Help Center>
MapReduce Service>
User Guide (Kuala Lumpur Region)>
FusionInsight Manager Operation Guide (Applicable to 3.x)>
Security Management>
Account Management>
Changing the Password for a Database User>
Changing the Password for the OMS Database Data Access User
Updated on 2022-08-12 GMT+08:00
Periodically change the password for the OMS data access user to ensure the system O&M security.
Impact on the System
The OMS service needs to be restarted for the password changing to take effect. The cluster is unavailable during the restart.
- Choose System > OMS > gaussDB > Change Password on FusionInsight Manager.
- Locate the row that contains user omm and click Change Password in the Operation to change the password for the OMS database user.
- In the displayed window, enter the password of the current login administrator user and click OK.
- Enter the old and new passwords as prompted.
The password complexity requirements are as follows:
- The password ranges from 8 to 32 characters.
- The password must contain at least three types of the following: lowercase letters, uppercase letters, digits, and special characters which can only be ~`!@#$%^&*()-+_=\|[{}];",<.>/?
- The password cannot be the same as the username or reverse username.
- The password cannot be the same as the last 20 historical passwords.
- Click OK. After the system displays Operation succeeded, click Finish.
- Locate the row that contains user omm and click Restart OMS Service in the Operation to restart the OMS database.
- In the dialog box that is displayed, click OK, and then restart the OMS service.
Parent topic: Changing the Password for a Database User
