of Data?
- NodeManager OOM Occurs During Spark Application Execution
Spark SQL and DataFrame
- What Do I have to Note When Using Spark SQL ROLLUP and CUBE?
- Why Spark SQL Is Displayed as a Temporary Table in Different Databases?
- How to Assign a Parameter Value in a Spark Command?
- What Directory Permissions Do I Need to Create a Table Using SparkSQL?
- Why Do I Fail to Delete the UDF Using Another Service?
- Why Cannot I Query Newly Inserted Data in a Parquet Hive Table Using SparkSQL?
- How to Use Cache Table?
- Why Are Some Partitions Empty During Repartition?
- Why Does 16 Terabytes of Text Data Fails to Be Converted into 4 Terabytes of Parquet Data?
- How Do I Rectify the Exception Occurred When I Perform an Operation on the Table Named table?
- Why Is a Task Suspended When the ANALYZE TABLE Statement Is Executed and Resources Are Insufficient?
- If I Access a parquet Table on Which I Do not Have Permission, Why a Job Is Run Before "Missing Privileges" Is Displayed?
- Why Is "RejectedExecutionException" Displayed When I Exit Spark SQL?
- How Do I Do If I Incidentally Kill the JDBCServer Process During Health Check?
- Why No Result Is found When 2016-6-30 Is Set in the Date Field as the Filter Condition?
- Why Is the "Code of method ... grows beyond 64 KB" Error Message Displayed When I Run Complex SQL Statements?
- Why Is Memory Insufficient if 10 Terabytes of TPCDS Test Suites Are Consecutively Run in Beeline/JDBCServer Mode?
- Why Functions Cannot Be Used When Different JDBCServers Are Connected?
- Why Does an Exception Occur When I Drop Functions Created Using the Add Jar Statement?
- Why Does Spark2x Have No Access to DataSource Tables Created by Spark1.5?
- Why Cannot I Query Newly Inserted Data in an ORC Hive Table Using Spark SQL?
Spark Streaming
- Same DAG Log Is Recorded Twice for a Streaming Task
- What Can I Do If Spark Streaming Tasks Are Blocked?
- What Should I Pay Attention to When Optimizing Spark Streaming Task Parameters?
- Why Does the Spark Streaming Application Fail to Be Submitted After the Token Validity Period Expires?
- Why Does the Spark Streaming Application Fail to Be Started from the Checkpoint When the Input Stream Has No Output Logic?
- Why Is the Input Size Corresponding to Batch Time on the Web UI Set to 0 Records When Kafka Is Restarted During Spark Streaming Running?
- What Should I Do If Recycle Bin Version I Set on the Spark Client Does Not Take Effect?
- How Do I Change the Log Level to INFO When Using Spark yarn-client?
Spark Core
Spark Troubleshooting
- Why the Job Information Obtained from the restful Interface of an Ended Spark Application Is Incorrect?
- Why Cannot I Switch from the Yarn Web UI to the Spark Web UI?
- What Can I Do If an Error Occurs when I Access the Application Page Because the Application Cached by HistoryServer Is Recycled?
- Apps Cannot Be Displayed on the JobHistory Page When an Empty Part File Is Loaded
- Why Does Spark Fail to Export a Table with the Same Field Name?
- Why JRE fatal error after running Spark application multiple times?
- Native Spark2x UI Fails to Be Accessed or Is Incorrectly Displayed when Internet Explorer Is Used for Access
- How Does Spark2x Access External Cluster Components?
- Why Does the Foreign Table Query Fail When Multiple Foreign Tables Are Created in the Same Directory?
- Why Is the Native Page of an Application in Spark2x JobHistory Displayed Incorrectly?
- Why Do I Fail to Create a Table in the Specified Location on OBS After Logging to spark-beeline?
- Spark Shuffle Exception Handling
- Why Cannot Common Users Log In to the Spark Client When There Are Multiple Service Scenarios in Spark?
- Why Does the Cluster Port Fail to Connect When a Client Outside the Cluster Is Installed or Used?
- How Do I Handle the Exception Occurred When I Query Datasource Avro Formats?
- What Should I Do If Statistics of Hudi or Hive Tables Created Using Spark SQLs Are Empty Before Data Is Inserted?
- Failed to Query Table Statistics by Partition Using Non-Standard Time Format When the Partition Column in the Table Creation Statement is timestamp
- How Do I Use Special Characters with TIMESTAMP and DATE?
- Using Sqoop
- Using Tez
Using YARN
- Yarn User Permission Management
- Submitting a Task Using the Yarn Client
- Configuring Container Log Aggregation
- Enabling Yarn CGroups to Limit the Container CPU Usage
- Configuring HA for TimelineServer
Enterprise-Class Enhancements of Yarn
- Configuring the Yarn Permission Control
- Specifying the User Who Runs Yarn Tasks
- Configuring the Number of ApplicationMaster Retries
- Configure the ApplicationMaster to Automatically Adjust the Allocated Memory
- Configuring ApplicationMaster Work Preserving
- Configuring the Access Channel Protocol
- Configuring the Additional Scheduler WebUI
- Configuring Resources for a NodeManager Role Instance
- Configuring Yarn Restart
- Yarn Performance Tuning
- Yarn O&M Management
Common Issues About Yarn
- Why Mounted Directory for Container is Not Cleared After the Completion of the Job While Using CGroups?
- Why the Job Fails with HDFS_DELEGATION_TOKEN Expired Exception?
- Why Are Local Logs Not Deleted After YARN Is Restarted?
- Why the Task Does Not Fail Even Though AppAttempts Restarts for More Than Two Times?
- Why Is an Application Moved Back to the Original Queue After ResourceManager Restarts?
- Why Does Yarn Not Release the Blacklist Even All Nodes Are Added to the Blacklist?
- Why Does the Switchover of ResourceManager Occur Continuously?
- Why Does a New Application Fail If a NodeManager Has Been in Unhealthy Status for 10 Minutes?
- Why Does an Error Occur When I Query the ApplicationID of a Completed or Non-existing Application Using the RESTful APIs?
- Why May A Single NodeManager Fault Cause MapReduce Task Failures in the Superior Scheduling Mode?
- Why Are Applications Suspended After They Are Moved From Lost_and_Found Queue to Another Queue?
- How Do I Limit the Size of Application Diagnostic Messages Stored in the ZKstore?
- Why Does a MapReduce Job Fail to Run When a Non-ViewFS File System Is Configured as ViewFS?
- Why Do Reduce Tasks Fail to Run in Some OSs After the Native Task Feature is Enabled?
Using ZooKeeper
- Using ZooKeeper from Scratch
- Configuring the ZooKeeper Permissions
- ZooKeeper Common Configuration Parameters
- ZooKeeper Log Overview
Common Issues About ZooKeeper
- Why Do ZooKeeper Servers Fail to Start After Many znodes Are Created?
- Why Does the ZooKeeper Server Display the java.io.IOException: Len Error Log?
- Why Four Letter Commands Don't Work With Linux netcat Command When Secure Netty Configurations Are Enabled at Zookeeper Server?
- How Do I Check Which ZooKeeper Instance Is a Leader?
- Why Cannot the Client Connect to ZooKeeper using the IBM JDK?
- What Should I Do When the ZooKeeper Client Fails to Refresh a TGT?
- Why Is Message "Node does not exist" Displayed when A Large Number of Znodes Are Deleted Using the deleteallCommand
- Appendix
Using CarbonData
Component Operation Guide (Normal)
- Using Alluxio
- Using CarbonData (for Versions Earlier Than MRS 3.x)
Using CarbonData (for MRS 3.x or Later)
- CarbonData Syntax Reference
- CarbonData Troubleshooting
CarbonData FAQs
- Why Does the Missing Privileges Exception Occur When the Database Is Dropped?
- Why Does Data Query or Loading Fail and "org.apache.carbondata.core.memory.MemoryException: Not enough memory" Is Displayed?
Using ClickHouse
- Using the ClickHouse Client
- Creating a ClickHouse Table
- ClickHouse Data Import
- Enterprise-Class Enhancements of ClickHouse
- ClickHouse O&M Management
ClickHouse FAQ
- Using DBService
Using Flink
- Flink Job Engine
- Creating a FlinkServerJob
- Managing FlinkServer Jobs
- Example of Issuing a Certificate
Using Flume
Using HBase
- Creating HBase Roles
- Quickly Using HBase for Offline Data Analysis
- Enterprise-Class Enhancements of HBase
- HBase Performance Tuning
- What Should I Do If HMaster Exits Due to Timeout When Waiting for the Namespace Table to Go Online?
- What Should I Do If Error Message "java.lang.UnsatisfiedLinkError: Permission denied" Is Displayed When I Start the HBase Shell?
- When Will the" Dead Region Servers" Information Displayed on the HMaster Web UI Be Cleared After a RegionServer Is Stopped?
- What Can I Do If a Message Indicating Insufficient Permission Is Displayed When I Access HBase Phoenix?
- What Can I Do If a Message Indicating Insufficient Permission Is Displayed When a Tenant Uses HBase BulkLoad?
- How Do I Restore an HBase Region in Overlap State?
- Phoenix BulkLoad Use Restrictions
- The HBase Client Failed to Connect to the Server for a Long Time
- An Exception Occurred When HBase Deletes and Creates a Table Consecutively
- Other Services Are Unstable When Too Many HBase Connections Occupy the Network Ports
- HBase BulkLoad Tasks of 210,000 Map Tasks and 10,000 Reduce Tasks failed To Be Executed
- Modified and Deleted Data Can Still Be Queried by the Scan Command
- Failed to Create Tables When the Region is in FAILED_OPEN State
- How to Delete the residual Table Name on the ZooKeeper table-lock Node After a Table Creation Failure
- HBase Become Faulty When I Set a Quota for the Directory Used by HBase in HDFS
- HMaster Failed to Be Started After the OfflineMetaRepair Tool Is Used to Rebuild Metadata
- FileNotFoundException Is Frequently Printed in HMaster Logs
- "Permission denied" Was Displayed When the ImportTsv Tool Failed to Run
- Data Is Successfully Imported Using HBase BulkLoad, but Different Results May Be Returned To the Same Query
- HBase Data Restoration Task Failed to Be Rolled Back
- RegionServer Failed to Be Started When GC Parameters Xms and Xmx of HBase RegionServer Are Set to 31 GB
- When LoadIncrementalHFiles Is Used to Import Data in Batches on Cluster Nodes, the Insufficient Permission Error Is Reported
- "import argparse" Is Reported When the Phoenix Sqlline Script Is Used
Using HDFS
- Using Hadoop
- Configuring HDFS Disk Balancing
- Using HDFS Mover to Migrate Data
- Configuring the Label Policy (NodeLabel) for HDFS File Directories
- Configuring NameNode Memory Parameters
- Setting the Number Limit of HBase and HDFS Handles
- Enterprise-Class Enhancements of HDFS
- Improving HDFS Write Performance
- Improving Read Performance By HDFS Client Metadata Caching
- Improving the HDFS Client Connection Performance with Active NameNode Caching
- Optimization for Unstable HDFS Network
- Using the LZC Compression Algorithm to Store HDFS Files
HDFS O&M Management
- HDFS Common Configuration Parameters
- HDFS Log Overview
- Viewing the HDFS Capacity
- Changing the DataNode Storage Directory
- Adjusting Parameters Related to Damaged DataNode Disk Volumes
- Configuring the Maximum Lifetime of an HDFS Token
- Using DistCp to Copy HDFS Data Across Clusters
- Configuring the NFS Server to Store NameNode Metadata
- What Should I Do If an Error Is Reported When I Run DistCp Commands?
- What Should I Do If the HDFS Web UI Cannot Update the Information About the Damaged Data?
- What Should I Do If the HDFS Client Is Irresponsive When the NameNode Is Overloaded for a Long Time?
- Why Does DataNode Fail to Report Data Blocks?
- Can I Modify the DataNode Data Storage Directory?
- What Can I Do If the DataNode Capacity Is Incorrectly Calculated?
- Why Is Data in the Cache Lost When Small Files Are Stored?
- Why Some Blocks Are Missing on the NameNode UI?
- Why Is "java.net.SocketException" Reported When Data Is Written to HDFS
- It Takes a Long Time to Restart NameNode After a Large Number of Files Are Deleted
- The standby NameNode Fails to Be Started After It Is Powered Off During Metadata Storage
- DataNode Fails to Be Started When the Number of Disks Defined in dfs.datanode.data.dir Equals the Value of dfs.datanode.failed.volumes.tolerated
- "ArrayIndexOutOfBoundsException: 0" Occurs When HDFS Invokes getsplit of FileInputFormat
Using Hive
- Hive on HBase
Enterprise-Class Enhancement of Hive
- How Do I Delete All Permanent Functions from HiveServer?
- Why Cannot the DROP Operation Be Performed on a Backed Up Hive Table?
- What Are the Special Characters Not Supported by Hive in Complex Field Names?
- How Do I Handle a Slow Hive on Spark Task When HBase Is Not Installed?
- What Should I Do If an Error Is Reported When the WHERE Condition Is Used to Query Tables with Excessive Partitions in Hive?
- Does the Location of a Hive Table Support Cross-OBS and Cross-HDFS Paths?
- What Should I Do If the MapReduce Engine Cannot Query the Data Written by the Union Statement Running on Tez?
- Does Hive Support Concurrent Data Writing to the Same Table or Partition?
- What Should I Do If the Task Fails When the HDFS Data Directory of the Hive Table Is Deleted By Mistake, But The Metadata Still Exists?
- Why Is the OBS Quick Deletion Directory Not Applied After Being Added to the Custom Hive Configuration?
- Hive Configuration Problems
Using Hudi
- Data Management and Maintenance
Data Write
- Parquet/Avro schema Is Reported When Updated Data Is Written
- Data Collection
- Hive Synchronization
Data Write
- Using Hue (Versions Earlier Than MRS 3.x)
Using Hue (MRS 3.x or Later)
- Using Hue WebUI to Operate Hive Tables
- Typical Application Scenarios of the Hue Web UI
- Typical Hue Configurations
- Hue Log Overview
- Why Do HQL Statements Fail to Execute in Hue Using Internet Explorer?
- How Do I Solve the Problem of Setting the Time Zone of the Oozie Editor on the Hue Web UI?
- Using Impala
Using Kafka
- Kafka Data Consumption
- Kafka User Permission Management
- Using the Kafka Client
- Quickly Using Kafka to Produce and Consume Data
- Creating a Kafka Topic
- Checking the Consumption Information of Kafka Topics
- Managing Kafka Topics
- Enterprise-Class Enhancements of Kafka
- Kafka Performance Tuning
- Kafka O&M Management
- Common Issues About Kafka
- Using KafkaManager
Using Loader
- Using Loader from Scratch
- How to Use Loader
- Common Loader Parameters
- Creating a Loader Role
- Loader Link Configuration
- Managing Loader Links (Versions Earlier Than MRS 3.x)
- Managing Loader Links (MRS 3.x and Later Versions)
- Source Link Configurations of Loader Jobs
- Destination Link Configurations of Loader Jobs
- Preparing a Driver for MySQL Database Link
Importing Data
- Overview
- Importing Data Using Loader
- Typical Scenario: Importing Data from an SFTP Server to HDFS or OBS
- Typical Scenario: Importing Data from an SFTP Server to HBase
- Typical Scenario: Importing Data from an SFTP Server to Hive
- Typical Scenario: Importing Data from an FTP Server to HBase
- Typical Scenario: Importing Data from a Relational Database to HDFS or OBS
- Typical Scenario: Importing Data from a Relational Database to HBase
- Typical Scenario: Importing Data from a Relational Database to Hive
- Typical Scenario: Importing Data from HDFS or OBS to HBase
- Typical Scenario: Importing Data from a Relational Database to ClickHouse
- Typical Scenario: Importing Data from HDFS to ClickHouse
Exporting Data
- Overview
- Typical Scenario: Exporting Data from HDFS or OBS to an SFTP Server
- Typical Scenario: Exporting Data from HBase to an SFTP Server
- Typical Scenario: Exporting Data from Hive to an SFTP Server
- Typical Scenario: Exporting Data from HDFS or OBS to a Relational Database
- Typical Scenario: Exporting Data from HBase to a Relational Database
- Typical Scenario: Exporting Data from Hive to a Relational Database
- Typical Scenario: Importing Data from HBase to HDFS or OBS
- Managing Jobs
- Operator Help
Client Tools
- Example for Using the Open-Source sqoop-shell Tool (SFTP-HDFS)
- Example for Using the Open-Source sqoop-shell Tool (Oracle-HBase)
- Loader Log Overview
- Example: Using Loader to Import Data from OBS to HDFS
- Common Issues About Loader
- Using Kudu
Using MapReduce
- Configuring the Distributed Cache to Execute MapReduce Jobs
- Submitting a MapReduce Task on Windows
- MapReduce Optimization Configuration for Multiple CPU Cores
- Configuring the Baseline Parameters for MapReduce Jobs
- MapReduce Shuffle Tuning
- AM Optimization for Big MapReduce Tasks
- Configuring Speculative Execution for MapReduce Tasks
- Tuning MapReduce Tasks Using Slow Start
- Optimizing the Commit Phase of MapReduce Tasks
- Improving MapReduce Client Task Reliability
- MapReduce Log Overview
- How Do I Handle the Problem that MapReduce Task Has No Progress for a Long Time?
- Why Is the Client Unavailable When a Task Is Running?
- What Should I Do If HDFS_DELEGATION_TOKEN Cannot Be Found in the Cache?
- What Should I Do If MapReduce Job Information Cannot Be Opened Through Tracking URL on the ResourceManager Web UI?
- Why MapReduce Tasks Fails in the Environment with Multiple NameServices?
- What Should I Do If the Partition-based Task Blacklist Is Abnormal?
- Using OpenTSDB
Using Oozie
- Using Oozie Client to Submit an Oozie Job
- Submitting an Oozie Sub Workflow Job Using Hue
- Submitting an Oozie Distcp Job Using Hue
- Querying Oozie Job Results on the Hue Web UI
- Enabling Oozie High Availability (HA)
- Using Presto
- Using Ranger (MRS 1.9.2)
Using Ranger (MRS 3.x)
- Adding a Ranger Access Permission Policy for Impala
- Adding a Ranger Access Permission Policy for Storm
- Changing the Ranger Data Source to LDAP for a Normal Cluster
- Why Ranger Startup Fails During the Cluster Installation?
- When an HBase Policy Is Added or Modified on Ranger, Wildcard Characters Cannot Be Used to Search for Existing HBase Tables
- Why Can't I View the Created MRS User on the Ranger Management Page?
- What Should I Do If MRS Users Failed to Be Synchronized to the Ranger Web UI?
- Using Spark (for Versions Earlier Than MRS 3.x)
Using Spark2x (for MRS 3.x or Later)
- Spark Core Enterprise-Class Enhancements
- Spark SQL Enterprise-Class Enhancements
- Experience
- Optimizing Memory when Data Is Inserted into Dynamic Partitioned Tables
- Merging CBO
- Configuring Parameters Rapidly
- Common Parameters
- Spark2x Logs
- Configuring the Number of Lost Executors Displayed in WebUI
- Configuring the Column Statistics Histogram to Enhance the CBO Accuracy
Common Issues About Spark2x
Spark Core
- Why Does the Realm Information Fail to Be Obtained When SparkBench is Run on HiBench for the Cluster in Security Mode?
- Why Do I Fail to Modify MetaData by Running the Hive Command?
- Why Does the --hivevar Option I Specified in the Command for Starting spark-beeline Fail to Take Effect?
Spark Streaming
- Why Is not an Application Displayed When I Run the Application with the Empty Part File?
- Why Does Spark2x Fail to Export a Table with the Same Field Name?
Spark Core
Using Sqoop
- Using Sqoop from Scratch
- Adapting Sqoop 1.4.7 to MRS 3.x Clusters
- Common Sqoop Commands and Parameters
Common Issues About Sqoop
- What Should I Do If Class QueryProvider Is Unavailable?
- What Should I Do If Method getHiveClient Does Not Exist?
- How Do I Do If PostgreSQL or GaussDB Fails to Connect?
- What Should I Do If Data Failed to Be Synchronized to a Hive Table on the OBS Using hive-table?
- What Should I Do If Data Failed to Be Synchronized to an ORC or Parquet Table Using hive-table?
- What Should I Do If Data Failed to Be Synchronized Using hive-table?
- What Should I Do If Data Failed to Be Synchronized to a Hive Parquet Table Using HCatalog?
- What Should I Do If the Data Type of Fields timestamp and data Is Incorrect During Data Synchronization Between Hive and MySQL?
Using Storm
- Using Storm from Scratch
- Using the Storm Client
- Submitting Storm Topologies on the Client
- Accessing the Storm Web UI
- Managing Storm Topologies
- Querying Storm Topology Logs
- Storm Common Parameters
- Configuring a Storm Service User Password Policy
- Migrating Storm Services to Flink
- Storm Log Introduction
- Performance Tuning
- Using Tez
Using YARN
- YARN User Permission Management
Enterprise-Class Enhancement of YARN
- YARN O&M Management
Using ZooKeeper
- Common ZooKeeper Parameters
- Appendix
Best Practices
Data Analytics
- Using Spark2x to Analyze IoV Drivers' Driving Behavior
- Using Hive to Load HDFS Data and Analyze Book Scores
- Using Hive to Load OBS Data and Analyze Enterprise Employee Information
- Using Flink Jobs to Process OBS Data
- Consuming Kafka Data Using Spark Streaming Jobs
- Using Flume to Collect Log Files from a Specified Directory to HDFS
- Kafka-based WordCount Data Flow Statistics Case
Data Migration
- Data Migration Solution
- Information Collection Before Data Migrated to MRS
- Preparing the Network Before Data Migration to MRS
- Migrating Data from Hadoop to MRS
- Migrating Data from HBase to MRS
- Migrating Data from Hive to MRS
- Using BulkLoad to Import Data to HBase in Batches
- Migrating MySQL Data to MRS Hive with CDM
- Migrating Data from MRS HDFS to OBS with CDM
- Interconnection with Other Cloud Services
Interconnection with Ecosystem Components
- Using DBeaver to Access Phoenix
- Using DBeaver to Access HetuEngine
- Using Tableau to Access HetuEngine
- Using Yonghong BI to Access HetuEngine
- Interconnecting Hive with External Self-Built Relational Databases
- Interconnecting Hive with External LDAP
- Interconnecting MRS Kafka with Kafka Eagle
- Using Jupyter Notebook to Connect to MRS Spark
- MRS Cluster Management
Data Analytics
Developer Guide
Developer Guide (LTS)
- Introduction to MRS Application Development
- Obtaining the MRS Application Development Sample Project
- MRS Application Security Authentication Description
- Preparing MRS Application Development User
- Rapidly Develop MRS Component Applications
- ClickHouse Development Guide (Security Mode)
- ClickHouse Development Guide (Normal Mode)
Flink Development Guide (Security Mode)
- Flink Application Development Overview
- Flink Application Development Process
- Environment Preparation
Developing a Flink Application
- Flink DataStream Sample Program
- Flink Kafka Sample Program
- Sample Program for Starting Checkpoint on Flink
- Flink Job Pipeline Sample Program
- Flink Join Sample Program
- Flink Jar Job Submission SQL Sample Program
- FlinkServer REST API Sample Program
- Flink Sample Program for Reading HBase Tables
- Sample Program for Reading Hudi Tables on Flink
- PyFlink Sample Program
- Commissioning the Flink Application
FAQs in Flink Application Development
- Common Flink APIs
- What If the Chrome Browser Cannot Display the Title
- What If the Page Is Displayed Abnormally on Internet Explorer 10/11
- What If Checkpoint Is Executed Slowly in RocksDBStateBackend Mode When the Data Amount Is Large
- What If yarn-session Start Fails When blob.storage.directory Is Set to /home
- Why Does Non-static KafkaPartitioner Class Object Fail to Construct FlinkKafkaProducer010?
- When I Use a Newly Created Flink User to Submit Tasks, Why Does the Task Submission Fail and a Message Indicating Insufficient Permission on ZooKeeper Directory Is Displayed?
- Why Cannot I Access the Apache Flink Dashboard?
- How Do I View the Debugging Information Printed Using System.out.println or Export the Debugging Information to a Specified File?
- Incorrect GLIBC Version
Flink Development Guide (Normal Mode)
- Overview
Developing an Application
- DataStream Application
- Interconnecting with Kafka
- Asynchronous Checkpoint Mechanism
- Job Pipeline Program
- Stream SQL Join Program
- Flink Reading Data from and Writing Data to HBase
- Debugging the Application
More Information
- Introduction to Common APIs
- Overview of RESTful APIs
- Overview of Savepoints CLI
- Introduction to Flink Client CLI
FAQ
- Savepoints-related Problems
HBase Development Guide (Security Mode)
- Overview
HBase data read/write sample program
- Typical Scenario Description
- Development Idea
- Creating Configuration
- Creating Connection
- Creating a Table
- Deleting a Table
- Inserting Data
- Deleting Data
- Modifying a Table
- Reading Data Using Get
- Reading Data Using Scan
- Filtering Data
- Creating a Secondary Index
- Deleting an Index
- Secondary Index-based Query
- Multi-Point Region Division
- Creating a Phoenix Table
- Writing Data to the PhoenixTable
- Reading the PhoenixTable
- Using HBase Dual-Read
- Configuring Log4j Log Output
- HBase Rest API Invoking Sample Program
- Accessing the HBase ThriftServer Sample Program
- Sample Program for HBase to Access Multiple ZooKeepers
- Application Commissioning
More Information
- SQL Query
- HBase Dual-Read Configuration Items
- External Interfaces
- Phoenix Command Line
- How to Rectify the Fault When an Exception Occurs During the Running of an HBase-developed Application and "org.apache.hadoop.hbase.ipc.controller.ServerRpcControllerFactory" Is Displayed in the Error Information?
- What Are the Application Scenarios of the Bulkload and put Data-loading Modes?
- An Error Occurred When Building a JAR Package
HBase Development Guide (Normal Mode)
- Overview
HBase Data Read/Write Sample Program
- Development Idea
- Creating a Table
- Deleting a Table
- Modifying a Table
- Inserting Data
- Deleting Data
- Filtering Data
- Deleting an Index
More Information
- SQL Query
- What Are the Application Scenarios of the bulkload and put Data-loading Modes?
- HDFS Development Guide (Security Mode)
- HDFS Development Guide (Normal Mode)
HetuEngine Development Guide (Security Mode)
- Overview
- Application Development
- HetuEngine Development Guide (Normal Mode)
- Hive Development Guide (Security Mode)
- Hive Development Guide (Normal Mode)
IoTDB Development Guide (Security Mode)
- Overview
- Environment Preparations
- More Information
IoTDB Development Guide (Normal Mode)
- Overview
- More Information
- Kafka Development Guide (Security Mode)
- Kafka Development Guide (Normal Mode)
- MapReduce Development Guide (Security Mode)
- MapReduce Development Guide (Normal Mode)
- Oozie Development Guide (Security Mode)
- Oozie Development Guide (Normal Mode)
Spark2x Development Guide (Security Mode)
- Spark Application Development Overview
- Spark Application Development Process
- Preparing a Spark Application Development Environment
Developing Spark Applications
- Spark Core Sample Projects
- Spark SQL Sample Projects
- Sample Projects for Accessing Spark SQL Through JDBC
Sample Projects for Spark to Read HBase Tables
- Operating Data in Avro Format
- Performing Operations on the HBase Data Source
- Using the BulkPut API
- Using the BulkGet API
- Using the BulkDelete API
- Using the BulkLoad API
- Using the foreachPartition API
- Distributedly Scanning HBase Tables
- Using the mapPartition API
- Writing Data to HBase Tables In Batches Using Spark Streaming
- Sample Projects for Spark to Implement Bidirectional Data Exchange with HBase
- Sample Projects for Spark to Implement Data Transition Between Hive and HBase
- Sample Projects for Connecting Spark Streaming to Kafka0-10
- Spark Structured Streaming Sample Projects
- Sample Project for Interconnecting Spark Structured Streaming with Kafka
- Sample Project for Spark Structured Streaming Status Operations
- Sample Project for Spark Concurrent Access to Two HBase Sample Projects
- Sample Project for Spark to Synchronize HBase Sata to CarbonData
- Using Spark to Execute the Hudi Sample Project
- Sample Project for Customizing Configuration Items in Hudi
- Commissioning a Spark Application
FAQs About Spark Application Development
- Common Spark APIs
- Structured Streaming Functions and Reliability
- How to Add a User-Defined Library
- How to Automatically Load Jars Packages?
- Why the "Class Does not Exist" Error Is Reported While the SparkStreamingKafka Project Is Running?
- Privilege Control Mechanism of SparkSQL UDF Feature
- Why Does Kafka Fail to Receive the Data Written Back by SLog in to the node where the client is installed as the client installation user.park Streaming?
- Why a Spark Core Application Is Suspended Instead of Being Exited When Driver Memory Is Insufficient to Store Collected Intensive Data?
- Why the Name of the Spark Application Submitted in Yarn-Cluster Mode Does not Take Effect?
- How Do I Perform Remote Debugging Using IDEA?
- How Do I Submit the Spark Application Using Java Commands?
- A Message Stating "Problem performing GSS wrap" Is Displayed When IBM JDK Is Used
- Why Does the ApplicationManager Fail to Be Terminated When Data Is Being Processed in the Structured Streaming Cluster Mode?
- Restrictions on Restoring the Spark Application from the Checkpoint
- Support for Third-party JAR Packages on x86 and TaiShan Platforms
- What Should I Do If a Large Number of Directories Whose Names Start with blockmgr- or spark- Exist in the /tmp Directory on the Client Installation Node?
- Error Code 139 Reported When Python Pipeline Runs in the ARM Environment
- What Should I Do If the Method of Submitting Structured Streaming Tasks Is Changed?
- Common JAR File Conflicts
Spark2x Development Guide (Common Mode)
- Common Spark APIs
- Why the "Class Does not Exist" Error Is Reported While the SparkStresmingKafka Project Is Running?
- Why Does Kafka Fail to Receive the Data Written Back by Spark Streaming?
- YARN Development Guide (Security Mode)
- YARN Development Guide (Normal Mode)
Manager Management Development Guide
- Overview
- Developing an Application
More Information
FAQ
- JDK1.6 Fails to Connect to the FusionInsight System Using JDK1.8
- An Operation Fails and "authorize failed" Is Displayed in Logs
- An Operation Fails and "log4j:WARN No appenders could be found for logger(basicAuth.Main)" Is Displayed in Logs
- An Operation Fails and "illegal character in path at index 57" Is Displayed in Logs
- Run the curl Command to Access REST APIs
- Using Open-source JAR File Conflict Lists
- Mapping Between Maven Repository JAR Versions and MRS Component Versions
Developer Guide (Normal_3.x)
- Sample Projects of MRS Components
- Security Authentication
- Overview
More Information
FAQ
- Overview
More Information
FAQ
- Overview
- Preparing the Development Environment
- Preparing the Configuration Files for Connecting to the Cluster
- Configuring and Importing a Sample Project
Preparing for Security Authentication
- Security Authentication for HBase Data Read and Write (Single-Cluster Scenario)
- HBase Service Data Read/Write Example Security Authentication (Multi-Cluster Mutual Trust Scenario)
- Accessing HBase REST Service Security Authentication
- Authentication for Accessing the ThriftServer Service
- Authentication for Accessing Multiple ZooKeepers
Reading/Writing Data
- Development Idea
- Creating a Table
- Deleting a Table
- Modifying a Table
- Inserting Data
- Deleting Data
- Filtering Data
- Deleting an Index
- Using HBase Dual-Read Capability
- Calling REST Interfaces
- Accessing HBase ThriftServer
- Accessing Multiple ZooKeepers with HBase
More Information
- SQL Query
- HBase Access Configuration on Windows Using EIPs
- Overview
- Service Scenario Description
- Application Development Approach
- Creating a Table
- Deleting a Table
- Modifying a Table
- Inserting Data
- Deleting Data
- Filtering Data
- Deleting an Index
More Information
- SQL Query
- HBase of the Cluster in Normal Mode Access Configuration on Windows Using EIPs
- HDFS Application Development Overview
- HDFS Application Development Process
- HDFS Sample Project
- Preparing an HDFS Application Development Environment
Developing an HDFS Application
- HDFS Application Development Approach
- Initializing the HDFS
- Creating an HDFS Directories
- Writing Data into an HDFS File
- Appending Data to an HDFS File
- Reading Data from an HDFS File
- Deleting a File
- Deleting Directories
- Multi-Thread Tasks
- Setting Storage Policies
- Configuring the HDFS Colocation Policy
- Commissioning an HDFS Application
- FAQs in HDFS Application Development
- Deleting a File
- Overview
- Preparing the Environment
- More Information
- Impala Development Guide (Security Mode)
- Impala Development Guide (Normal Mode)
- Kudu Development Guide (Security Mode)
- Kudu Development Guide (Normal Mode)
- Introduction to Spark Application Development
- Spark2x Sample Project
- Preparing a Local Application Development Environment
- Preparing the Configuration File for Connecting Spark to the Cluster
- Importing and Configuring Spark Sample Projects
- (Optional) Creating Spark Sample Projects
- Configuring Security Authentication for Spark Applications
- Configuring the Spark Python3 Sample Project
Developing a Spark Application
- Performing Operations on Data in Avro Format
- Using the BulkPut Interface
- Using the BulkGet Interface
- Using the BulkDelete Interface
- Using the BulkLoad Interface
- Using the foreachPartition Interface
- Using the mapPartition Interface
- Writing Data to HBase Tables In Batches Using SparkStreaming
- Common Spark APIs
- How to Perform Remote Debugging Using IDEA?
- How to Submit the Spark Application Using Java Commands?
- Application Fails When ApplicationManager Is Terminated During Data Processing in the Cluster Mode of Structured Streaming
- Restrictions on Restoring the Spark Application from the checkpoint
- What Should I Do If the Structured Streaming Task Submission Way Is Changed?
Spark2x Development Guide (Normal Mode)
- Performing Operation on Data in Avro Format
- Common Spark APIs
Storm Development Guide (Security Mode)
- Overview
- Running an Application
- More Information
Storm Development Guide (Normal Mode)
- Overview
- More Information
Developer Guide (Normal_Earlier Than 3.x)
- Alluxio Development Guide
- Preparing a Flink Application Development Environment
- Developing Flink Applications
- Commissioning a Flink Application
FAQs About Flink Application Development
- Flink Savepoints CLI
- Flink Client CLI
- Flink Performance Tuning Suggestions
- Savepoints FAQs
- What Should I Do If Running a Checkpoint Is Slow When RocksDBStateBackend is Set for the Checkpoint and a Large Amount of Data Exists?
- What Should I Do If yarn-session Failed to Be Started When blob.storage.directory Is Set to /home?
- When I Use the Newly-Created Flink User to Submit Tasks, Why Does the Task Submission Fail and a Message Indicating Insufficient Permission on ZooKeeper Directory Is Displayed?
- Why Can't I Access the Flink Web Page?
- HBase Application Development Overview
- Preparing an HBase Application Development Environment
Developing an HBase Application
- HBase Development Plan
- Creating the Configuration Object
- Creating a Connection Object
- Creating an HBase Table
- Deleting an HBase Table
- Modifying an HBase Table
- Inserting HBase Data
- Deleting HBase Data
- Reading HBase Data Using the GET Command
- Reading HBase Data Using the Scan Command
- Using an HBase Filter
- Adding an HBase Secondary Index
- Enabling or Disabling an HBase Secondary Index
- Querying the HBase Secondary Index List
- Using an HBase Secondary Index to Read Data
- Deleting an HBase Secondary Index
- HBase Multi-Point Region Splitting
- Configuring HBase ACL Security Policies
- Commissioning an HBase Application
- FAQs About HBase Application Development
- Kafka Application Development Overview
- Preparing a Kafka Application Development Environment
Developing a Kafka Application
- Kafka Development Plan
- Kafka Old Producer API Usage Sample
- Kafka Old Consumer API Usage Sample
- Kafka Producer API Usage Sample
- Kafka Consumer API Usage Sample
- Kafka Multi-Thread Producer API Usage Sample
- Kafka Multi-Thread Consumer API Usage Sample
- Kafka SimpleConsumer API Usage Sample
- Kafka Configuration File
- Commissioning a Kafka Application
- FAQs About Kafka Application Development
- OpenTSDB Development Guide
- Presto Development Guide
Spark Development Guide
- Spark Application Development Environment
- Preparing a Spark Application Development User
- Preparing a Java Development Environment for Spark
- Preparing a Scala Development Environment for Spark
- Preparing a Python Development Environment for Spark
- Preparing a Spark Application Running Environment
- (Optional) Creating a Spark Application Development Project
- Spark Core Application
- Spark SQL Application
- Spark Streaming Application
- Application for Accessing Spark SQL Through JDBC
- Spark on HBase Application
- Reading Data from HBase and Writing Data Back to HBase
- Reading Data from Hive and Write Data to HBase
- Using Streaming to Read Data from Kafka and Write Data to HBase
- Application for Connecting Spark Streaming to Kafka0-10
- Structured Streaming Application
- Spark APIs
Spark Application Tuning
Spark Core Tuning
- Data Serialization
- Memory Configuration Optimization
- Setting a Degree of Parallelism
- Using Broadcast Variables
- Using the External Shuffle Service to Improve Performance
- Configuring Dynamic Resource Scheduling in Yarn Mode
- Configuring Process Parameters
- Designing a Direction Acyclic Graph (DAG)
- SQL and DataFrame Tuning
- Spark Streaming Tuning
- Spark CBO Tuning
Spark Core Tuning
- How Do I Add a Dependency Package with Customized Codes?
