Overview
Dashboard
Log in to FusionInsight Manager and choose Cluster > Name of the desired cluster > Dashboard to view the status of the current cluster.
On the Dashboard page, you can start, stop, rolling restart, synchronize configurations for, and perform basic management operations for the current cluster, as described in Table 1.
        UI Portal  |
        Description  |
        Start  |
        Start all services in the cluster.  |
        Stop  |
        Stop all services in the cluster.  |
        More > Restart  |
        Restart all services in the cluster.  |
        More > Rolling-restart Service  |
        Restart all services in the cluster without interrupting services. For details, see Performing a Rolling Restart of a Cluster.  |
        Synchronize parameter configurations for all services in the cluster.  |
        Restart all instances whose configurations have expired. For details, see Managing Expired Configurations.  |
        Perform health checks on the OMS, and all services and nodes in the cluster. The health check covers checks on the running status of each object, alarms, and user-defined monitoring metrics. The check result differs from the displayed Running Status. To export the result of the health check, click Export Report in the upper left corner. If any problem is detected, click Help.  |
        Download the default client for the user. For details, see Downloading the Client.  |
        Export all installation configurations of the cluster in batches, including the cluster authentication mode, node information, and service configurations. This operation is performed when the cluster needs to be reinstalled in the same environment.  |
        Export configurations of all services in the cluster in batches.  |
        More > Enter Maintenance Mode/Exit Maintenance Mode  |
        Configure the cluster to enter or exit the maintenance mode.  |
        More > O&M View  |
        Check the services or hosts that are in the maintenance state.  |
