Updated on 2025-03-11 GMT+08:00
OBS Server-Side Error Codes (SDK for Python)
If the OBS server encounters an error when processing a request, a response containing the error code and error description is returned.
The following table lists details about each error and its HTTP status code.
HTTP Status Code
Error Code
Error Message
Solution
301 Moved Permanently
PermanentRedirect
The requested bucket can be accessed only through the specified address. Send subsequent requests to the address.
Send the request to the returned redirection address.
WebsiteRedirect
The website request lacks bucketName.
Put the bucket name in the request and try again.
307 Moved Temporarily
TemporaryRedirect
Temporary redirection. If the DNS is updated, the request is redirected to the bucket.
The system automatically redirects the request or sends the request to the redirection address.
400 Bad Request
BadDigest
The specified value of Content-MD5 does not match the value received by OBS.
Check whether the MD5 value carried in the header is the same as that calculated by the message body.
400 Bad Request
BadDomainName
Invalid domain name.
Use a valid domain name.
400 Bad Request
BadRequest
Invalid request parameter.
Modify the parameter according to the error details returned in the message body.
400 Bad Request
CustomDomainAreadyExist
The configured domain already exists.
It has been configured and does not need to be configured again.
400 Bad Request
CustomDomainNotExist
Delete the domain that does not exist.
It is not configured or has been deleted. You do not need to delete it.
400 Bad Request
EntityTooLarge
The size of the object uploaded using the POST method exceeds the upper limit.
Modify the conditions specified in the policy when posting the object or reduce the object size.
400 Bad Request
EntityTooSmall
The size of the object uploaded using the POST method does not reach the lower limit.
Modify the conditions specified in the policy when posting the object or increase the object size.
400 Bad Request
IllegalLocationConstraintException
A request without Location is sent for creating a bucket in a non-default region.
Send the bucket creation request to the default region, or send the request with the Location of the non-default region.
400 Bad Request
IncompleteBody
No complete request body is received due to network or other problems.
Upload the object again.
400 Bad Request
IncorrectNumberOfFilesInPost Request
Each POST request must contain one file to be uploaded.
Carry a file to be uploaded.
400 Bad Request
InvalidArgument
Invalid parameter.
400 Bad Request
InvalidBucket
The bucket to be accessed does not exist.
Try another bucket name.
400 Bad Request
InvalidBucketName
The bucket name specified in the request is invalid, which may have exceeded the maximum length, or contain special characters that are not allowed.
400 Bad Request
InvalidEncryptionAlgorithmError
Incorrect encryption algorithm. The object cannot be decrypted due to incorrect encryption header carried when downloading the SSE-C encrypted object.
Carry the correct encryption header when downloading the object.
400 Bad Request
InvalidLocationConstraint
The specified Location in the bucket creation request is invalid or does not exist.
Correct the Location in the bucket creation request.
400 Bad Request
InvalidPart
One or more specified parts are not found. The parts may not be uploaded or the specified entity tags (ETags) do not match the parts' ETags.
Specify the correct parts and entity tags.
400 Bad Request
InvalidPartOrder
Parts are not listed in ascending order by part number.
Sort the parts in ascending order and merge them again.
400 Bad Request
InvalidPolicyDocument
The content of the form does not meet the conditions specified in the policy document.
Modify the policy in the constructed form according to the error details in the message body and try again.
400 Bad Request
InvalidRedirectLocation
Invalid redirect location.
Specify the correct IP address.
400 Bad Request
InvalidRequest
Invalid request.
400 Bad Request
InvalidRequestBody
The request body is invalid. The request requires a message body but no message body is uploaded.
Upload the message body in the correct format.
400 Bad Request
InvalidTargetBucketForLogging
The delivery group has no ACL permission for the target bucket.
Configure the target bucket ACL and try again.
400 Bad Request
KeyTooLongError
The provided key is too long.
Use a shorter key.
400 Bad Request
KMS.DisabledException
The master key is disabled in the SSE-KMS mode.
Replace the key and try again, or contact the technical support.
400 Bad Request
KMS.NotFoundException
The customer master key (CMK) does not exist in SSE-KMS mode.
Retry with the correct master key.
400 Bad Request
MalformedACLError
The provided XML file has syntax errors or does not meet the format requirements.
Use the correct XML format to retry.
400 Bad Request
MalformedError
The XML format in the request is incorrect.
400 Bad Request
MalformedLoggingStatus
The XML format of Logging is incorrect.
400 Bad Request
MalformedPolicy
The bucket policy does not pass.
Modify the bucket policy according to the error details returned in the message body.
400 Bad Request
MalformedQuotaError
The Quota XML format is incorrect.
400 Bad Request
MalformedXML
An XML file of a configuration item is in incorrect format.
400 Bad Request
MaxMessageLengthExceeded
Copying an object does not require a message body in the request.
Remove the message body and retry.
400 Bad Request
MetadataTooLarge
The size of the metadata header has exceeded the upper limit.
Reduce the size of the metadata header.
400 Bad Request
MissingRegion
The region information is missing in the request, and the default region is required in the system.
Carry the region information in the request.
