Help Center>
MapReduce Service>
User Guide (Kuala Lumpur Region)>
FusionInsight Manager Operation Guide (Applicable to 3.x)>
Tenant Resources>
Using the Capacity Scheduler in Multi-Tenant Scenarios>
Managing Resources>
Modifying a Resource Pool
Updated on 2022-12-14 GMT+08:00
If hosts in the resource pool need to be adjusted based on service requirements, administrators can modify members in the existing resource pool on FusionInsight Manager.
- Choose Tenant Resources > Resource Pool.
- Locate the row that contains the specified resource pool in the resource pool list, and click Edit in the Operation column.
- In Edit Resource Pool, modify Hosts.
- Adding a host: In the host list on the left, select the name of a specified host and click
to add the selected host to the resource pool.
- Deleting a host: In the host list on the right, select the name of a specified host and click
to delete the selected host from the resource pool. The host list of a resource pool can be left blank.
- Click OK to save the settings.
Parent topic: Managing Resources