- How Do I Handle the Dependency Package That Is Automatically Loaded?
- How Does the Permission Control Mechanism Work for the UDF Function in SparkSQL?
- What Should I Do If FileNotFoundException Occurs When spark-submit Is Used to Submit a Job in Spark on Yarn Client Mode?
- What Should I Do If the "had a not serializable result" Error Is Reported When a Spark Task Reads HBase Data?
- How Do I Connect to Hive and HDFS of an MRS Cluster when the Spark Program Is Running on a Local Host?
- Storm Development Guide
Component Development Specifications
- ClickHouse
- Doris
- Flink
- HBase
- HDFS
- Hive
Hudi
- Hudi Development Specifications Overview
- Hudi Data Sheet Design Specification
- Hudi Data Table Management Operation Specifications
Spark on Hudi Development Specifications
Spark Read/Write Hudi Development Specifications
- SparkSQL table creation parameter specifications
- Specifications for Spark to read Hudi parameters in incremental mode
- Specifications for setting the compaction parameter in the Spark asynchronous task execution table
- Spark Table Data Maintenance Specifications
- Suggestions for Spark Concurrently Write Hudi Data
- Suggestions on configuring resources for Spark read and write Hudi resources
- Spark On Hudi Performance Optimization
- Bucket Tuning Example
- IoTDB
- Kafka
- Mapreduce
- Spark
API Reference
- Before You Start
- API Overview
- Selecting an API Type
- Calling APIs
- Application Cases
- API V2
- API V1.1
- Out-of-Date APIs
- Appendix
- SDK Reference
MRS Basics
- What Is MRS Used For?
- What Types of Distributed Storage Does MRS Support?
- What Are Regions and AZs?
- Can I Change the Network Segment of Nodes in an MRS Cluster?
- Can I Downgrade the Specifications of an MRS Cluster Node?
- Are Hive Components of Different Versions Compatible with Each Other?
- What Are the Differences Between OBS and HDFS in Data Storage?
- What Are the Solutions for Processing 1 Billion Data Records?
- What are the advantages of the compression ratio of zstd?
- Billing
Cluster Creation
- How Do I Create an MRS Cluster Using a Custom Security Group?
- What Should I Do If HDFS, Yarn, and MapReduce Components Are Unavailable When I Buy an MRS Cluster?
- What Should I Do If the ZooKeeper Component Is Unavailable When I Buy an MRS Cluster?
- What Should I Do If Invalid Authentication Is Reported When I Submit an Order for Purchasing an MRS Cluster?
Web Page Access
- How Do I Change the Session Timeout Duration for an Open Source Component Web UI?
- What Can I Do If the Dynamic Resource Plan Page in MRS Tenant Management Cannot Be Refreshed?
- What Do I Do If the Kafka Topic Monitoring Tab Is Not Displayed on Manager?
- What CAN I DO IF an Error Is Reported or Some Functions Are Unavailable When I Access the Web UIs of Components such as HDFS, Hue, Yarn, Flink, and HetuEngine?
- How Do I Switch the Methods to Access MRS Manager?
- Why Cannot I Find the User Management Page on MRS Manager?
- What Can I Do If the Excel File Downloaded by Hue Cannot Be Opened?
Authentication and Permission
- What Is the User for Logging in to FusionInsight Manager?
- How Do I Query and Change the Password Validity Period of a User In a Cluster?
- Does an MRS Cluster Support Access Permission Control If Kerberos Authentication Is not Enabled?
- How Do I Add Tenant Management Permission to Users in a Cluster?
- Does Hue Provide the Function of Configuring Account Permissions?
- Why Can't I Submit Jobs on the Console After My IAM Account Is Assigned with MRS Permissions?
- How Do I View the Hive Table Created by Another User?
- How Do I Prevent Kerberos Authentication Expiration?
- How Do I Enable or Disable Kerberos Authentication for an Existing MRS Cluster?
- What Are the Ports of the Kerberos Authentication Service?
Client Usage
- How Do I Disable SASL Authentication for ZooKeeper?
- What Can I Do If the Error Message "Permission denied" Is Displayed When kinit Is Executed on a Client Outside the MRS Cluster?
- What Should I Do If an Alarm Is Reported Indicating that the Memory Is Insufficient When I Execute a SQL Statement on the ClickHouse Client?
- How Do I Connect to Spark Shell from MRS?
- How Do I Connect to Spark Beeline from MRS?
- What Should I Do If the Connection to the ClickHouse Server Fails and Error Code 516 Is Reported?
Component Configurations
- Does MRS Support Running Hive on Kudu?
- Does an MRS Cluster Support Hive on Spark?
- Can I Change the IP address of DBService?
- What Access Protocols Does Kafka Support?
- What Python Versions Are Supported by Spark Tasks in an MRS Cluster?
- What Are the Restrictions on the Storm Log Size in an MRS 2.1.0 Cluster?
- How Do I Modify the HDFS fs.defaultFS of an Existing Cluster?
- Can MRS Run Multiple Flume Tasks at a Time?
- How Do I Change FlumeClient Logs to Standard Logs?
- Where Are the JAR Files and Environment Variables of Hadoop Stored?
- How Do I View HBase Logs?
- How Do I Set the TTL for an HBase Table?
- How Do I Change the Number of HDFS Replicas?
- How Do I Modify the HDFS Active/Standby Switchover Class?
- What Data Type in Hive Tables Is Recommended for the Number Type of DynamoDB?
- Can I Export the Query Result of Hive Data?
- What Should I Do If an Error Occurs When Hive Runs the beeline -e Command to Execute Multiple Statements?
- What Do I Do If "over max user connections" Is Displayed When Hue Connects to HiveServer?
- How Do I View MRS Hive Metadata?
- How Do I Reset Kafka Data?
- What Should I Do If the Error Message "Not Authorized to access group XXX" Is Displayed When Kafka Topics Are Consumed?
- What Compression Algorithms Does Kudu Support?
- How Do I View Kudu Logs?
- How Do I Handle the Kudu Service Exceptions Generated During Cluster Creation?
- How Do I Configure Other Data Sources on Presto?
- How Do I Update the Ranger Certificate in MRS 1.9.3?
- How Do I Specify a Log Path When Submitting a Task in an MRS Storm Cluster?
- How Do I Check the ResourceManager Configuration of Yarn?
- How Do I Modify the allow_drop_detached Parameter of ClickHouse?
- How Do I Add a Periodic Deletion Policy to Prevent Large ClickHouse System Table Logs?
- How Do I Change the Time Zone of the ClickHouse Service?
Cluster Management
- How Do I View All Clusters?
- How Do I View MRS Operation Logs?
- How Do I View MRS Cluster Configuration Information?
- How Do I Add Components to an MRS Cluster?
- How Do I Cancel Message Notification for Cluster Alarms?
- Why Is the Resource Pool Memory Displayed in the MRS Cluster Smaller Than the Actual Cluster Memory?
- What Is the Python Version Installed for an MRS Cluster?
- How Do I Upload a Local File to a Node Inside a Cluster?
- What Can I Do If the Time Information of an MRS Cluster Node Is Incorrect?
- What Are the Differences and Relationships Between the MRS Management Console and MRS Manager?
- How Do I Unbind an EIP from FusionInsight Manager of an MRS Cluster?
- How Do I Stop the Firewall Service?
- How Do I Switch the Login Mode of a Node in an MRS Cluster?
- How Do I Access an MRS Cluster from a Node Outside the Cluster?
- In an MRS Streaming Cluster, Can the Kafka Topic Monitoring Function Send Alarm Notifications?
- Where can I view the running resource queues when ALM-18022 Insufficient Yarn Queue Resources is generated?
- How Do I Understand the Multi-Level Chart Statistics in the HBase Operation Requests Metric?
Node Management
- What are the Operating Systems of Hosts in MRS Clusters of Different Versions?
- Do I Need to Shut Down a Master Node Before Upgrading It?
- Can I Change MRS Cluster Nodes on the MRS Console?
- How Do I Query the Startup Time of an MRS Node?
- What Do I Do If Trust Relationships Between Nodes Are Abnormal?
- Can Master Node Specifications Be Adjusted in an MRS Cluster?
- Can Sudo Logs of Nodes in an MRS Cluster Be Cleared?
- How Do I Partition Disks in an MRS Cluster?
- Does an MRS Cluster Support System Reinstallation?
- Can I Change the OS of an MRS Cluster?
- Component Management
Job Management
- What Types of Spark Jobs Can Be Submitted in a Cluster?
- What Should I Do If Error 408 Is Reported When an MRS Node Accesses OBS?
- How Do I Enable Different Service Programs to Use Different Yarn Queues?
- What Should I Do If a Job Fails to Be Submitted and the Error Is Related to OBS?
- Can I Run Multiple Spark Tasks at the Same Time After the Minimum Tenant Resources of an MRS Cluster Is Changed to 0?
- What Should I Do If Job Parameters Separated By Spaces Cannot Be Identified?
- What Are the Differences Between the Client Mode and Cluster Mode of Spark Jobs?
- How Do I View MRS Job Logs?
- What Can I Do If the System Displays a Message Indicating that the Current User Does Not Exist on Manager When I Submit a Job?
- What Can I Do If LauncherJob Fails to Be Executed and the Error Message "jobPropertiesMap is null" Is Displayed?
- What Should I Do If the Flink Job Status on the MRS Console Is Inconsistent with That on Yarn?
- What Can I Do If a SparkStreaming Job Fails After Running for Dozens of Hours and Error 403 Is Reported for OBS Access?
- What Should I Do If Error Message "java.io.IOException: Connection reset by peer" Is Displayed During the Execution of a Spark Job?
- What Should I Do If the Error Message "requestId=XXX" Is Displayed When a Spark Job Accesses OBS?
- What Should I Do If the Error Message "UnknownScannerExeception" Is Displayed for Spark Jobs?
- What Can I Do If DataArts Studio Occasionally Fails to Schedule Spark Jobs?
- What Should I Do If a Flink Job Fails to Execute and the Error Message "java.lang.NoSuchFieldError: SECURITY_SSL_ENCRYPT_ENABLED" Is Displayed?
- What Should I Do If Submitted Yarn Jobs Cannot Be Viewed on the Web UI?
- What Can I Do If launcher-job Is Terminated by Yarn When a Flink Task Is Submitted?
- What Should I Do If the Error Message "slot request timeout" Is Displayed When I Submit a Flink Job?
- FAQs About Importing and Exporting Data Using DistCP Jobs
- How Do I View SQL Statements of Hive Jobs on the Yarn Web UI?
- How Do I View Logs of a Specified Yarn Task?
- What Should I Do If a HiveSQL/HiveScript Job Fails to be Submitted After Hive Is Added?
- Where Are the Execution Logs of Spark Jobs Stored?
- What Should I Do If an Alarm Indicating Insufficient Memory Is Reported During Spark Task Execution?
- What Can I Do If an Alarm is Generated Because the NameNode Is not Restarted on Time After the hdfs-site.xml File Is Modified?
- What Should I Do If It Takes a Long Time for Spark SQL to Access Hive Partitioned Tables Before a Job Starts?
- How Does the System Select the Queue When an MRS Cluster User Is Associated to Multiple Queues?
Performance Tuning
- How Do I Obtain the Hadoop Pressure Test Tool?
- How Do I Improve the Resource Utilization of Core Nodes in a Cluster?
- How Do I Configure the knox Memory?
- How Do I Adjust the Memory Size of the manager-executor Process?
- How Do I Configure Spark Jobs to Automatically Obtain More Resources During Execution?
- What Should I Do If the spark.yarn.executor.memoryOverhead Setting Does Not Take Effect?
- How Do I Get My Data into OBS or HDFS?
- Can MRS Write Data to HBase Through an HBase External Table of Hive?
- Where Can I Download the Dependency Package (com.huawei.gaussc10) in the Hive Sample Project?
- Does MRS Support Python Code?
- Does OpenTSDB Support Python APIs?
- How Do I Obtain a Spark JAR File?
- How Do I Configure the node_id Parameter When Calling the API for Adjusting Cluster Nodes?
Peripheral Service Interconnection
- Does MRS Support Read and Write Operations on DLI Service Tables?
- Does OBS Support the ListObjectsV2 Protocol?
- Can a Crawler Service Be Deployed on Nodes in an MRS Cluster?
- Does MRS Support Secure Deletion?
- How Do I Use PySpark to Connect MRS Spark?
- Why Mapped Fields Do not Exist in the Database After HBase Synchronizes Data to CSS?
- Can MRS Connect to an External KDC?
- What Can I Do If Jetty Is Incompatible with MRS when Open-Source Kylin 3.x Is Interconnected with MRS 1.9.3?
- What Should I Do If Data Failed to Be Exported from MRS to an OBS Encrypted Bucket?
- How Do I Interconnect MRS with LTS?
- How Do I Install HSS on MRS Cluster Nodes?
- How Do I Connect to HBase of MRS Through HappyBase?
- Can the Hive Driver Be Interconnected with DBCP2?
- Upgrade and Patching
MRS Basics
Troubleshooting
- Account Passwords
- Account Permissions
Common Exceptions in Logging In to the Cluster Manager
- Failed to Access Manager of an MRS Cluster
Accessing the Web Pages
- Error "502 Bad Gateway" Is Reported During the Access to MRS Manager
- An Error Message Occurs Indicating that the VPC Request Is Incorrect During the Access
- Error 503 Is Reported When Manager Is Accessed Through Direct Connect
- Error Message "You have no right to access this page." Is Displayed When Users log in to the Cluster Page
- Error Message "Invalid credentials" Is Displayed When a User Logs In to Manager
- Failed to Log In to the Manager After Timeout
- Failed to Log In to MRS Manager After the Python Upgrade
- Failed to Log In to MRS Manager After Changing the Domain Name
- Manager Page Is Blank After a Success Login
- Cluster Login Fails Because Native Kerberos Is Installed on Cluster Nodes
- Using Google Chrome to Access MRS Manager on macOS
- How Do I Unlock a User Who Logs in to Manager?
- Why Does the Manager Page Freeze?
Common Exceptions in Accessing the MRS Web UI
- How Do I Do If an Error Is Reported or Some Functions Are Unavailable When I Access the Web UIs of HDFS, Hue, YARN, HetuEngine, and Flink?
- Error 500 Is Reported When a User Accesses the Component Web UI
- [HBase WebUI] Users cannot switch from the HBase WebUI to the RegionServer WebUI
- [HDFS WebUI] When users access the HDFS WebUI, an error message is displayed indicating that the number of redirections is too large
- [HDFS WebUI] Failed to access the HDFS WebUI using the Internet Explorer
- [Hue Web UI] A "No Permission" Error Is Displayed When a User Log In to the Hue Web UI
- [Hue Web UI] Failed to Access the Hue Web UI
- [Hue WebUI] The error "Proxy Error" is reported when a user accesses the Hue WebUI
- [Hue WebUI] Why Is the Hue Native Page Cannot Be Properly Displayed If the Hive Service Is Not Installed in a Cluster?
- Hue (Active) Cannot Open Web Pages
- [Ranger WebUI] Why Cannot a New User Log In to Ranger After Changing the Password?
- [Tez WebUI] Error 404 is reported when users access the Tez WebUI
- [Spark WebUI] Why Cannot I Switch from the Yarn Web UI to the Spark Web UI?
- [Spark WebUI] What Can I Do If an Error Occurs when I Access the Application Page Because the Application Cached by HistoryServer Is Recycled?
- [Spark WebUI] Why Is the Native Page of an Application in Spark2x JobHistory Displayed Incorrectly?
- [Spark WebUI] The Spark2x WebUI fails to be accessed using the Internet Explorer
- [Yarn Web UI] Failed to Access the Yarn Web UI
- APIs
Cluster Management
- Failed to Reduce Task Nodes
- OBS Certificate in a Cluster Expired
- Replacing a Disk in an MRS Cluster (Applicable to 2.x and Earlier)
- Replacing a Disk in an MRS Cluster (Applicable to 3.x)
- Failed to Execute an MRS Backup Task
- Inconsistency Between df and du Command Output on the Core Node
- Disassociating a Subnet from a Network ACL
- MRS Cluster Becomes Abnormal After the Hostname of a Node Is Changed
- Processes Are Terminated Unexpectedly
- Failed to Configure Cross-Cluster Mutual Trust for MRS
- Network Is Unreachable When Python Is Installed on an MRS Cluster Node Using Pip3
- Connecting the Open-Source confluent-kafka-go to an MRS Security Cluster
- Failed to Execute the Periodic Backup Task of an MRS Cluster
- Failed to Download the MRS Cluster Client
- An Error Is Reported When a Flink Job Is Submitted in an MRS Cluster with Kerberos Authentication Enabled
- An Error Is Reported When the Insert Command Is Executed on the Hive Beeline CLI
- Upgrading the OS to Fix Vulnerabilities for an MRS Cluster Node
- Failed to Migrate Data to MRS HDFS Using CDM
- Alarms Indicating Heartbeat Interruptions Between Nodes Are Frequently Generated in the MRS Cluster
- High Memory Usage of the PMS Process
- High Memory Usage of the Knox Process
- It Takes a Long Time to Access HBase from a Client Outside a Security Cluster
- Failed to Submit Jobs
- OS Disk Space Is Insufficient Due to Oversized HBase Log Files
- OS Disk Space Is Insufficient Due to Oversized HDFS Log Files
- An Exception Occurs During Specifications Upgrade of Nodes in an MRS Cluster
- Failed to Delete a New Tenant on FusionInsight Manager
- MRS Cluster Becomes Unavailable After the VPC Is Changed
- Failed to Submit Jobs on the MRS Console
- Error "symbol xxx not defined in file libcrypto.so.1.1" Is Displayed During HA Certificate Generation
- Some Instances Fail to Be Started After Core Nodes Are Added to the MRS Cluster
- Using Alluixo
- Using ClickHouse
Using DBService
- DBServer Instance Is in Abnormal Status
- DBServer Instance Remains in the Restoring State
- Default Port 20050 or 20051 of DBService Is Occupied
- DBServer Instance Is Always in the Restoring State Because the Incorrect /tmp Directory Permission
- Failed to Execute a DBService Backup Task
- Components Failed to Connect to DBService in Normal State
- DBServer Failed to Start
- DBService Backup Failed Because the Floating IP Address Is Unreachable
- DBService Failed to Start Due to the Loss of the DBService Configuration File
Using Flink
- Error Message "Error While Parsing YAML Configuration File: Security.kerberos.login.keytab" Is Displayed When a Command Is Executed on the Flink Client
- Error Message "Error while parsing YAML configuration file : security.kerberos.login.principal:pippo" Is Displayed When a Command Is Executed on the Flink Client
- Error Message "Could Not Connect to the Leading JobManager" Is Displayed When a Command Is Executed on the Flink Client
- Failed to Create a Flink Cluster by Running yarn-session As Different Users
- Flink Service Program Fails to Read Files on the NFS Disk
- Failed to Customize the Flink Log4j Log Level
- Using Flume
Using HBase
- Slow Response to HBase Connection
- Failed to Authenticate the HBase User
- RegionServer Failed to Start Because the Port Is Occupied
- HBase Failed to Start Due to Insufficient Node Memory
- HBase Service Unavailable Due to Poor HDFS Performance
- HBase Failed to Start Due to Inappropriate Parameter Settings
- RegionServer Failed to Start Due to Residual Processes
- HBase Failed to Start Due to a Quota Set on HDFS
- HBase Failed to Start Due to Corrupted Version Files
- High CPU Usage Caused by Zero-Loaded RegionServer
- HBase Failed to Start with "FileNotFoundException" in RegionServer Logs
- The Number of RegionServers Displayed on the Native Page Is Greater Than the Actual Number After HBase Is Started
- RegionServer Instance Is in the Restoring State
- HBase Failed to Start in a Newly Installed Cluster
- HBase Failed to Start Due to the Loss of the ACL Table Directory
- HBase Failed to Start After the Cluster Is Powered Off and On
- Failed to Import HBase Data Due to Oversized File Blocks
- Failed to Load Data to the Index Table After an HBase Table Is Created Using Phoenix
- Failed to Run the hbase shell Command on the MRS Cluster Client
- Disordered Information Display on the HBase Shell Client Console Due to Printing of the INFO Information
- HBase Failed to Start Due to Insufficient RegionServer Memory
- Failed to Start HRegionServer on the Node Newly Added to the Cluster
- Region in the RIT State for a Long Time Due to HBase File Loss
Using HDFS
- HDFS NameNode Instances Become Standby After the RPC Port Is Changed
- An Error Is Reported When the HDFS Client Is Connected Through a Public IP Address
- Failed to Use Python to Remotely Connect to the Port of HDFS
- HDFS Capacity Reaches 100%, Causing Unavailable Upper-Layer Services Such as HBase and Spark
- Error Message "Permission denied" Is Displayed When HDFS and Yarn Are Started
- HDFS Users Can Create or Delete Files in Directories of Other Users
- A DataNode of HDFS Is Always in the Decommissioning State
- HDFS NameNode Failed to Start Due to Insufficient Memory
- A Large Number of Blocks Are Lost in HDFS due to the Time Change Using ntpdate
- CPU Usage of DataNodes Is Close to 100% Occasionally, Causing Node Loss
- Manually Performing Checkpoints When a NameNode Is Faulty for a Long Time
- Error "Failed to place enough replicas" Is Reported When HDFS Reads or Writes Files
- Maximum Number of File Handles Is Set to a Too Small Value, Causing File Reading and Writing Exceptions
- HDFS Client File Fails to Be Closed After Data Writing
- File Fails to Be Uploaded to HDFS Due to File Errors
- After dfs.blocksize Is Configured on the UI and Data Is Uploaded, the Block Size Does Not Change
- HDFS File Fails to Be Read, and Error Message "FileNotFoundException" Is Displayed
- Failed to Write Files to HDFS, and Error Message "item limit of xxx is exceeded" Is Displayed
- Adjusting the Log Level of the HDFS SHDFShell Client
- HDFS File Read Fails, and Error Message "No common protection layer" Is Displayed
- Failed to Write Files Because the HDFS Directory Quota Is Insufficient
- Balancing Fails, and Error Message "Source and target differ in block-size" Is Displayed
- Failed to Query or Delete HDFS Files
- Uneven Data Distribution Due to Non-HDFS Data Residuals
- Uneven Data Distribution Due to HDFS Client Installation on the DataNode
- Unbalanced DataNode Disk Usages of a Node
- Locating Common Balance Problems
- HDFS Displays Insufficient Disk Space But 10% Disk Space Remains
- Error Message "error creating DomainSocket" Is Displayed When the HDFS Client Installed on the Core Node in a Normal Cluster Is Used
- HDFS Files Fail to Be Uploaded When the Client Is Installed on a Node Outside the Cluster
- Insufficient Number of Replicas Is Reported During High Concurrent HDFS Writes
- HDFS Client Failed to Delete Overlong Directories
- An Error Is Reported When a Node Outside the Cluster Accesses MRS HDFS
- "ALM-12027 Host PID Usage Exceeds the Threshold" Is Generated for a NameNode
- ALM-14012 JournalNode Is Out of Synchronization Is Generated in the Cluster
- Failed to Decommission a DataNode Due to HDFS Block Loss
- An Error Is Reported When DistCP Is Used to Copy an Empty Folder
Using Hive
- Common Hive Logs
- Failed to Start Hive
- Error Message "Cannot modify xxx at runtime" Is Displayed When the set Command Is Executed in a Security Cluster
- Specifying a Queue When Submitting a Hive Task
- Setting the Map/Reduce Memory on the Client
- Specifying the Output File Compression Format When Importing a Hive Table
- Description of the Hive Table Is Too Long to Be Completely Displayed
- NULL Is Displayed When Data Is Inserted After the Partition Column Is Added to a Hive Table
- New User Created in the Cluster Does Not Have the Permission to Query Hive Data
- An Error Is Reported When SQL Is Executed to Submit a Task to a Specified Queue
- An Error Is Reported When the "load data inpath" Command Is Executed
- An Error Is Reported When the "load data local inpath" Command Is Executed
- An Error Is Reported When the create external table Command Is Executed
- An Error Is Reported When the dfs -put Command Is Executed on the Beeline Client
- Insufficient Permissions to Execute the set role admin Command
- An Error Is Reported When a UDF Is Created on the Beeline Client
- Hive Is Faulty
- Difference Between Hive Service Health Status and Hive Instance Health Status
- "authentication failed" Is Displayed During an Attempt to Connect to the Shell Client
- Failed to Access ZooKeeper from the Client
- "Invalid function" Is Displayed When a UDF Is Used
- Hive Service Status Is Unknown
- Health Status of a HiveServer or MetaStore Instance Is unknown
- Health Status of a HiveServer or MetaStore Instance Is Concerning
- Garbled Characters Returned Upon a Query If Text Files Are Compressed Using ARC4
- Hive Task Failed to Run on the Client but Successful on Yarn
- Error Message "Execution Error return code 2" Is Displayed When the SELECT Statement Is Executed
- Failed to Perform drop partition When There Are a Large Number of Partitions
- Failed to Start the Local Task When the Join Operation Is Performed
- WebHCat Fails to Be Started After the Hostname Is Changed
- An Error Is Reported When the Hive Sample Program Is Running After the Domain Name of a Cluster Is Changed
- Hive MetaStore Exception Occurs When the Number of DBService Connections Exceeds the Upper Limit
- Error Message "Failed to execute session hooks: over max connections" Is Displayed on the Beeline Client
- Error Message "OutOfMemoryError" Is Displayed on the Beeline Client
- Task Execution Fails Because the Input File Number Exceeds the Threshold
- Hive Task Execution Fails Because of Stack Memory Overflow
- Task Failed Due to Concurrent Writes to One Table or Partition
- Hive Task Failed Due to a Lack of HDFS Directory Permission
- Failed to Load Data to Hive Tables
- Failed to Run the Application Developed Based on the Hive JDBC Code Case
- HiveServer and HiveHCat Process Faults
- Error Message "ConnectionLoss for hiveserver2" Is Displayed When MRS Hive Connects to ZooKeeper
- An Error Is Reported When Hive Executes the insert into Statement
- Timeout Reported When Adding the Hive Table Field
- Failed to Restart Hive
- Failed to Delete a Table Due to Excessive Hive Partitions
- An Error Is Reported When msck repair table Is Executed on Hive
- Insufficient User Permission for Running the insert into Command on Hive
- Releasing Disk Space After Dropping a Table in Hive
- Abnormal Hive Query Due to Damaged Data in the JSON Table
- Connection Timed Out During SQL Statement Execution on the Hive Client
- WebHCat Failed to Start Due to Abnormal Health Status
- WebHCat Failed to Start Because the mapred-default.xml File Cannot Be Parsed
- An SQL Error Is Reported When the Number of MetaStore Dynamic Partitions Exceeds the Threshold
Using Hue
- An Unknown Job Is Running on the Hue Page
- HQL Fails to Be Executed on Hue Using Internet Explorer
- Failed to Access the Hue Web UI
- HBase Tables Cannot Be Loaded on the Hue Web UI
- Chinese Characters Entered in the Hue Text Box Are Displayed Incorrectly
- An Error Is Reported If the Query Result of an Impala SQL Statement Executed on Hue Contains Chinese Characters
- Using Impala
Using Kafka
- An Error Is Reported When the Kafka Client Is Run to Obtain Topics
- Using Python3.x to Connect to Kafka in a Security Cluster
- Flume Normally Connects to Kafka but Fails to Send Messages
- Producer Fails to Send Data and Error Message "NullPointerException" Is Displayed
- Producer Fails to Send Data and Error Message "TOPIC_AUTHORIZATION_FAILED" Is Displayed
- Producer Occasionally Fails to Send Data and the Log Displays "Too many open files in system"
- Consumer Is Initialized Successfully, but the Specified Topic Message Cannot Be Obtained from Kafka
- Consumer Fails to Consume Data and Remains in the Waiting State
- SparkStreaming Fails to Consume Kafka Messages, and "Error getting partition metadata" Is Displayed
- Consumer Fails to Consume Data in a Newly Created Cluster, and Message " GROUP_COORDINATOR_NOT_AVAILABLE" Is Displayed
- SparkStreaming Fails to Consume Kafka Messages, and Message "Couldn't find leader offsets" Is Displayed
- Consumer Fails to Consume Data and Message "SchemaException: Error reading field" Is Displayed
- Kafka Consumer Loses Consumed Data
- Failed to Start Kafka Due to Account Lockout
- Kafka Broker Reports Abnormal Processes and the Log Shows "IllegalArgumentException"
- Kafka Topics Cannot Be Deleted
- Error "AdminOperationException" Is Displayed When a Kafka Topic Is Deleted
- When a Kafka Topic Fails to Be Created, "NoAuthException" Is Displayed
- Failed to Set an ACL for a Kafka Topic, and "NoAuthException" Is Displayed
- When a Kafka Topic Fails to Be Created, "NoNode for /brokers/ids" Is Displayed
- When a Kafka Topic Fails to Be Created, "replication factor larger than available brokers" Is Displayed
- Consumer Repeatedly Consumes Data
- Leader for the Created Kafka Topic Partition Is Displayed as none
- Safety Instructions on Using Kafka
- Obtaining Kafka Consumer Offset Information
- Adding or Deleting Configurations for a Topic
- Reading the Content of the __consumer_offsets Internal Topic
- Configuring Logs for Shell Commands on the Kafka Client
- Obtaining Topic Distribution Information
- Kafka HA Usage Description
- Failed to Manage a Kafka Cluster Using the Kafka Shell Command
- Kafka Producer Writes Oversized Records
- Kafka Consumer Reads Oversized Records
- High Usage of Multiple Disks on a Kafka Cluster Node
- Kafka Is Disconnected from the ZooKeeper Client
- Using Oozie
Using Presto
- During sql-standard-with-group Configuration, a Schema Fails to Be Created and the Error Message "Access Denied" Is Displayed
- Coordinator Process of Presto Cannot Be Started
- When Presto Queries a Kudu Table, an Error Is Reported Indicating That the Table Cannot Be Found
- No Data is Found in the Hive Table Using Presto
- Error Message "The node may have crashed or be under too much load" Is Displayed During MRS Presto Query
- Accessing Presto from an MRS Cluster Through a Public Network
Using Spark
- An Error Is Reported When the Split Size Is Changed for a Running Spark Application
- Incorrect Parameter Format Is Displayed When a Spark Task Is Submitted
- Spark, Hive, and Yarn Are Unavailable Due to Insufficient Disk Capacity
- A Spark Job Fails to Run Due to Incorrect JAR File Import
- Spark Job Suspended Due to Insufficient Memory or Lack of JAR Packages
- Error "ClassNotFoundException" Is Reported When a Spark Task Is Submitted
- Driver Displays a Message Indicating That the Running Memory Exceeds the Threshold When a Spark Task Is Submitted
- Error "Can't get the Kerberos realm" Is Reported When a Spark Task Is Submitted in Yarn-Cluster Mode
- Failed to Start spark-sql and spark-shell Due to JDK Version Mismatch
- ApplicationMaster Fails to Start Twice When a Spark Task Is Submitted in Yarn-client Mode
- Failed to Connect to ResourceManager When a Spark Task Is Submitted
- DataArts Studio Failed to Schedule Spark Jobs
- Job Status Is error After a Spark Job Is Submitted Through an API
- ALM-43006 Is Repeatedly Reported for the MRS Cluster
- Failed to Create or Delete a Table in Spark Beeline
- Failed to Connect to the Driver When a Spark Job Is Submitted on a Node Outside the Cluster
- Large Number of Shuffle Results Are Lost During Spark Task Execution
- Disk Space Is Insufficient Due to Long-Term Running of JDBCServer
- Failed to Load Data to a Hive Table Across File Systems by Running SQL Statements Using Spark Shell
- Spark Task Submission Failure
- Spark Task Execution Failure
- JDBCServer Connection Failure
- Failed to View Spark Task Logs
- Spark Streaming Task Submission Issues
- Authentication Fails When Spark Connects to Other Services
- Authentication Fails When Spark Connects to Kafka
- An Error Occurs When SparkSQL Reads the ORC Table
- Failed to Switch to the Log Page from stderr and stdout on the Native Spark Web UI
- An Error Is Reported When spark-beeline Is Used to Query a Hive View
Using Sqoop
- Connecting Sqoop to MySQL
- Failed to Find the HBaseAdmin.<init> Method When Sqoop Reads Data from the MySQL Database to HBase
- An Error Is Reported When a Sqoop Task Is Created Using Hue to Import Data from HBase to HDFS
- A Data Format Error Is Reported When Data Is Exported from Hive to MySQL 8.0 Using Sqoop
- An Error Is Reported When the sqoop import Command Is Executed to Extract Data from PgSQL to Hive
- Failed to Use Sqoop to Read MySQL Data and Write Parquet Files to OBS
- An Error Is Reported When Database Data Is Migrated Using Sqoop
Using Storm
- Invalid Hyperlink of Events on the Storm Web UI
- Failed to Submit the Storm Topology
- Failed to Submit the Storm Topology and Message "Failed to check principle for keytab" Is Displayed
- Worker Logs Are Empty After the Storm Topology Is Submitted
- Worker Runs Abnormally After the Storm Topology Is Submitted and Error "Failed to bind to XXX" Is Displayed
- "well-known file is not secure" Is Displayed When the jstack Command Is Used to Check the Process Stack
- Data Cannot Be Written to Bolts When the Storm-JDBC Plug-in Is Used to Develop Oracle Databases
- Internal Server Error Is Displayed When the User Queries Information on the Storm UI
- Using Ranger
Using Yarn
- A Large Number of Jobs Occupying Resources After Yarn Is Started in a Cluster
- Error "GC overhead" Is Reported When Tasks Are Submitted Using the hadoop jar Command on the Client
- Disk Space of a Node Is Used Up Due to Oversized Aggregated Logs of Yarn
- Temporary Files Are Not Deleted When a MapReduce Job Is Abnormal
- Incorrect Port Information of the Yarn Client Causes Error "connection refused" After a Task Is Submitted
- "Could not access logs page!" Is Displayed When Job Logs Are Queried on the Yarn Web UI
- Error "ERROR 500" Is Displayed When Queue Information Is Queried on the Yarn Web UI
- Error "ERROR 500" Is Displayed When Job Logs Are Queried on the Yarn Web UI
- An Error Is Reported When a Yarn Client Command Is Used to Query Historical Jobs
- Number of Files in the TimelineServer Directory Reaches the Upper Limit
- Using ZooKeeper
Storage-Compute Decoupling
- A User Without the Permission on the /tmp Directory Failed to Execute a Job for Accessing OBS
- When the Hadoop Client Is Used to Delete Data from OBS, It Does Not Have the Permission for the .Trash Directory
- An MRS Cluster Fails Authentication When Accessing OBS Because the NTP Time of Cluster Nodes Is Not Synchronized
- Videos
- Glossary
More Documents
Overview
- What Is MRS?
