Help Center/
      MapReduce Service/
        User Guide (ME-Abu Dhabi Region)/
        FusionInsight Manager Operation Guide (Applicable to 3.x)/
        Tenant Resources/
        Using the Capacity Scheduler in Multi-Tenant Scenarios/
        Managing Resources/
      Modifying a Resource Pool
        Updated on 2022-12-08 GMT+08:00
If hosts in the resource pool need to be adjusted based on service requirements, MRS cluster administrators can modify members in the existing resource pool on FusionInsight Manager.
 - Choose Tenant Resources > Resource Pool.
 - Locate the row that contains the specified resource pool in the resource pool list, and click Edit in the Operation column.
 - In Edit Resource Pool, modify Hosts.
- Adding a host: In the host list on the left, select the name of a specified host and click
 to add the selected host to the resource pool. - Deleting a host: In the host list on the right, select the name of a specified host and click
 to delete the selected host from the resource pool. The host list of a resource pool can be left blank.
 - Click OK to save the settings.
   Parent topic: Managing Resources