400 Bad Request
MissingRequestBodyError
This error code is returned after you send an empty XML file.
Provide the correct XML file.
400 Bad Request
MissingRequiredHeader
A required header is missing in the request.
Provide the required header.
400 Bad Request
MissingSecurityHeader
400 Bad Request
TooManyBuckets
You have attempted to create more buckets than allowed.
Delete some buckets and try again.
400 Bad Request
TooManyCustomDomains
Too many user accounts are configured.
Delete some user accounts and try again.
400 Bad Request
TooManyWrongSignature
The request is rejected due to high-frequency errors.
Replace AK and try again.
400 Bad Request
UnexpectedContent
The request requires a message body which is not carried by the client, or the request does not require a message body but the client carries the message body.
Try again according to the instruction.
400 Bad Request
UserKeyMustBeSpecified
This operation is only available to special users.
Contact the technical support.
403 Forbidden
AccessDenied
Access denied, because the request does not carry a date header or the header format is incorrect.
Provide a correct date header in the request.
403 Forbidden
AccessForbidden
Insufficient permissions. No CORS rule is configured for the bucket, or the CORS rule is not matched.
Modify the CORS configuration of the bucket or send the matched OPTIONS request based on the CORS configuration of the bucket.
403 Forbidden
AllAccessDisabled
The user has no permission to perform a specific operation. The bucket name is forbidden.
403 Forbidden
DeregisterUserId
The user has been deregistered.
Top up or re-register.
403 Forbidden
InArrearOrInsufficientBalance
The user account is in arrears, or the account balance insufficient.
Top up the account.
403 Forbidden
InsufficientStorageSpace
Insufficient storage space.
If the quota is exceeded, increase quota or delete some objects.
403 Forbidden
InvalidAccessKeyId
The access key ID provided by the customer does not exist in the system.
Provide correct access key ID.
403 Forbidden
NotSignedUp
You have not registered with the system.
Register OBS.
403 Forbidden
RequestTimeTooSkewed
The request time and the server's time differ a lot.
Check whether the difference between the client time and the current time is too large.
403 Forbidden
SignatureDoesNotMatch
The provided signature in the request does not match the signature calculated by OBS.
Check your secret access key and signature calculation method.
403 Forbidden
Unauthorized
You have not been authenticated in real name.
Authenticate your real name and try again.
404 Not Found
NoSuchBucket
The bucket does not exist.
Create a bucket and perform the operation again.
404 Not Found
NoSuchBucketPolicy
No bucket policy exists.
Configure a bucket policy.
404 Not Found
NoSuchCORSConfiguration
No CORS configuration exists.
Configure CORS first.
404 Not Found
NoSuchCustomDomain
The requested user domain does not exist.
Set a user domain first.
404 Not Found
NoSuchKey
The specified key does not exist.
Upload the object first.
404 Not Found
NoSuchLifecycleConfiguration
The requested Lifecycle does not exist.
Configure a lifecycle rule first.
404 Not Found
NoSuchUpload
The specified multipart upload does not exist. The upload ID does not exist or the multipart upload has been aborted or completed.
Use the existing part or reinitialize the part.
404 Not Found
NoSuchVersion
The specified version ID does not match any existing version.
Use a correct version ID.
404 Not Found
NoSuchWebsiteConfiguration
The requested website does not exist.
Configure the website first.
405 Method Not Allowed
MethodNotAllowed
The specified method is not allowed against the requested resource.
The message "Specified method is not supported." is returned.
The method is not allowed.
408 Request Timeout
RequestTimeout
The socket connection to the server has no read or write operations within the timeout period.
Check the network and try again, or contact technical support.
409 Conflict
BucketAlreadyExists
The requested bucket name already exists. The bucket namespace is shared by all users of OBS. Try again with another bucket name.
409 Conflict
BucketAlreadyOwnedByYou
Your previous request for creating the named bucket succeeded and you already own it.
You do not need to create the bucket again.
409 Conflict
BucketNotEmpty
The bucket that you tried to delete is not empty.
Delete the objects in the bucket and then delete the bucket.
409 Conflict
InvalidBucketState
Invalid bucket status. After cross-region replication is configured, bucket versioning cannot be disabled.
Enable bucket versioning or cancel cross-region replication.
409 Conflict
OperationAborted
A conflicting operation is being performed on this resource. Try again later.
Try again later.
409 Conflict
ServiceNotSupported
The request method is not supported by the server.
Not supported by the server. Contact technical support.
411 Length Required
MissingContentLength
The HTTP header Content-Length is not provided.
Provide the Content-Length header.
412 Precondition Failed
PreconditionFailed
At least one of the specified preconditions is not met.
Modify according to the condition prompt in the returned message body.
416 Client Requested Range Not Satisfiable
InvalidRange
The requested range cannot be obtained.
Replace the range value and try again.
500 Internal Server Error
InternalError
An internal error occurs. Try again later.
501 Not Implemented
ServiceNotImplemented
The request method is not implemented by the server.
Not supported currently. Contact the technical support.
503 Service Unavailable
ServiceUnavailable
The server is overloaded or has internal errors.
Try again later or contact the technical support.
SlowDown
Reduce your request frequency.