- Application Scenarios
- Components
- Functions
- Constraints
- Permissions Management
- Related Services
- IAM Permissions Management
- MRS Quick Start
Configuring a Cluster
- Overview
- Cluster List
- Methods of Creating MRS Clusters
- Quick Creation of a Hadoop Analysis Cluster
- Quick Creation of an HBase Analysis Cluster
- Quick Creation of a Kafka Streaming Cluster
- Quick Creation of a ClickHouse Cluster
- Quick Creation of a Real-time Analysis Cluster
- Creating a Custom Cluster
- Customizing a Topology Cluster
- Adding a Tag to a Cluster
- Communication Security Authorization
- Installing the Third-Party Software Using Bootstrap Actions
Managing an Existing Cluster
- Managing and Monitoring a Cluster
- Manually Scaling Out a Cluster
- Manually Scaling In a Cluster
- Configuring an Auto Scaling Rule
- Configuring Auto Scaling Rules When Creating a Cluster
- Changing the Subnet of a Cluster
- Configuring Message Notification
- O&M
- Terminating a Cluster
- Deleting a Failed Task
Job Management
- Introduction to MRS Jobs
- Running a MapReduce Job
- Running a SparkSubmit Job
- Running a HiveSQL Job
- Running a SparkSql Job
- Running a Flink Job
- Running a Kafka Job
- Viewing Job Configuration and Logs
- Stopping a Job
- Deleting a Job
- Using Encrypted OBS Data for Job Running
- Configuring Job Notification Rules
- Importing and Exporting Data
- Object Management
- Viewing Configuration
- Managing Services
- Configuring Service Parameters
- Configuring Customized Service Parameters
- Synchronizing Service Configuration
- Managing Role Instances
- Configuring Role Instance Parameters
- Synchronizing Role Instance Configuration
- Decommissioning and Recommissioning a Role Instance
- Managing a Host (Node)
- Isolating a Host
- Canceling Host Isolation
- Starting and Stopping a Cluster
- Synchronizing Cluster Configuration
- Exporting Cluster Configuration
- Performing Rolling Restart
- Alarm Management
- Patch Management
Health Check Management
- Before You Start
- Performing a Health Check
- Viewing and Exporting a Health Check Report
- DBService Health Check Indicators
- Flume Health Check Indicators
- HBase Health Check Indicators
- Host Health Check Indicators
- HDFS Health Check Indicators
- Hive Health Check Indicators
- Kafka Health Check Indicators
- KrbServer Health Check Indicators
- LdapServer Health Check Indicators
- Loader Health Check Indicators
- MapReduce Health Check Indicators
- OMS Health Check Indicators
- Spark Health Check Indicators
- Storm Health Check Indicators
- Yarn Health Check Indicators
- ZooKeeper Health Check Indicators
Tenant Management
- Before You Start
- Overview
- Creating a Tenant
- Creating a Sub-tenant
- Deleting a Tenant
- Managing a Tenant Directory
- Restoring Tenant Data
- Creating a Resource Pool
- Modifying a Resource Pool
- Deleting a Resource Pool
- Configuring a Queue
- Configuring the Queue Capacity Policy of a Resource Pool
- Clearing Configuration of a Queue
- Backup and Restoration
MRS Multi-User Permission Management
- Users and Permissions of MRS Clusters
- Default Users of Clusters with Kerberos Authentication Enabled
- Creating a Role
- Creating a User Group
- Creating a User
- Modifying User Information
- Locking a User
- Unlocking a User
- Deleting a User
- Changing the Password of an Operation User
- Initializing the Password of a System User
- Downloading a User Authentication File
- Modifying a Password Policy
- Configuring Cross-Cluster Mutual Trust Relationships
- Configuring Users to Access Resources of a Trusted Cluster
- Configuring Fine-Grained Permissions for MRS Multi-User Access to OBS
- Managing Historical Clusters
- Viewing Operation Logs
- Metadata
- Connecting to Clusters
- Using an MRS Client
MRS Manager Operation Guide (Applicable to 2.x and Earlier Versions)
- Introduction to MRS Manager
- Checking Running Tasks
- Monitoring Management
- Alarm Management
Object Management
- Managing Objects
- Viewing Configurations
- Managing Services
- Synchronizing Service Configurations
- Managing a Host
- Isolating a Host
- Starting or Stopping a Cluster
- Synchronizing Cluster Configurations
- Exporting Configuration Data of a Cluster
- Log Management
- Configuring the Number of Health Check Reports to Be Reserved
- Managing Health Check Reports
- Static Service Pool Management
Tenant Management
- Overview
- Creating a Tenant
- Deleting a tenant
Security Management
- Default Users of Clusters with Kerberos Authentication Disabled
- Changing the Password of an OS User
- Changing the password of user admin
- Changing the Password of the Kerberos Administrator
- Changing the Passwords of the LDAP Administrator and the LDAP User
- Changing the Password of a Component Running User
- Changing the Password of the OMS Database Administrator
- Changing the Password of the Data Access User of the OMS Database
- Changing the Password of a Component Database User
- Updating Cluster Keys
- Patch Operation Guide
- Restoring Patches for the Isolated Hosts
- Rolling Restart
FusionInsight Manager Operation Guide (Applicable to 3.x)
- Getting Started
- Homepage
Cluster
- Cluster Management
- Managing a Service
- Instance Management
- Hosts
- O&M
- Audit
- Tenant Resources
- System Configuration
- Log Management
- Backup and Recovery Management
Security Management
- Security Overview
- Account Management
Security Hardening
- Hardening Policy
- Configuring a Trusted IP Address to Access LDAP
- HFile and WAL Encryption
- Security Configuration
- Configuring an IP Address Whitelist for Modifications Allowed by HBase
- Updating a Key for a Cluster
- Hardening the LDAP
- Configuring Kafka Data Encryption During Transmission
- Configuring HDFS Data Encryption During Transmission
- Configuring Communication Authentication for Storm Processes
- Encrypting the Communication Between Controller and Agent
- Updating SSH Keys for User omm
- Security Maintenance
- Security Statement
- Data Backup and Restoration
- Storage-Compute Decoupling Operation Guide
- Security
- High-Risk Operations Overview
MRS Overview
- How Do I Use MRS?
- How Does MRS Ensure Security of Data and Services?
- Can I Configure a Phoenix Connection Pool?
- Does MRS Support Change of the Network Segment?
- What Is the Relationship Between Hive and Other Components?
- What Are the Differences Between Hive Versions?
- Which MRS Cluster Version Supports Hive Connection and User Synchronization?
- What Is the Relationship Between Impala and Other Components?
- Statement About the Public IP Addresses in the Open-Source Third-Party SDK Integrated by MRS
- What Is the Relationship Between Kudu and HBase?
- What Are the Solutions for processing 1 Billion Data Records?
- Can I Clear MRS sudo Logs?
- Is the Storm Log also limited to 20 GB in MRS cluster 2.1.0?
- What Is Spark ThriftServer?
- What Access Protocols Are Supported by Kafka?
- What If Error 408 Is Reported When an MRS Node Accesses OBS?
- What Is the Compression Ratio of zstd?
- Why Are the HDFS, YARN, and MapReduce Components Unavailable When an MRS Cluster Is Created?
- Why Is the ZooKeeper Component Unavailable When an MRS Cluster Is Created?
- Which Python Versions Are Supported by Spark Tasks in an MRS 3.1.0 Cluster?
- How Do I Enable Different Service Programs to Use Different YARN Queues?
- Differences and Relationships Between the MRS Management Console and Cluster Manager
- How Do I Unbind an EIP from an MRS Cluster Node?
- Account and Password
Accounts and Permissions
- How Do I Assign Tenant Management Permission to a New Account?
- How Do I Customize an MRS Policy?
- Why Is the Manage User Function Unavailable on the System Page on MRS Manager?
- Does Hue Support Account Permission Configuration?
- Client Usage
Web Page Access
- Why Cannot I Refresh the Dynamic Resource Plan Page on MRS Tenant Tab?
- What Do I Do If the Kafka Topic Monitoring Tab Is Unavailable on Manager?
- How Do I Do If an Error Is Reported or Some Functions Are Unavailable When I Access the Web UIs of HDFS, Hue, YARN, and Flink?
Alarm Monitoring
- Where Can I View the Running Resource Queues When the Alarm "ALM-18022 Insufficient Yarn Queue Resources" Is Reported?
Job Development
- How Do I Do If the Message "The current user does not exist on MRS Manager. Grant the user sufficient permissions on IAM and then perform IAM user synchronization on the Dashboard tab page." Is Displayed?
- LauncherJob Job Execution Is Failed And the Error Message "jobPropertiesMap is null." Is Displayed
- How Do I Do If the Flink Job Status on the MRS Console Is Inconsistent with That on Yarn?
- How Do I Do If a SparkStreaming Job Fails After Being Executed Dozens of Hours and the OBS Access 403 Error is Reported?
- How Do I Do If an Alarm Is Reported Indicating that the Memory Is Insufficient When I Execute a SQL Statement on the ClickHouse Client?
- How Do I Do If Error Message "java.io.IOException: Connection reset by peer" Is Displayed During the Execution of a Spark Job?
- How Do I Do If Error Message "requestId=4971883851071737250" Is Displayed When a Spark Job Accesses OBS?
- Why DataArtsStudio Occasionally Fail to Schedule Spark Jobs and the Rescheduling also Fails?
- How Do I Do If a Flink Job Fails to Execute and the Error Message "java.lang.NoSuchFieldError: SECURITY_SSL_ENCRYPT_ENABLED" Is Displayed?
- Why Submitted Yarn Job Cannot Be Viewed on the Web UI?
- How Do I Modify the HDFS NameSpace (fs.defaultFS) of an Existing Cluster?
- How Do I Do If the launcher-job Queue Is Stopped by YARN due to Insufficient Heap Size When I Submit a Flink Job on the Management Plane?
- How Do I Do If the Error Message "slot request timeout" Is Displayed When I Submit a Flink Job?
- Data Import and Export of DistCP Jobs
- Cluster Upgrade/Patching
- Cluster Access
Big Data Service Development
- Where Are the .jar Files and Environment Variables of Hadoop Located?
- What Compression Algorithms Does HBase Support?
- Can MRS Write Data to HBase Through the HBase External Table of Hive?
- How Do I Balance HDFS Data?
- What Is the Port for Accessing HDFS Using Python?
- What Is the Recommended Number Type of DynamoDB in Hive Tables?
- How Do I Do If an Error Occurs When Hive Runs the beeline -e Command to Execute Multiple Statements?
- How Do I Do If a "hivesql/hivescript" Job Fails to Submit After Hive Is Added?
- What If an Excel File Downloaded on Hue Failed to Open?
- How Do I Do If Sessions Are Not Released After Hue Connects to HiveServer and the Error Message "over max user connections" Is Displayed?
- How Do I Obtain the Client Version of MRS Kafka?
- How Do I Do If Error Message "Not Authorized to access group xxx" Is Displayed When a Kafka Topic Is Consumed?
- How Do I Check Whether the ResourceManager Configuration of Yarn Is Correct?
- How Do I Do If an Alarm Indicating Insufficient Memory Is Reported During Spark Task Execution?
- How Do I Do If ClickHouse Consumes Excessive CPU Resources?
- How Do I Enable the Map Type on ClickHouse?
- A Large Number of OBS APIs Are Called When Spark SQL Accesses Hive Partitioned Tables
- API
Cluster Management
- How Do I View Log Information?
- How Do I View Cluster Configuration Information?
- How Do I Install Kafka and Flume in an MRS Cluster?
- How Do I Stop an MRS Cluster?
- Can I Expand Data Disk Capacity for MRS?
- Can I Add Components to an Existing Cluster?
- Can I Delete Components Installed in an MRS Cluster?
- How Do I Shield Cluster Alarm/Event Notifications?
- How Do I View the Configuration File Directory of Each Component?
- How Do I Do If the Time on MRS Nodes Is Incorrect?
- How Do I Do If Trust Relationships Between Nodes Are Abnormal?
Kerberos Usage
- How Do I Change the Kerberos Authentication Status of a Created MRS Cluster?
- How Do I Deploy the Kerberos Service in a Running Cluster?
- How Do I Access Hive in a Cluster with Kerberos Authentication Enabled?
- How Do I Access Presto in a Cluster with Kerberos Authentication Enabled?
- How Do I Access Spark in a Cluster with Kerberos Authentication Enabled?
- Metadata Management
MRS Overview
Troubleshooting
- Accessing the Web Pages
Cluster Management
- Adding a New Disk to an MRS Cluster
- MRS Backup Failure
- Disassociating a Subnet from the ACL Network
- MRS Becomes Abnormal After hostname Modification
- DataNode Restarts Unexpectedly
- Network Is Unreachable When Using pip3 to Install the Python Package in an MRS Cluster
- Failed to Scale Out an MRS Cluster
- Error Occurs When MRS Executes the Insert Command Using Beeline
- How Do I Upgrade EulerOS to Fix Vulnerabilities in an MRS Cluster?
- Using CDM to Migrate Data to HDFS
- Alarms Are Frequently Generated in the MRS Cluster
- Memory Usage of the PMS Process Is High
- It Takes a Long Time to Access HBase from a Client Installed on a Node Outside the Security Cluster
- How Do I Locate a Job Submission Failure?
- Using Alluixo
- Using ClickHouse
Using DBService
- Default Port 20050 or 20051 Is Occupied
- DBService Backup Failure
Using Flink
- "IllegalConfigurationException: Error while parsing YAML configuration file: "security.kerberos.login.keytab" Is Displayed When a Command Is Executed on an Installed Client
- "IllegalConfigurationException: Error while parsing YAML configuration file" Is Displayed When a Command Is Executed After Configurations of the Installed Client Are Changed
- The yarn-session.sh Command Fails to Be Executed When the Flink Cluster Is Created
- Failed to Create a Cluster by Executing the yarn-session Command When a Different User Is Used
- Using Flume
Using HBase
- HBase Failed to Started with "FileNotFoundException" in RegionServer Logs
Using HDFS
- All NameNodes Become the Standby State After the NameNode RPC Port of HDFS Is Changed
- An Error Is Reported When the HDFS Client Is Used After the Host Is Connected Using a Public Network IP Address
- HDFS Capacity Usage Reaches 100%, Causing Unavailable Upper-layer Services Such as HBase and Spark
- An Error Is Reported During HDFS and Yarn Startup
- HDFS Permission Setting Error
- HDFS Failed to Start Due to Insufficient Memory
- CPU Usage of a DataNode Reaches 100% Occasionally, Causing Node Loss (SSH Connection Is Slow or Fails)
- Common File Read/Write Faults
- A Client File Fails to Be Closed After Data Writing
- After dfs.blocksize Is Configured and Data Is Put, Block Size Remains Unchanged
- Failed to Read Files, and "FileNotFoundException" Is Displayed
- Failed to Write Files to HDFS, and "item limit of / is exceeded" Is Displayed
- Adjusting the Log Level of the Shell Client
- File Read Fails, and "No common protection layer" Is Displayed
- Balancing Fails, and "Source and target differ in block-size" Is Displayed
- A File Fails to Be Queried or Deleted, and the File Can Be Viewed in the Parent Directory (Invisible Characters)
- Uneven Data Distribution Due to the Client Installation on the DataNode
- Handling Unbalanced DataNode Disk Usage on Nodes
- An Error Is Reported When the HDFS Client Is Installed on the Core Node in a Common Cluster
- Client Installed on a Node Outside the Cluster Fails to Upload Files Using hdfs
Using Hive
- Content Recorded in Hive Logs
- Causes of Hive Startup Failure
- "Cannot modify xxx at runtime" Is Reported When the set Command Is Executed in a Security Cluster
- How to Specify a Queue When Hive Submits a Job
- How to Set Map and Reduce Memory on the Client
- Specifying the Output File Compression Format When Importing a Table
- desc Table Cannot Be Completely Displayed
- A Newly Created User Has No Query Permissions
- An Error Is Reported When the "create external table" Command Is Executed
- An Error Is Reported When UDF Is Created Using Beeline
- Hive Alarms and Triggering Conditions
- Health Status of a HiveServer or MetaStore Instance Is Unknown
- Garbled Characters Returned upon a select Query If Text Files Are Compressed Using ARC4
- Hive Task Failed to Run on the Client But Successful on Yarn
- An Error Is Reported When the select Statement Is Executed
- Failed to Drop a Large Number of Partitions
- Failed to Start a Local Task
- Failed to Start WebHCat
- Sample Code Error for Hive Secondary Development After Domain Switching
- MetaStore Exception Occurs When the Number of DBService Connections Exceeds the Upper Limit
- "Failed to execute session hooks: over max connections" Reported by Beeline
- beeline Reports the "OutOfMemoryError" Error
- Task Execution Fails Because of Stack Memory Overflow
- An Error Occurs When the INSERT INTO Statement Is Executed on Hive But the Error Message Is Unclear
- Failed to Restart the Hive Service
- Hive Failed to Delete a Table
- An Error Is Reported When msck repair table table_name Is Run on Hive
- How Do I Release Disk Space After Dropping a Table in Hive?
- Connection Timeout During SQL Statement Execution on the Client
- Using Hue
- Using Impala
Using Kafka
- An Error Is Reported When Kafka Is Run to Obtain a Topic
- Flume Normally Connects to Kafka But Fails to Send Messages
- Producer Failed to Send Data and Threw "NullPointerException"
- Producer Fails to Send Data and "TOPIC_AUTHORIZATION_FAILED" Is Thrown
- Consumer Is Initialized Successfully, But the Specified Topic Message Cannot Be Obtained from Kafka
- Consumer Fails to Consume Data in a Newly Created Cluster, and the Message " GROUP_COORDINATOR_NOT_AVAILABLE" Is Displayed
- SparkStreaming Fails to Consume Kafka Messages, and the Message "Couldn't find leader offsets" Is Displayed
- Consumer Fails to Consume Data and the Message " SchemaException: Error reading field 'brokers'" Is Displayed
- Checking Whether Data Consumed by a Customer Is Lost
- Failed to Start a Component Due to Account Lock
- Configuring Logs for Shell Commands on the Client
- Using Oozie
- Using Presto
Using Spark
- An Error Occurs When the Split Size Is Changed in a Spark Application
- An Error Is Reported When Spark Is Used
- A Spark Job Is Pending Due to Insufficient Memory
- An Error Is Reported During Spark Running
- Executor Memory Reaches the Threshold Is Displayed in Driver
- Message "Can't get the Kerberos realm" Is Displayed in Yarn-cluster Mode
- ApplicationMaster Failed to Start Twice in Yarn-client Mode
- Submission Status of the Spark Job API Is Error
- Alarm 43006 Is Repeatedly Generated in the Cluster
- Failed to Connect to the Driver When a Node Outside the Cluster Submits a Spark Job to Yarn
- An Error Occurs When Spark Connects to Redis
Using Sqoop
- Failed to Export HBase Data to HDFS Through Hue's Sqoop Task
- A Format Error Is Reported When Sqoop Is Used to Export Data from Hive to MySQL 8.0
- An Error Is Reported When sqoop import Is Executed to Import PostgreSQL Data to Hive
- Sqoop Failed to Read Data from MySQL and Write Parquet Files to OBS
Using Storm
- Invalid Hyperlink of Events on the Storm UI
- Failed to Submit a Topology
- Topology Submission Fails and the Message "Failed to check principle for keytab" Is Displayed
- The Worker Log Is Empty After a Topology Is Submitted
- Worker Runs Abnormally After a Topology Is Submitted and Error "Failed to bind to:host:ip" Is Displayed
- When the Storm-JDBC plug-in is used to develop Oracle write Bolts, data cannot be written into the Bolts.
- The GC Parameter Configured for the Service Topology Does Not Take Effect
- Internal Server Error Is Displayed When the User Queries Information on the UI
- Using Ranger
Using Yarn
- Plenty of Jobs Are Found After Yarn Is Started
- "GC overhead" Is Displayed on the Client When Tasks Are Submitted Using the Hadoop Jar Command
- Disk Space Is Used Up Due to Oversized Aggregated Logs of Yarn
- Temporary Files Are Not Deleted When an MR Job Is Abnormal
- ResourceManager of Yarn (Port 8032) Throws Error "connection refused"
- Failed to View Job Logs on the Yarn Web UI
- An Error Is Reported When a Queue Name Is Clicked on the Yarn Page
- Using ZooKeeper
- Accessing OBS
- Appendix
Overview
Component Operation Guide (ME-Abu Dhabi Region)
- Using Alluxio
- Using CarbonData (for Versions Earlier Than MRS 3.x)
Using CarbonData (for MRS 3.x or Later)
- Overview
- Configuration Reference
- CarbonData Operation Guide
- CarbonData Performance Tuning
- CarbonData Access Control
- CarbonData Syntax Reference
- CarbonData Troubleshooting
CarbonData FAQ
- Why Is Incorrect Output Displayed When I Perform Query with Filter on Decimal Data Type Values?
- How to Avoid Minor Compaction for Historical Data?
- How to Change the Default Group Name for CarbonData Data Loading?
- Why Does INSERT INTO CARBON TABLE Command Fail?
- Why Is the Data Logged in Bad Records Different from the Original Input Data with Escape Characters?
- Why Data Load Performance Decreases due to Bad Records?
- Why INSERT INTO/LOAD DATA Task Distribution Is Incorrect and the Opened Tasks Are Less Than the Available Executors when the Number of Initial ExecutorsIs Zero?
- Why Does CarbonData Require Additional Executors Even Though the Parallelism Is Greater Than the Number of Blocks to Be Processed?
- Why Data loading Fails During off heap?
- Why Do I Fail to Create a Hive Table?
- Why CarbonData tables created in V100R002C50RC1 not reflecting the privileges provided in Hive Privileges for non-owner?
- How Do I Logically Split Data Across Different Namespaces?
- Why Missing Privileges Exception is Reported When I Perform Drop Operation on Databases?
- Why the UPDATE Command Cannot Be Executed in Spark Shell?
- How Do I Configure Unsafe Memory in CarbonData?
- Why Exception Occurs in CarbonData When Disk Space Quota is Set for Storage Directory in HDFS?
- Why Does Data Query or Loading Fail and "org.apache.carbondata.core.memory.MemoryException: Not enough memory" Is Displayed?
- Why Do Files of a Carbon Table Exist in the Recycle Bin Even If the drop table Command Is Not Executed When Mis-deletion Prevention Is Enabled?
Using ClickHouse
- Using ClickHouse from Scratch
- ClickHouse Table Engine Overview
- Creating a ClickHouse Table
- ClickHouse Data Type
- Common ClickHouse SQL Syntax
- Migrating ClickHouse Data
- User Management and Authentication
- Backing Up and Restoring ClickHouse Data Using a Data File
- ClickHouse Log Overview
- ClickHouse Performance Tuning
ClickHouse FAQ
- How Do I Do If the Disk Status Displayed in the System.disks Table Is fault or abnormal?
- How Do I Migrate Data from Hive/HDFS to ClickHouse?
- How Do I Migrate Data from OBS/S3 to ClickHouse?
- An Error Is Reported in Logs When the Auxiliary ZooKeeper or Replica Data Is Used to Synchronize Table Data
- How Do I Grant the Select Permission at the Database Level to ClickHouse Users?
- Using DBService
- Using Flink
Using Flume
- Using Flume from Scratch
- Overview
- Installing the Flume Client
- Viewing Flume Client Logs
- Stopping or Uninstalling the Flume Client
- Using the Encryption Tool of the Flume Client
- Flume Service Configuration Guide
- Flume Configuration Parameter Description
- Using Environment Variables in the properties.properties File
Non-Encrypted Transmission
- Configuring Non-encrypted Transmission
- Typical Scenario: Collecting Local Static Logs and Uploading Them to Kafka
- Typical Scenario: Collecting Local Static Logs and Uploading Them to HDFS
- Typical Scenario: Collecting Local Dynamic Logs and Uploading Them to HDFS
- Typical Scenario: Collecting Logs from Kafka and Uploading Them to HDFS
- Typical Scenario: Collecting Logs from Kafka and Uploading Them to HDFS Through the Flume Client
- Typical Scenario: Collecting Local Static Logs and Uploading Them to HBase
- Encrypted Transmission
- Viewing Flume Client Monitoring Information
- Connecting Flume to Kafka in Security Mode
- Connecting Flume with Hive in Security Mode
- Configuring the Flume Service Model
- Introduction to Flume Logs
- Flume Client Cgroup Usage Guide
- Secondary Development Guide for Flume Third-Party Plug-ins
- Common Issues About Flume
Using HBase
- Using HBase from Scratch
- Using an HBase Client
- Creating HBase Roles
- Configuring HBase Replication
- Configuring HBase Parameters
- Enabling Cross-Cluster Copy
- Using the ReplicationSyncUp Tool
- Using HIndex
- Configuring HBase DR
- Configuring HBase Data Compression and Encoding
- Performing an HBase DR Service Switchover
- Performing an HBase DR Active/Standby Cluster Switchover
- Community BulkLoad Tool
- Configuring the MOB
- Configuring Secure HBase Replication
- Configuring Region In Transition Recovery Chore Service
- Using a Secondary Index
- HBase Log Overview
- HBase Performance Tuning
Common Issues About HBase
- Why Does a Client Keep Failing to Connect to a Server for a Long Time?
- Operation Failures Occur in Stopping BulkLoad On the Client
- Why May a Table Creation Exception Occur When HBase Deletes or Creates the Same Table Consecutively?
- Why Other Services Become Unstable If HBase Sets up A Large Number of Connections over the Network Port?
- Why Does the HBase BulkLoad Task (One Table Has 26 TB Data) Consisting of 210,000 Map Tasks and 10,000 Reduce Tasks Fail?
- How Do I Restore a Region in the RIT State for a Long Time?
- Why Does HMaster Exits Due to Timeout When Waiting for the Namespace Table to Go Online?
- Why Does SocketTimeoutException Occur When a Client Queries HBase?
- Why Modified and Deleted Data Can Still Be Queried by Using the Scan Command?
- Why "java.lang.UnsatisfiedLinkError: Permission denied" exception thrown while starting HBase shell?
- When does the RegionServers listed under "Dead Region Servers" on HMaster WebUI gets cleared?
- Why Are Different Query Results Returned After I Use Same Query Criteria to Query Data Successfully Imported by HBase bulkload?
- What Should I Do If I Fail to Create Tables Due to the FAILED_OPEN State of Regions?
- How Do I Delete Residual Table Names in the /hbase/table-lock Directory of ZooKeeper?
- Why Does HBase Become Faulty When I Set a Quota for the Directory Used by HBase in HDFS?
- Why HMaster Times Out While Waiting for Namespace Table to be Assigned After Rebuilding Meta Using OfflineMetaRepair Tool and Startups Failed
- Why Messages Containing FileNotFoundException and no lease Are Frequently Displayed in the HMaster Logs During the WAL Splitting Process?
- Why Does the ImportTsv Tool Display "Permission denied" When the Same Linux User as and a Different Kerberos User from the Region Server Are Used?
- Insufficient Rights When a Tenant Accesses Phoenix
- What Can I Do When HBase Fails to Recover a Task and a Message Is Displayed Stating "Rollback recovery failed"?
- How Do I Fix Region Overlapping?
- Why Does RegionServer Fail to Be Started When GC Parameters Xms and Xmx of HBase RegionServer Are Set to 31 GB?
- Why Does the LoadIncrementalHFiles Tool Fail to Be Executed and "Permission denied" Is Displayed When Nodes in a Cluster Are Used to Import Data in Batches?
- Why Is the Error Message "import argparse" Displayed When the Phoenix sqlline Script Is Used?
- How Do I Deal with the Restrictions of the Phoenix BulkLoad Tool?
- Why a Message Is Displayed Indicating that the Permission is Insufficient When CTBase Connects to the Ranger Plug-ins?
Using HDFS
- Using Hadoop from Scratch
- Configuring Memory Management
- Creating an HDFS Role
- Using the HDFS Client
- Running the DistCp Command
- Overview of HDFS File System Directories
- Changing the DataNode Storage Directory
- Configuring HDFS Directory Permission
- Configuring NFS
- Planning HDFS Capacity
- Configuring ulimit for HBase and HDFS
- Balancing DataNode Capacity
- Configuring Replica Replacement Policy for Heterogeneous Capacity Among DataNodes
- Configuring the Number of Files in a Single HDFS Directory
- Configuring the Recycle Bin Mechanism
- Setting Permissions on Files and Directories
- Setting the Maximum Lifetime and Renewal Interval of a Token
- Configuring the Damaged Disk Volume
- Configuring Encrypted Channels
- Reducing the Probability of Abnormal Client Application Operation When the Network Is Not Stable
- Configuring the NameNode Blacklist
- Optimizing HDFS NameNode RPC QoS
- Optimizing HDFS DataNode RPC QoS
- Configuring Reserved Percentage of Disk Usage on DataNodes
- Configuring HDFS NodeLabel
- Configuring HDFS Mover
- Using HDFS AZ Mover
- Configuring HDFS DiskBalancer
- Configuring the Observer NameNode to Process Read Requests
- Performing Concurrent Operations on HDFS Files
- Introduction to HDFS Logs
- HDFS Performance Tuning
FAQ
- NameNode Startup Is Slow
- DataNode Is Normal but Cannot Report Data Blocks
- HDFS WebUI Cannot Properly Update Information About Damaged Data
- Why Does the Distcp Command Fail in the Secure Cluster, Causing an Exception?
- Why Does DataNode Fail to Start When the Number of Disks Specified by dfs.datanode.data.dir Equals dfs.datanode.failed.volumes.tolerated?
- Failed to Calculate the Capacity of a DataNode when Multiple data.dir Directories Are Configured in a Disk Partition
- Standby NameNode Fails to Be Restarted When the System Is Powered off During Metadata (Namespace) Storage
- Why Data in the Buffer Is Lost If a Power Outage Occurs During Storage of Small Files
- Why Does Array Border-crossing Occur During FileInputFormat Split?
- Why Is the Storage Type of File Copies DISK When the Tiered Storage Policy Is LAZY_PERSIST?
- The HDFS Client Is Unresponsive When the NameNode Is Overloaded for a Long Time
- Can I Delete or Modify the Data Storage Directory in DataNode?
- Blocks Miss on the NameNode UI After the Successful Rollback
- Why Is "java.net.SocketException: No buffer space available" Reported When Data Is Written to HDFS
- Why are There Two Standby NameNodes After the active NameNode Is Restarted?
- When Does a Balance Process in HDFS, Shut Down and Fail to be Executed Again?
- "This page can't be displayed" Is Displayed When Internet Explorer Fails to Access the Native HDFS UI
- NameNode Fails to Be Restarted Due to EditLog Discontinuity
Using Hive
- Using Hive from Scratch
- Configuring Hive Parameters
- Hive SQL
- Permission Management
- Using a Hive Client
- Using HDFS Colocation to Store Hive Tables
- Using the Hive Column Encryption Function
- Customizing Row Separators
- Configuring Hive on HBase in Across Clusters with Mutual Trust Enabled
- Deleting Single-Row Records from Hive on HBase
- Configuring HTTPS/HTTP-based REST APIs
- Enabling or Disabling the Transform Function
- Access Control of a Dynamic Table View on Hive
- Specifying Whether the ADMIN Permissions Is Required for Creating Temporary Functions
- Using Hive to Read Data in a Relational Database
- Supporting Traditional Relational Database Syntax in Hive
- Creating User-Defined Hive Functions
- Enhancing beeline Reliability
- Viewing Table Structures Using the show create Statement as Users with the select Permission
- Writing a Directory into Hive with the Old Data Removed to the Recycle Bin
- Inserting Data to a Directory That Does Not Exist
- Creating Databases and Creating Tables in the Default Database Only as the Hive Administrator
- Disabling of Specifying the location Keyword When Creating an Internal Hive Table
- Enabling the Function of Creating a Foreign Table in a Directory That Can Only Be Read
- Authorizing Over 32 Roles in Hive
- Restricting the Maximum Number of Maps for Hive Tasks
- HiveServer Lease Isolation
- Hive Supporting Transactions
- Switching the Hive Execution Engine to Tez
- Hive Materialized View
- Hive Log Overview
- Hive Performance Tuning
Common Issues About Hive
- How Do I Delete UDFs on Multiple HiveServers at the Same Time?
- Why Cannot the DROP operation Be Performed on a Backed-up Hive Table?
- How to Perform Operations on Local Files with Hive User-Defined Functions
- How Do I Forcibly Stop MapReduce Jobs Executed by Hive?
- Table Creation Fails Because Hive Complex Fields' Names Contain Special Characters
- How Do I Monitor the Hive Table Size?
- How Do I Prevent Key Directories from Data Loss Caused by Misoperations of the insert overwrite Statement?
- Why Is Hive on Spark Task Freezing When HBase Is Not Installed?
- Error Reported When the WHERE Condition Is Used to Query Tables with Excessive Partitions in FusionInsight Hive
- Why Cannot I Connect to HiveServer When I Use IBM JDK to Access the Beeline Client?
- Description of Hive Table Location (Either Be an OBS or HDFS Path)
- Why Cannot Data Be Queried After the MapReduce Engine Is Switched After the Tez Engine Is Used to Execute Union-related Statements?
- Why Does Hive Not Support Concurrent Data Writing to the Same Table or Partition?
- Why Does Hive Not Support Vectorized Query?
- Why Does Metadata Still Exist When the HDFS Data Directory of the Hive Table Is Deleted by Mistake?
- How Do I Disable the Logging Function of Hive?
- Why Hive Tables in the OBS Directory Fail to Be Deleted?
- Hive Configuration Problems
Using Hudi
- Getting Started
- Basic Operations
- Hudi Performance Tuning
Common Issues About Hudi
Data Write
- Parquet/Avro schema Is Reported When Updated Data Is Written
- UnsupportedOperationException Is Reported When Updated Data Is Written
- SchemaCompatabilityException Is Reported When Updated Data Is Written
- What Should I Do If Hudi Consumes Much Space in a Temporary Folder During Upsert?
- Hudi Fails to Write Decimal Data with Lower Precision
- Data Collection
- Hive Synchronization
Data Write
- Using Hue (Versions Earlier Than MRS 3.x)
Using Hue (MRS 3.x or Later)
- Using Hue from Scratch
- Accessing the Hue Web UI
- Hue Common Parameters
- Using HiveQL Editor on the Hue Web UI
- Using the SparkSql Editor on the Hue Web UI
- Using the Metadata Browser on the Hue Web UI
- Using File Browser on the Hue Web UI
- Using Job Browser on the Hue Web UI
- Using HBase on the Hue Web UI
- Typical Scenarios
- Hue Log Overview
Common Issues About Hue
- Why Do HQL Statements Fail to Execute in Hue Using Internet Explorer?
- Why Does the use database Statement Become Invalid in Hive?
- Why Do HDFS Files Fail to Access Through the Hue Web UI?
- Why Do Large Files Fail to Upload on the Hue Page
- Why Is the Hue Native Page Cannot Be Properly Displayed If the Hive Service Is Not Installed in a Cluster?
- Using Impala
Using Kafka
- Using Kafka from Scratch
- Managing Kafka Topics
- Querying Kafka Topics
- Managing Kafka User Permissions
- Managing Messages in Kafka Topics
- Synchronizing Binlog-based MySQL Data to the MRS Cluster
- Creating a Kafka Role
- Kafka Common Parameters
- Kafka Specifications
- Using the Kafka Client
- Configuring Kafka HA and High Reliability Parameters
- Changing the Broker Storage Directory
- Checking the Consumption Status of Consumer Group
- Kafka Balancing Tool Instructions
- Balancing Data After Kafka Node Scale-Out
- Kafka Token Authentication Mechanism Tool Usage
- Introduction to Kafka Logs
- Performance Tuning
- Kafka Feature Description
- Migrating Data Between Kafka Nodes
- Common Issues About Kafka
- Using KafkaManager
Using Loader
- Using Loader from Scratch
- How to Use Loader
- Common Loader Parameters
- Creating a Loader Role
- Loader Link Configuration
- Managing Loader Links (Versions Earlier Than MRS 3.x)
- Managing Loader Links (MRS 3.x and Later Versions)
- Source Link Configurations of Loader Jobs
- Destination Link Configurations of Loader Jobs
- Managing Loader Jobs
- Preparing a Driver for MySQL Database Link
Importing Data
- Overview
- Importing Data Using Loader
- Typical Scenario: Importing Data from an SFTP Server to HDFS or OBS
- Typical Scenario: Importing Data from an SFTP Server to HBase
- Typical Scenario: Importing Data from an SFTP Server to Hive
- Typical Scenario: Importing Data from an FTP Server to HBase
- Typical Scenario: Importing Data from a Relational Database to HDFS or OBS
- Typical Scenario: Importing Data from a Relational Database to HBase
- Typical Scenario: Importing Data from a Relational Database to Hive
- Typical Scenario: Importing Data from HDFS or OBS to HBase
- Typical Scenario: Importing Data from a Relational Database to ClickHouse
- Typical Scenario: Importing Data from HDFS to ClickHouse
Exporting Data
- Overview
- Using Loader to Export Data
- Typical Scenario: Exporting Data from HDFS or OBS to an SFTP Server
- Typical Scenario: Exporting Data from HBase to an SFTP Server
- Typical Scenario: Exporting Data from Hive to an SFTP Server
- Typical Scenario: Exporting Data from HDFS or OBS to a Relational Database
- Typical Scenario: Exporting Data from HBase to a Relational Database
- Typical Scenario: Exporting Data from Hive to a Relational Database
- Typical Scenario: Importing Data from HBase to HDFS or OBS
- Managing Jobs
- Operator Help
Client Tools
- Running a Loader Job by Using Commands
- loader-tool Usage Guide
- loader-tool Usage Example
- schedule-tool Usage Guide
- schedule-tool Usage Example
- Using loader-backup to Back Up Job Data
- Open Source sqoop-shell Tool Usage Guide
- Example for Using the Open-Source sqoop-shell Tool (SFTP-HDFS)
- Example for Using the Open-Source sqoop-shell Tool (Oracle-HBase)
- Loader Log Overview
- Example: Using Loader to Import Data from OBS to HDFS
- Common Issues About Loader
- Using Kudu
Using MapReduce
- Configuring the Log Archiving and Clearing Mechanism
- Reducing Client Application Failure Rate
- Transmitting MapReduce Tasks from Windows to Linux
- Configuring the Distributed Cache
- Configuring the MapReduce Shuffle Address
- Configuring the Cluster Administrator List
- Introduction to MapReduce Logs
- MapReduce Performance Tuning
Common Issues About MapReduce
- Why Does a MapReduce Task Stay Unchanged for a Long Time?
