Updated on 2026-08-21 GMT+08:00
Removing Image Metadata
You can edit code on OBS Console or make an API call to remove image metadata.
For details about how to use image styles, see Step 3: Creating an Image Style and Processing the Image.
The following operation is used to remove image metadata.
This operation is represented by strip.
