Help Center/ Object Storage Service/ User Guide/ Object Management/ Object Management/ Configuring, Editing, and Viewing Object Metadata
Updated on 2026-11-24 GMT+08:00
Object metadata is a set of name-value pairs that describe an object and is used for object management. OBS has two types of metadata: system-defined object metadata and user-defined object metadata. System-defined metadata includes the object's creation date, size, and storage class. User-defined metadata is the metadata that you can set for an object to identify the purpose or properties of the object.
You can configure metadata for an OBS object during upload. After the upload, you can also add or edit metadata for the object.
Metadata Introduction
  • In a versioning-enabled bucket, you can only configure metadata for the latest version of an object, but not for historical versions.
  • Metadata cannot be configured for Archive or Deep Archive objects.
  • The total size of user-defined metadata is limited to 8 KB.
  • For the permissions required to configure, edit, or view object metadata, see Object Actions.
Ways to Configure Object Metadata
You can configure object metadata through OBS Console or APIs.
Ways to Edit Object Metadata
You can edit object metadata through OBS Console or APIs.
Ways to View Object Metadata
You can view object metadata through OBS Console, SDKs, or obsutil, or APIs.