- Why the Client Hangs During Job Running?
- Why Cannot HDFS_DELEGATION_TOKEN Be Found in the Cache?
- How Do I Set the Task Priority When Submitting a MapReduce Task?
- Why Physical Memory Overflow Occurs If a MapReduce Task Fails?
- After the Address of MapReduce JobHistoryServer Is Changed, Why the Wrong Page is Displayed When I Click the Tracking URL on the ResourceManager WebUI?
- MapReduce Job Failed in Multiple NameService Environment
- Why a Fault MapReduce Node Is Not Blacklisted?
- Using OpenTSDB
Using Oozie
- Using Oozie from Scratch
- Using the Oozie Client
- Using Oozie Client to Submit an Oozie Job
Using Hue to Submit an Oozie Job
- Creating a Workflow
Submitting a Workflow Job
- Submitting a Hive2 Job
- Submitting a Spark2x Job
- Submitting a Java Job
- Submitting a Loader Job
- Submitting a MapReduce Job
- Submitting a Sub-workflow Job
- Submitting a Shell Job
- Submitting an HDFS Job
- Submitting a Streaming Job
- Submitting a DistCp Job
- Example of Mutual Trust Operations
- Submitting an SSH Job
- Submitting a Hive Script
- Submitting a Coordinator Periodic Scheduling Job
- Submitting a Bundle Batch Processing Job
- Querying Job Execution Results
- Oozie Log Overview
- Common Issues About Oozie
- Using Presto
- Using Ranger (MRS 1.9.2)
Using Ranger (MRS 3.x)
- Logging In to the Ranger Web UI
- Enabling Ranger Authentication
- Configuring Component Permission Policies
- Viewing Ranger Audit Information
- Configuring a Security Zone
- Viewing Ranger Permission Information
- Adding a Ranger Access Permission Policy for HDFS
- Adding a Ranger Access Permission Policy for HBase
- Adding a Ranger Access Permission Policy for Hive
- Adding a Ranger Access Permission Policy for Yarn
- Adding a Ranger Access Permission Policy for Spark2x
- Adding a Ranger Access Permission Policy for Kafka
- Adding a Ranger Access Permission Policy for Storm
- Ranger Log Overview
Common Issues About Ranger
- Why Ranger Startup Fails During the Cluster Installation?
- How Do I Determine Whether the Ranger Authentication Is Used for a Service?
- Why Cannot a New User Log In to Ranger After Changing the Password?
- When an HBase Policy Is Added or Modified on Ranger, Wildcard Characters Cannot Be Used to Search for Existing HBase Tables
- Using Spark
Using Spark2x
- Precautions
Basic Operation
- Getting Started
- Configuring Parameters Rapidly
- Common Parameters
- Spark on HBase Overview and Basic Applications
- Spark on HBase V2 Overview and Basic Applications
- SparkSQL Permission Management(Security Mode)
Scenario-Specific Configuration
- Configuring Multi-active Instance Mode
- Configuring the Multi-tenant Mode
- Configuring the Switchover Between the Multi-active Instance Mode and the Multi-tenant Mode
- Configuring the Size of the Event Queue
- Configuring Executor Off-Heap Memory
- Enhancing Stability in a Limited Memory Condition
- Viewing Aggregated Container Logs on the Web UI
- Configuring Environment Variables in Yarn-Client and Yarn-Cluster Modes
- Configuring the Default Number of Data Blocks Divided by SparkSQL
- Configuring the Compression Format of a Parquet Table
- Configuring the Number of Lost Executors Displayed in WebUI
- Setting the Log Level Dynamically
- Configuring Whether Spark Obtains HBase Tokens
- Configuring LIFO for Kafka
- Configuring Reliability for Connected Kafka
- Configuring Streaming Reading of Driver Execution Results
- Filtering Partitions without Paths in Partitioned Tables
- Configuring Spark2x Web UI ACLs
- Configuring Vector-based ORC Data Reading
- Broaden Support for Hive Partition Pruning Predicate Pushdown
- Hive Dynamic Partition Overwriting Syntax
- Configuring the Column Statistics Histogram to Enhance the CBO Accuracy
- Configuring Local Disk Cache for JobHistory
- Configuring Spark SQL to Enable the Adaptive Execution Feature
- Configuring Event Log Rollover
- Adapting to the Third-party JDK When Ranger Is Used
- Spark2x Logs
- Obtaining Container Logs of a Running Spark Application
- Small File Combination Tools
- Using CarbonData for First Query
Spark2x Performance Tuning
- Spark Core Tuning
Spark SQL and DataFrame Tuning
- Optimizing the Spark SQL Join Operation
- Improving Spark SQL Calculation Performance Under Data Skew
- Optimizing Spark SQL Performance in the Small File Scenario
- Optimizing the INSERT...SELECT Operation
- Multiple JDBC Clients Concurrently Connecting to JDBCServer
- Optimizing Memory when Data Is Inserted into Dynamic Partitioned Tables
- Optimizing Small Files
- Optimizing the Aggregate Algorithms
- Optimizing Datasource Tables
- Merging CBO
- Optimizing SQL Query of Data of Multiple Sources
- SQL Optimization for Multi-level Nesting and Hybrid Join
- Spark Streaming Tuning
Common Issues About Spark2x
Spark Core
- How Do I View Aggregated Spark Application Logs?
- Why Cannot Exit the Driver Process?
- Why Does FetchFailedException Occur When the Network Connection Is Timed out
- How to Configure Event Queue Size If Event Queue Overflows?
- What Can I Do If the getApplicationReport Exception Is Recorded in Logs During Spark Application Execution and the Application Does Not Exit for a Long Time?
- What Can I Do If "Connection to ip:port has been quiet for xxx ms while there are outstanding requests" Is Reported When Spark Executes an Application and the Application Ends?
- Why Do Executors Fail to be Removed After the NodeManeger Is Shut Down?
- What Can I Do If the Message "Password cannot be null if SASL is enabled" Is Displayed?
- What Should I Do If the Message "Failed to CREATE_FILE" Is Displayed in the Restarted Tasks When Data Is Inserted Into the Dynamic Partition Table?
- Why Tasks Fail When Hash Shuffle Is Used?
- What Can I Do If the Error Message "DNS query failed" Is Displayed When I Access the Aggregated Logs Page of Spark Applications?
- What Can I Do If Shuffle Fetch Fails Due to the "Timeout Waiting for Task" Exception?
- Why Does the Stage Retry due to the Crash of the Executor?
- Why Do the Executors Fail to Register Shuffle Services During the Shuffle of a Large Amount of Data?
- Why Does the Out of Memory Error Occur in NodeManager During the Execution of Spark Applications
- Why Does the Realm Information Fail to Be Obtained When SparkBench is Run on HiBench for the Cluster in Security Mode?
- What Do I have to Note When Using Spark SQL ROLLUP and CUBE?
- Why Spark SQL Is Displayed as a Temporary Table in Different Databases?
- How to Assign a Parameter Value in a Spark Command?
- What Directory Permissions Do I Need to Create a Table Using SparkSQL?
- Why Do I Fail to Delete the UDF Using Another Service?
- Why Cannot I Query Newly Inserted Data in a Parquet Hive Table Using SparkSQL?
- How to Use Cache Table?
- Why Are Some Partitions Empty During Repartition?
- Why Does 16 Terabytes of Text Data Fails to Be Converted into 4 Terabytes of Parquet Data?
- Why the Operation Fails When the Table Name Is TABLE?
- Why Is a Task Suspended When the ANALYZE TABLE Statement Is Executed and Resources Are Insufficient?
- If I Access a parquet Table on Which I Do not Have Permission, Why a Job Is Run Before "Missing Privileges" Is Displayed?
- Why Do I Fail to Modify MetaData by Running the Hive Command?
- Why Is "RejectedExecutionException" Displayed When I Exit Spark SQL?
- How Do I Do If I Incidentally Kill the JDBCServer Process During Health Check?
- Why No Result Is found When 2016-6-30 Is Set in the Date Field as the Filter Condition?
- Why Does the "--hivevar" Option I Specified in the Command for Starting spark-beeline Fail to Take Effect?
- Why Does the "Permission denied" Exception Occur When I Create a Temporary Table or View in Spark-beeline?
- Why Is the "Code of method ... grows beyond 64 KB" Error Message Displayed When I Run Complex SQL Statements?
- Why Is Memory Insufficient if 10 Terabytes of TPCDS Test Suites Are Consecutively Run in Beeline/JDBCServer Mode?
- Why Functions Cannot Be Used When Different JDBCServers Are Connected?
- Why Does an Exception Occur When I Drop Functions Created Using the Add Jar Statement?
- Why Does Spark2x Have No Access to DataSource Tables Created by Spark1.5?
- Why Does Spark-beeline Fail to Run and Error Message "Failed to create ThriftService instance" Is Displayed?
- Why Cannot I Query Newly Inserted Data in an ORC Hive Table Using Spark SQL?
Spark Streaming
- Same DAG Log Is Recorded Twice for a Streaming Task
- What Can I Do If Spark Streaming Tasks Are Blocked?
- What Should I Pay Attention to When Optimizing Spark Streaming Task Parameters?
- Why Does the Spark Streaming Application Fail to Be Submitted After the Token Validity Period Expires?
- Why does Spark Streaming Application Fail to Restart from Checkpoint When It Creates an Input Stream Without Output Logic?
- Why Is the Input Size Corresponding to Batch Time on the Web UI Set to 0 Records When Kafka Is Restarted During Spark Streaming Running?
- Why the Job Information Obtained from the restful Interface of an Ended Spark Application Is Incorrect?
- Why Cannot I Switch from the Yarn Web UI to the Spark Web UI?
- What Can I Do If an Error Occurs when I Access the Application Page Because the Application Cached by HistoryServer Is Recycled?
- Why Is not an Application Displayed When I Run the Application with the Empty Part File?
- Why Does Spark2x Fail to Export a Table with the Same Field Name?
- Why JRE fatal error after running Spark application multiple times?
- Native Spark2x UI Fails to Be Accessed or Is Incorrectly Displayed when Internet Explorer Is Used for Access
- How Does Spark2x Access External Cluster Components?
- Why Does the Foreign Table Query Fail When Multiple Foreign Tables Are Created in the Same Directory?
- Why Is the Native Page of an Application in Spark2x JobHistory Displayed Incorrectly?
- Why Do I Fail to Create a Table in the Specified Location on OBS After Logging to spark-beeline?
- Spark Shuffle Exception Handling
Spark Core
Using Sqoop
- Using Sqoop from Scratch
- Adapting Sqoop 1.4.7 to MRS 3.x Clusters
- Common Sqoop Commands and Parameters
Common Issues About Sqoop
- What Should I Do If Class QueryProvider Is Unavailable?
- How Do I Do If PostgreSQL or GaussDB Fails to Connect?
- What Should I Do If Data Failed to Be Synchronized to a Hive Table on the OBS Using hive-table?
- What Should I Do If Data Failed to Be Synchronized to an ORC or Parquet Table Using hive-table?
- What Should I Do If Data Failed to Be Synchronized Using hive-table?
- What Should I Do If Data Failed to Be Synchronized to a Hive Parquet Table Using HCatalog?
- What Should I Do If the Data Type of Fields timestamp and data Is Incorrect During Data Synchronization Between Hive and MySQL?
Using Storm
- Using Storm from Scratch
- Using the Storm Client
- Submitting Storm Topologies on the Client
- Accessing the Storm Web UI
- Managing Storm Topologies
- Querying Storm Topology Logs
- Storm Common Parameters
- Configuring a Storm Service User Password Policy
- Migrating Storm Services to Flink
- Storm Log Introduction
- Using Tez
Using YARN
- Common YARN Parameters
- Creating Yarn Roles
- Using the YARN Client
- Configuring Resources for a NodeManager Role Instance
- Changing NodeManager Storage Directories
- Configuring Strict Permission Control for Yarn
- Configuring Container Log Aggregation
- Using CGroups with YARN
- Configuring the Number of ApplicationMaster Retries
- Configure the ApplicationMaster to Automatically Adjust the Allocated Memory
- Configuring the Access Channel Protocol
- Configuring Memory Usage Detection
- Configuring the Additional Scheduler WebUI
- Configuring Yarn Restart
- Configuring ApplicationMaster Work Preserving
- Configuring the Localized Log Levels
- Configuring Users That Run Tasks
- Yarn Log Overview
- Yarn Performance Tuning
Common Issues About Yarn
- Why Mounted Directory for Container is Not Cleared After the Completion of the Job While Using CGroups?
- Why the Job Fails with HDFS_DELEGATION_TOKEN Expired Exception?
- Why Are Local Logs Not Deleted After YARN Is Restarted?
- Why the Task Does Not Fail Even Though AppAttempts Restarts for More Than Two Times?
- Why Is an Application Moved Back to the Original Queue After ResourceManager Restarts?
- Why Does Yarn Not Release the Blacklist Even All Nodes Are Added to the Blacklist?
- Why Does the Switchover of ResourceManager Occur Continuously?
- Why Does a New Application Fail If a NodeManager Has Been in Unhealthy Status for 10 Minutes?
- Why Does an Error Occur When I Query the ApplicationID of a Completed or Non-existing Application Using the RESTful APIs?
- Why May A Single NodeManager Fault Cause MapReduce Task Failures in the Superior Scheduling Mode?
- Why Are Applications Suspended After They Are Moved From Lost_and_Found Queue to Another Queue?
- How Do I Limit the Size of Application Diagnostic Messages Stored in the ZKstore?
- Why Does a MapReduce Job Fail to Run When a Non-ViewFS File System Is Configured as ViewFS?
- Why Do Reduce Tasks Fail to Run in Some OSs After the Native Task Feature is Enabled?
Using ZooKeeper
- Using ZooKeeper from Scratch
- Common ZooKeeper Parameters
- Using a ZooKeeper Client
- Configuring the ZooKeeper Permissions
- ZooKeeper Log Overview
Common Issues About ZooKeeper
- Why Do ZooKeeper Servers Fail to Start After Many znodes Are Created?
- Why Does the ZooKeeper Server Display the java.io.IOException: Len Error Log?
- Why Four Letter Commands Don't Work With Linux netcat Command When Secure Netty Configurations Are Enabled at Zookeeper Server?
- How Do I Check Which ZooKeeper Instance Is a Leader?
- Why Cannot the Client Connect to ZooKeeper using the IBM JDK?
- What Should I Do When the ZooKeeper Client Fails to Refresh a TGT?
- Why Is Message "Node does not exist" Displayed when A Large Number of Znodes Are Deleted Using the deleteallCommand
- Appendix
- Before You Start
- API Overview
- Calling APIs
- Application Cases
- API V2
- API V1.1
- Out-of-Date APIs
- Appendix
User Guide (Paris Region)
Overview
- What Is MRS?
- Components
- Functions
- Constraints
- Related Services
- Preparing a User
- Quick Creation of a Cluster
- Creating a Custom Topology Cluster
- Overview
- Configuring Auto Scaling During Cluster Creation
- Creating an Auto Scaling Policy for an Existing Cluster
- Scenario 1: Using Auto Scaling Rules Alone
- Scenario 2: Using Resource Plans Alone
- Scenario 3: Using Both Auto Scaling Rules and Resource Plans
- Modifying an Auto Scaling Policy
- Deleting an Auto Scaling Policy
- Enabling or Disabling an Auto Scaling Policy
- Viewing an Auto Scaling Policy
- Configuring Automation Scripts
- Configuring Auto Scaling Metrics
- Managing Data Connections
- Installing Third-Party Software Using Bootstrap Actions
- Viewing Failed MRS Tasks
- Viewing Information of a Historical Cluster
Managing Clusters
- Logging In to a Cluster
- Cluster Overview
- Cluster O&M
- Managing Nodes
Job Management
- Stopping a Job
- Deleting a Job
Component Management
- Object Management
- Managing Services
- Alarm Management
- Patch Management
Tenant Management
- Before You Start
- Overview
- Creating a Tenant
- Deleting a Tenant
- Bootstrap Actions
- Configuring a Cluster with Storage and Compute Decoupled
- Accessing Web Pages of Open Source Components Managed in MRS Clusters
- Interconnecting Jupyter Notebook with MRS Using Custom Python
- Accessing Manager
- Getting Started
- Homepage
Cluster
- Hosts
- O&M
- Audit
- Tenant Resources
- System
- Log Management
- Introduction
Backing Up Data
- Backing Up Manager Data
- Backing Up CDL Data
- Backing Up ClickHouse Metadata
- Backing Up ClickHouse Service Data
- Backing Up DBService Data
- Backing Up HBase Metadata
- Backing Up HBase Service Data
- Backing Up NameNode Data
- Backing Up HDFS Service Data
- Backing Up Hive Service Data
- Backing Up IoTDB Metadata
- Backing Up IoTDB Service Data
- Backing Up Kafka Metadata
Recovering Data
- Restoring Manager Data
- Restoring CDL Data
- Restoring ClickHouse Metadata
- Restoring ClickHouse Service Data
- Restoring DBService data
- Restoring HBase Metadata
- Restoring HBase Service Data
- Restoring NameNode Data
- Restoring HDFS Service Data
- Restoring Hive Service Data
- Restoring IoTDB Metadata
- Restoring IoTDB Service Data
- Restoring Kafka Metadata
- Enabling Cross-Cluster Replication
- Managing Local Quick Restoration Tasks
- Modifying a Backup Task
- Viewing Backup and Restoration Tasks
- How Do I Configure the Environment When I Create a ClickHouse Backup Task on FusionInsight Manager and Set the Path Type to RemoteHDFS?
Security Management
- Security Overview
Security Hardening
- Hardening Policies
- Configuring Hadoop Security Parameters
- Configuring an IP Address Whitelist for Modification Allowed by HBase
- Encrypting the Communication Between the Controller and the Agent
- Alarm Management
Object Management
- Managing Objects
- Managing Services
- Managing a Host
- Isolating a Host
- Log Management
Tenant Management
- Overview
- Creating a Tenant
- Deleting a tenant
Security Management
- Replacing the HA Certificate
- Creating a Role
- Creating a User
- Locking a User
- Unlocking a User
- Deleting a User
- Rolling Restart
- Security Description
- MRS Quick Start
Troubleshooting
Cluster Management
- Failed to Reduce Task Nodes
- Replacing a Disk in an MRS Cluster (Applicable to 2.x and Earlier)
- Replacing a Disk in an MRS Cluster (Applicable to 3.x)
- Inconsistency Between df and du Command Output on the Core Node
- Failed to Download the MRS Cluster Client
- High Memory Usage of the Knox Process
- OS Disk Space Is Insufficient Due to Oversized HBase Log Files
- Failed to Delete a New Tenant on FusionInsight Manager
- Using Alluixo
- Using ClickHouse
Using DBService
- DBServer Instance Is in Abnormal Status
- DBServer Instance Remains in the Restoring State
- DBServer Instance Is Always in the Restoring State Because the Incorrect /tmp Directory Permission
- Components Failed to Connect to DBService in Normal State
- DBServer Failed to Start
- DBService Backup Failed Because the Floating IP Address Is Unreachable
- DBService Failed to Start Due to the Loss of the DBService Configuration File
Using Flink
- Flink Service Program Fails to Read Files on the NFS Disk
- Failed to Customize the Flink Log4j Log Level
- Using Flume
Using HBase
- Slow Response to HBase Connection
- Failed to Authenticate the HBase User
- RegionServer Failed to Start Because the Port Is Occupied
- HBase Failed to Start Due to Insufficient Node Memory
- HBase Service Unavailable Due to Poor HDFS Performance
- HBase Failed to Start Due to Inappropriate Parameter Settings
- RegionServer Failed to Start Due to Residual Processes
- HBase Failed to Start Due to a Quota Set on HDFS
- HBase Failed to Start Due to Corrupted Version Files
- High CPU Usage Caused by Zero-Loaded RegionServer
- The Number of RegionServers Displayed on the Native Page Is Greater Than the Actual Number After HBase Is Started
- RegionServer Instance Is in the Restoring State
- HBase Failed to Start in a Newly Installed Cluster
- HBase Failed to Start Due to the Loss of the ACL Table Directory
- HBase Failed to Start After the Cluster Is Powered Off and On
- Failed to Import HBase Data Due to Oversized File Blocks
- Failed to Load Data to the Index Table After an HBase Table Is Created Using Phoenix
- Failed to Run the hbase shell Command on the MRS Cluster Client
- Disordered Information Display on the HBase Shell Client Console Due to Printing of the INFO Information
- HBase Failed to Start Due to Insufficient RegionServer Memory
Using HDFS
- Failed to Use Python to Remotely Connect to the Port of HDFS
- A DataNode of HDFS Is Always in the Decommissioning State
- A Large Number of Blocks Are Lost in HDFS due to the Time Change Using ntpdate
- Manually Performing Checkpoints When a NameNode Is Faulty for a Long Time
- Maximum Number of File Handles Is Set to a Too Small Value, Causing File Reading and Writing Exceptions
- File Fails to Be Uploaded to HDFS Due to File Errors
- Failed to Write Files Because the HDFS Directory Quota Is Insufficient
- Uneven Data Distribution Due to Non-HDFS Data Residuals
- Locating Common Balance Problems
- HDFS Displays Insufficient Disk Space But 10% Disk Space Remains
- Insufficient Number of Replicas Is Reported During High Concurrent HDFS Writes
- HDFS Client Failed to Delete Overlong Directories
- An Error Is Reported When a Node Outside the Cluster Accesses MRS HDFS
Using Hive
- NULL Is Displayed When Data Is Inserted After the Partition Column Is Added
- An Error Is Reported When SQL Is Executed to Submit a Task to a Specified Queue
- An Error Is Reported When the "load data inpath" Command Is Executed
- An Error Is Reported When the "load data local inpath" Command Is Executed
- An Error Is Reported When the dfs -put Command Is Executed on the Beeline Client
- Insufficient Permissions to Execute the set role admin Command
- Difference Between Hive Service Health Status and Hive Instance Health Status
- "authentication failed" Is Displayed During an Attempt to Connect to the Shell Client
- Failed to Access ZooKeeper from the Client
- "Invalid function" Is Displayed When a UDF Is Used
- Hive Service Status Is Unknown
- Health Status of a HiveServer or MetaStore Instance Is Concerning
- Task Execution Fails Because the Input File Number Exceeds the Threshold
- Task Failed Due to Concurrent Writes to One Table or Partition
- Hive Task Failed Due to a Lack of HDFS Directory Permission
- Failed to Load Data to Hive Tables
- HiveServer and HiveHCat Process Faults
- Timeout Reported When Adding the Hive Table Field
- WebHCat Failed to Start Due to Abnormal Health Status
- WebHCat Failed to Start Because the mapred-default.xml File Cannot Be Parsed
- Using Hue
- Using Impala
Using Kafka
- Producer Occasionally Fails to Send Data and the Log Displays "Too many open files in system"
- Consumer Fails to Consume Data and Remains in the Waiting State
- SparkStreaming Fails to Consume Kafka Messages, and "Error getting partition metadata" Is Displayed
- Kafka Broker Reports Abnormal Processes and the Log Shows "IllegalArgumentException"
- Kafka Topics Cannot Be Deleted
- Error "AdminOperationException" Is Displayed When a Kafka Topic Is Deleted
- When a Kafka Topic Fails to Be Created, "NoAuthException" Is Displayed
- Failed to Set an ACL for a Kafka Topic, and "NoAuthException" Is Displayed
- When a Kafka Topic Fails to Be Created, "NoNode for /brokers/ids" Is Displayed
- When a Kafka Topic Fails to Be Created, "replication factor larger than available brokers" Is Displayed
- Consumer Repeatedly Consumes Data
- Leader for the Created Kafka Topic Partition Is Displayed as none
- Safety Instructions on Using Kafka
- Obtaining Kafka Consumer Offset Information
- Adding or Deleting Configurations for a Topic
- Reading the Content of the __consumer_offsets Internal Topic
- Obtaining Topic Distribution Information
- Kafka HA Usage Description
- Kafka Producer Writes Oversized Records
- Kafka Consumer Reads Oversized Records
- High Usage of Multiple Disks on a Kafka Cluster Node
- Using Oozie
- Using Presto
Using Spark
- A Spark Job Fails to Run Due to Incorrect JAR File Import
- Failed to Start spark-sql and spark-shell Due to JDK Version Mismatch
- Failed to Connect to ResourceManager When a Spark Task Is Submitted
- DataArts Studio Failed to Schedule Spark Jobs
- Failed to Create or Delete a Table in Spark Beeline
- Large Number of Shuffle Results Are Lost During Spark Task Execution
- Disk Space Is Insufficient Due to Long-Term Running of JDBCServer
- Failed to Load Data to a Hive Table Across File Systems by Running SQL Statements Using Spark Shell
- Spark Task Submission Failure
- Spark Task Execution Failure
- JDBCServer Connection Failure
- Failed to View Spark Task Logs
- Authentication Fails When Spark Connects to Other Services
- An Error Is Reported When spark-beeline Is Used to Query a Hive View
Using Sqoop
- Connecting Sqoop to MySQL
- Failed to Find the HBaseAdmin.<init> Method When Sqoop Reads Data from the MySQL Database to HBase
Using Storm
- "well-known file is not secure" Is Displayed When the jstack Command Is Used to Check the Process Stack
- Using Ranger
Using Yarn
- Using ZooKeeper
- Accessing OBS
- Appendix
- Change History
Overview
Component Operation Guide (Paris Region)
- Overview
CarbonData FAQ
- Using ClickHouse
- Using DBService
Using Flink
- Using Flink from Scratch
- Viewing Flink Job Information
- Flink Configuration Management
- Security Hardening
- Using the Flink Web UI
- Flink Log Overview
- Flink Performance Tuning
- Common Flink Shell Commands
Using Flume
- Overview
Using HBase
- GeoMesa Command Line
- Using HIndex
Using HDFS
- Configuring NFS
FAQ
Using Hive
- Hive SQL
- Hive Log Overview
Using Hudi
- Getting Started
- Basic Operations
Data Write
- Data Collection
Data Write
- Typical Scenarios
- Hue Log Overview
- How Do I Solve the Problem that HQL Fails to Be Executed in Hue Using Internet Explorer?
- Why Does the use database Statement Become Invalid When Hive Is Used?
- What Can I Do If HDFS Files Fail to Be Accessed Using Hue WebUI?
- How Do I Do If a Large File Fails to Upload on the Hue Page?
- Using Impala
Using Kafka
Using Loader
- How to Use Loader
- Using Kudu
Using MapReduce
- Why Does It Take a Long Time to Run a Task Upon ResourceManager Active/Standby Switchover?
- Using OpenTSDB
Using Oozie
- Querying the Operation Results
- Using Presto
- Changing the Ranger Data Source to LDAP for a Normal Cluster
- Using Spark
Using Spark2x
- Precautions
Basic Operation
- Getting Started
- Common Parameters
- Spark2x Logs
- Spark Core Tuning
- Merging CBO
Spark Core
- Why Is the Return Code of Driver Inconsistent with Application State Displayed on ResourceManager WebUI?
- What Should I Do If the JDBCServer Process is Mistakenly Killed During a Health Check?
- Why Are Some Functions Not Available when Another JDBCServer Is Connected?
Spark Streaming
- "This page can't be displayed" Is Displayed When Internet Explorer Fails to Access the Native Spark2x UI
- What Should I Do If the Native Page of an Application of Spark2x JobHistory Fails to Display During Access to the Page
Spark Core
Using Sqoop
Using Storm
- Using Tez
Using Yarn
- Yarn Log Overview
Using ZooKeeper
- Appendix
Component Operation Guide (LTS) (Paris Region)
Using CarbonData
- Overview
CarbonData FAQ
- Why INSERT INTO/LOAD DATA Task Distribution Is Incorrect and the Opened Tasks Are Less Than the Available Executors when the Number of Initial Executors Is Zero?
Using ClickHouse
- CREATE DATABASE: Creating a Database
- CREATE TABLE: Creating a Table
- INSERT INTO: Inserting Data into a Table
- SELECT: Querying Table Data
- ALTER TABLE: Modifying a Table Structure
- DESC: Querying a Table Structure
- DROP: Deleting a Table
- SHOW: Displaying Information About Databases and Tables
- Importing and Exporting File Data
- Using the ClickHouse Data Migration Tool
- Monitoring of Slow ClickHouse Query Statements and Replication Table Data Synchronization
- Adaptive MV Usage in ClickHouse
- Using DBService
Using Flink
- Overview
- FlinkServer Permissions Management
- Accessing the Flink Web UI
- Creating an Application on the Flink Web UI
- Creating a Cluster Connection on the Flink Web UI
- Creating a Data Connection on the Flink Web UI
- Managing Tables on the Flink Web UI
- Managing Jobs on the Flink Web UI
- Managing UDFs on the Flink Web UI
- Interconnecting FlinkServer with External Components
- Deleting Residual Information About Flink Tasks
Using Flume
- Overview
- Installing the Flume Client on Clusters
Using HBase
- Supporting Full-Text Index
- Using HIndex
Using HDFS
- Configuring NFS
FAQ
- Why MapReduce Tasks Fails in the Environment with Multiple NameServices?
- Why Does an Error Occur During DataNode Capacity Calculation When Multiple data.dir Are Configured in a Partition?
Using HetuEngine
- Using HetuEngine from Scratch
- HetuEngine Permission Management
- Creating HetuEngine Compute Instances
- Configuring Data Sources
- Managing Data Sources
Managing Compute Instances
- Configuring Resource Groups
- Adjusting the Number of Worker Nodes
- Managing a HetuEngine Compute Instance
- Importing and Exporting Compute Instance Configurations
- Viewing the Instance Monitoring Page
- Viewing Coordinator and Worker Logs
- Using Resource Labels to Specify on Which Node Coordinators Should Run
- Using the HetuEngine Client
- Using the HetuEngine Cross-Source Function
- Using HetuEngine Cross-Domain Function
- Using a Third-Party Visualization Tool to Access HetuEngine
- Function & UDF Development and Application
- Introduction to HetuEngine Logs
- HetuEngine Performance Tuning
- Common Issues About HetuEngine
Using Hive
- Hive SQL
- Connecting Hive with External RDS
- Redis-based CacheStore of HiveMetaStore
- Hive Supporting Reading Hudi Tables
- Hive Supporting Cold and Hot Storage of Partitioned Metadata
- Hive Supporting ZSTD Compression Formats
- Hive Log Overview
- Using Hudi
Using Hue
- Typical Scenarios
- Hue Log Overview
- What Should I Do If a Large File Fails to Be Uploaded on the Hue Page?
- Hue Page Cannot Be Displayed When the Hive Service Is Not Installed in a Cluster
Using Kafka
- Using Kafka UI
Using Loader
Importing Data
- Overview
- Typical Scenario: Importing Data from an SFTP Server to Spark
- Typical Scenario: Importing Data from a Relational Database to Spark
Exporting Data
- Overview
- Typical Scenario: Exporting Data from HDFS/OBS to an SFTP Server
- Typical Scenario: Exporting Data from Spark to an SFTP Server
- Typical Scenario: Exporting Data from HDFS/OBS to a Relational Database
- Typical Scenario: Exporting Data from Spark to a Relational Database
- Typical Scenario: Importing Data from HBase to HDFS/OBS
- Job Management
- Operator Help
Client Tool Description
Using MapReduce
- Converting MapReduce from the Single Instance Mode to the HA Mode
Using Oozie
- Enabling Oozie High Availability (HA)
- Submitting an Email Job
Using Ranger
- Adding a Ranger Access Permission Policy for HetuEngine
Using Spark2x
Basic Operation
- Getting Started
- Common Parameters
- Configuring Whether to Display Spark SQL Statements Containing Sensitive Words
- Spark2x Logs
- Spark Core Tuning
- Merging CBO
- Spark on OBS Tuning
Spark Core
Spark Streaming
- Streaming Task Prints the Same DAG Log Twice
Spark Core
Basic Operation
- Using Tez
Using Yarn
- Common Yarn Parameters
- Using the Yarn Client
- Yarn Log Overview
- What Is the Queue Replacement Policy?
Using ZooKeeper
- Changing the ZooKeeper Storage Directory
- Configuring the ZooKeeper Connection
- Configuring ZooKeeper Response Timeout Interval
- Binding the Client to an IP Address
- Configuring the Port Range Bound to the Client
- Performing Special Configuration on ZooKeeper Clients in the Same JVM
- Configuring a Quota for a Znode
- Appendix
Using CarbonData
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
- Application Cases
- API V2
- API V1.1
- Out-of-Date APIs
- Appendix
- Change History
Overview
- What Is MRS?
