Limiting Download Speed By Single-Connection Bandwidth Throttling
To prevent a client from using a large amount of bandwidth to download objects, you can use single-connection bandwidth throttling to limit the download speed, allowing other applications to have enough bandwidth.
You can limit the speed by:
SDK
When you use an SDK to send a request, you can only limit the download speed by single-connection bandwidth throttling. For details, see Single-Connection Bandwidth Throttling.
Object URL
| Item | Description |
| Object | Public read or public read/write object |
| Method | Add the bandwidth limit parameter in the x-obs-traffic-limit=value format to the end of the URL of the shared object. The value can be from 819200 to 838860800, in bit/s. |
| Scenarios | Downloading objects |
| Example | https://bucketname.obs.cn-north-4.myhuaweicloud.com/object1?x-obs-traffic-limit=819200 indicates that the maximum download speed of object1 is 100 KB/s. |
Signed URL
| Object | Private object |
| Method | When you use an SDK to generate a signed URL, add the bandwidth limit parameter in the x-obs-traffic-limit=value format to the signature for calculation. The value can be from 819200 to 838860800, in bit/s. |
| Example | https://bucketname.obs.cn-north-4.myhuaweicloud.com/object1?x-obs-traffic-limit=819200&Signature=signature |
Header Field
| Item | Description | ||
| Object | Private object | ||
| Method | Add the bandwidth limit parameter in the x-obs-traffic-limit:value format to the header field. The value can be from 819200 to 838860800, in bit/s. | ||
| Scenarios | Downloading objects | ||
| Example |
