Viewing Backup and Recovery Tasks
On FusionInsight Manager, view created backup and recovery tasks and check their running status.
You have logged in to FusionInsight Manager. For details, see Logging In to the Management System.
- On FusionInsight Manager, choose O&M > Backup and Restoration.
- Click Backup Management or Restoration Management.
- In the task list, obtain the previous execution result in the Task Status and Task Progress column. Green indicates that the task is executed successfully, and red indicates that the execution fails.
- In the task list, locate a specified task and choose More > View History or click View History in the Operation column to display historical records of backup and recovery task execution.
In the displayed window, click before a specified record to display log information about the execution.
Related Tasks
- Starting Backup and Recovery Tasks
In the task list, locate a specified task and choose More > Back Up Now or click Start in the Operation column to start a backup or recovery task that is ready or fails to be executed. Executed recovery tasks cannot be repeatedly executed.
- Stopping Backup and Recovery Tasks
In the task list, locate a specified task and choose More > Stop or click Stop in the Operation column to start a backup or recovery task that is running. After the task is successfully stopped, its Task Status changes to Stopped.
- Deleting Backup and Recovery Tasks
In the task list, locate a specified task and choose More > Delete or click Delete in the Operation column to delete a backup or recovery task. Backup data will be reserved by default after a task is deleted.
- Suspending Backup Tasks
In the task list, locate a specified task and choose More > Suspend in the Operation column to suspend a backup task. Only periodic backup tasks can be suspended. Suspended backup tasks are no longer executed automatically. When you suspend a backup task that is being executed, the task execution stops. To Resume a task, choose More > Resume.