- Advantages of MRS Compared with Self-Built Hadoop
- Application Scenarios
Components
- Alluxio
- CarbonData
- ClickHouse
- DBService
- Flink
- Flume
- HBase
- HDFS
- Hive
- Hue
- Impala
- Kafka
- KafkaManager
- KrbServer and LdapServer
- Kudu
- Loader
- Manager
- MapReduce
- Oozie
- OpenTSDB
- Presto
- Ranger
- Spark
- Spark2x
- Storm
- Tez
- Yarn
- ZooKeeper
- Functions
- Constraints
- Technical Support
- Permissions Management
- Related Services
- Common Concepts
- MRS Quick Start
- Preparing a User
- Methods of Creating MRS Clusters
- Creating a Custom Cluster
- Adding a Tag to a Cluster
- Communication Security Authorization
- Configuring an Auto Scaling Rule
- Installing the Third-Party Software Using Bootstrap Actions
Managing Clusters
- Cluster Overview
- Cluster O&M
- Managing Nodes
Job Management
- Introduction to MRS Jobs
- Running a MapReduce Job
- Running a SparkSubmit Job
- Running a HiveSQL Job
- Running a SparkSql Job
- Running a Flink Job
- Running a Kafka Job
- Viewing Job Configuration and Logs
- Stopping a Job
- Deleting a Job
- Using Encrypted OBS Data for Job Running
- Configuring Job Notification Rules
- Object Management
- Viewing Configuration
- Managing Services
- Configuring Service Parameters
- Configuring Customized Service Parameters
- Synchronizing Service Configuration
- Managing Role Instances
- Configuring Role Instance Parameters
- Synchronizing Role Instance Configuration
- Decommissioning and Recommissioning a Role Instance
- Starting and Stopping a Cluster
- Synchronizing Cluster Configuration
- Exporting Cluster Configuration
- Performing Rolling Restart
- Alarm Management
- Patch Management
Tenant Management
- Before You Start
- Overview
- Creating a Tenant
- Creating a Sub-tenant
- Deleting a Tenant
- Managing a Tenant Directory
- Restoring Tenant Data
- Creating a Resource Pool
- Modifying a Resource Pool
- Deleting a Resource Pool
- Configuring a Queue
- Configuring the Queue Capacity Policy of a Resource Pool
- Clearing Configuration of a Queue
- Using an MRS Client
- Accessing Manager
FusionInsight Manager Operation Guide (Applicable to 3.x)
- Getting Started
- Homepage
Cluster
- Cluster Management
- Managing a Service
- Instance Management
- Hosts
- O&M
- Audit
- Tenant Resources
- System Configuration
- Log Management
- Backup and Recovery Management
Security Management
- Security Overview
- Account Management
Security Hardening
- Hardening Policy
- Configuring a Trusted IP Address to Access LDAP
- HFile and WAL Encryption
- Security Configuration
- Configuring an IP Address Whitelist for Modifications Allowed by HBase
- Updating a Key for a Cluster
- Hardening the LDAP
- Configuring Kafka Data Encryption During Transmission
- Configuring HDFS Data Encryption During Transmission
- Encrypting the Communication Between Controller and Agent
- Updating SSH Keys for User omm
- Security Maintenance
- Security Statement
Alarm Reference (Applicable to MRS 3.x)
- ALM-12001 Audit Log Dumping Failure
- ALM-12004 OLdap Resource Abnormal
- ALM-12005 OKerberos Resource Abnormal
- ALM-12006 Node Fault
- ALM-12007 Process Fault
- ALM-12010 Manager Heartbeat Interruption Between the Active and Standby Nodes
- ALM-12011 Manager Data Synchronization Exception Between the Active and Standby Nodes
- ALM-12014 Partition Lost
- ALM-12015 Partition Filesystem Readonly
- ALM-12016 CPU Usage Exceeds the Threshold
- ALM-12017 Insufficient Disk Capacity
- ALM-12018 Memory Usage Exceeds the Threshold
- ALM-12027 Host PID Usage Exceeds the Threshold
- ALM-12028 The number of processes that are in the D state on the host exceeds the threshold
- ALM-12033 Slow Disk Fault
- ALM-12034 Periodical Backup Failure
- ALM-12035 Unknown Data Status After Recovery Task Failure
- ALM-12038 Monitoring Indicator Dumping Failure
- ALM-12039 Active/Standby OMS Databases Not Synchronized
- ALM-12040 Insufficient System Entropy
- ALM-12041 Incorrect Permission on Key Files
- ALM-12042 Incorrect Configuration of Key Files
- ALM-12045 Network Read Packet Dropped Rate Exceeds the Threshold
- ALM-12046 Network Write Packet Dropped Rate Exceeds the Threshold
- ALM-12047 Network Read Packet Error Rate Exceeds the Threshold
- ALM-12048 Network Write Packet Error Rate Exceeds the Threshold
- ALM-12049 Network Read Throughput Rate Exceeds the Threshold
- ALM-12050 Network Write Throughput Rate Exceeds the Threshold
- ALM-12051 Disk Inode Usage Exceeds the Threshold
- ALM-12052 TCP Temporary Port Usage Exceeds the Threshold
- ALM-12053 Host File Handle Usage Exceeds the Threshold
- ALM-12054 Invalid Certificate File
- ALM-12055 The Certificate File Is About to Expire
- ALM-12057 Metadata Not Configured with the Task to Periodically Back Up Data to a Third-Party Server
- ALM-12061 Process Usage Exceeds the Threshold
- ALM-12062 OMS Parameter Configurations Mismatch with the Cluster Scale
- ALM-12063 Unavailable Disk
- ALM-12064 Host Random Port Range Conflicts with Cluster Used Port
- ALM-12066 Trust Relationships Between Nodes Become Invalid
- ALM-12067 Tomcat Resource Is Abnormal
- ALM-12068 ACS Resource Is Abnormal
- ALM-12069 AOS Resource Is Abnormal
- ALM-12070 Controller Resource Is Abnormal
- ALM-12071 Httpd Resource Is Abnormal
- ALM-12072 FloatIP Resource Is Abnormal
- ALM-12073 CEP Resource Is Abnormal
- ALM-12074 FMS Resource Is Abnormal
- ALM-12075 PMS Resource Is Abnormal
- ALM-12076 GaussDB Resource Is Abnormal
- ALM-12077 User omm Expired
- ALM-12078 Password of User omm Expired
- ALM-12079 User omm Is About to Expire
- ALM-12080 Password of User omm Is About to Expire
- ALM-12081User ommdba Expired
- ALM-12082 User ommdba Is About to Expire
- ALM-12083 Password of User ommdba Is About to Expire
- ALM-12084 Password of User ommdba Expired
- ALM-12085 Service Audit Log Dump Failure
- ALM-12087 System Is in the Upgrade Observation Period
- ALM-12089 Inter-Node Network Is Abnormal
- ALM-12101 AZ Unhealthy
- ALM-12102 AZ HA Component Is Not Deployed Based on DR Requirements
- ALM-12110 Failed to get ECS temporary ak/sk
- ALM-13000 ZooKeeper Service Unavailable
- ALM-13001 Available ZooKeeper Connections Are Insufficient
- ALM-13002 ZooKeeper Direct Memory Usage Exceeds the Threshold
- ALM-13003 GC Duration of the ZooKeeper Process Exceeds the Threshold
- ALM-13004 ZooKeeper Heap Memory Usage Exceeds the Threshold
- ALM-13005 Failed to Set the Quota of Top Directories of ZooKeeper Components
- ALM-13006 Znode Number or Capacity Exceeds the Threshold
- ALM-13007 Available ZooKeeper Client Connections Are Insufficient
- ALM-13008 ZooKeeper Znode Usage Exceeds the Threshold
- ALM-13009 ZooKeeper Znode Capacity Usage Exceeds the Threshold
- ALM-13010 Znode Usage of a Directory with Quota Configured Exceeds the Threshold
- ALM-14000 HDFS Service Unavailable
- ALM-14001 HDFS Disk Usage Exceeds the Threshold
- ALM-14002 DataNode Disk Usage Exceeds the Threshold
- ALM-14003 Number of Lost HDFS Blocks Exceeds the Threshold
- ALM-14006 Number of HDFS Files Exceeds the Threshold
- ALM-14007 NameNode Heap Memory Usage Exceeds the Threshold
- ALM-14008 DataNode Heap Memory Usage Exceeds the Threshold
- ALM-14009 Number of Dead DataNodes Exceeds the Threshold
- ALM-14010 NameService Service Is Abnormal
- ALM-14011 DataNode Data Directory Is Not Configured Properly
- ALM-14012 JournalNode Is Out of Synchronization
- ALM-14013 Failed to Update the NameNode FsImage File
- ALM-14014 NameNode GC Time Exceeds the Threshold
- ALM-14015 DataNode GC Time Exceeds the Threshold
- ALM-14016 DataNode Direct Memory Usage Exceeds the Threshold
- ALM-14017 NameNode Direct Memory Usage Exceeds the Threshold
- ALM-14018 NameNode Non-heap Memory Usage Exceeds the Threshold
- ALM-14019 DataNode Non-heap Memory Usage Exceeds the Threshold
- ALM-14020 Number of Entries in the HDFS Directory Exceeds the Threshold
- ALM-14021 NameNode Average RPC Processing Time Exceeds the Threshold
- ALM-14022 NameNode Average RPC Queuing Time Exceeds the Threshold
- ALM-14023 Percentage of Total Reserved Disk Space for Replicas Exceeds the Threshold
- ALM-14024 Tenant Space Usage Exceeds the Threshold
- ALM-14025 Tenant File Object Usage Exceeds the Threshold
- ALM-14026 Blocks on DataNode Exceed the Threshold
- ALM-14027 DataNode Disk Fault
- ALM-14028 Number of Blocks to Be Supplemented Exceeds the Threshold
- ALM-14029 Number of Blocks in a Replica Exceeds the Threshold
- ALM-16000 Percentage of Sessions Connected to the HiveServer to Maximum Number Allowed Exceeds the Threshold
- ALM-16001 Hive Warehouse Space Usage Exceeds the Threshold
- ALM-16002 Hive SQL Execution Success Rate Is Lower Than the Threshold
- ALM-16003 Background Thread Usage Exceeds the Threshold
- ALM-16004 Hive Service Unavailable
- ALM-16005 The Heap Memory Usage of the Hive Process Exceeds the Threshold
- ALM-16006 The Direct Memory Usage of the Hive Process Exceeds the Threshold
- ALM-16007 Hive GC Time Exceeds the Threshold
- ALM-16008 Non-Heap Memory Usage of the Hive Process Exceeds the Threshold
- ALM-16009 Map Number Exceeds the Threshold
- ALM-16045 Hive Data Warehouse Is Deleted
- ALM-16046 Hive Data Warehouse Permission Is Modified
- ALM-16047 HiveServer Has Been Deregistered from ZooKeeper
- ALM-16048 Tez or Spark Library Path Does Not Exist
- ALM-17003 Oozie Service Unavailable
- ALM-17004 Oozie Heap Memory Usage Exceeds the Threshold
- ALM-17005 Oozie Non Heap Memory Usage Exceeds the Threshold
- ALM-17006 Oozie Direct Memory Usage Exceeds the Threshold
- ALM-17007 Garbage Collection (GC) Time of the Oozie Process Exceeds the Threshold
- ALM-18000 Yarn Service Unavailable
- ALM-18002 NodeManager Heartbeat Lost
- ALM-18003 NodeManager Unhealthy
- ALM-18008 Heap Memory Usage of ResourceManager Exceeds the Threshold
- ALM-18009 Heap Memory Usage of JobHistoryServer Exceeds the Threshold
- ALM-18010 ResourceManager GC Time Exceeds the Threshold
- ALM-18011 NodeManager GC Time Exceeds the Threshold
- ALM-18012 JobHistoryServer GC Time Exceeds the Threshold
- ALM-18013 ResourceManager Direct Memory Usage Exceeds the Threshold
- ALM-18014 NodeManager Direct Memory Usage Exceeds the Threshold
- ALM-18015 JobHistoryServer Direct Memory Usage Exceeds the Threshold
- ALM-18016 Non Heap Memory Usage of ResourceManager Exceeds the Threshold
- ALM-18017 Non Heap Memory Usage of NodeManager Exceeds the Threshold
- ALM-18018 NodeManager Heap Memory Usage Exceeds the Threshold
- ALM-18019 Non Heap Memory Usage of JobHistoryServer Exceeds the Threshold
- ALM-18020 Yarn Task Execution Timeout
- ALM-18021 Mapreduce Service Unavailable
- ALM-18022 Insufficient Yarn Queue Resources
- ALM-18023 Number of Pending Yarn Tasks Exceeds the Threshold
- ALM-18024 Pending Yarn Memory Usage Exceeds the Threshold
- ALM-18025 Number of Terminated Yarn Tasks Exceeds the Threshold
- ALM-18026 Number of Failed Yarn Tasks Exceeds the Threshold
- ALM-19000 HBase Service Unavailable
- ALM-19006 HBase Replication Sync Failed
- ALM-19007 HBase GC Time Exceeds the Threshold
- ALM-19008 Heap Memory Usage of the HBase Process Exceeds the Threshold
- ALM-19009 Direct Memory Usage of the HBase Process Exceeds the Threshold
- ALM-19011 RegionServer Region Number Exceeds the Threshold
- ALM-19012 HBase System Table Directory or File Lost
- ALM-19013 Duration of Regions in transaction State Exceeds the Threshold
- ALM-19014 Capacity Quota Usage on ZooKeeper Exceeds the Threshold Severely
- ALM-19015 Quantity Quota Usage on ZooKeeper Exceeds the Threshold
- ALM-19016 Quantity Quota Usage on ZooKeeper Exceeds the Threshold Severely
- ALM-19017 Capacity Quota Usage on ZooKeeper Exceeds the Threshold
- ALM-19018 HBase Compaction Queue Exceeds the Threshold
- ALM-19019 Number of HBase HFiles to Be Synchronized Exceeds the Threshold
- ALM-19020 Number of HBase WAL Files to Be Synchronized Exceeds the Threshold
- ALM-20002 Hue Service Unavailable
- ALM-24000 Flume Service Unavailable
- ALM-24001 Flume Agent Exception
- ALM-24003 Flume Client Connection Interrupted
- ALM-24004 Exception Occurs When Flume Reads Data
- ALM-24005 Exception Occurs When Flume Transmits Data
- ALM-24006 Heap Memory Usage of Flume Server Exceeds the Threshold
- ALM-24007 Flume Server Direct Memory Usage Exceeds the Threshold
- ALM-24008 Flume Server Non-Heap Memory Usage Exceeds the Threshold
- ALM-24009 Flume Server Garbage Collection (GC) Time Exceeds the Threshold
- ALM-24010 Flume Certificate File Is Invalid or Damaged
- ALM-24011 Flume Certificate File Is About to Expire
- ALM-24012 Flume Certificate File Has Expired
- ALM-24013 Flume MonitorServer Certificate File Is Invalid or Damaged
- ALM-24014 Flume MonitorServer Certificate Is About to Expire
- ALM-24015 Flume MonitorServer Certificate File Has Expired
- ALM-25000 LdapServer Service Unavailable
- ALM-25004 Abnormal LdapServer Data Synchronization
- ALM-25005 nscd Service Exception
- ALM-25006 Sssd Service Exception
- ALM-25500 KrbServer Service Unavailable
- ALM-26051 Storm Service Unavailable
- ALM-26052 Number of Available Supervisors of the Storm Service Is Less Than the Threshold
- ALM-26053 Storm Slot Usage Exceeds the Threshold
- ALM-26054 Nimbus Heap Memory Usage Exceeds the Threshold
- ALM-27001 DBService Service Unavailable
- ALM-27003 DBService Heartbeat Interruption Between the Active and Standby Nodes
- ALM-27004 Data Inconsistency Between Active and Standby DBServices
- ALM-27005 Database Connections Usage Exceeds the Threshold
- ALM-27006 Disk Space Usage of the Data Directory Exceeds the Threshold
- ALM-27007 Database Enters the Read-Only Mode
- ALM-29000 Impala Service Unavailable
- ALM-29004 Impalad Process Memory Usage Exceeds the Threshold
- ALM-29005 Number of JDBC Connections to Impalad Exceeds the Threshold
- ALM-29006 Number of ODBC Connections to Impalad Exceeds the Threshold
- ALM-29100 Kudu Service Unavailable
- ALM-29104 Tserver Process Memory Usage Exceeds the Threshold
- ALM-29106 Tserver Process CPU Usage Exceeds the Threshold
- ALM-29107 Tserver Process Memory Usage Exceeds the Threshold
- ALM-38000 Kafka Service Unavailable
- ALM-38001 Insufficient Kafka Disk Capacity
- ALM-38002 Kafka Heap Memory Usage Exceeds the Threshold
- ALM-38004 Kafka Direct Memory Usage Exceeds the Threshold
- ALM-38005 GC Duration of the Broker Process Exceeds the Threshold
- ALM-38006 Percentage of Kafka Partitions That Are Not Completely Synchronized Exceeds the Threshold
- ALM-38007 Status of Kafka Default User Is Abnormal
- ALM-38008 Abnormal Kafka Data Directory Status
- ALM-38009 Busy Broker Disk I/Os
- ALM-38010 Topics with Single Replica
- ALM-43001 Spark2x Service Unavailable
- ALM-43006 Heap Memory Usage of the JobHistory2x Process Exceeds the Threshold
- ALM-43007 Non-Heap Memory Usage of the JobHistory2x Process Exceeds the Threshold
- ALM-43008 The Direct Memory Usage of the JobHistory2x Process Exceeds the Threshold
- ALM-43009 JobHistory2x Process GC Time Exceeds the Threshold
- ALM-43010 Heap Memory Usage of the JDBCServer2x Process Exceeds the Threshold
- ALM-43011 Non-Heap Memory Usage of the JDBCServer2x Process Exceeds the Threshold
- ALM-43012 Direct Heap Memory Usage of the JDBCServer2x Process Exceeds the Threshold
- ALM-43013 JDBCServer2x Process GC Time Exceeds the Threshold
- ALM-43017 JDBCServer2x Process Full GC Number Exceeds the Threshold
- ALM-43018 JobHistory2x Process Full GC Number Exceeds the Threshold
- ALM-43019 Heap Memory Usage of the IndexServer2x Process Exceeds the Threshold
- ALM-43020 Non-Heap Memory Usage of the IndexServer2x Process Exceeds the Threshold
- ALM-43021 Direct Memory Usage of the IndexServer2x Process Exceeds the Threshold
- ALM-43022 IndexServer2x Process GC Time Exceeds the Threshold
- ALM-43023 IndexServer2x Process Full GC Number Exceeds the Threshold
- ALM-44004 Presto Coordinator Resource Group Queuing Tasks Exceed the Threshold
- ALM-44005 Presto Coordinator Process GC Time Exceeds the Threshold
- ALM-44006 Presto Worker Process GC Time Exceeds the Threshold
- ALM-45175 Average Time for Calling OBS Metadata APIs Is Greater than the Threshold
- ALM-45176 Success Rate of Calling OBS Metadata APIs Is Lower than the Threshold
- ALM-45177 Success Rate of Calling OBS Data Read APIs Is Lower than the Threshold
- ALM-45178 Success Rate of Calling OBS Data Write APIs Is Lower Than the Threshold
- ALM-45275 Ranger Service Unavailable
- ALM-45276 Abnormal RangerAdmin status
- ALM-45277 RangerAdmin Heap Memory Usage Exceeds the Threshold
- ALM-45278 RangerAdmin Direct Memory Usage Exceeds the Threshold
- ALM-45279 RangerAdmin Non Heap Memory Usage Exceeds the Threshold
- ALM-45280 RangerAdmin GC Duration Exceeds the Threshold
- ALM-45281 UserSync Heap Memory Usage Exceeds the Threshold
- ALM-45282 UserSync Direct Memory Usage Exceeds the Threshold
- ALM-45283 UserSync Non Heap Memory Usage Exceeds the Threshold
- ALM-45284 UserSync Garbage Collection (GC) Time Exceeds the Threshold
- ALM-45285 TagSync Heap Memory Usage Exceeds the Threshold
- ALM-45286 TagSync Direct Memory Usage Exceeds the Threshold
- ALM-45287 TagSync Non Heap Memory Usage Exceeds the Threshold
- ALM-45288 TagSync Garbage Collection (GC) Time Exceeds the Threshold
- ALM-45425 ClickHouse Service Unavailable
- ALM-45426 ClickHouse Service Quantity Quota Usage in ZooKeeper Exceeds the Threshold
- ALM-45427 ClickHouse Service Capacity Quota Usage in ZooKeeper Exceeds the Threshold
- ALM-45736 Guardian Service Unavailable
MRS Manager Operation Guide (Applicable to 2.x and Earlier Versions)
- Introduction to MRS Manager
- Checking Running Tasks
- Monitoring Management
- Alarm Management
Object Management
- Managing Objects
- Viewing Configurations
- Managing Services
- Synchronizing Service Configurations
- Managing a Host
- Isolating a Host
- Canceling Host Isolation
- Starting or Stopping a Cluster
- Synchronizing Cluster Configurations
- Exporting Configuration Data of a Cluster
- Log Management
Health Check Management
- Performing a Health Check
- Viewing and Exporting a Health Check Report
- Configuring the Number of Health Check Reports to Be Reserved
- Managing Health Check Reports
- DBService Health Check Indicators
- Flume Health Check Indicators
- HBase Health Check Indicators
- Host Health Check Indicators
- HDFS Health Check Indicators
- Hive Health Check Indicators
- Kafka Health Check Indicators
- KrbServer Health Check Indicators
- LdapServer Health Check Indicators
- Loader Health Check Indicators
- MapReduce Health Check Indicators
- OMS Health Check Indicators
- Spark Health Check Indicators
- Storm Health Check Indicators
- Yarn Health Check Indicators
- ZooKeeper Health Check Indicators
- Static Service Pool Management
Tenant Management
- Overview
- Creating a Tenant
- Deleting a tenant
- Backup and Restoration
Security Management
- Default Users of Clusters with Kerberos Authentication Disabled
- Default Users of Clusters with Kerberos Authentication Enabled
- Changing the Password of an OS User
- Changing the password of user admin
- Changing the Password of the Kerberos Administrator
- Changing the Passwords of the LDAP Administrator and the LDAP User
- Changing the Password of a Component Running User
- Changing the Password of the OMS Database Administrator
- Changing the Password of the Data Access User of the OMS Database
- Changing the Password of a Component Database User
- Updating Cluster Keys
MRS Multi-User Permission Management
- Users and Permissions of MRS Clusters
- Creating a Role
- Creating a User Group
- Creating a User
- Modifying User Information
- Locking a User
- Unlocking a User
- Deleting a User
- Changing the Password of an Operation User
- Initializing the Password of a System User
- Downloading a User Authentication File
- Modifying a Password Policy
- Configuring Cross-Cluster Mutual Trust Relationships
- Configuring Users to Access Resources of a Trusted Cluster
- Configuring Fine-Grained Permissions for MRS Multi-User Access to OBS
- Patch Operation Guide
- Restoring Patches for the Isolated Hosts
- Rolling Restart
MRS Cluster Component Operation Guide
- Using Alluxio
- Using CarbonData (for Versions Earlier Than MRS 3.x)
Using CarbonData (for MRS 3.x or Later)
- Overview
- Configuration Reference
- CarbonData Operation Guide
- CarbonData Performance Tuning
- CarbonData Access Control
- CarbonData Syntax Reference
- CarbonData Troubleshooting
CarbonData FAQ
- Why Is Incorrect Output Displayed When I Perform Query with Filter on Decimal Data Type Values?
- How to Avoid Minor Compaction for Historical Data?
- How to Change the Default Group Name for CarbonData Data Loading?
- Why Does INSERT INTO CARBON TABLE Command Fail?
- Why Is the Data Logged in Bad Records Different from the Original Input Data with Escape Characters?
- Why Data Load Performance Decreases due to Bad Records?
- Why INSERT INTO/LOAD DATA Task Distribution Is Incorrect and the Opened Tasks Are Less Than the Available Executors when the Number of Initial ExecutorsIs Zero?
- Why Does CarbonData Require Additional Executors Even Though the Parallelism Is Greater Than the Number of Blocks to Be Processed?
- Why Data loading Fails During off heap?
- Why Do I Fail to Create a Hive Table?
- Why CarbonData tables created in V100R002C50RC1 not reflecting the privileges provided in Hive Privileges for non-owner?
- How Do I Logically Split Data Across Different Namespaces?
- Why Missing Privileges Exception is Reported When I Perform Drop Operation on Databases?
- Why the UPDATE Command Cannot Be Executed in Spark Shell?
- How Do I Configure Unsafe Memory in CarbonData?
- Why Exception Occurs in CarbonData When Disk Space Quota is Set for Storage Directory in HDFS?
- Why Does Data Query or Loading Fail and "org.apache.carbondata.core.memory.MemoryException: Not enough memory" Is Displayed?
- Why Do Files of a Carbon Table Exist in the Recycle Bin Even If the drop table Command Is Not Executed When Mis-deletion Prevention Is Enabled?
- Using ClickHouse
- Using DBService
Using Flink
- Reference
Using Flume
- Using Flume from Scratch
- Overview
- Viewing Flume Client Logs
- Stopping or Uninstalling the Flume Client
- Using the Encryption Tool of the Flume Client
- Flume Service Configuration Guide
- Flume Configuration Parameter Description
- Using Environment Variables in the properties.properties File
Non-Encrypted Transmission
- Configuring Non-encrypted Transmission
- Typical Scenario: Collecting Local Static Logs and Uploading Them to Kafka
- Typical Scenario: Collecting Local Static Logs and Uploading Them to HDFS
- Typical Scenario: Collecting Local Dynamic Logs and Uploading Them to HDFS
- Typical Scenario: Collecting Logs from Kafka and Uploading Them to HDFS
- Typical Scenario: Collecting Logs from Kafka and Uploading Them to HDFS Through the Flume Client
- Typical Scenario: Collecting Local Static Logs and Uploading Them to HBase
- Encrypted Transmission
- Viewing Flume Client Monitoring Information
- Connecting Flume to Kafka in Security Mode
- Connecting Flume with Hive in Security Mode
- Configuring the Flume Service Model
- Introduction to Flume Logs
- Flume Client Cgroup Usage Guide
- Secondary Development Guide for Flume Third-Party Plug-ins
- Common Issues About Flume
Using HBase
- Using HBase from Scratch
- Using an HBase Client
- Creating HBase Roles
- Configuring HBase Replication
- Configuring HBase Parameters
- Enabling Cross-Cluster Copy
- Using the ReplicationSyncUp Tool
- Using HIndex
- Configuring HBase DR
- Configuring HBase Data Compression and Encoding
- Performing an HBase DR Service Switchover
- Performing an HBase DR Active/Standby Cluster Switchover
- Community BulkLoad Tool
- Configuring the MOB
- Configuring Secure HBase Replication
- Configuring Region In Transition Recovery Chore Service
- Using a Secondary Index
- HBase Log Overview
- HBase Performance Tuning
Common Issues About HBase
- Why Does a Client Keep Failing to Connect to a Server for a Long Time?
- Operation Failures Occur in Stopping BulkLoad On the Client
- Why May a Table Creation Exception Occur When HBase Deletes or Creates the Same Table Consecutively?
- Why Other Services Become Unstable If HBase Sets up A Large Number of Connections over the Network Port?
- Why Does the HBase BulkLoad Task (One Table Has 26 TB Data) Consisting of 210,000 Map Tasks and 10,000 Reduce Tasks Fail?
- How Do I Restore a Region in the RIT State for a Long Time?
- Why Does HMaster Exits Due to Timeout When Waiting for the Namespace Table to Go Online?
- Why Does SocketTimeoutException Occur When a Client Queries HBase?
- Why Modified and Deleted Data Can Still Be Queried by Using the Scan Command?
- Why "java.lang.UnsatisfiedLinkError: Permission denied" exception thrown while starting HBase shell?
- When does the RegionServers listed under "Dead Region Servers" on HMaster WebUI gets cleared?
- Why Are Different Query Results Returned After I Use Same Query Criteria to Query Data Successfully Imported by HBase bulkload?
- What Should I Do If I Fail to Create Tables Due to the FAILED_OPEN State of Regions?
- How Do I Delete Residual Table Names in the /hbase/table-lock Directory of ZooKeeper?
- Why Does HBase Become Faulty When I Set a Quota for the Directory Used by HBase in HDFS?
- Why HMaster Times Out While Waiting for Namespace Table to be Assigned After Rebuilding Meta Using OfflineMetaRepair Tool and Startups Failed
- Why Messages Containing FileNotFoundException and no lease Are Frequently Displayed in the HMaster Logs During the WAL Splitting Process?
- Why Does the ImportTsv Tool Display "Permission denied" When the Same Linux User as and a Different Kerberos User from the Region Server Are Used?
- Insufficient Rights When a Tenant Accesses Phoenix
- What Can I Do When HBase Fails to Recover a Task and a Message Is Displayed Stating "Rollback recovery failed"?
- How Do I Fix Region Overlapping?
- Why Does RegionServer Fail to Be Started When GC Parameters Xms and Xmx of HBase RegionServer Are Set to 31 GB?
- Why Does the LoadIncrementalHFiles Tool Fail to Be Executed and "Permission denied" Is Displayed When Nodes in a Cluster Are Used to Import Data in Batches?
- Why Is the Error Message "import argparse" Displayed When the Phoenix sqlline Script Is Used?
- How Do I Deal with the Restrictions of the Phoenix BulkLoad Tool?
- Why a Message Is Displayed Indicating that the Permission is Insufficient When CTBase Connects to the Ranger Plug-ins?
Using HDFS
- Using Hadoop from Scratch
- Configuring Memory Management
- Creating an HDFS Role
- Using the HDFS Client
- Running the DistCp Command
- Overview of HDFS File System Directories
- Changing the DataNode Storage Directory
- Configuring HDFS Directory Permission
- Configuring NFS
- Planning HDFS Capacity
- Configuring ulimit for HBase and HDFS
- Balancing DataNode Capacity
- Configuring Replica Replacement Policy for Heterogeneous Capacity Among DataNodes
- Configuring the Number of Files in a Single HDFS Directory
- Configuring the Recycle Bin Mechanism
- Setting Permissions on Files and Directories
- Setting the Maximum Lifetime and Renewal Interval of a Token
- Configuring the Damaged Disk Volume
- Configuring Encrypted Channels
- Reducing the Probability of Abnormal Client Application Operation When the Network Is Not Stable
- Configuring the NameNode Blacklist
- Optimizing HDFS NameNode RPC QoS
- Optimizing HDFS DataNode RPC QoS
- Configuring Reserved Percentage of Disk Usage on DataNodes
- Configuring HDFS NodeLabel
- Configuring HDFS Mover
- Using HDFS AZ Mover
- Configuring HDFS DiskBalancer
- Configuring the Observer NameNode to Process Read Requests
- Performing Concurrent Operations on HDFS Files
- Introduction to HDFS Logs
- HDFS Performance Tuning
FAQ
- NameNode Startup Is Slow
- DataNode Is Normal but Cannot Report Data Blocks
- HDFS WebUI Cannot Properly Update Information About Damaged Data
- Why Does the Distcp Command Fail in the Secure Cluster, Causing an Exception?
- Why Does DataNode Fail to Start When the Number of Disks Specified by dfs.datanode.data.dir Equals dfs.datanode.failed.volumes.tolerated?
- Standby NameNode Fails to Be Restarted When the System Is Powered off During Metadata (Namespace) Storage
- Why Data in the Buffer Is Lost If a Power Outage Occurs During Storage of Small Files
- Why Does Array Border-crossing Occur During FileInputFormat Split?
- Why Is the Storage Type of File Copies DISK When the Tiered Storage Policy Is LAZY_PERSIST?
- The HDFS Client Is Unresponsive When the NameNode Is Overloaded for a Long Time
- Can I Delete or Modify the Data Storage Directory in DataNode?
- Blocks Miss on the NameNode UI After the Successful Rollback
- Why Is "java.net.SocketException: No buffer space available" Reported When Data Is Written to HDFS
- Why are There Two Standby NameNodes After the active NameNode Is Restarted?
- When Does a Balance Process in HDFS, Shut Down and Fail to be Executed Again?
- "This page can't be displayed" Is Displayed When Internet Explorer Fails to Access the Native HDFS UI
- NameNode Fails to Be Restarted Due to EditLog Discontinuity
Using Hive
- Using Hive from Scratch
- Configuring Hive Parameters
- Hive SQL
- Permission Management
- Using a Hive Client
- Using HDFS Colocation to Store Hive Tables
- Using the Hive Column Encryption Function
- Customizing Row Separators
- Configuring Hive on HBase in Across Clusters with Mutual Trust Enabled
- Deleting Single-Row Records from Hive on HBase
- Configuring HTTPS/HTTP-based REST APIs
- Enabling or Disabling the Transform Function
- Access Control of a Dynamic Table View on Hive
- Specifying Whether the ADMIN Permissions Is Required for Creating Temporary Functions
- Using Hive to Read Data in a Relational Database
- Supporting Traditional Relational Database Syntax in Hive
- Creating User-Defined Hive Functions
- Enhancing beeline Reliability
- Viewing Table Structures Using the show create Statement as Users with the select Permission
- Writing a Directory into Hive with the Old Data Removed to the Recycle Bin
- Inserting Data to a Directory That Does Not Exist
- Creating Databases and Creating Tables in the Default Database Only as the Hive Administrator
- Disabling of Specifying the location Keyword When Creating an Internal Hive Table
- Enabling the Function of Creating a Foreign Table in a Directory That Can Only Be Read
- Authorizing Over 32 Roles in Hive
- Restricting the Maximum Number of Maps for Hive Tasks
- HiveServer Lease Isolation
- Hive Supporting Transactions
- Switching the Hive Execution Engine to Tez
- Hive Materialized View
- Hive Log Overview
- Hive Performance Tuning
Common Issues About Hive
- How Do I Delete UDFs on Multiple HiveServers at the Same Time?
- Why Cannot the DROP operation Be Performed on a Backed-up Hive Table?
- How to Perform Operations on Local Files with Hive User-Defined Functions
- How Do I Forcibly Stop MapReduce Jobs Executed by Hive?
- How Do I Monitor the Hive Table Size?
- How Do I Prevent Key Directories from Data Loss Caused by Misoperations of the insert overwrite Statement?
- Why Is Hive on Spark Task Freezing When HBase Is Not Installed?
- Error Reported When the WHERE Condition Is Used to Query Tables with Excessive Partitions in FusionInsight Hive
- Why Cannot I Connect to HiveServer When I Use IBM JDK to Access the Beeline Client?
- Description of Hive Table Location (Either Be an OBS or HDFS Path)
- Why Cannot Data Be Queried After the MapReduce Engine Is Switched After the Tez Engine Is Used to Execute Union-related Statements?
- Why Does Hive Not Support Concurrent Data Writing to the Same Table or Partition?
- Why Does Hive Not Support Vectorized Query?
- Why Does Metadata Still Exist When the HDFS Data Directory of the Hive Table Is Deleted by Mistake?
- How Do I Disable the Logging Function of Hive?
- Why Hive Tables in the OBS Directory Fail to Be Deleted?
- Hive Configuration Problems
- Using Hue (Versions Earlier Than MRS 3.x)
Using Hue (MRS 3.x or Later)
- Using Hue from Scratch
- Accessing the Hue Web UI
- Hue Common Parameters
- Using HiveQL Editor on the Hue Web UI
- Using the SparkSql Editor on the Hue Web UI
- Using the Metadata Browser on the Hue Web UI
- Using File Browser on the Hue Web UI
- Using Job Browser on the Hue Web UI
- Using HBase on the Hue Web UI
- Typical Scenarios
- Hue Log Overview
Common Issues About Hue
- What Can I Do If a Large File Fails to Be Uploaded on the Hue Page?
- Why Is the Hue Native Page Cannot Be Properly Displayed If the Hive Service Is Not Installed in a Cluster?
- Using Impala
Using Kafka
- Using Kafka from Scratch
- Managing Kafka Topics
- Querying Kafka Topics
- Managing Kafka User Permissions
- Managing Messages in Kafka Topics
- Synchronizing Binlog-based MySQL Data to the MRS Cluster
- Creating a Kafka Role
- Kafka Common Parameters
- Kafka Specifications
- Using the Kafka Client
- Configuring Kafka HA and High Reliability Parameters
- Changing the Broker Storage Directory
- Checking the Consumption Status of Consumer Group
- Kafka Balancing Tool Instructions
- Balancing Data After Kafka Node Scale-Out
- Kafka Token Authentication Mechanism Tool Usage
- Introduction to Kafka Logs
- Performance Tuning
- Kafka Feature Description
- Migrating Data Between Kafka Nodes
- Common Issues About Kafka
- Using KafkaManager
- Using Kudu
Using Loader
- Using Loader from Scratch
- How to Use Loader
- Loader Link Configuration
- Managing Loader Links (Versions Earlier Than MRS 3.x)
- Source Link Configurations of Loader Jobs
- Destination Link Configurations of Loader Jobs
- Managing Loader Jobs
- Preparing a Driver for MySQL Database Link
- Loader Log Overview
- Example: Using Loader to Import Data from OBS to HDFS
- Common Issues About Loader
Using MapReduce
- Configuring the Log Archiving and Clearing Mechanism
- Reducing Client Application Failure Rate
- Transmitting MapReduce Tasks from Windows to Linux
- Configuring the Distributed Cache
- Configuring the MapReduce Shuffle Address
- Configuring the Cluster Administrator List
- Introduction to MapReduce Logs
- MapReduce Performance Tuning
Common Issues About MapReduce
- Why Does a MapReduce Task Stay Unchanged for a Long Time?
- Why the Client Hangs During Job Running?
- Why Cannot HDFS_DELEGATION_TOKEN Be Found in the Cache?
- How Do I Set the Task Priority When Submitting a MapReduce Task?
- Why Physical Memory Overflow Occurs If a MapReduce Task Fails?
- After the Address of MapReduce JobHistoryServer Is Changed, Why the Wrong Page is Displayed When I Click the Tracking URL on the ResourceManager WebUI?
- MapReduce Job Failed in Multiple NameService Environment
- Why a Fault MapReduce Node Is Not Blacklisted?
Using Oozie
- Using Oozie from Scratch
- Using the Oozie Client
- Using Oozie Client to Submit an Oozie Job
Using Hue to Submit an Oozie Job
- Creating a Workflow
Submitting a Workflow Job
- Submitting a Hive2 Job
- Submitting a Spark2x Job
- Submitting a Java Job
- Submitting a Loader Job
- Submitting a MapReduce Job
- Submitting a Sub-workflow Job
- Submitting a Shell Job
- Submitting an HDFS Job
- Submitting a Streaming Job
- Submitting a DistCp Job
- Example of Mutual Trust Operations
- Submitting an SSH Job
- Submitting a Hive Script
- Submitting a Coordinator Periodic Scheduling Job
- Submitting a Bundle Batch Processing Job
- Oozie Log Overview
- Common Issues About Oozie
- Using Presto
Using Ranger (MRS 3.x)
- Logging In to the Ranger Web UI
- Enabling Ranger Authentication
- Configuring Component Permission Policies
- Viewing Ranger Audit Information
- Configuring a Security Zone
- Viewing Ranger Permission Information
- Adding a Ranger Access Permission Policy for HDFS
- Adding a Ranger Access Permission Policy for HBase
- Adding a Ranger Access Permission Policy for Hive
- Adding a Ranger Access Permission Policy for Yarn
- Adding a Ranger Access Permission Policy for Spark2x
- Adding a Ranger Access Permission Policy for Kafka
- Adding a Ranger Access Permission Policy for Storm
- Ranger Log Overview
Common Issues About Ranger
- Why Ranger Startup Fails During the Cluster Installation?
- How Do I Determine Whether the Ranger Authentication Is Used for a Service?
- Why Cannot a New User Log In to Ranger After Changing the Password?
