Overview
Overview
Log in to FusionInsight Manager and choose Cluster > Name of the desired cluster > Services.
The service management page containing the function area and service list is displayed.
![Click to enlarge](https://support.huaweicloud.com/intl/en-us/my-kualalumpur-1-usermanual-mrs/en-us_image_0000001244011374.png)
Functional Area
In the function area of the service management page, you can select a view type and filter and search by services. You can use the advanced search function to select required services based on the running status.
Service List
The service list on the service management page contains all installed services in the cluster. If the tile view mode is selected, the services will be displayed in pane style. If you select the list view mode, the services will be displayed in a table.
![](https://support.huaweicloud.com/intl/en-us/my-kualalumpur-1-usermanual-mrs/public_sys-resources/note_3.0-en-us.png)
In this section, the Tile View is used by default.
The service list displays the running status, configuration status, role type, and number of instances of each service. On this page, you can perform some service maintenance tasks, such as starting, stopping, and restarting services.
Status |
Description |
Normal |
Indicates that the service is running properly. |
Faulty |
Indicates that the service cannot run properly. |
Subhealthy |
Indicates that some enhanced functions of the service are abnormal. |
Not started |
Indicates that the service is stopped. |
Unknown |
Indicates that the initial status of the service cannot be detected. |
Starting |
Indicates that the service is being started. |
Stopping |
Indicates that the service is being stopped. |
Failed to start |
Indicates that the service fails to be started. |
Failed to stop |
Indicates that the service fails to be stopped. |
- If the health status of a service is Faulty, an alarm is generated. Rectify the fault based on the alarm information.
- HBase, Hive, Spark, and Loader may be in the Subhealthy state.
- If YARN is installed but is abnormal, HBase is in the Subhealthy state. If the multi-instance function is enabled, all installed HBase service instances are in the Subhealthy state.
- If HBase is installed but is abnormal, Hive, Spark, and Loader are in the Subhealthy state.
- If any HBase instance is installed but is abnormal after the multi-instance function is enabled, Loader is in the Subhealthy state.
- If an HBase instance is installed but is abnormal after the multi-instance function is enabled, the Hive and Spark instances that map to the HBase instance are in the Subhealthy state. That is, if HBase 2 is installed but is abnormal, Hive 2 and Spark2 are in the Subhealthy state.
Status |
Description |
Synchronized |
Indicates that all service parameter settings have taken effect in the cluster. |
Expired |
Indicates that the latest configuration is not synchronized and does not take effect after service parameter settings are modified. The configuration needs to be synchronized and the related services need to be restarted. You can click |
Failed |
Indicates that a communication or read/write exception occurs during the parameter configuration synchronization. Use Synchronize Configuration to rectify the fault. |
Synchronizing |
Indicates that the service parameter configuration is being synchronized. |
Unknown |
You can click a service in the service list to perform simple maintenance and management operations on the service, as described in Table 3.
UI Portal |
Description |
Start Service |
Start a specified service in the cluster. |
Stop Service |
Stop a specified service in the cluster. |
Restart Service |
Restart a specified service in the cluster.
If a service is restarted, other services that depend on this service will be unavailable. Therefore, select Restart upper-layer services. Determine whether to perform this operation based on the displayed service list. Services are restarted one by one due to their dependency. Table 4 describes the restart duration of a single service. |
Service Rolling Restart |
Restart a specified service in the cluster without interrupting services. For details about the parameter settings, see Table 1. |
Synchronize Configuration |
After some services are synchronized, restart the services for the settings to take effect. |
Service Name |
Restart Duration |
Start Duration |
Remarks |
CDL |
2min |
CDLConnector: 1min CDLService: 1min |
ClickHouse |
4min |
ClickHouseServer: 2min ClickHouseBalancer: 2min |
HDFS |
10min+x |
NameNode: 4 min + x DataNode: 2 min JournalNode: 2 min Zkfc: 2 min |
X indicates the duration for loading NameNode metadata. About two minutes are required for each ten million files. For example, if there are 50 million files, x indicates 10 minutes. The start duration is affected by the duration for DataNode to report data blocks. |
Yarn |
5min+x |
ResourceManager: 3 min + x NodeManager: 2 min |
x indicates the time corresponding to the number of reserved tasks that need to be restored by ResourceManager. Each 10 thousand reserved tasks require one minute. |
MapReduce |
2min+x |
JobHistoryServer: 2 min + x |
x indicates the scanning duration of historical tasks. Each 100 thousand tasks take about 2.5 minutes. |
Zookeeper |
2min+x |
quorumpeer: 2 min + x |
x indicates the duration for loading Znodes. Each one million Znodes take about one minute. |
Hive |
3.5min |
HiveServer: 3 min MetaStore: 90s WebHcat: 1 min Hiveoverall service: 3 min |
Spark2x |
5min |
JobHistory2x: 5 min SparkResource2x: 5 min JDBCServer2x: 5 min |
Flink |
4min |
FlinkResource: 1 min FlinkServer: 3min |
Kafka |
2min+x |
Broker: 1 min + x |
X indicates the data recovery duration. It takes about two minutes to start a single instance with 20000 partitions. |
Storm |
6min |
Nimbus: 3 min UI: 1 min Supervisor: 1 min Logviewer: 1 min |
Flume |
3min |
Flume: 2 min MonitorServer: 1 min |
