Updated on 2026-11-24 GMT+08:00
Server-Side Encryption Overview
Server-side encryption helps secure data stored in OBS and meet compliance requirements. It encrypts data at rest, storing data as ciphertext on physical storage media like hard disks. This ensures that even if the media is lost or accessed without authorization, the data remains protected. When the data is accessed, the OBS server decrypts it and then returns the plaintext data.
OBS supports three encryption methods: server-side encryption with KMS-managed keys (SSE-KMS), server-side encryption with OBS-managed keys (SSE-OBS), and server-side encryption with customer-provided keys (SSE-C).
Table 1 OBS server-side encryption methods
Comparison Dimension
SSE-KMS
SSE-OBS
SSE-C
Scenarios that require high compliance and security. Keys are generated by third-party validated Hardware Secure Modules (HSMs). Access to keys is controlled and all operations involving keys are traceable by logs.
Scenarios that require basic encryption and batch processing. OBS does not need to interact with KMS. SSE-OBS features lower access latency and better performance than SSE-KMS.
Scenarios where users need to store and manage keys by themselves
Key management
KMS generates and keeps keys, and OBS uses the keys to encrypt objects.
OBS generates and keeps keys, and uses the keys to encrypt objects.
A user generates and keeps keys, and OBS uses the keys to encrypt objects.
Encryption algorithm
AES-256 and SM4
AES-256
AES-256
Encryption scope
Bucket level and object level
Object level
Details
See SSE-KMS.
See SSE-OBS.
See SSE-C.
  • For the regions where SSE-KMS is supported, see the management console. If you want to use the SM4 encryption algorithm when enabling SSE-KMS, choose the CN North-Ulanqab1 region.
  • SSE-C is available in the regions where the SSE-C API is supported.
  • Only one encryption method can be used each time an object is uploaded. The encryption configuration of an uploaded object cannot be changed.
  • If a bucket or its objects are encrypted with SSE-KMS, you must have the kms:cmk:get, kms:cmk:list, kms:cmk:create, kms:dek:create, kms:dek:encrypt, and kms:dek:decrypt permissions granted using IAM, so that you can upload objects to or download objects from that bucket.
  • If server-side encryption is not configured for a bucket, you must use HTTPS to access encrypted objects in it.
  • A key in use cannot be deleted, or the object encrypted with this key cannot be downloaded.
  • Server-side encryption for parallel file systems has the following constraints:
    • Only SSE-KMS is supported, and the bucket key must be enabled. (For parallel file systems, the bucket key is also called the parallel file system key.)
    • Encrypting files during upload with encryption headers is not supported. Such headers include x-obs-server-side-encryption, x-obs-server-side-data-encryption, and x-obs-server-side-encryption-kms-key-id. By default, uploaded files inherit the encryption settings of the parallel file system.
    • Changes to the server-side encryption settings of a parallel file system take about three seconds to take effect.
Bucket-Level and Object-Level Server-Side Encryption
The following table compares bucket-level and object-level server-side encryption.
Table 2 Comparison between bucket-level and object-level server-side encryption
Item
Bucket-Level Encryption
Object-Level Encryption
You need to encrypt all objects when they are uploaded to a bucket.
You need to encrypt only some objects or select an encryption method and key each time you upload an object.
Encryption methods
SSE-KMS and SSE-OBS
SSE-KMS, SSE-OBS, and SSE-C
Configuration
You can change your encryption configuration at any time.
You can configure encryption during object upload and the configuration cannot be changed after the upload.
Impacts
  • If encryption is not enabled for a bucket, you can separately configure encryption when uploading objects to the bucket.
  • If encryption is enabled for a bucket, OBS only encrypts the objects uploaded after encryption is enabled, and does not encrypt those uploaded before. When you upload objects to this bucket, they will inherit the bucket's encryption by default, but you can change the configuration if needed.
  • If you change the encryption configuration for a bucket, only the objects uploaded after the change will inherit the new configuration. Objects uploaded before the change will retain the original configuration.
  • Disabling encryption for a bucket does not change the encryption status of existing objects in the bucket. However, objects uploaded later will not be forcibly encrypted. If necessary, you can manually encrypt subsequent objects when you upload them to the bucket.
Helpful Links
  • You can use Cloud Trace Service (CTS) to monitor bucket encryption operations, including setBucketEncryption (which configures server-side encryption for a bucket) and deleteBucketEncryption (which deletes the bucket's server-side encryption settings). For more information, see Using CTS to Audit OBS.
  • You can enable logging for OBS to automatically log bucket encryption operations, including REST.PUT.ENCRYPTION (which configures encryption for a bucket), REST.GET.ENCRYPTION (which obtains the bucket's encryption settings), and REST.DELETE.ENCRYPTION (which deletes the bucket's encryption settings). OBS writes the generated log files to the specified bucket. For more information, see Configuring Logging for a Bucket.