- When an HBase Policy Is Added or Modified on Ranger, Wildcard Characters Cannot Be Used to Search for Existing HBase Tables
- Using Spark
Using Spark2x
- Precautions
Basic Operation
- Getting Started
- Configuring Parameters Rapidly
- Common Parameters
- Spark on HBase Overview and Basic Applications
- Spark on HBase V2 Overview and Basic Applications
- SparkSQL Permission Management(Security Mode)
Scenario-Specific Configuration
- Configuring Multi-active Instance Mode
- Configuring the Multi-tenant Mode
- Configuring the Switchover Between the Multi-active Instance Mode and the Multi-tenant Mode
- Configuring the Size of the Event Queue
- Configuring Executor Off-Heap Memory
- Enhancing Stability in a Limited Memory Condition
- Viewing Aggregated Container Logs on the Web UI
- Configuring Environment Variables in Yarn-Client and Yarn-Cluster Modes
- Configuring the Default Number of Data Blocks Divided by SparkSQL
- Configuring the Compression Format of a Parquet Table
- Configuring the Number of Lost Executors Displayed in WebUI
- Setting the Log Level Dynamically
- Configuring Whether Spark Obtains HBase Tokens
- Configuring LIFO for Kafka
- Configuring Reliability for Connected Kafka
- Configuring Streaming Reading of Driver Execution Results
- Filtering Partitions without Paths in Partitioned Tables
- Configuring Spark2x Web UI ACLs
- Configuring Vector-based ORC Data Reading
- Broaden Support for Hive Partition Pruning Predicate Pushdown
- Hive Dynamic Partition Overwriting Syntax
- Configuring the Column Statistics Histogram to Enhance the CBO Accuracy
- Configuring Local Disk Cache for JobHistory
- Configuring Spark SQL to Enable the Adaptive Execution Feature
- Configuring Event Log Rollover
- Adapting to the Third-party JDK When Ranger Is Used
- Spark2x Logs
- Obtaining Container Logs of a Running Spark Application
- Small File Combination Tools
- Using CarbonData for First Query
Spark2x Performance Tuning
- Spark Core Tuning
Spark SQL and DataFrame Tuning
- Optimizing the Spark SQL Join Operation
- Improving Spark SQL Calculation Performance Under Data Skew
- Optimizing Spark SQL Performance in the Small File Scenario
- Optimizing the INSERT...SELECT Operation
- Multiple JDBC Clients Concurrently Connecting to JDBCServer
- Optimizing Memory when Data Is Inserted into Dynamic Partitioned Tables
- Optimizing Small Files
- Optimizing the Aggregate Algorithms
- Optimizing Datasource Tables
- Merging CBO
- Optimizing SQL Query of Data of Multiple Sources
- SQL Optimization for Multi-level Nesting and Hybrid Join
- Spark Streaming Tuning
Common Issues About Spark2x
Spark Core
- How Do I View Aggregated Spark Application Logs?
- Why Cannot Exit the Driver Process?
- Why Does FetchFailedException Occur When the Network Connection Is Timed out
- How to Configure Event Queue Size If Event Queue Overflows?
- What Can I Do If the getApplicationReport Exception Is Recorded in Logs During Spark Application Execution and the Application Does Not Exit for a Long Time?
- What Can I Do If "Connection to ip:port has been quiet for xxx ms while there are outstanding requests" Is Reported When Spark Executes an Application and the Application Ends?
- Why Do Executors Fail to be Removed After the NodeManeger Is Shut Down?
- What Can I Do If the Message "Password cannot be null if SASL is enabled" Is Displayed?
- What Should I Do If the Message "Failed to CREATE_FILE" Is Displayed in the Restarted Tasks When Data Is Inserted Into the Dynamic Partition Table?
- Why Tasks Fail When Hash Shuffle Is Used?
- What Can I Do If the Error Message "DNS query failed" Is Displayed When I Access the Aggregated Logs Page of Spark Applications?
- What Can I Do If Shuffle Fetch Fails Due to the "Timeout Waiting for Task" Exception?
- Why Does the Stage Retry due to the Crash of the Executor?
- Why Do the Executors Fail to Register Shuffle Services During the Shuffle of a Large Amount of Data?
- Why Does the Out of Memory Error Occur in NodeManager During the Execution of Spark Applications
- Why Does the Realm Information Fail to Be Obtained When SparkBench is Run on HiBench for the Cluster in Security Mode?
- What Do I have to Note When Using Spark SQL ROLLUP and CUBE?
- Why Spark SQL Is Displayed as a Temporary Table in Different Databases?
- How to Assign a Parameter Value in a Spark Command?
- What Directory Permissions Do I Need to Create a Table Using SparkSQL?
- Why Do I Fail to Delete the UDF Using Another Service?
- Why Cannot I Query Newly Inserted Data in a Parquet Hive Table Using SparkSQL?
- How to Use Cache Table?
- Why Are Some Partitions Empty During Repartition?
- Why Does 16 Terabytes of Text Data Fails to Be Converted into 4 Terabytes of Parquet Data?
- Why the Operation Fails When the Table Name Is TABLE?
- Why Is a Task Suspended When the ANALYZE TABLE Statement Is Executed and Resources Are Insufficient?
- If I Access a parquet Table on Which I Do not Have Permission, Why a Job Is Run Before "Missing Privileges" Is Displayed?
- Why Do I Fail to Modify MetaData by Running the Hive Command?
- Why Is "RejectedExecutionException" Displayed When I Exit Spark SQL?
- Why No Result Is found When 2016-6-30 Is Set in the Date Field as the Filter Condition?
- Why Does the "--hivevar" Option I Specified in the Command for Starting spark-beeline Fail to Take Effect?
- Why Does the "Permission denied" Exception Occur When I Create a Temporary Table or View in Spark-beeline?
- Why Is the "Code of method ... grows beyond 64 KB" Error Message Displayed When I Run Complex SQL Statements?
- Why Is Memory Insufficient if 10 Terabytes of TPCDS Test Suites Are Consecutively Run in Beeline/JDBCServer Mode?
- Why Does Spark2x Have No Access to DataSource Tables Created by Spark1.5?
- Why Does Spark-beeline Fail to Run and Error Message "Failed to create ThriftService instance" Is Displayed?
- Why Cannot I Query Newly Inserted Data in an ORC Hive Table Using Spark SQL?
Spark Streaming
- What Can I Do If Spark Streaming Tasks Are Blocked?
- What Should I Pay Attention to When Optimizing Spark Streaming Task Parameters?
- Why Does the Spark Streaming Application Fail to Be Submitted After the Token Validity Period Expires?
- Why does Spark Streaming Application Fail to Restart from Checkpoint When It Creates an Input Stream Without Output Logic?
- Why Is the Input Size Corresponding to Batch Time on the Web UI Set to 0 Records When Kafka Is Restarted During Spark Streaming Running?
- Why the Job Information Obtained from the restful Interface of an Ended Spark Application Is Incorrect?
- Why Cannot I Switch from the Yarn Web UI to the Spark Web UI?
- What Can I Do If an Error Occurs when I Access the Application Page Because the Application Cached by HistoryServer Is Recycled?
- Why Is not an Application Displayed When I Run the Application with the Empty Part File?
- Why Does Spark2x Fail to Export a Table with the Same Field Name?
- Why JRE fatal error after running Spark application multiple times?
- How Does Spark2x Access External Cluster Components?
- Why Does the Foreign Table Query Fail When Multiple Foreign Tables Are Created in the Same Directory?
- Why Do I Fail to Create a Table in the Specified Location on OBS After Logging to spark-beeline?
- Spark Shuffle Exception Handling
Spark Core
Using Sqoop
- Using Sqoop from Scratch
- Adapting Sqoop 1.4.7 to MRS 3.x Clusters
- Common Sqoop Commands and Parameters
Common Issues About Sqoop
- What Should I Do If Class QueryProvider Is Unavailable?
- What Should I Do If PostgreSQL or GaussDB Failed to Be Connected?
- What Should I Do If Data Failed to Be Synchronized to a Hive Table on the OBS Using hive-table?
- What Should I Do If Data Failed to Be Synchronized to an ORC or Parquet Table Using hive-table?
- What Should I Do If Data Failed to Be Synchronized Using hive-table?
- What Should I Do If Data Failed to Be Synchronized to a Hive Parquet Table Using HCatalog?
- What Should I Do If the Data Type of Fields timestamp and data Is Incorrect During Data Synchronization Between Hive and MySQL?
Using Storm
- Using Storm from Scratch
- Using the Storm Client
- Submitting Storm Topologies on the Client
- Accessing the Storm Web UI
- Managing Storm Topologies
- Querying Storm Topology Logs
- Storm Common Parameters
- Configuring a Storm Service User Password Policy
- Migrating Storm Services to Flink
- Storm Log Introduction
- Using Tez
Using Yarn
- Common YARN Parameters
- Creating Yarn Roles
- Using the YARN Client
- Configuring Resources for a NodeManager Role Instance
- Changing NodeManager Storage Directories
- Configuring Strict Permission Control for Yarn
- Configuring Container Log Aggregation
- Using CGroups with YARN
- Configuring the Number of ApplicationMaster Retries
- Configure the ApplicationMaster to Automatically Adjust the Allocated Memory
- Configuring the Access Channel Protocol
- Configuring Memory Usage Detection
- Configuring the Additional Scheduler WebUI
- Configuring Yarn Restart
- Configuring ApplicationMaster Work Preserving
- Configuring the Localized Log Levels
- Configuring Users That Run Tasks
- Yarn Log Overview
- Yarn Performance Tuning
Common Issues About Yarn
- Why Mounted Directory for Container is Not Cleared After the Completion of the Job While Using CGroups?
- Why the Job Fails with HDFS_DELEGATION_TOKEN Expired Exception?
- Why Are Local Logs Not Deleted After YARN Is Restarted?
- Why the Task Does Not Fail Even Though AppAttempts Restarts for More Than Two Times?
- Why Is an Application Moved Back to the Original Queue After ResourceManager Restarts?
- Why Does Yarn Not Release the Blacklist Even All Nodes Are Added to the Blacklist?
- Why Does the Switchover of ResourceManager Occur Continuously?
- Why Does a New Application Fail If a NodeManager Has Been in Unhealthy Status for 10 Minutes?
- Why Does an Error Occur When I Query the ApplicationID of a Completed or Non-existing Application Using the RESTful APIs?
- Why May A Single NodeManager Fault Cause MapReduce Task Failures in the Superior Scheduling Mode?
- Why Are Applications Suspended After They Are Moved From Lost_and_Found Queue to Another Queue?
- How Do I Limit the Size of Application Diagnostic Messages Stored in the ZKstore?
- Why Does a MapReduce Job Fail to Run When a Non-ViewFS File System Is Configured as ViewFS?
- Why Do Reduce Tasks Fail to Run in Some OSs After the Native Task Feature is Enabled?
Using ZooKeeper
- Using ZooKeeper from Scratch
- Common ZooKeeper Parameters
- Using a ZooKeeper Client
- Configuring the ZooKeeper Permissions
- ZooKeeper Log Overview
Common Issues About ZooKeeper
- Why Do ZooKeeper Servers Fail to Start After Many znodes Are Created?
- Why Does the ZooKeeper Server Display the java.io.IOException: Len Error Log?
- Why Four Letter Commands Don't Work With Linux netcat Command When Secure Netty Configurations Are Enabled at Zookeeper Server?
- How Do I Check Which ZooKeeper Instance Is a Leader?
- Why Cannot the Client Connect to ZooKeeper using the IBM JDK?
- What Should I Do When the ZooKeeper Client Fails to Refresh a TGT?
- Why Is Message "Node does not exist" Displayed when A Large Number of Znodes Are Deleted Using the deleteallCommand
- Appendix
- Security Description
- High-Risk Operations Overview
MRS Overview
- What Is MRS Used For?
- What Types of Distributed Storage Does MRS Support?
- How Do I Create an MRS Cluster Using a Custom Security Group?
- How Do I Use MRS?
- How Does MRS Ensure Security of Data and Services?
- Can I Configure a Phoenix Connection Pool?
- Does MRS Support Change of the Network Segment?
- Can I Downgrade the Specifications of an MRS Cluster Node?
- What Is the Relationship Between Hive and Other Components?
- Does an MRS Cluster Support Hive on Spark?
- What Are the Differences Between Hive Versions?
- Which MRS Cluster Version Supports Hive Connection and User Synchronization?
- What Are the Differences Between OBS and HDFS in Data Storage?
- How Do I Obtain the Hadoop Pressure Test Tool?
- What Is the Relationship Between Impala and Other Components?
- Statement About the Public IP Addresses in the Open-Source Third-Party SDK Integrated by MRS
- What Is the Relationship Between Kudu and HBase?
- Does MRS Support Running Hive on Kudu?
- What Are the Solutions for processing 1 Billion Data Records?
- Can I Change the IP address of DBService?
- Can I Clear MRS sudo Logs?
- Is the Storm Log also limited to 20 GB in MRS cluster 2.1.0?
- What Is Spark ThriftServer?
- What Access Protocols Are Supported by Kafka?
- What Is the Compression Ratio of zstd?
- Why Are the HDFS, YARN, and MapReduce Components Unavailable When an MRS Cluster Is Created?
- Why Is the ZooKeeper Component Unavailable When an MRS Cluster Is Created?
- Which Python Versions Are Supported by Spark Tasks in an MRS 3.1.0 Cluster?
- How Do I Enable Different Service Programs to Use Different YARN Queues?
- Differences and Relationships Between the MRS Management Console and Cluster Manager
- How Do I Unbind an EIP from an MRS Cluster Node?
- Account and Password
Accounts and Permissions
- Does an MRS Cluster Support Access Permission Control If Kerberos Authentication Is not Enabled?
- How Do I Assign Tenant Management Permission to a New Account?
- How Do I Customize an MRS Policy?
- Why Is the Manage User Function Unavailable on the System Page on MRS Manager?
- Does Hue Support Account Permission Configuration?
- Client Usage
Web Page Access
- How Do I Change the Session Timeout Duration for an Open Source Component Web UI?
- Why Cannot I Refresh the Dynamic Resource Plan Page on MRS Tenant Tab?
- What Do I Do If the Kafka Topic Monitoring Tab Is Unavailable on Manager?
- How Do I Do If an Error Is Reported or Some Functions Are Unavailable When I Access the Web UIs of HDFS, Hue, YARN, and Flink?
Alarm Monitoring
- In an MRS Streaming Cluster, Can the Kafka Topic Monitoring Function Send Alarm Notifications?
- Where Can I View the Running Resource Queues When the Alarm "ALM-18022 Insufficient Yarn Queue Resources" Is Reported?
- How Do I Understand the Multi-Level Chart Statistics in the HBase Operation Requests Metric?
Job Development
- How Do I Get My Data into OBS or HDFS?
- What Types of Spark Jobs Can Be Submitted in a Cluster?
- Can I Run Multiple Spark Tasks at the Same Time After the Minimum Tenant Resources of an MRS Cluster Is Changed to 0?
- What Are the Differences Between the Client Mode and Cluster Mode of Spark Jobs?
- How Do I View MRS Job Logs?
- How Do I Do If the Message "The current user does not exist on MRS Manager. Grant the user sufficient permissions on IAM and then perform IAM user synchronization on the Dashboard tab page." Is Displayed?
- LauncherJob Job Execution Is Failed And the Error Message "jobPropertiesMap is null." Is Displayed
- How Do I Do If the Flink Job Status on the MRS Console Is Inconsistent with That on Yarn?
- How Do I Do If a SparkStreaming Job Fails After Being Executed Dozens of Hours and the OBS Access 403 Error is Reported?
- How Do I Do If an Alarm Is Reported Indicating that the Memory Is Insufficient When I Execute a SQL Statement on the ClickHouse Client?
- How Do I Do If Error Message "java.io.IOException: Connection reset by peer" Is Displayed During the Execution of a Spark Job?
- How Do I Do If Error Message "requestId=4971883851071737250" Is Displayed When a Spark Job Accesses OBS?
- Why DataArtsStudio Occasionally Fail to Schedule Spark Jobs and the Rescheduling also Fails?
- How Do I Do If a Flink Job Fails to Execute and the Error Message "java.lang.NoSuchFieldError: SECURITY_SSL_ENCRYPT_ENABLED" Is Displayed?
- Why Submitted Yarn Job Cannot Be Viewed on the Web UI?
- How Do I Modify the HDFS NameSpace (fs.defaultFS) of an Existing Cluster?
- How Do I Do If the launcher-job Queue Is Stopped by YARN due to Insufficient Heap Size When I Submit a Flink Job on the Management Plane?
- How Do I Do If the Error Message "slot request timeout" Is Displayed When I Submit a Flink Job?
- Data Import and Export of DistCP Jobs
- Cluster Upgrade/Patching
- Cluster Access
Big Data Service Development
- Can MRS Run Multiple Flume Tasks at a Time?
- How Do I Change FlumeClient Logs to Standard Logs?
- Where Are the .jar Files and Environment Variables of Hadoop Located?
- What Compression Algorithms Does HBase Support?
- Can MRS Write Data to HBase Through the HBase External Table of Hive?
- How Do I View HBase Logs?
- How Do I Set the TTL for an HBase Table?
- How Do I Balance HDFS Data?
- How Do I Change the Number of HDFS Replicas?
- What Is the Port for Accessing HDFS Using Python?
- How Do I Modify the HDFS Active/Standby Switchover Class?
- What Is the Recommended Number Type of DynamoDB in Hive Tables?
- Can the Hive Driver Be Interconnected with DBCP2?
- How Do I View the Hive Table Created by Another User?
- Can I Export the Query Result of Hive Data?
- How Do I Do If an Error Occurs When Hive Runs the beeline -e Command to Execute Multiple Statements?
- How Do I Do If a "hivesql/hivescript" Job Fails to Submit After Hive Is Added?
- What If an Excel File Downloaded on Hue Failed to Open?
- How Do I Do If Sessions Are Not Released After Hue Connects to HiveServer and the Error Message "over max user connections" Is Displayed?
- How Do I Reset Kafka Data?
- How Do I Obtain the Client Version of MRS Kafka?
- How Do I Do If Error Message "Not Authorized to access group xxx" Is Displayed When a Kafka Topic Is Consumed?
- What Compression Algorithms Does Kudu Support?
- How Do I View Kudu Logs?
- How Do I Handle the Kudu Service Exceptions Generated During Cluster Creation?
- Does OpenTSDB Support Python APIs?
- How Do I Configure Other Data Sources on Presto?
- How Do I Connect to Spark Shell from MRS?
- How Do I Connect to Spark Beeline from MRS?
- Where Are the Execution Logs of Spark Jobs Stored?
- How Do I Specify a Log Path When Submitting a Task in an MRS Storm Cluster?
- How Do I Check Whether the ResourceManager Configuration of Yarn Is Correct?
- How Do I Modify the allow_drop_detached Parameter of ClickHouse?
- How Do I Do If an Alarm Indicating Insufficient Memory Is Reported During Spark Task Execution?
- How Do I Do If ClickHouse Consumes Excessive CPU Resources?
- How Do I Enable the Map Type on ClickHouse?
- A Large Number of OBS APIs Are Called When Spark SQL Accesses Hive Partitioned Tables
- API
Cluster Management
- How Do I View All Clusters?
- How Do I View Log Information?
- How Do I View Cluster Configuration Information?
- How Do I Install Kafka and Flume in an MRS Cluster?
- How Do I Stop an MRS Cluster?
- Can I Expand Data Disk Capacity for MRS?
- Can I Add Components to an Existing Cluster?
- Can I Delete Components Installed in an MRS Cluster?
- Can I Change MRS Cluster Nodes on the MRS Console?
- How Do I Shield Cluster Alarm/Event Notifications?
- Why Is the Resource Pool Memory Displayed in the MRS Cluster Smaller Than the Actual Cluster Memory?
- How Do I Configure the knox Memory?
- What Is the Python Version Installed for an MRS Cluster?
- How Do I View the Configuration File Directory of Each Component?
- How Do I Do If the Time on MRS Nodes Is Incorrect?
- How Do I Query the Startup Time of an MRS Node?
- How Do I Do If Trust Relationships Between Nodes Are Abnormal?
- How Do I Adjust the Memory Size of the manager-executor Process?
Kerberos Usage
- How Do I Change the Kerberos Authentication Status of a Created MRS Cluster?
- What Are the Ports of the Kerberos Authentication Service?
- How Do I Deploy the Kerberos Service in a Running Cluster?
- How Do I Access Hive in a Cluster with Kerberos Authentication Enabled?
- How Do I Access Presto in a Cluster with Kerberos Authentication Enabled?
- How Do I Access Spark in a Cluster with Kerberos Authentication Enabled?
- How Do I Prevent Kerberos Authentication Expiration?
- Metadata Management
MRS Overview
Troubleshooting
- Accessing the Web Pages
Cluster Management
- Failed to Reduce Task Nodes
- Adding a New Disk to an MRS Cluster
- Replacing a Disk in an MRS Cluster (Applicable to 2.x and Earlier)
- Replacing a Disk in an MRS Cluster (Applicable to 3.x)
- MRS Backup Failure
- Inconsistency Between df and du Command Output on the Core Node
- Disassociating a Subnet from the ACL Network
- MRS Becomes Abnormal After hostname Modification
- DataNode Restarts Unexpectedly
- Network Is Unreachable When Using pip3 to Install the Python Package in an MRS Cluster
- Failed to Download the MRS Cluster Client
- Failed to Scale Out an MRS Cluster
- Error Occurs When MRS Executes the Insert Command Using Beeline
- How Do I Upgrade EulerOS to Fix Vulnerabilities in an MRS Cluster?
- Using CDM to Migrate Data to HDFS
- Alarms Are Frequently Generated in the MRS Cluster
- Memory Usage of the PMS Process Is High
- High Memory Usage of the Knox Process
- It Takes a Long Time to Access HBase from a Client Installed on a Node Outside the Security Cluster
- How Do I Locate a Job Submission Failure?
- OS Disk Space Is Insufficient Due to Oversized HBase Log Files
- Failed to Delete a New Tenant on FusionInsight Manager
- Using Alluixo
- Using ClickHouse
Using DBService
- DBServer Instance Is in Abnormal Status
- DBServer Instance Remains in the Restoring State
- Default Port 20050 or 20051 Is Occupied
- DBServer Instance Is Always in the Restoring State Because the Incorrect /tmp Directory Permission
- DBService Backup Failure
- Components Failed to Connect to DBService in Normal State
- DBServer Failed to Start
- DBService Backup Failed Because the Floating IP Address Is Unreachable
- DBService Failed to Start Due to the Loss of the DBService Configuration File
Using Flink
- "IllegalConfigurationException: Error while parsing YAML configuration file: "security.kerberos.login.keytab" Is Displayed When a Command Is Executed on an Installed Client
- "IllegalConfigurationException: Error while parsing YAML configuration file" Is Displayed When a Command Is Executed After Configurations of the Installed Client Are Changed
- The yarn-session.sh Command Fails to Be Executed When the Flink Cluster Is Created
- Failed to Create a Cluster by Executing the yarn-session Command When a Different User Is Used
- Flink Service Program Fails to Read Files on the NFS Disk
- Failed to Customize the Flink Log4j Log Level
- Using Flume
Using HBase
- Slow Response to HBase Connection
- Failed to Authenticate the HBase User
- RegionServer Failed to Start Because the Port Is Occupied
- HBase Failed to Start Due to Insufficient Node Memory
- HBase Service Unavailable Due to Poor HDFS Performance
- HBase Failed to Start Due to Inappropriate Parameter Settings
- RegionServer Failed to Start Due to Residual Processes
- HBase Failed to Start Due to a Quota Set on HDFS
- HBase Failed to Start Due to Corrupted Version Files
- High CPU Usage Caused by Zero-Loaded RegionServer
- HBase Failed to Started with "FileNotFoundException" in RegionServer Logs
- The Number of RegionServers Displayed on the Native Page Is Greater Than the Actual Number After HBase Is Started
- RegionServer Instance Is in the Restoring State
- HBase Failed to Start in a Newly Installed Cluster
- HBase Failed to Start Due to the Loss of the ACL Table Directory
- HBase Failed to Start After the Cluster Is Powered Off and On
- Failed to Import HBase Data Due to Oversized File Blocks
- Failed to Load Data to the Index Table After an HBase Table Is Created Using Phoenix
- Failed to Run the hbase shell Command on the MRS Cluster Client
- Disordered Information Display on the HBase Shell Client Console Due to Printing of the INFO Information
- HBase Failed to Start Due to Insufficient RegionServer Memory
Using HDFS
- All NameNodes Become the Standby State After the NameNode RPC Port of HDFS Is Changed
- An Error Is Reported When the HDFS Client Is Used After the Host Is Connected Using a Public Network IP Address
- Failed to Use Python to Remotely Connect to the Port of HDFS
- HDFS Capacity Usage Reaches 100%, Causing Unavailable Upper-layer Services Such as HBase and Spark
- An Error Is Reported During HDFS and Yarn Startup
- HDFS Permission Setting Error
- A DataNode of HDFS Is Always in the Decommissioning State
- HDFS Failed to Start Due to Insufficient Memory
- A Large Number of Blocks Are Lost in HDFS due to the Time Change Using ntpdate
- CPU Usage of a DataNode Reaches 100% Occasionally, Causing Node Loss (SSH Connection Is Slow or Fails)
- Manually Performing Checkpoints When a NameNode Is Faulty for a Long Time
- Common File Read/Write Faults
- Maximum Number of File Handles Is Set to a Too Small Value, Causing File Reading and Writing Exceptions
- A Client File Fails to Be Closed After Data Writing
- File Fails to Be Uploaded to HDFS Due to File Errors
- After dfs.blocksize Is Configured and Data Is Put, Block Size Remains Unchanged
- Failed to Read Files, and "FileNotFoundException" Is Displayed
- Failed to Write Files to HDFS, and "item limit of / is exceeded" Is Displayed
- Adjusting the Log Level of the Shell Client
- File Read Fails, and "No common protection layer" Is Displayed
- Failed to Write Files Because the HDFS Directory Quota Is Insufficient
- Balancing Fails, and "Source and target differ in block-size" Is Displayed
- A File Fails to Be Queried or Deleted, and the File Can Be Viewed in the Parent Directory (Invisible Characters)
- Uneven Data Distribution Due to Non-HDFS Data Residuals
- Uneven Data Distribution Due to the Client Installation on the DataNode
- Handling Unbalanced DataNode Disk Usage on Nodes
- Locating Common Balance Problems
- HDFS Displays Insufficient Disk Space But 10% Disk Space Remains
- An Error Is Reported When the HDFS Client Is Installed on the Core Node in a Common Cluster
- Client Installed on a Node Outside the Cluster Fails to Upload Files Using hdfs
- Insufficient Number of Replicas Is Reported During High Concurrent HDFS Writes
- HDFS Client Failed to Delete Overlong Directories
- An Error Is Reported When a Node Outside the Cluster Accesses MRS HDFS
Using Hive
- Content Recorded in Hive Logs
- Causes of Hive Startup Failure
- "Cannot modify xxx at runtime" Is Reported When the set Command Is Executed in a Security Cluster
- How to Specify a Queue When Hive Submits a Job
- How to Set Map and Reduce Memory on the Client
- Specifying the Output File Compression Format When Importing a Table
- desc Table Cannot Be Completely Displayed
- NULL Is Displayed When Data Is Inserted After the Partition Column Is Added
- A Newly Created User Has No Query Permissions
- An Error Is Reported When SQL Is Executed to Submit a Task to a Specified Queue
- An Error Is Reported When the "load data inpath" Command Is Executed
- An Error Is Reported When the "load data local inpath" Command Is Executed
- An Error Is Reported When the "create external table" Command Is Executed
- An Error Is Reported When the dfs -put Command Is Executed on the Beeline Client
- Insufficient Permissions to Execute the set role admin Command
- An Error Is Reported When UDF Is Created Using Beeline
- Difference Between Hive Service Health Status and Hive Instance Health Status
- Hive Alarms and Triggering Conditions
- "authentication failed" Is Displayed During an Attempt to Connect to the Shell Client
- Failed to Access ZooKeeper from the Client
- "Invalid function" Is Displayed When a UDF Is Used
- Hive Service Status Is Unknown
- Health Status of a HiveServer or MetaStore Instance Is Unknown
- Health Status of a HiveServer or MetaStore Instance Is Concerning
- Garbled Characters Returned upon a select Query If Text Files Are Compressed Using ARC4
- Hive Task Failed to Run on the Client But Successful on Yarn
- An Error Is Reported When the select Statement Is Executed
- Failed to Drop a Large Number of Partitions
- Failed to Start a Local Task
- Failed to Start WebHCat
- Sample Code Error for Hive Secondary Development After Domain Switching
- MetaStore Exception Occurs When the Number of DBService Connections Exceeds the Upper Limit
- "Failed to execute session hooks: over max connections" Reported by Beeline
- beeline Reports the "OutOfMemoryError" Error
- Task Execution Fails Because the Input File Number Exceeds the Threshold
- Task Execution Fails Because of Stack Memory Overflow
- Task Failed Due to Concurrent Writes to One Table or Partition
- Hive Task Failed Due to a Lack of HDFS Directory Permission
- Failed to Load Data to Hive Tables
- HiveServer and HiveHCat Process Faults
- An Error Occurs When the INSERT INTO Statement Is Executed on Hive But the Error Message Is Unclear
- Timeout Reported When Adding the Hive Table Field
- Failed to Restart the Hive Service
- Hive Failed to Delete a Table
- An Error Is Reported When msck repair table table_name Is Run on Hive
- How Do I Release Disk Space After Dropping a Table in Hive?
- Connection Timeout During SQL Statement Execution on the Client
- WebHCat Failed to Start Due to Abnormal Health Status
- WebHCat Failed to Start Because the mapred-default.xml File Cannot Be Parsed
- Using Hue
- Using Impala
Using Kafka
- An Error Is Reported When Kafka Is Run to Obtain a Topic
- Flume Normally Connects to Kafka But Fails to Send Messages
- Producer Failed to Send Data and Threw "NullPointerException"
- Producer Fails to Send Data and "TOPIC_AUTHORIZATION_FAILED" Is Thrown
- Producer Occasionally Fails to Send Data and the Log Displays "Too many open files in system"
- Consumer Is Initialized Successfully, But the Specified Topic Message Cannot Be Obtained from Kafka
- Consumer Fails to Consume Data and Remains in the Waiting State
- SparkStreaming Fails to Consume Kafka Messages, and "Error getting partition metadata" Is Displayed
- Consumer Fails to Consume Data in a Newly Created Cluster, and the Message " GROUP_COORDINATOR_NOT_AVAILABLE" Is Displayed
- SparkStreaming Fails to Consume Kafka Messages, and the Message "Couldn't find leader offsets" Is Displayed
- Consumer Fails to Consume Data and the Message " SchemaException: Error reading field 'brokers'" Is Displayed
- Checking Whether Data Consumed by a Customer Is Lost
- Failed to Start a Component Due to Account Lock
- Kafka Broker Reports Abnormal Processes and the Log Shows "IllegalArgumentException"
- Kafka Topics Cannot Be Deleted
- Error "AdminOperationException" Is Displayed When a Kafka Topic Is Deleted
- When a Kafka Topic Fails to Be Created, "NoAuthException" Is Displayed
- Failed to Set an ACL for a Kafka Topic, and "NoAuthException" Is Displayed
- When a Kafka Topic Fails to Be Created, "NoNode for /brokers/ids" Is Displayed
- When a Kafka Topic Fails to Be Created, "replication factor larger than available brokers" Is Displayed
- Consumer Repeatedly Consumes Data
- Leader for the Created Kafka Topic Partition Is Displayed as none
- Safety Instructions on Using Kafka
- Obtaining Kafka Consumer Offset Information
- Adding or Deleting Configurations for a Topic
- Reading the Content of the __consumer_offsets Internal Topic
- Configuring Logs for Shell Commands on the Client
- Obtaining Topic Distribution Information
- Kafka HA Usage Description
- Kafka Producer Writes Oversized Records
- Kafka Consumer Reads Oversized Records
- High Usage of Multiple Disks on a Kafka Cluster Node
- Using Oozie
- Using Presto
Using Spark
- An Error Occurs When the Split Size Is Changed in a Spark Application
- An Error Is Reported When Spark Is Used
- A Spark Job Fails to Run Due to Incorrect JAR File Import
- A Spark Job Is Pending Due to Insufficient Memory
- An Error Is Reported During Spark Running
- Executor Memory Reaches the Threshold Is Displayed in Driver
- Message "Can't get the Kerberos realm" Is Displayed in Yarn-cluster Mode
- Failed to Start spark-sql and spark-shell Due to JDK Version Mismatch
- ApplicationMaster Failed to Start Twice in Yarn-client Mode
- Failed to Connect to ResourceManager When a Spark Task Is Submitted
- DataArts Studio Failed to Schedule Spark Jobs
- Submission Status of the Spark Job API Is Error
- Alarm 43006 Is Repeatedly Generated in the Cluster
- Failed to Create or Delete a Table in Spark Beeline
- Failed to Connect to the Driver When a Node Outside the Cluster Submits a Spark Job to Yarn
- Large Number of Shuffle Results Are Lost During Spark Task Execution
- Disk Space Is Insufficient Due to Long-Term Running of JDBCServer
- Failed to Load Data to a Hive Table Across File Systems by Running SQL Statements Using Spark Shell
- Spark Task Submission Failure
- Spark Task Execution Failure
- JDBCServer Connection Failure
- Failed to View Spark Task Logs
- Authentication Fails When Spark Connects to Other Services
- An Error Occurs When Spark Connects to Redis
- An Error Is Reported When spark-beeline Is Used to Query a Hive View
Using Sqoop
- Connecting Sqoop to MySQL
- Failed to Find the HBaseAdmin.<init> Method When Sqoop Reads Data from the MySQL Database to HBase
- Failed to Export HBase Data to HDFS Through Hue's Sqoop Task
- A Format Error Is Reported When Sqoop Is Used to Export Data from Hive to MySQL 8.0
- An Error Is Reported When sqoop import Is Executed to Import PostgreSQL Data to Hive
- Sqoop Failed to Read Data from MySQL and Write Parquet Files to OBS
Using Storm
- Invalid Hyperlink of Events on the Storm UI
- Failed to Submit a Topology
- Topology Submission Fails and the Message "Failed to check principle for keytab" Is Displayed
- The Worker Log Is Empty After a Topology Is Submitted
- Worker Runs Abnormally After a Topology Is Submitted and Error "Failed to bind to:host:ip" Is Displayed
- "well-known file is not secure" Is Displayed When the jstack Command Is Used to Check the Process Stack
- When the Storm-JDBC plug-in is used to develop Oracle write Bolts, data cannot be written into the Bolts.
- The GC Parameter Configured for the Service Topology Does Not Take Effect
- Internal Server Error Is Displayed When the User Queries Information on the UI
- Using Ranger
Using Yarn
- Plenty of Jobs Are Found After Yarn Is Started
- "GC overhead" Is Displayed on the Client When Tasks Are Submitted Using the Hadoop Jar Command
- Disk Space Is Used Up Due to Oversized Aggregated Logs of Yarn
- Temporary Files Are Not Deleted When an MR Job Is Abnormal
- ResourceManager of Yarn (Port 8032) Throws Error "connection refused"
- Failed to View Job Logs on the Yarn Web UI
- An Error Is Reported When a Queue Name Is Clicked on the Yarn Page
- Using ZooKeeper
- Accessing OBS
- Appendix
Overview
- Before You Start
- API Overview
- Calling APIs
- Application Cases
- API V2
- API V1.1
- Appendix
User Guide (Ankara Region)
Overview
- What Is MRS?
