Updated on 2026-11-24 GMT+08:00
Sharing an Object
You can share temporary URLs of your objects with others for them to access your objects stored in OBS.
Background Information
You can share files with other users temporarily or permanently.
  • Temporary sharing:
    Share a file to other users through the temporary URL of the file. File sharing is temporary. All shared URLs are only valid for a limited period of time.
    A temporary URL consists of the access domain name and the temporary authentication information of a file. Example:
    https://bucketname.obs.ap-southeast-1.myhuaweicloud.com:443/image.png?AccessKeyId=xxx&Expires=xxx&x-obs-security-token=xxx&Signature=xxx
    The temporary authentication information contains the AccessKeyId, Expires, x-obs-security-token, and Signature parameters. AccessKeyId, x-obs-security-token, and Signature are used for authentication. The Expires parameter specifies the validity period of the authentication.
    For details about temporary authentication and its parameters, see Using a Pre-Signed URL in the Object Storage Service API Reference.
  • Permanent sharing:
    If you set the permission for an object to allow anonymous users to read it, anonymous users can access the object through the URL that you shared. For details about how to configure permissions, see Granting All Accounts the Read Permission for Certain Objects.
    The method of using a browser to access objects varies depending on the object type. You can directly open .txt and .html files using a browser. However, when you open .exe and .dat files using a browser, the files are automatically downloaded to your local computer.
    For details about how to obtain the object access URL, see How Do I Obtain the Access Path to an Object?
    If access to an object using the URL fails, fix the problem by referring to Why Can't I Access an Object Through Its URL?
  • An access code is not required for temporarily sharing a file. For temporarily sharing a folder, choose sharing by access code. For details, see Sharing a Folder.
  • The following table describes the URL validity period of the files that are temporarily shared in different ways.
    Way
    URL Validity Period
    OBS Console
    The URL is valid for 1 minute to 18 hours.
    When you click the Share button for an object, OBS retrieves temporary authentication information with a default validity of 5 minutes and creates a sharing link. Each time you change the validity period of a URL, OBS obtains the authentication information again to create a new shared URL. This new URL is in effect immediately upon the change.
    If you need a longer validity period, you can use OBS Browser+ to set a validity period of up to one year. If you want a shared object to be permanently valid, use a bucket policy to grant anonymous users the read-only permission for the object.
    SDKs
    Configure the Expires parameter to define when a temporary authorization ends. A temporary authorization can last for up to 20 years.
    APIs
    OBS Browser+
    • When you log in with an account and password, a shared URL can be valid for up to 24 hours. The default validity period is 10 hours.
    • When you log in with a permanent AK/SK pair, a shared URL can be valid for up to one year. The default validity period is one day.
    • When you log in with an access code, the shared URL is valid for the period set by the sharer.
    obsutil
    Use the additional parameter e to specify when an object download URL expires. The minimum value is 60s, the default is 300s, and there is no upper limit.
  • Only buckets whose version is 3.0 support object sharing. For details about how to query the bucket version, see Checking Your OBS Version (OBS 2.0 or OBS 3.0).
  • Archive objects can be shared only after they have been restored.
  • Deep Archive objects can be shared only after they have been restored.
  • Object sharing is currently available only in some regions.
Ways to Share an Object
You can share objects through OBS Console, APIs, SDKs, OBS Browser+, or obsutil.