- Application Scenarios
- Components
- Functions
- Constraints
- Permissions Management
- Related Services
- Preparing a User
- Getting Started
Configuring a Cluster
- How to Create an MRS Cluster
- Quick Configuration
- Creating a Custom Cluster
- Configuring Custom Topology
- Adding a Tag to a Cluster/Node
- Communication Security Authorization
Configuring Auto Scaling Rules
- Overview
- Configuring Auto Scaling During Cluster Creation
- Creating an Auto Scaling Policy for an Existing Cluster
- Scenario 1: Using Auto Scaling Rules Alone
- Scenario 2: Using Resource Plans Alone
- Scenario 3: Using Both Auto Scaling Rules and Resource Plans
- Modifying an Auto Scaling Policy
- Deleting an Auto Scaling Policy
- Enabling or Disabling an Auto Scaling Policy
- Viewing an Auto Scaling Policy
- Configuring Automation Scripts
- Configuring Auto Scaling Metrics
- Managing Data Connections
- Installing Third-Party Software Using Bootstrap Actions
- Viewing Failed MRS Tasks
- Viewing Information of a Historical Cluster
Managing Clusters
- Logging In to a Cluster
- Cluster Overview
- Viewing and Customizing Cluster Monitoring Metrics
- Cluster O&M
- Managing Nodes
- Job Management
Component Management
- Object Management
- Managing Services
- Configuring Service Parameters
- Configuring Customized Service Parameters
- Managing Role Instances
- Configuring Role Instance Parameters
- Synchronizing Role Instance Configuration
- Decommissioning and Recommissioning a Role Instance
- Starting and Stopping a Cluster
- Performing Rolling Restart
- Alarm Management
Tenant Management
- Overview
- Creating a Tenant
- Creating a Sub-tenant
- Deleting a Tenant
- Managing a Tenant Directory
- Restoring Tenant Data
- Creating a Resource Pool
- Modifying a Resource Pool
- Deleting a Resource Pool
- Configuring a Queue
- Configuring the Queue Capacity Policy of a Resource Pool
- Clearing Configuration of a Queue
- Bootstrap Actions
- Using an MRS Client
Configuring a Cluster with Decoupled Storage and Compute
- MRS Storage-Compute Decoupling
- Interconnecting with OBS Using the Cluster Agency Mechanism
- Interconnecting with OBS Using the Guardian Service
- Accessing Web Pages of Open Source Components Managed in MRS Clusters
- Accessing FusionInsight Manager
FusionInsight Manager Operation Guide
- Getting Started
- Home Page
Cluster
- Cluster Management
- Managing a Service
- Instance Management
- Hosts
- O&M
- Audit
- Tenant Resources
- System Configuration
- Log Management
Backup and Recovery Management
- Introduction
Backing Up Data
- Backing Up Manager Data
- Backing Up CDL Data
- Backing Up Containers Metadata
- Backing Up ClickHouse Metadata
- Backing Up ClickHouse Service Data
- Backing Up DBService Data
- Backing Up Flink Metadata
- Backing Up HBase Metadata
- Backing Up HBase Service Data
- Backing Up Elasticsearch Service Data
- Backing Up MOTService Service Data
- Backing Up NameNode Data
- Backing Up HDFS Service Data
- Backing Up Hive Service Data
- Backing Up IoTDB Metadata
- Backing Up IoTDB Service Data
- Backing Up Kafka Metadata
- Backing Up Redis Data
- Backing Up RTDService Metadata
- Backing Up Solr Metadata
- Backing Up Solr Service Data
Recovering Data
- Restoring Manager Data
- Restoring CDL Data
- Restoring Containers Metadata
- Restoring ClickHouse Metadata
- Restoring ClickHouse Service Data
- Restoring DBService Data
- Restoring Flink Metadata
- Restoring HBase Metadata
- Restoring HBase Service Data
- Restoring Elasticsearch Service Data
- Restoring MOTService Service Data
- Restoring NameNode Data
- Restoring HDFS Service Data
- Restoring Hive Service Data
- Restoring IoTDB Metadata
- Restoring IoTDB Service Data
- Restoring Kafka Metadata
- Restoring Redis Data
- Restoring RTDService Metadata
- Restoring Solr Metadata
- Restoring Solr Service Data
- Enabling Cross-Cluster Replication
- Managing Local Quick Restoration Tasks
- Modifying a Backup Task
- Viewing Backup and Restoration Tasks
- SQL Inspector
Security Management
- Security Overview
- Account Management
Security Hardening
- Hardening Policies
- Configuring a Trusted IP Address to Access LDAP
- HFile and WAL Encryption
- Configuring Hadoop Security Parameters
- Configuring an IP Address Whitelist for Modification Allowed by HBase
- Updating a Key for a Cluster
- Changing the Cluster Encryption Mode
- Hardening the LDAP
- Configuring Kafka Data Encryption During Transmission
- Configuring HDFS Data Encryption During Transmission
- Configuring HetuEngine Data Encryption During Transmission
- Configuring RTD Data Encryption During Transmission
- Configuring IoTDB Data Encryption During Transmission
- ClickHouse Security Hardening
- Hive Metastore Security Hardening
- Configuring ZooKeeper SSL
- Encrypting the Communication Between the Controller and the Agent
- Updating SSH Keys for User omm
- Changing the Timeout Duration of the Manager Page
- Resetting Sessions During Secondary Authentication Configuration
- Security Maintenance
- Security Statement
Alarm Reference
- ALM-12001 Audit Log Dumping Failure
- ALM-12004 Manager OLdap Resource Abnormal
- ALM-12005 Manager OKerberos Resource Abnormal
- ALM-12006 NodeAgent Process Is Abnormal
- ALM-12007 Process Fault
- ALM-12010 Manager Heartbeat Interruption Between the Active and Standby Nodes
- ALM-12011 Manager Data Synchronization Exception Between the Active and Standby Nodes
- ALM-12014 Device Partition Lost
- ALM-12015 Partition Filesystem Readonly
- ALM-12016 CPU Usage Exceeds the Threshold
- ALM-12017 Insufficient Disk Capacity
- ALM-12018 Memory Usage Exceeds the Threshold
- ALM-12027 Host PID Usage Exceeds the Threshold
- ALM-12028 Number of Processes in the D State on a Host Exceeds the Threshold
- ALM-12033 Slow Disk Fault
- ALM-12034 Periodical Backup Failure
- ALM-12035 Unknown Data Status After Recovery Task Failure
- ALM-12038 Monitoring Indicator Dumping Failure
- ALM-12039 Active/Standby OMS Databases Not Synchronized
- ALM-12040 Insufficient OS Entropy
- ALM-12041 Incorrect Permission on Key Files
- ALM-12042 Incorrect Configuration of Key Files
- ALM-12045 Read Packet Dropped Rate Exceeds the Threshold
- ALM-12046 Write Packet Dropped Rate Exceeds the Threshold
- ALM-12047 Read Packet Error Rate Exceeds the Threshold
- ALM-12048 Write Packet Error Rate Exceeds the Threshold
- ALM-12049 Network Read Throughput Rate Exceeds the Threshold
- ALM-12050 Network Write Throughput Rate Exceeds the Threshold
- ALM-12051 Disk Inode Usage Exceeds the Threshold
- ALM-12052 TCP Temporary Port Usage Exceeds the Threshold
- ALM-12053 Host File Handle Usage Exceeds the Threshold
- ALM-12054 Invalid Certificate File
- ALM-12055 The Certificate File Is About to Expire
- ALM-12057 Metadata Not Configured with the Task to Periodically Back Up Data to a Third-Party Server
- ALM-12061 Process Usage Exceeds the Threshold
- ALM-12062 OMS Parameter Configurations Mismatch with the Cluster Scale
- ALM-12063 Unavailable Disk
- ALM-12064 Host Random Port Range Conflicts with Cluster Used Port
- ALM-12066 Trust Relationships Between Nodes Become Invalid
- ALM-12067 Abnormal Tomcat Resources of Manager
- ALM-12068 Abnormal ACS Resources of Manager
- ALM-12069 Abnormal AOS Resources of Manager
- ALM-12070 Controller Resource Is Abnormal
- ALM-12071 Httpd Resource Is Abnormal
- ALM-12072 FloatIP Resource Is Abnormal
- ALM-12073 CEP Resource Is Abnormal
- ALM-12074 FMS Resource Is Abnormal
- ALM-12075 PMS Resource Is Abnormal
- ALM-12076 GaussDB Resource Is Abnormal
- ALM-12077 User omm Expired
- ALM-12078 Password of User omm Expired
- ALM-12079 User omm Is About to Expire
- ALM-12080 Password of User omm Is About to Expire
- ALM-12081User ommdba Expired
- ALM-12082 User ommdba Is About to Expire
- ALM-12083 Password of User ommdba Is About to Expire
- ALM-12084 Password of User ommdba Expired
- ALM-12085 Service Audit Log Dump Failure
- ALM-12087 System Is in the Upgrade Observation Period
- ALM-12089 Network Connections Between Nodes Are Abnormal
- ALM-12099 Core Dump for Cluster Processes
- ALM-12101 AZ Unhealthy
- ALM-12102 AZ HA Component Is Not Deployed Based on DR Requirements
- ALM-12110 Failed to get ECS temporary AK/SK
- ALM-12180 Suspended Disk I/O
- ALM-12190 Number of Knox Connections Exceeds the Threshold
- ALM-12191 Disk I/O Usage Exceeds the Threshold
- ALM-12192 Host Load Exceeds the Threshold
- ALM-12200 Password Is About to Expire
- ALM-12201 Process CPU Usage Exceeds the Threshold
- ALM-12202 Process Memory Usage Exceeds the Threshold
- ALM-12203 Process Full GC Duration Exceeds the Threshold
- ALM-12204 Wait Duration of a Disk Read Exceeds the Threshold
- ALM-12205 Wait Duration of a Disk Write Exceeds the Threshold
- ALM-12206 Password Has Expired
- ALM-13000 ZooKeeper Service Unavailable
- ALM-13001 Available ZooKeeper Connections Are Insufficient
- ALM-13002 ZooKeeper Direct Memory Usage Exceeds the Threshold
- ALM-13003 GC Duration of the ZooKeeper Process Exceeds the Threshold
- ALM-13004 ZooKeeper Heap Memory Usage Exceeds the Threshold
- ALM-13005 Failed to Set the Quota of Top Directories of ZooKeeper Components
- ALM-13006 Znode Number or Capacity Exceeds the Threshold
- ALM-13007 Available ZooKeeper Client Connections Are Insufficient
- ALM-13008 ZooKeeper Znode Usage Exceeds the Threshold
- ALM-13009 ZooKeeper Znode Capacity Usage Exceeds the Threshold
- ALM-13010 Znode Usage of a Directory with Quota Configured Exceeds the Threshold
- ALM-14000 HDFS Service Unavailable
- ALM-14001 HDFS Disk Usage Exceeds the Threshold
- ALM-14002 DataNode Disk Usage Exceeds the Threshold
- ALM-14003 Number of Lost HDFS Blocks Exceeds the Threshold
- ALM-14006 Number of HDFS Files Exceeds the Threshold
- ALM-14007 NameNode Heap Memory Usage Exceeds the Threshold
- ALM-14008 DataNode Heap Memory Usage Exceeds the Threshold
- ALM-14009 Number of Dead DataNodes Exceeds the Threshold
- ALM-14010 NameService Service Is Abnormal
- ALM-14011 DataNode Data Directory Is Not Configured Properly
- ALM-14012 JournalNode Is Out of Synchronization
- ALM-14013 Failed to Update the NameNode FsImage File
- ALM-14014 NameNode GC Time Exceeds the Threshold
- ALM-14015 DataNode GC Time Exceeds the Threshold
- ALM-14016 DataNode Direct Memory Usage Exceeds the Threshold
- ALM-14017 NameNode Direct Memory Usage Exceeds the Threshold
- ALM-14018 NameNode Non-heap Memory Usage Exceeds the Threshold
- ALM-14019 DataNode Non-heap Memory Usage Exceeds the Threshold
- ALM-14020 Number of Entries in the HDFS Directory Exceeds the Threshold
- ALM-14021 NameNode Average RPC Processing Time Exceeds the Threshold
- ALM-14022 NameNode Average RPC Queuing Time Exceeds the Threshold
- ALM-14023 Percentage of Total Reserved Disk Space for Replicas Exceeds the Threshold
- ALM-14024 Tenant Space Usage Exceeds the Threshold
- ALM-14025 Tenant File Object Usage Exceeds the Threshold
- ALM-14026 Blocks on DataNode Exceed the Threshold
- ALM-14027 DataNode Disk Fault
- ALM-14028 Number of Blocks to Be Supplemented Exceeds the Threshold
- ALM-14029 Number of Blocks in a Replica Exceeds the Threshold
- ALM-14030 HDFS Allows Write of Single-Replica Data
- ALM-14031 DataNode Process Is Abnormal
- ALM-14032 JournalNode Process Is Abnormal
- ALM-14033 ZKFC Process Is Abnormal
- ALM-14034 Router Process Is Abnormal
- ALM-14035 HttpFS Process Is Abnormal
- ALM-16000 Percentage of Sessions Connected to the HiveServer to Maximum Number Allowed Exceeds the Threshold
- ALM-16001 Hive Warehouse Space Usage Exceeds the Threshold
- ALM-16002 Hive SQL Execution Success Rate Is Lower Than the Threshold
- ALM-16003 Background Thread Usage Exceeds the Threshold
- ALM-16004 Hive Service Unavailable
- ALM-16005 The Heap Memory Usage of the Hive Process Exceeds the Threshold
- ALM-16006 The Direct Memory Usage of the Hive Process Exceeds the Threshold
- ALM-16007 Hive GC Time Exceeds the Threshold
- ALM-16008 Non-Heap Memory Usage of the Hive Process Exceeds the Threshold
- ALM-16009 Map Number Exceeds the Threshold
- ALM-16045 Hive Data Warehouse Is Deleted
- ALM-16046 Hive Data Warehouse Permission Is Modified
- ALM-16047 HiveServer Has Been Deregistered from ZooKeeper
- ALM-16048 Tez or Spark Library Path Does Not Exist
- ALM-16051 Percentage of Sessions Connected to MetaStore Exceeds the Threshold
- ALM-17003 Oozie Service Unavailable
- ALM-17004 Oozie Heap Memory Usage Exceeds the Threshold
- ALM-17005 Oozie Non Heap Memory Usage Exceeds the Threshold
- ALM-17006 Oozie Direct Memory Usage Exceeds the Threshold
- ALM-17007 Garbage Collection (GC) Time of the Oozie Process Exceeds the Threshold
- ALM-17008 Abnormal Connection Between Oozie and ZooKeeper
- ALM-17009 Abnormal Connection Between Oozie and DBService
- ALM-17010 Abnormal Connection Between Oozie and HDFS
- ALM-17011 Abnormal Connection Between Oozie and Yarn
- ALM-18000 Yarn Service Unavailable
- ALM-18002 NodeManager Heartbeat Lost
- ALM-18003 NodeManager Unhealthy
- ALM-18008 Heap Memory Usage of ResourceManager Exceeds the Threshold
- ALM-18009 Heap Memory Usage of JobHistoryServer Exceeds the Threshold
- ALM-18010 ResourceManager GC Time Exceeds the Threshold
- ALM-18011 NodeManager GC Time Exceeds the Threshold
- ALM-18012 JobHistoryServer GC Time Exceeds the Threshold
- ALM-18013 ResourceManager Direct Memory Usage Exceeds the Threshold
- ALM-18014 NodeManager Direct Memory Usage Exceeds the Threshold
- ALM-18015 JobHistoryServer Direct Memory Usage Exceeds the Threshold
- ALM-18016 Non Heap Memory Usage of ResourceManager Exceeds the Threshold
- ALM-18017 Non Heap Memory Usage of NodeManager Exceeds the Threshold
- ALM-18018 NodeManager Heap Memory Usage Exceeds the Threshold
- ALM-18019 Non Heap Memory Usage of JobHistoryServer Exceeds the Threshold
- ALM-18020 Yarn Task Execution Timeout
- ALM-18021 Mapreduce Service Unavailable
- ALM-18022 Insufficient YARN Queue Resources
- ALM-18023 Number of Pending Yarn Tasks Exceeds the Threshold
- ALM-18024 Pending Yarn Memory Usage Exceeds the Threshold
- ALM-18025 Number of Terminated Yarn Tasks Exceeds the Threshold
- ALM-18026 Number of Failed Yarn Tasks Exceeds the Threshold
- ALM-19000 HBase Service Unavailable
- ALM-19006 HBase Replication Sync Failed
- ALM-19007 HBase GC Time Exceeds the Threshold
- ALM-19008 Heap Memory Usage of the HBase Process Exceeds the Threshold
- ALM-19009 Direct Memory Usage of the HBase Process Exceeds the Threshold
- ALM-19011 RegionServer Region Number Exceeds the Threshold
- ALM-19012 HBase System Table Directory or File Lost
- ALM-19013 Duration of Regions in transaction State Exceeds the Threshold
- ALM-19014 Capacity Quota Usage on ZooKeeper Exceeds the Threshold Severely
- ALM-19015 Quantity Quota Usage on ZooKeeper Exceeds the Threshold
- ALM-19016 Quantity Quota Usage on ZooKeeper Exceeds the Threshold Severely
- ALM-19017 Capacity Quota Usage on ZooKeeper Exceeds the Threshold
- ALM-19018 HBase Compaction Queue Size Exceeds the Threshold
- ALM-19019 Number of HBase HFiles to Be Synchronized Exceeds the Threshold
- ALM-19020 Number of HBase WAL Files to Be Synchronized Exceeds the Threshold
- ALM-19022 HBase Hotspot Detection Is Unavailable
- ALM-19023 Region Traffic Restriction for HBase
- ALM-19024 RPC Requests P99 Latency on RegionServer Exceeds the Threshold
- ALM-19025 Damaged StoreFile in HBase
- ALM-19026 Damaged WAL Files in HBase
- ALM-19030 P99 Latency of RegionServer RPC Request Exceeds the Threshold
- ALM-19031 Number of RegionServer RPC Connections Exceeds the Threshold
- ALM-19032 Number of Tasks in the RegionServer RPC Write Queue Exceeds the Threshold
- ALM-19033 Number of Tasks in the RegionServer RPC Read Queue Exceeds the Threshold
- ALM-19034 Number of RegionServer WAL Write Timesouts Exceeds the Threshold
- ALM-19035 Size of the RegionServer Call Queue Exceeds the Threshold
- ALM-20002 Hue Service Unavailable
- ALM-23001 Loader Service Unavailable
- ALM-23003 Loader Task Execution Failed
- ALM-23004 Loader Heap Memory Usage Exceeds the Threshold
- ALM-23005 Loader Non-Heap Memory Usage Exceeds the Threshold
- ALM-23006 Loader Direct Memory Usage Exceeds the Threshold
- ALM-23007 GC Duration of the Loader Process Exceeds the Threshold
- ALM-24000 Flume Service Unavailable
- ALM-24001 Flume Agent Exception
- ALM-24003 Flume Client Connection Interrupted
- ALM-24004 Exception Occurs When Flume Reads Data
- ALM-24005 Exception Occurs When Flume Transmits Data
- ALM-24006 Heap Memory Usage of Flume Server Exceeds the Threshold
- ALM-24007 Flume Server Direct Memory Usage Exceeds the Threshold
- ALM-24008 Flume Server Non Heap Memory Usage Exceeds the Threshold
- ALM-24009 Flume Server Garbage Collection (GC) Duration Exceeds the Threshold
- ALM-24010 Flume Certificate File Is Invalid or Damaged
- ALM-24011 Flume Certificate File Is About to Expire
- ALM-24012 Flume Certificate File Has Expired
- ALM-24013 Flume MonitorServer Certificate File Is Invalid or Damaged
- ALM-24014 Flume MonitorServer Certificate Is About to Expire
- ALM-24015 Flume MonitorServer Certificate File Has Expired
- ALM-25000 LdapServer Service Unavailable
- ALM-25004 Abnormal LdapServer Data Synchronization
- ALM-25005 nscd Service Exception
- ALM-25006 Sssd Service Exception
- ALM-25500 KrbServer Service Unavailable
- ALM-25501 Too Many KerberosServer Requests
- ALM-27001 DBService Is Unavailable
- ALM-27003 DBService Heartbeat Interruption Between the Active and Standby Nodes
- ALM-27004 Data Inconsistency Between Active and Standby DBServices
- ALM-27005 Database Connection Usage Exceeds the Threshold
- ALM-27006 Data Directory Disk Usage Exceeds the Threshold
- ALM-27007 Database Enters the Read-Only Mode
- ALM-33004 BLU Instance Health Status of Containers Is Abnormal
- ALM-33005 Maximum Number of Concurrent Containers Requests Exceeds the Threshold
- ALM-33006 Failure Rate of Containers Calls Exceeds the Threshold
- ALM-33007 ALB TPS of Containers Exceeds the Threshold
- ALM-33008 Average Latency of Containers Exceeds the Threshold
- ALM-33009 Containers Heap Memory Usage Exceeds the Threshold
- ALM-33010 Containers Non-Heap Memory Usage Exceeds the Threshold
- ALM-33011 Containers Metaspace Usage Exceeds the Threshold
- ALM-33012 Containers' ZooKeeper Client Is Disconnected
- ALM-38000 Kafka Service Unavailable
- ALM-38001 Insufficient Kafka Disk Space
- ALM-38002 Kafka Heap Memory Usage Exceeds the Threshold
- ALM-38004 Kafka Direct Memory Usage Exceeds the Threshold
- ALM-38005 GC Duration of the Broker Process Exceeds the Threshold
- ALM-38006 Percentage of Kafka Partitions That Are Not Completely Synchronized Exceeds the Threshold
- ALM-38007 Status of Kafka Default User Is Abnormal
- ALM-38008 Abnormal Kafka Data Directory Status
- ALM-38009 Busy Broker Disk I/Os
- ALM-38010 Topics with Single Replica
- ALM-38011 User Connection Usage on Broker Exceeds the Threshold
- ALM-41007 RTDService Unavailable
- ALM-43001 Spark Service Unavailable
- ALM-43006 Heap Memory Usage of the JobHistory Process Exceeds the Threshold
- ALM-43007 Non-Heap Memory Usage of the JobHistory Process Exceeds the Threshold
- ALM-43008 Direct Memory Usage of the JobHistory Process Exceeds the Threshold
- ALM-43009 JobHistory Process GC Duration Exceeds the Threshold
- ALM-43010 Heap Memory Usage of the JDBCServer Process Exceeds the Threshold
- ALM-43011 Non-Heap Memory Usage of the JDBCServer Process Exceeds the Threshold
- ALM-43012 Direct Memory Usage of the JDBCServer Process Exceeds the Threshold
- ALM-43013 JDBCServer Process GC Duration Exceeds the Threshold
- ALM-43017 JDBCServer Process Full GC Times Exceeds the Threshold
- ALM-43018 JobHistory Process Full GC Times Exceeds the Threshold
- ALM-43019 Heap Memory Usage of the IndexServer Process Exceeds the Threshold
- ALM-43020 Non-Heap Memory Usage of the IndexServer Process Exceeds the Threshold
- ALM-43021 Direct Memory Usage of the IndexServer Process Exceeds the Threshold
- ALM-43022 IndexServer Process GC Time Exceeds the Threshold
- ALM-43023 IndexServer Process Full GC Number Exceeds the Threshold
- ALM-43200 Elasticsearch Service Unavailable
- ALM-43201 Heap Memory Usage of Elasticsearch Exceeds the Threshold
- ALM-43202 Indices in the Yellow State Exist in Elasticsearch
- ALM-43203 Indices in the Red State Exist in Elasticsearch
- ALM-43204 GC Duration of the Elasticsearch Process Exceeds the Threshold
- ALM-43205 Elasticsearch Stored Shard Data Volume Exceeds the Threshold
- ALM-43206 Elasticsearch Shard Document Number Exceeds the Threshold
- ALM-43207 Elasticsearch Has Indexes Without Replicas
- ALM-43208 Elasticsearch Data Directory Usage Exceeds the Threshold
- ALM-43209 Total Number of Elasticsearch Instance Shards Exceeds the Threshold
- ALM-43210 Total Number of Elasticsearch Shards Exceeds the Threshold
- ALM-43600 GraphBase Service Unavailable
- ALM-43605 Number of Real-Time Requests on a GraphBase Node Exceeds the Threshold
- ALM-43607 Nginx Fault in GraphBase
- ALM-43608 Floating IP Address of GraphBase Is Faulty
- ALM-43609 TaskManager of GraphBase Is Faulty
- ALM-43610 GC Time of the Old-Generation GraphServer Process Exceeds the Threshold
- ALM-43611 Number of GC Times of the Old-Generation GraphServer Process Exceeds the Threshold
- ALM-43612 GC Duration of the Young-Generation GraphServer Process Exceeds the Threshold
- ALM-43613 Number of GC Times of the Young-Generation GraphServer Process Exceeds the Threshold
- ALM-43614 Time Spent on a GraphBase Path Query Request Exceeds the Threshold
- ALM-43615 Time Spent on a Line Expansion Query Request in GraphBase Exceeds the Threshold
- ALM-43616 GraphBase-related Yarn Jobs Are Abnormal
- ALM-43617 Number of Waiting Queues for Real-Time Data Import to GraphBase Exceeds the Threshold
- ALM-43618 GraphServer Heap Memory Usage Exceeds the Threshold
- ALM-43619 Invalid GraphBase HA Certificate Files
- ALM-43620 GraphBase HA Certificates Are About to Expire
- ALM-43621 GraphBase HA Certificate Files Have Expired
- ALM-43850 KMS Service Unavailable
- ALM-45000 HetuEngine Service Unavailable
- ALM-45001 Faulty HetuEngine Compute Instances
- ALM-45003 HetuEngine QAS Disk Capacity Is Insufficient
- ALM-45004 Tasks Stacked on HetuEngine Compute Instance
- ALM-45005 CPU Usage of HetuEngine Compute Instance Exceeded the Threshold
- ALM-45006 Memory Usage of a HetuEngine Compute Instance Exceeded the Threshold
- ALM-45007 Number of Workers of a HetuEngine Compute Instance Is Less Than the Threshold
- ALM-45191 Failed to Obtain ECS Metadata
- ALM-45192 Failed to Obtain the IAM Security Token
- ALM-45275 Ranger Service Unavailable
- ALM-45276 Abnormal RangerAdmin Status
- ALM-45277 RangerAdmin Heap Memory Usage Exceeds the Threshold
- ALM-45278 RangerAdmin Direct Memory Usage Exceeds the Threshold
- ALM-45279 RangerAdmin Non-Heap Memory Usage Exceeds the Threshold
- ALM-45280 RangerAdmin GC Duration Exceeds the Threshold
- ALM-45281 UserSync Heap Memory Usage Exceeds the Threshold
- ALM-45282 UserSync Direct Memory Usage Exceeds the Threshold
- ALM-45283 UserSync Non-Heap Memory Usage Exceeds the Threshold
- ALM-45284 UserSync Garbage Collection (GC) Time Exceeds the Threshold
- ALM-45285 TagSync Heap Memory Usage Exceeds the Threshold
- ALM-45286 TagSync Direct Memory Usage Exceeds the Threshold
- ALM-45287 TagSync Non-Heap Memory Usage Exceeds the Threshold
- ALM-45288 TagSync Garbage Collection (GC) Time Exceeds the Threshold
- ALM-45289 PolicySync Heap Memory Usage Exceeds the Threshold
- ALM-45290 PolicySync Direct Memory Usage Exceeds the Threshold
- ALM-45291 PolicySync Non-Heap Memory Usage Exceeds the Threshold
- ALM-45292 PolicySync GC Duration Exceeds the Threshold
- ALM-45293 Ranger User Synchronization Exception
- ALM-45425 ClickHouse Service Unavailable
- ALM-45426 ClickHouse Service Quantity Quota Usage in ZooKeeper Exceeds the Threshold
- ALM-45427 ClickHouse Service Capacity Quota Usage in ZooKeeper Exceeds the Threshold
- ALM-45428 ClickHouse Disk I/O Exception
- ALM-45429 Table Metadata Synchronization Failed on the Added ClickHouse Node
- ALM-45430 Permission Metadata Synchronization Failed on the Added ClickHouse Node
- ALM-45434 A Single Replica Exists in the ClickHouse Data Table
- ALM-45440 Inconsistency Between ClickHouse Replicas
- ALM-45441 Zookeeper Disconnected
- ALM-45442 Too Many Concurrent SQL Statements
- ALM-45443 Slow SQL Queries in the Cluster
- ALM-45444 Abnormal ClickHouse Process
- ALM-45445 Failed to Send Data Files to Remote Shards When ClickHouse Writes Data to a Distributed Table
- ALM-45446 Mutation Task of ClickHouse Is Not Complete for a Long Time
- ALM-45585 IoTDB Service Unavailable
- ALM-45586 IoTDBServer Heap Memory Usage Exceeds the Threshold
- ALM-45587 IoTDBServer GC Duration Exceeds the Threshold
- ALM-45588 IoTDBServer Direct Memory Usage Exceeds the Threshold
- ALM-45589 ConfigNode Heap Memory Usage Exceeds the Threshold
- ALM-45590 ConfigNode GC Duration Exceeds the Threshold
- ALM-45591 ConfigNode Direct Memory Usage Exceeds the Threshold
- ALM-45592 IoTDBServer RPC Execution Duration Exceeds the Threshold
- ALM-45593 IoTDBServer Flush Execution Duration Exceeds the Threshold
- ALM-45594 IoTDBServer Intra-Space Merge Duration Exceeds the Threshold
- ALM-45595 IoTDBServer Cross-Space Merge Duration Exceeds the Threshold
- ALM-45596 Procedure Execution Failed
- ALM-45615 CDL Service Unavailable
- ALM-45616 CDL Job Execution Exception
- ALM-45617 Data Queued in the CDL Replication Slot Exceeds the Threshold
- ALM-45635 FlinkServer Job Execution Failure
- ALM-45636 Number of Consecutive Checkpoint Failures of a Flink Job Exceeds the Threshold
- ALM-45637 Continuous Back Pressure Time of a Flink Job Exceeds the Threshold
- ALM-45638 Number of Restarts After Flink Job Failures Exceeds the Threshold
- ALM-45639 Checkpointing of a Flink Job Times Out
- ALM-45640 FlinkServer Heartbeat Interruption Between the Active and Standby Nodes
- ALM-45641 Data Synchronization Exception Between the Active and Standby FlinkServer Nodes
- ALM-45642 RocksDB Continuously Triggers Write Traffic Limiting
- ALM-45643 MemTable Size of RocksDB Continuously Exceeds the Threshold
- ALM-45644 Number of SST Files at Level 0 of RocksDB Continuously Exceeds the Threshold
- ALM-45645 Pending Flush Size of RocksDB Continuously Exceeds the Threshold
- ALM-45646 Pending Compaction Size of RocksDB Continuously Exceeds the Threshold
- ALM-45647 Estimated Pending Compaction Size of RocksDB Continuously Exceeds the Threshold
- ALM-45648 RocksDB Frequently Encounters Write-Stopped
- ALM-45649 P95 Latency of RocksDB Get Requests Continuously Exceeds the Threshold
- ALM-45650 P95 Latency of RocksDB Write Requests Continuously Exceeds the Threshold
- ALM-45652 Flink Service Unavailable
- ALM-45653 Invalid Flink HA Certificate File
- ALM-45654 Flink HA Certificate Is About to Expire
- ALM-45655 Flink HA Certificate File Has Expired
- ALM-45736 Guardian Service Unavailable
- ALM-45737 Guardian TokenServer Heap Memory Usage Exceeds the Threshold
- ALM-45738 Guardian TokenServer Direct Memory Usage Exceeds the Threshold
- ALM-45739 Guardian TokenServer Non-Heap Memory Usage Exceeds the Threshold
- ALM-45740 Guardian TokenServer GC Duration Exceeds the Threshold
- ALM-45741 Guardian Failed to Call the ECS securitykey API
- ALM-45742 Guardian Failed to Call the ECS Metadata API
- ALM-45743 Guardian Failed to Call the IAM API
- ALM-46001 MOTService Unavailable
- ALM-46003 MOTService Heartbeat Interruption Between the Active and Standby Nodes
- ALM-46004 Data Inconsistency Between Active and Standby MOTService Nodes
- ALM-46005 MOTService Database Connection Usage Exceeds the Threshold
- ALM-46006 Disk Space Usage of the MOTService Data Directory Exceeds the Threshold
- ALM-46007 MOTService Database Enters the Read-Only Mode
- ALM-46008 MOTService Memory Usage Exceeds the Threshold
- ALM-46009 MOTService CPU Usage Exceeds the Threshold
- ALM-46010 MOTService Certificate File Is About to Expire
- ALM-46011 MOTService Certificate File Has Expired
- ALM-46012 Abnormal Nginx of MOTService
- ALM-47000 MemArtsCC Instance Unavailable
- ALM-47002 MemArtsCC Disk Fault
- ALM-50201 Doris Service Unavailable
- ALM-50202 FE CPU Usage Exceeds the Threshold
- ALM-50203 FE Memory Usage Exceeds the Threshold
- ALM-50205 BE CPU Usage Exceeds the Threshold
- ALM-50206 BE Memory Usage Exceeds the Threshold
- ALM-50207 Ratio of Connections to the FE MySQL Port to the Maximum Connections Allowed Exceeds the Threshold
- ALM-50208 Failures to Clear Historical Metadata Image Files Exceed the Threshold
- ALM-50209 Failures to Generate Metadata Image Files Exceed the Threshold
- ALM-50210 Maximum Compaction Score of All BE Nodes Exceeds the Threshold
- ALM-50211 FE Queue Length of BE Periodic Report Tasks Exceeds the Threshold
- ALM-50212 Accumulated Old-Generation GC Duration of the FE Process Exceeds the Threshold
- ALM-50213 Number of Tasks Queuing in the FE Thread Pool for Interacting with BE Exceeds the Threshold
- ALM-50214 Number of Tasks Queuing in the FE Thread Pool for Task Processing Exceeds the Threshold
- ALM-50215 Longest Duration of RPC Requests Received by Each FE Thrift Method Exceeds the Threshold
- ALM-50216 Memory Usage of the FE Node Exceeds the Threshold
- ALM-50217 Heap Memory Usage of the FE Node Exceeds the Threshold
- ALM-50219 Length of the Queue in the Thread Pool for Query Execution Exceeds the Threshold
- ALM-50220 Error Rate of TCP Packet Receiving Exceeds the Threshold
- ALM-50221 BE Data Disk Usage Exceeds the Threshold
- ALM-50222 Disk Status of a Specified Data Directory on BE Is Abnormal
- ALM-50223 Maximum Memory Required by BE Is Greater Than the Remaining Memory of the Machine
- ALM-50224 Failures a Certain Task Type on BE Are Increasing
- ALM-50225 Unavailable FE Instances
- ALM-50226 Unavailable BE Instances
- ALM-50227 Concurrent Doris Tenant Queries Exceeds the Threshold
- ALM-50228 Memory Usage of a Doris Tenant Exceeds the Threshold
- ALM-50229 Doris FE Failed to Connect to OBS
- ALM-50230 Doris BE Cannot Connect to OBS
- ALM-50401 Number of JobServer Waiting Tasks Exceeds the Threshold
- ALM-50402 JobGateway Service Unavailable
- ALM-51201 LakeSearch Unavailable
- ALM-51202 LakeSearch Heap Memory Usage Exceeds the Threshold
- ALM-51203 GC Duration of the LakeSearch Instance Exceeds the Threshold
- Interconnecting Jupyter Notebook with MRS Using Custom Python
- Client Usage
- Web Page Access
- Alarm Monitoring
- Performance Tuning
Job Development
- Cluster Access
- What Are the Differences Between Sample Project Building and Application Development? Is Python Code Supported?
- API
Cluster Management
Kerberos Usage
Troubleshooting
Cluster Management
- Scale-Out Failure
- Using ClickHouse
Using DBService
Using Flink
- Using Flume
Using HBase
Using HDFS
Using Hive
- Using Hue
Using Kafka
- Using Oozie
Using Spark
- Using Sqoop
Using Storm
- Using Ranger
Using Yarn
- Temporary Files Are Not Deleted When a MapReduce Job Is Abnormal
- Using ZooKeeper
- Accessing OBS
- Appendix
Overview
Component Operation Guide (LTS) (Ankara Region)
Using CarbonData
- Overview
- Common CarbonData Parameters
- CarbonData Operation Guide
- CarbonData Performance Tuning
- CarbonData Access Control
- CarbonData Syntax Reference
- CarbonData Troubleshooting
CarbonData FAQ
- Why Is Incorrect Output Displayed When I Perform Query with Filter on Decimal Data Type Values?
- How to Avoid Minor Compaction for Historical Data?
- How to Change the Default Group Name for CarbonData Data Loading?
- Why Does INSERT INTO CARBON TABLE Command Fail?
- Why Is the Data Logged in Bad Records Different from the Original Input Data with Escape Characters?
- Why INSERT INTO/LOAD DATA Task Distribution Is Incorrect and the Opened Tasks Are Less Than the Available Executors when the Number of Initial Executors Is Zero?
- Why Does CarbonData Require Additional Executors Even Though the Parallelism Is Greater Than the Number of Blocks to Be Processed?
- Why Do I Fail to Create a Hive Table?
- How Do I Logically Split Data Across Different Namespaces?
- Why the UPDATE Command Cannot Be Executed in Spark Shell?
- How Do I Configure Unsafe Memory in CarbonData?
- Why Exception Occurs in CarbonData When Disk Space Quota is Set for Storage Directory in HDFS?
- Why Does Data Query or Loading Fail and "org.apache.carbondata.core.memory.MemoryException: Not enough memory" Is Displayed?
- Why Do Files of a Carbon Table Exist in the Recycle Bin Even If the drop table Command Is Not Executed When Mis-deletion Prevention Is Enabled?
- How Do I Restore the Latest tablestatus File That Has Been Lost or Damaged When TableStatus Versioning Is Enabled?
Using ClickHouse
- Using ClickHouse from Scratch
- ClickHouse Permission Management
- ClickHouse Table Engine Overview
- Creating a ClickHouse Table
Common ClickHouse SQL Syntax
- CREATE DATABASE: Creating a Database
- CREATE TABLE: Creating a Table
- INSERT INTO: Inserting Data into a Table
- DELETE: Lightweight Deleting Table Data
- SELECT: Querying Table Data
- ALTER TABLE: Modifying a Table Schema
- ALTER TABLE: Modifying Table Data
- DESC: Querying a Table Structure
- DROP: Deleting a Table
- SHOW: Displaying Information About Databases and Tables
- UPSERT: Writing Data
- Migrating ClickHouse Data
- Adaptive MV Usage in ClickHouse
- Configuring Interconnection Between ClickHouse and HDFS
- Configuring Interconnection Between ClickHouse and Kafka
- Configuring the Connection Between ClickHouse and Open-Source ClickHouse
- Configuring Strong Data Consistency Between ClickHouse Replicas
- Configuring the Support for Transactions on ClickHouse
- Pre-Caching ClickHouse Metadata to the Memory
- Collecting Dumping Logs of the ClickHouse System Tables
- ClickHouse Log Overview
ClickHouse FAQ
- How Do I Do If the Disk Status Displayed in the System.disks Table Is fault or abnormal?
- How Do I Quickly Restore the Status of a Logical Cluster in a Scale-in Fault Scenario?
- What Should I Do If a File System Error Is Reported and Core Dump Occurs During Process Startup and part Loading After a ClickHouserServer Instance Node Is Power Cycled?
- What Should I Do If an Exception Occurred in the replication_queue and Data Is Inconsistent Between Replicas After a ClickHouse Cluster Is Powered On from a Sudden Poweroff?
- Using DBService
Using Doris
- Installing a MySQL Client
- Using Doris from Scratch
- Multi-Tenancy
- Native Web UI
- Doris Data Model
- Doris Cold and Hot Data Separation
- Data Operations
- Typical SQL Syntax
- Backing Up and Restoring Data
- Hive Data Analysis
- Ecosystem
Doris FAQs
- What Should I Do If "Failed to find enough host with storage medium and tag" Occasionally Occurs During Table Creation Due to the Configuration of the SSD and HDD Data Directories?
- What Should I Do If a Query Is Performed on the BE Node Where Some Copies Are Lost or Damaged and an Error Is Reported?
- What Should I Do If RPC Timeout Error Is Reported When Stream Load Is Used?
- How Do I Restore the FE Service from a Fault?
- What Do I Do If the Error Message "plugin not enabled" Is Displayed When the MySQL Client Is Used to Connect to the Doris Database?
- How Do I Handle the FE Startup Failure?
- How Do I Handle the Startup Failure Due to Incorrect IP Address Matching for the BE Instance?
- What Should I Do If Error Message "Read timed out" Is Displayed When the MySQL Client Connects to the Doris?
- What Should I Do If an Error Is Reported When the BE Runs a Data Import or Query Task?
- What Should I Do If a Timeout Error Is Reported When Broker Load Imports Data?
- What Should I Do If the Data Volume of a Broker Load Import Task Exceeds the Threshold?
- What Should I Do If an Error Message Is Displayed When Broker Load Is Used to Import Data?
- How Do I Rectify the Serialization Exception Reported When Data Is Imported to Spark Load?
- What Should I Do If An App ID Cannot Be Obtained When Spark Load Imports Data?
- Doris Logs
Using Flink
- Using Flink from Scratch
- Viewing Flink Job Information
- Configuring Flink Service Parameters
- Configuring Flink Security Features
Configuring and Developing a Flink Visualization Job
- Introduction to Flink Web UI
- Flink Web UI Permission Management
- Creating a FlinkServer Role
- Accessing the Flink Web UI
- Creating an Application
- Creating a Cluster Connection
- Creating a Data Connection
- Creating a Stream Table
- Creating a Job
- Restoring a Job
- Configuring Dependency Management
- Configuring and Managing UDFs
- Configuring the FlinkServer UDF Sandbox
- Reusing Flink UDFs
- Importing and Exporting Jobs
- Verifying Flink's Job Inspection
Configuring Interconnection Between FlinkServer and Other Components
- Interconnecting FlinkServer with ClickHouse
- Interconnecting FlinkServer with GaussDB(DWS)
- Interconnecting FlinkServer with JDBC
- Interconnecting FlinkServer with HBase
- Interconnecting FlinkServer with HDFS
- Interconnecting FlinkServer with Hive
- Interconnecting FlinkServer with Hudi
- Interconnecting FlinkServer with Kafka
- Interconnecting FlinkServer with Redis
- Flink Log Overview
- Flink Performance Tuning
- Common Flink Shell Commands
- Reference
- Flink Restart Policy
Enhancements to Flink SQL
- Using the DISTRIBUTEBY Feature
- Supporting Late Data in Flink SQL Window Functions
- Configuring Table-Level Time To Live (TTL) for Joining Multiple Flink Streams
- Verifying SQL Statements with the FlinkSQL Client
- Submitting a Job on the FlinkSQL Client
- Joining Big and Small Tables
- Deduplicating Data When Joining Big and Small Tables
- Setting Source Parallelism
- Limiting Read Rate for Flink SQL Kafka and Upsert-Kafka Connector
- Consuming Data in drs-json Format with FlinkSQL Kafka Connector
- Using ignoreDelete in JDBC Data Writes
- Join-To-Live
- Flink on Hudi Development Specifications
Using Flume
- Using Flume from Scratch
- Overview
- Installing the Flume Client
- Viewing Flume Client Logs
- Stopping or Uninstalling the Flume Client
- Using the Encryption Tool of the Flume Client
- Flume Service Configuration Guide
- Flume Configuration Parameter Description
- Using Environment Variables in the properties.properties File
Non-Encrypted Transmission
- Configuring Non-encrypted Transmission
- Typical Scenario: Collecting Local Static Logs and Uploading Them to Kafka
- Typical Scenario: Collecting Local Static Logs and Uploading Them to HDFS
- Typical Scenario: Collecting Local Dynamic Logs and Uploading Them to HDFS
- Typical Scenario: Collecting Logs from Kafka and Uploading Them to HDFS
- Typical Scenario: Collecting Logs from Kafka and Uploading Them to HDFS Through the Flume Client
- Typical Scenario: Collecting Local Static Logs and Uploading Them to HBase
- Encrypted Transmission
- Viewing Flume Client Monitoring Information
- Connecting Flume to Kafka in Security Mode
- Connecting Flume with Hive in Security Mode
- Configuring the Flume Service Model
- Introduction to Flume Logs
- Flume Client Cgroup Usage Guide
- Secondary Development Guide for Flume Third-Party Plug-ins
- Common Issues About Flume
Using HBase
- Using HBase from Scratch
- Using an HBase Client
- Creating HBase Roles
- Configuring HBase Replication
- Configuring HBase Parameters
- Enabling Cross-Cluster Copy
- Using the ReplicationSyncUp Tool
- GeoMesa Command Line
- Using HIndex
- Using Global Secondary Indexes
- Configuring HBase DR
- Configuring HBase Data Compression and Encoding
- Performing an HBase DR Service Switchover
- Performing an HBase DR Active/Standby Cluster Switchover
- Community BulkLoad Tool
- Configuring Secure HBase Replication
- Configuring Region In Transition Recovery Chore Service
- Enabling the HBase Compaction
- Using a Secondary Index
- Hot-Cold Data Separation
- Configuring HBase Table-Level Overload Control
- HBase Log Overview
- HBase Performance Tuning
Common Issues About HBase
- Why Does a Client Keep Failing to Connect to a Server for a Long Time?
- Operation Failures Occur in Stopping BulkLoad On the Client
- Why May a Table Creation Exception Occur When HBase Deletes or Creates the Same Table Consecutively?
- Why Other Services Become Unstable If HBase Sets up A Large Number of Connections over the Network Port?
- Why Does the HBase BulkLoad Task (One Table Has 26 TB Data) Consisting of 210,000 Map Tasks and 10,000 Reduce Tasks Fail?
- How Do I Restore a Region in the RIT State for a Long Time?
- Why Does HMaster Exits Due to Timeout When Waiting for the Namespace Table to Go Online?
- Why Does SocketTimeoutException Occur When a Client Queries HBase?
- Why Modified and Deleted Data Can Still Be Queried by Using the Scan Command?
- Why "java.lang.UnsatisfiedLinkError: Permission denied" exception thrown while starting HBase shell?
- When does the RegionServers listed under "Dead Region Servers" on HMaster WebUI gets cleared?
- Why Are Different Query Results Returned After I Use Same Query Criteria to Query Data Successfully Imported by HBase bulkload?
- What Should I Do If I Fail to Create Tables Due to the FAILED_OPEN State of Regions?
- How Do I Delete Residual Table Names in the /hbase/table-lock Directory of ZooKeeper?
- Why Does HBase Become Faulty When I Set a Quota for the Directory Used by HBase in HDFS?
- Why HMaster Times Out While Waiting for Namespace Table to be Assigned After Rebuilding Meta Using OfflineMetaRepair Tool and Startups Failed
- Why Messages Containing FileNotFoundException and no lease Are Frequently Displayed in the HMaster Logs During the WAL Splitting Process?
- Insufficient Rights When a Tenant Accesses Phoenix
- What Can I Do When HBase Fails to Recover a Task and a Message Is Displayed Stating "Rollback recovery failed"?
- How Do I Fix Region Overlapping?
- Why Does RegionServer Fail to Be Started When GC Parameters Xms and Xmx of HBase RegionServer Are Set to 31 GB?
- Why Does the LoadIncrementalHFiles Tool Fail to Be Executed and "Permission denied" Is Displayed When Nodes in a Cluster Are Used to Import Data in Batches?
- Why Is the Error Message "import argparse" Displayed When the Phoenix sqlline Script Is Used?
- How Do I Deal with the Restrictions of the Phoenix BulkLoad Tool?
- Why a Message Is Displayed Indicating that the Permission is Insufficient When CTBase Connects to the Ranger Plug-ins?
- How Do I View Regions in the CLOSED State in an ENABLED Table?
- How Can I Quickly Recover the Service When HBase Files Are Damaged Due to a Cluster Power-Off?
- How Do I Disable HDFS Hedged Read on HBase?
- Using Guardian
Using HetuEngine
- Using HetuEngine from Scratch
- HetuEngine Permission Management
- Creating a HetuEngine User
- Creating a HetuEngine Compute Instance
Managing HetuEngine Compute Instances
- Configuring Resource Groups
- Configuring the Number of Worker Nodes
- Configuring a HetuEngine Maintenance Instance
- Configuring the Nodes on Which Coordinator Is Running
- Importing and Exporting Compute Instance Configurations
- Viewing the Instance Monitoring Page
- Viewing Coordinator and Worker Logs
- Configuring Query Fault Tolerance Execution
- Using the HetuEngine Client
- Using the HetuEngine Cross-Source Function
- Using the HetuEngine Cross-Domain Function
Configuring Data Sources
- Before You Start
- Configuring a Hive Data Source
- Configuring a Hudi Data Source
- Configuring a ClickHouse Data Source
- Configuring an Elasticsearch Data Source
- Configuring a GaussDB Data Source
- Configuring an HBase Data Source
- Configuring a HetuEngine Data Source
- Configuring an IoTDB Data Source
- Configuring a MySQL Data Source
- Managing Configured Data Sources
Using HetuEngine Materialized Views
- Overview of Materialized Views
- SQL Statement Example of Materialized Views
- Configuring Rewriting of Materialized Views
- Configuring Recommendation of Materialized Views
- Configuring Caching of Materialized Views
- Configuring the Validity Period and Data Update of Materialized Views
- Configuring Intelligent Materialized Views
- Viewing Automatic Tasks of Materialized Views
- Using HetuEngine SQL Diagnosis
- Using a Third-Party Visualization Tool to Access HetuEngine
- Developing and Applying Functions and UDFs
- HetuEngine Logs
- HetuEngine Performance Tuning
HetuEngine FAQ
- How Do I Perform Operations After the Domain Name Is Changed?
- What Do I Do If Starting a Cluster on the Client Times Out?
- How Do I Handle Data Source Loss?
- How Do I Handle HetuEngine Alarms?
- How Do I Do If an Error Is Reported Indicating that Python Does Not Exist When a Compute Instance Fails to Start?
- How Do I Do If a Compute Instance Fails 30 Seconds After It Is Started?
- What Do I Do If Data Fails to Be Written to a Table Because the Namespace of the Table Is Different from That of the /tmp Directory in the Federation Scenario?
- How Do I Configure HetuEngine SQL Inspection?
Using HDFS
- Using Hadoop from Scratch
- Configuring Memory Management
- Creating an HDFS Role
- Using the HDFS Client
- Running the DistCp Command
- Overview of HDFS File System Directories
- Changing the DataNode Storage Directory
- Configuring HDFS Directory Permission
- Configuring NFS
- Planning HDFS Capacity
- Configuring ulimit for HBase and HDFS
- Configuring HDFS DataNode Data Balancing
- Configuring Replica Replacement Policy for Heterogeneous Capacity Among DataNodes
- Configuring the Number of Files in a Single HDFS Directory
- Configuring the Recycle Bin Mechanism
- Setting Permissions on Files and Directories
- Setting the Maximum Lifetime and Renewal Interval of a Token
- Configuring the Damaged Disk Volume
- Configuring Encrypted Channels
- Reducing the Probability of Abnormal Client Application Operation When the Network Is Not Stable
- Configuring the NameNode Blacklist
- Optimizing HDFS NameNode RPC QoS
- Optimizing HDFS DataNode RPC QoS
- Configuring Reserved Percentage of Disk Usage on DataNodes
- Configuring HDFS NodeLabel
- Configuring HDFS Mover
- Using HDFS AZ Mover
- Configuring HDFS DiskBalancer
- Configuring the Observer NameNode to Process Read Requests
- Performing Concurrent Operations on HDFS Files
- Introduction to HDFS Logs
- HDFS Performance Tuning
FAQ
- NameNode Startup Is Slow
- DataNode Is Normal but Cannot Report Data Blocks
- HDFS WebUI Cannot Properly Update Information About Damaged Data
- Why Do DistCp Commands Fail to Run in a Security Cluster and Exceptions Are Thrown?
- How Do I Rectify the Faulty If DataNode Fails to Be Started When the Number of Disks Defined in dfs.datanode.data.dir Equals the Value of dfs.datanode.failed.volumes.tolerated?
- Failed to Calculate the Capacity of a DataNode when Multiple data.dir Directories Are Configured in a Disk Partition
- Standby NameNode Fails to Be Restarted When the System Is Powered off During Metadata (Namespace) Storage
- What Should I Do If Data in the Cache Is Lost When the System Is Powered Off During Small File Storage?
- Why Does Array Border-crossing Occur During FileInputFormat Split?
- Why Is the Storage Type of File Copies DISK When the Tiered Storage Policy Is LAZY_PERSIST?
- How Do I Handle the Problem that HDFS Client Is Irresponsive When the NameNode Is Overloaded for a Long Time?
- Can I Delete or Modify the Data Storage Directory in DataNode?
- Blocks Miss on the NameNode UI After the Successful Rollback
- Why Is "java.net.SocketException: No buffer space available" Reported When Data Is Written to HDFS
- Why are There Two Standby NameNodes After the active NameNode Is Restarted?
- When Does a Balance Process in HDFS, Shut Down and Fail to be Executed Again?
- "This page can't be displayed" Is Displayed When Internet Explorer Fails to Access the Native HDFS UI
- NameNode Fails to Be Restarted Due to EditLog Discontinuity
Using Hive
- Using Hive from Scratch
- Configuring Hive Parameters
- Hive SQL
- Permission Management
- Using a Hive Client
- Using HDFS Colocation to Store Hive Tables
- Using the Hive Column Encryption Function
- Customizing Row Separators
- Configuring Hive on HBase in Across Clusters with Mutual Trust Enabled
- Deleting Single-Row Records from Hive on HBase
- Configuring HTTPS/HTTP-based REST APIs
- Enabling or Disabling the Transform Function
- Access Control of a Dynamic Table View on Hive
- Specifying Whether the ADMIN Permissions Is Required for Creating Temporary Functions
- Using Hive to Read Data in a Relational Database
- Supporting Traditional Relational Database Syntax in Hive
- Creating User-Defined Hive Functions
- Enhancing beeline Reliability
- Viewing Table Structures Using the show create Statement as Users with the select Permission
- Writing a Directory into Hive with the Old Data Removed to the Recycle Bin
- Inserting Data to a Directory That Does Not Exist
- Creating Databases and Creating Tables in the Default Database Only as the Hive Administrator
- Disabling of Specifying the location Keyword When Creating an Internal Hive Table
- Enabling the Function of Creating a Foreign Table in a Directory That Can Only Be Read
- Authorizing Over 32 Roles in Hive
- Restricting the Maximum Number of Maps for Hive Tasks
- HiveServer Lease Isolation
- Hive Supports Isolation of Metastore instances Based on Components
- Switching the Hive Execution Engine to Tez
- Hive Supporting Reading Hudi Tables
- Hive Supporting Cold and Hot Storage of Partitioned Metadata
- Hive Supporting ZSTD Compression Formats
- Locating Abnormal Hive Files
- Using the ZSTD_JNI Compression Algorithm to Compress Hive ORC Tables
- Load Balancing for Hive MetaStore Client Connection
- Data Import and Export in Hive
- Hive Log Overview
- Hive Performance Tuning
Common Issues About Hive
- How Do I Delete UDFs on Multiple HiveServers at the Same Time?
- Why Cannot the DROP operation Be Performed on a Backed-up Hive Table?
- How to Perform Operations on Local Files with Hive User-Defined Functions
- How Do I Forcibly Stop MapReduce Jobs Executed by Hive?
- How Do I Monitor the Hive Table Size?
- How Do I Prevent Key Directories from Data Loss Caused by Misoperations of the insert overwrite Statement?
- Why Is Hive on Spark Task Freezing When HBase Is Not Installed?
- Error Reported When the WHERE Condition Is Used to Query Tables with Excessive Partitions in FusionInsight Hive
- Why Cannot I Connect to HiveServer When I Use IBM JDK to Access the Beeline Client?
- Description of Hive Table Location (Either Be an OBS or HDFS Path)
- Why Cannot Data Be Queried After the MapReduce Engine Is Switched After the Tez Engine Is Used to Execute Union-related Statements?
- Why Does Hive Not Support Concurrent Data Writing to the Same Table or Partition?
- Why Does Hive Not Support Vectorized Query?
- Why Does Metadata Still Exist When the HDFS Data Directory of the Hive Table Is Deleted by Mistake?
- How Do I Disable the Logging Function of Hive?
- Why Hive Tables in the OBS Directory Fail to Be Deleted?
- Hive Configuration Problems
- How Do I Handle the Error Reported When Setting hive.exec.stagingdir on the Hive Client?
Using Hudi
- Getting Started
- Common Hudi Parameters
- Basic Operations
- Hudi SQL Syntax Reference
- Setting Default Values for Hudi Columns
- Hudi Performance Tuning
Common Issues About Hudi
Data Write
- Parquet/Avro schema Is Reported When Updated Data Is Written
- UnsupportedOperationException Is Reported When Updated Data Is Written
- SchemaCompatabilityException Is Reported When Updated Data Is Written
- What Should I Do If Hudi Consumes Much Space in a Temporary Folder During Upsert?
- Hudi Fails to Write Decimal Data with Lower Precision
- Data in ro and rt Tables Cannot Be Synchronized to a MOR Table Recreated After Being Deleted Using Spark SQL
- Data Collection
- Hive Synchronization
Data Write
- Using IoTDB
- Using JobGateway
Using Kafka
- Using Kafka from Scratch
- Managing Kafka Topics
- Querying Kafka Topics
- Managing Kafka User Permissions
- Managing Messages in Kafka Topics
- Synchronizing Binlog-based MySQL Data to the MRS Cluster
- Creating a Kafka Role
- Kafka Common Parameters
- Kafka Specifications
- Using the Kafka Client
- Configuring Kafka HA and High Reliability Parameters
- Changing the Broker Storage Directory
- Checking the Consumption Status of Consumer Group
- Kafka Balancing Tool Instructions
- Kafka Token Authentication Mechanism Tool Usage
- Kafka Encryption and Decryption
- Using Kafka UI
- Kafka Logs
- Kafka Feature Description
- Migrating Data Between Kafka Nodes
- Common Issues About Kafka
Using Loader
- Common Loader Parameters
- Creating a Loader Role
- Managing Loader Links
- Preparing a Driver for MySQL Database Link
Importing Data
- Overview
- Importing Data Using Loader
- Typical Scenario: Importing Data from an SFTP Server to HDFS or OBS
- Typical Scenario: Importing Data from an SFTP Server to HBase
- Typical Scenario: Importing Data from an SFTP Server to Hive
- Typical Scenario: Importing Data from an FTP Server to HBase
- Typical Scenario: Importing Data from a Relational Database to HDFS or OBS
- Typical Scenario: Importing Data from a Relational Database to HBase
- Typical Scenario: Importing Data from a Relational Database to Hive
- Typical Scenario: Importing Data from HDFS or OBS to HBase
- Typical Scenario: Importing Data from a Relational Database to ClickHouse
Exporting Data
- Overview
- Using Loader to Export Data
- Typical Scenario: Exporting Data from HDFS or OBS to an SFTP Server
- Typical Scenario: Exporting Data from HBase to an SFTP Server
- Typical Scenario: Exporting Data from Hive to an SFTP Server
- Typical Scenario: Exporting Data from HDFS or OBS to a Relational Database
- Typical Scenario: Exporting Data from HDFS to MOTService
- Typical Scenario: Exporting Data from HBase to a Relational Database
- Typical Scenario: Exporting Data from Hive to a Relational Database
- Typical Scenario: Importing Data from HBase to HDFS or OBS
- Typical Scenario: Exporting Data from HDFS to ClickHouse
- Managing Jobs
- Operator Help
Client Tools
- Running a Loader Job Through CLI
- loader-tool Usage Guide
- loader-tool Usage Example
- schedule-tool Usage Guide
- schedule-tool Usage Example
- Using loader-backup to Back Up Job Data
- Open Source sqoop-shell Tool Usage Guide
- Example for Using the Open-Source sqoop-shell Tool (SFTP-HDFS)
- Example for Using the Open-Source sqoop-shell Tool (Oracle-HBase)
- Loader Log Overview
- Common Issues About Loader
Using MapReduce
- Configuring the Log Archiving and Clearing Mechanism
- Reducing Client Application Failure Rate
- Transmitting MapReduce Tasks from Windows to Linux
- Configuring the Distributed Cache
- Configuring the MapReduce Shuffle Address
- Configuring the Cluster Administrator List
- Introduction to MapReduce Logs
- MapReduce Performance Tuning
Common Issues About MapReduce
- How Do I Handle the Problem that MapReduce Task Has No Progress for a Long Time?
- Why the Client Hangs During Job Running?
- Why Cannot HDFS_DELEGATION_TOKEN Be Found in the Cache?
- How Do I Set the Task Priority When Submitting a MapReduce Task?
- Why Physical Memory Overflow Occurs If a MapReduce Task Fails?
- After the Address of MapReduce JobHistoryServer Is Changed, Why the Wrong Page is Displayed When I Click the Tracking URL on the ResourceManager WebUI?
- MapReduce Job Failed in Multiple NameService Environment
- Why a Fault MapReduce Node Is Not Blacklisted?
- Using MemArtsCC
Using Oozie
- Using Oozie from Scratch
- Using the Oozie Client
- Checking ShareLib
- Using Oozie Client to Submit an Oozie Job
- Oozie Log Overview
Common Issues About Oozie
- What Should I Do If Oozie Scheduled Tasks Are Not Executed on Time
- Why Update of the share lib Directory of Oozie on HDFS Does Not Take Effect?
- Common Oozie Troubleshooting Methods
- What Should I Do If the User Who Submits Jobs on the Oozie Client in a Normal Cluster Is Inconsistent with the User Displayed on the Yarn Web UI?
Using Ranger
- Logging In to the Ranger Web UI
- Enabling Ranger Authentication
- Configuring Component Permission Policies
- Viewing Ranger Audit Information
- Configuring a Security Zone
- Changing the Ranger Data Source to LDAP for a Normal Cluster
- Viewing Ranger Permission Information
- Adding a Ranger Access Permission Policy for CDL
- Adding a Ranger Access Permission Policy for HDFS
- Adding a Ranger Access Permission Policy for HBase
- Adding a Ranger Access Permission Policy for Hive
- Adding a Ranger Access Permission Policy for Yarn
- Adding a Ranger Access Permission Policy for Spark
- Adding a Ranger Access Permission Policy for Kafka
- Adding a Ranger Access Permission Policy for HetuEngine
- Adding a Ranger Access Permission Policy for Storm
- Adding a Ranger Access Permission Policy for Elasticsearch
- Adding a Ranger Access Permission Policy for OBS
- Hive Tables Supporting Cascading Authorization
- Configuring Multi-Instance for RangerKMS
- Using the RangerKMS Native UI to Manage Permissions and Keys
- Ranger Log Overview
Common Issues About Ranger
- Why Ranger Startup Fails During the Cluster Installation?
- How Do I Determine Whether the Ranger Authentication Is Used for a Service?
- Why Cannot a New User Log In to Ranger After Changing the Password?
- When an HBase Policy Is Added or Modified on Ranger, Wildcard Characters Cannot Be Used to Search for Existing HBase Tables
- How Do I Rectify the Problem that RangerKMS Authentication Fails and the KMS Tab Is Not Displayed on the Ranger Management Page?
Using Spark
Basic Operation
- Getting Started
- Configuring Parameters Rapidly
- Common Parameters
- Spark on HBase Overview and Basic Applications
- Spark on HBase V2 Overview and Basic Applications
- SparkSQL Permission Management(Security Mode)
Scenario-Specific Configuration
- Configuring Multi-active Instance Mode
- Configuring the Multi-Tenant Mode
- Configuring the Switchover Between the Multi-active Instance Mode and the Multi-tenant Mode
- Configuring the Size of the Event Queue
- Configuring Executor Off-Heap Memory
- Enhancing Stability in a Limited Memory Condition
- Viewing Aggregated Container Logs on the Web UI
- Configuring Environment Variables in Yarn-Client and Yarn-Cluster Modes
- Configuring the Default Number of Data Blocks Divided by SparkSQL
- Configuring the Compression Format of a Parquet Table
- Configuring the Number of Lost Executors Displayed in WebUI
- Setting the Log Level Dynamically
- Configuring Whether Spark Obtains HBase Tokens
- Configuring LIFO for Kafka
- Configuring Reliability for Connected Kafka
- Configuring Streaming Reading of Driver Execution Results
- Filtering Partitions without Paths in Partitioned Tables
- Configuring Spark Web UI ACLs
- Configuring Vector-based ORC Data Reading
- Broaden Support for Hive Partition Pruning Predicate Pushdown
- Hive Dynamic Partition Overwriting Syntax
- Configuring the Column Statistics Histogram for Higher CBO Accuracy
- Configuring Local Disk Cache for JobHistory
- Configuring Spark SQL to Enable the Adaptive Execution Feature
- Configuring Event Log Rollover
- Configuring the Spark Native Engine
- Configuring Automatic Merging of Small Files
- Adapting to the Third-party JDK When Ranger Is Used
- Spark Log Overview
- Obtaining Container Logs of a Running Spark Application
- Small File Combination Tools
- Using CarbonData for First Query
Spark Performance Tuning
- Spark Core Tuning
Spark SQL and DataFrame Tuning
- Optimizing the Spark SQL Join Operation
- Improving Spark SQL Calculation Performance Under Data Skew
- Optimizing Spark SQL Performance in the Small File Scenario
- Optimizing the INSERT...SELECT Operation
- Multiple JDBC Clients Concurrently Connecting to JDBCServer
- Optimizing Memory when Data Is Inserted into Dynamic Partitioned Tables
- Optimizing Small Files
- Optimizing the Aggregate Algorithms
- Optimizing Datasource Tables
- Merging CBO
- Optimizing SQL Query of Data of Multiple Sources
- SQL Optimization for Multi-level Nesting and Hybrid Join
- Spark Streaming Tuning
- Spark on OBS Tuning
Spark FAQ
Spark Core
- How Do I View Aggregated Spark Application Logs?
- Why Cannot Exit the Driver Process?
- Why Does FetchFailedException Occur When the Network Connection Is Timed out
- How to Configure Event Queue Size If Event Queue Overflows?
- What Can I Do If the getApplicationReport Exception Is Recorded in Logs During Spark Application Execution and the Application Does Not Exit for a Long Time?
- What Can I Do If "Connection to ip:port has been quiet for xxx ms while there are outstanding requests" Is Reported When Spark Executes an Application and the Application Ends?
- Why Do Executors Fail to be Removed After the NodeManeger Is Shut Down?
- What Can I Do If the Message "Password cannot be null if SASL is enabled" Is Displayed?
- What Should I Do If the Message "Failed to CREATE_FILE" Is Displayed in the Restarted Tasks When Data Is Inserted Into the Dynamic Partition Table?
- Why Tasks Fail When Hash Shuffle Is Used?
- What Can I Do If the Error Message "DNS query failed" Is Displayed When I Access the Aggregated Logs Page of Spark Applications?
- What Can I Do If Shuffle Fetch Fails Due to the "Timeout Waiting for Task" Exception?
- Why Does the Stage Retry due to the Crash of the Executor?
- Why Do the Executors Fail to Register Shuffle Services During the Shuffle of a Large Amount of Data?
- NodeManager OOM Occurs During Spark Application Execution
- Why Does the Realm Information Fail to Be Obtained When SparkBench is Run on HiBench for the Cluster in Security Mode?
- What Do I have to Note When Using Spark SQL ROLLUP and CUBE?
- Why Spark SQL Is Displayed as a Temporary Table in Different Databases?
- How to Assign a Parameter Value in a Spark Command?
- What Directory Permissions Do I Need to Create a Table Using SparkSQL?
- Why Do I Fail to Delete the UDF Using Another Service?
- Why Cannot I Query Newly Inserted Data in a Parquet Hive Table Using SparkSQL?
- How to Use Cache Table?
- Why Are Some Partitions Empty During Repartition?
- Why Does 16 Terabytes of Text Data Fails to Be Converted into 4 Terabytes of Parquet Data?
- How Do I Rectify the Exception Occurred When I Perform an Operation on the Table Named table?
- Why Is a Task Suspended When the ANALYZE TABLE Statement Is Executed and Resources Are Insufficient?
- If I Access a parquet Table on Which I Do not Have Permission, Why a Job Is Run Before "Missing Privileges" Is Displayed?
- Why Do I Fail to Modify MetaData by Running the Hive Command?
- Why Is "RejectedExecutionException" Displayed When I Exit Spark SQL?
- How Do I Do If I Incidentally Kill the JDBCServer Process During Health Check?
- Why No Result Is found When 2016-6-30 Is Set in the Date Field as the Filter Condition?
- Why Does the "--hivevar" Option I Specified in the Command for Starting spark-beeline Fail to Take Effect?
- Why Is Memory Insufficient if 10 Terabytes of TPCDS Test Suites Are Consecutively Run in Beeline/JDBCServer Mode?
- Why Are Some Functions Not Available when ThriftJDBCServers Are Connected?
- Why Does Spark-beeline Fail to Run and Error Message "Failed to create ThriftService instance" Is Displayed?
- Why Cannot I Query Newly Inserted Data in an ORC Hive Table Using Spark SQL?
Spark Streaming
- What Can I Do If Spark Streaming Tasks Are Blocked?
- What Should I Pay Attention to When Optimizing Spark Streaming Task Parameters?
- Why Does the Spark Streaming Application Fail to Be Submitted After the Token Validity Period Expires?
- Why Does the Spark Streaming Application Fail to Be Started from the Checkpoint When the Input Stream Has No Output Logic?
- Why Is the Input Size Corresponding to Batch Time on the Web UI Set to 0 Records When Kafka Is Restarted During Spark Streaming Running?
- Spark Ranger FAQ
- Why Is the RESTful Interface Information Obtained by Accessing Spark Incorrect?
- Why Cannot I Switch from the Yarn Web UI to the Spark Web UI?
- What Can I Do If an Error Occurs when I Access the Application Page Because the Application Cached by HistoryServer Is Recycled?
- Why Is not an Application Displayed When I Run the Application with the Empty Part File?
- Why Does Spark Fail to Export a Table with Duplicate Field Names?
- Why JRE fatal error after running Spark application multiple times?
- Why Is "This page can't be displayed" Displayed or an Error Reported When I Use Internet Explorer to Access the Native Web UI of Spark?
- How Does Spark Access External Cluster Components?
- Why Does the Foreign Table Query Fail When Multiple Foreign Tables Are Created in the Same Directory?
- Why Is an Error Reported When I Access the Native Page of an Application in Spark JobHistory?
- Why Do I Fail to Create a Table in the Specified Location on OBS After Logging to spark-beeline?
- Spark Shuffle Exception Handling
- Why Cannot Common Users Log In to the Spark Client When There Are Multiple Service Scenarios in Spark?
- Why Does the Cluster Port Fail to Connect When a Client Outside the Cluster Is Installed or Used?
- How Do I Handle the Exception Occurred When I Query Datasource Avro Formats?
- What Should I Do If Statistics of Hudi or Hive Tables Created Using Spark SQLs Are Empty Before Data Is Inserted?
- Failed to Query Table Statistics by Partition Using Non-Standard Time Format When the Partition Column in the Table Creation Statement is timestamp
- How Do I Use Special Characters with TIMESTAMP and DATE?
- What Should I Do If Recycle Bin Version I Set on the Spark Client Does Not Take Effect?
- How Do I Change the Log Level to INFO When Using Spark yarn-client?
Spark Core
Basic Operation
- Using Tez
Using YARN
- Common YARN Parameters
- Creating Yarn Roles
- Using the YARN Client
- Configuring Resources for a NodeManager Role Instance
- Changing NodeManager Storage Directories
- Configuring Strict Permission Control for Yarn
- Configuring Container Log Aggregation
- Using CGroups with YARN
- Configuring the Number of ApplicationMaster Retries
- Configure the ApplicationMaster to Automatically Adjust the Allocated Memory
- Configuring the Access Channel Protocol
- Configuring Memory Usage Detection
- Configuring the Additional Scheduler WebUI
- Configuring Yarn Restart
- Configuring ApplicationMaster Work Preserving
- Configuring the Localized Log Levels
- Configuring Users That Run Tasks
- Yarn Log Overview
- Yarn Performance Tuning
Common Issues About Yarn
- Why Mounted Directory for Container is Not Cleared After the Completion of the Job While Using CGroups?
- Why the Job Fails with HDFS_DELEGATION_TOKEN Expired Exception?
- Why Are Local Logs Not Deleted After YARN Is Restarted?
- Why the Task Does Not Fail Even Though AppAttempts Restarts for More Than Two Times?
- Application Moved Back to the Original Queue After the ResourceManager Is Restarted?
- Why Does Yarn Not Release the Blacklist Even All Nodes Are Added to the Blacklist?
- Why Does the Switchover of ResourceManager Occur Continuously?
- Why Does a New Application Fail If a NodeManager Has Been in Unhealthy Status for 10 Minutes?
- Why Does an Error Occur When I Query the ApplicationID of a Completed or Non-existing Application Using the RESTful APIs?
- Why May A Single NodeManager Fault Cause MapReduce Task Failures in the Superior Scheduling Mode?
- Why Are Applications Suspended After They Are Moved From Lost_and_Found Queue to Another Queue?
- How Do I Limit the Size of Application Diagnostic Messages Stored in the ZKstore?
- Why Does a MapReduce Job Fail to Run When a Non-ViewFS File System Is Configured as ViewFS?
- Why Do Reduce Tasks Fail to Run in Some OSs After the Native Task Feature is Enabled?
Using ZooKeeper
- Using ZooKeeper from Scratch
- Common ZooKeeper Parameters
- Using a ZooKeeper Client
- Configuring the ZooKeeper Permissions
- ZooKeeper Log Overview
Common Issues About ZooKeeper
- Why Do ZooKeeper Servers Fail to Start After Many znodes Are Created?
- Why Does the ZooKeeper Server Display the java.io.IOException: Len Error Log?
- Why Four Letter Commands Don't Work With Linux netcat Command When Secure Netty Configurations Are Enabled at Zookeeper Server?
- How Do I Check Which ZooKeeper Instance Is a Leader?
- Why Cannot the Client Connect to ZooKeeper using the IBM JDK?
- What Should I Do When the ZooKeeper Client Fails to Refresh a TGT?
- Why Is Message "Node does not exist" Displayed when A Large Number of Znodes Are Deleted Using the deleteallCommand
- Appendix
Using CarbonData
API Reference (Ankara Region)
- Before You Start
- API Overview
- Selecting an API Type
- Calling APIs
- Application Cases
- API V2
- API V1.1
- Out-of-Date APIs
- Appendix
Help Center/
MapReduce Service/
User Guide (Kuala Lumpur Region)/
FusionInsight Manager Operation Guide (Applicable to 3.x)/
Audit/
Overview
Overview
The Audit page displays the user operations on Manager. On this page, administrators can view historical user operations on Manager. For details about the audit information, see Audit Logs.
Overview
Log in to FusionInsight Manager and choose Audit. Figure 1 shows the audit information, including the operation type, risk level, start time, end time, user, host name, service, instance, and operation result.
- You can select audit logs at the Major, Minor, or Notice level from the All risk levels drop-down list.
- In Advanced Search, you can set filter criteria to query audit logs.
- You can query audit logs by user management, cluster, service, and health in the Operation Type column.
- In the Service column, you can select a service to query corresponding audit logs.
You can select -- to search for audit logs using all other search criteria except services.
- You can query audit logs by operation result, such as, Successful, Failed, or Unknown, as shown in the following figure.
- You can click
to manually refresh the current page or click
to filter the columns displayed in the page.
- Click Export All to export all audit information at a time. The audit information can be exported in TXT or CSV format.
Parent topic: Audit
