Updated on 2025-12-12 GMT+08:00
Lifecycle Configuration Examples
If you use APIs or SDKs to create a lifecycle rule, refer to the XML example.
Specifying a Rule with a Single Filter Condition
Example 1: Applying a lifecycle rule to all objects in a bucket
To apply the rule to all objects in the bucket, leave the prefix blank. Objects will be transitioned to the Archive storage class 100 days after creation.
XML:
 3
 4
 5
 6
 7
 8
 9
10
11
<LifecycleConfiguration>
    <Rule>
        <ID>sample-rule</ID>
        <Prefix></Prefix>
        <Status>Enabled</Status>
        <Transition>
            <Days>100</Days>
            <StorageClass>COLD</StorageClass>
        </Transition>
    </Rule>
</LifecycleConfiguration>
Example 2: Specifying a filter by object name prefix
The following lifecycle rule specifies prefix texta/ as the filter. It applies to objects with the texta/ prefix, such as texta/file1.txt and texta/file2.txt.
This rule specifies two actions: transitioning objects to the Infrequent Access storage class 90 days after creation and deleting objects 120 days after creation.
XML:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
    <Rule>
        <Prefix>texta/</Prefix>
        <Transition>
            <Days>90</Days>
            <StorageClass>WARM</StorageClass>
        </Transition>
        <Expiration>
            <Days>120</Days>
        </Expiration>
    </Rule>
Example 3: Specifying a filter by object name prefix to delete objects that were last modified before the given date
This rule specifies one action: deleting objects that were last modified before May 30, 2024.
XML:
 3
 4
 5
 6
 7
 8
 9
10
    <Rule>
        <Expiration>
            <Date>2024-05-30T00:00:00.000Z</Date>
        </Expiration>
    </Rule>
Example 4: Specifying a filter by object name prefix to transition objects that were last modified before the given date
This rule specifies one action: transitioning objects that were last modified before May 30, 2024 to the Archive storage class.
XML:
 3
 4
 5
 6
 7
 8
 9
10
11
    <Rule>
        <Transition>
        </Transition>
    </Rule>
Specifying a Rule with Multiple Filter Conditions
To use multiple filters in a single rule, you must wrap the filters in an And element.
Example 1: Specifying a rule with multiple filter conditions
  • The following rule deletes objects with the texta/ prefix and with tags key1/value1 and key2/value2 120 days after their creation.
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
        <Rule>
            <Filter>
                <And>
                    <Tag>
                        <Key>key1</Key>
                        <Value>value1</Value>
                    </Tag>
                    <Tag>
                        <Key>key2</Key>
                        <Value>value2</Value>
                    </Tag>
                </And>
            </Filter>
            <Expiration>
                <Days>120</Days>
            </Expiration>
        </Rule>
Specifying Multiple Rules
If you want objects to have different lifecycle actions, you can specify multiple rules. The following lifecycle configuration has two rules:
  1. Rule 1 applies to objects with the texta/ prefix. It directs OBS to transition objects to the Archive storage class 120 days after creation and to delete them 360 days after creation.
  2. Rule 2 applies to objects with the textb/ prefix. It directs OBS to transition objects to the Infrequent Access storage class 90 days after creation and to delete them 120 days after creation.
XML:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
    <Rule>
        <ID>sample-rule1</ID>
        <Transition>
            <Days>120</Days>
        </Transition>
        <Expiration>
            <Days>360</Days>
        </Expiration>
    </Rule>
    <Rule>
        <ID>sample-rule2</ID>
        <Prefix>textb/</Prefix>
        <Transition>
            <Days>90</Days>
        </Transition>
        <Expiration>
            <Days>120</Days>
        </Expiration>
    </Rule>
Specifying Multiple Rules with Overlapping Filter Conditions
For details about overlapping prefixes and conflicting actions, see Overlapping Lifecycle Rules.
Example 1: Overlapping prefixes (no conflict)
  • Rules: Rule 1 specifies an empty filter (indicating all objects in the bucket). It lets OBS delete all objects 120 days after creation. Rule 2 specifies the typea/ prefix (indicating objects with the typea/ prefix). It lets OBS transition objects to the Archive storage class 90 days after creation.
  • Result: There are no conflicting lifecycle actions. Objects with the typea/ prefix are transitioned to the Archive storage class 90 days after creation and then deleted 120 days after creation.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
    <Rule>
        <Prefix></Prefix>
        <Expiration>
            <Days>120</Days>
        </Expiration>
    </Rule>
    <Rule>
        <Prefix>typea/</Prefix>
        <Transition>
            <Days>90</Days>
        </Transition>
    </Rule>
Example 2: Conflicting prefixes and tags (no conflict)
  • Rules: Rule 1 specifies the ab prefix and a tag (key1/value1). It lets OBS delete objects 120 days after creation. Rule 2 specifies the abc prefix and two tags (key1/value1 and key2/value2). It lets OBS transition objects to the Archive storage class 90 days after creation.
  • Result: There are no conflicting lifecycle actions. Objects with the abc prefix and with tags key1/value1 and key2/value2 are transitioned to the Archive storage class 90 days after creation and then deleted 120 days after creation.
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
        <Rule>
            <Filter>
                <And>
                    <Prefix>ab</Prefix>
                    <Tag>
                        <Key>key1</Key>
                    </Tag>
               </And>
            </Filter>
            <Expiration>
                <Days>120</Days>
            </Expiration>
        </Rule>
        <Rule>
            <Filter>
                <And>
                    <Prefix>abc</Prefix>
                    <Tag>
                        <Key>key1</Key>
                    </Tag>
                    <Tag>
                        <Key>key2</Key>
                    </Tag>
                </And>
            </Filter>
            <Transition>
                <Days>90</Days>
            </Transition>
        </Rule>
Example 3: Overlapping prefixes resulting in conflicting lifecycle actions
  • Rules: Rule 1 specifies an empty filter (indicating all objects in the bucket). It lets OBS delete all objects 90 days after creation. Rule 2 specifies the typea/ prefix (indicating objects with the typea/ prefix). It lets OBS transition objects to the Archive storage class 120 days after creation.
  • Result: The lifecycle actions conflict. Such configuration is not allowed.
  •  1
     2
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
        <Rule>
            <Prefix></Prefix>
            <Expiration>
                <Days>90</Days>
            </Expiration>
        </Rule>
        <Rule>
            <Transition>
                <Days>120</Days>
            </Transition>
        </Rule>
Example 4: Overlapping prefixes and tags resulting in conflicting lifecycle actions
  • Rules: Rule 1 specifies the abc prefix and a tag (key1/value1). It lets OBS delete objects 90 days after creation. Rule 2 specifies the ab prefix and two tags (key1/value1 and key2/value2). It lets OBS transition objects to the Archive storage class 120 days after creation.
  •  1
     2
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
        <Rule>
            <Filter>
                <And>
                    <Tag>
                        <Key>key1</Key>
                    </Tag>
               </And>
            </Filter>
            <Expiration>
                <Days>90</Days>
            </Expiration>
        </Rule>
        <Rule>
            <Filter>
                <And>
                    <Prefix>ab</Prefix>
                    <Tag>
                        <Key>key1</Key>
                    </Tag>
                    <Tag>
                        <Key>key2</Key>
                    </Tag>
                </And>
            </Filter>
            <Transition>
                 <Days>120</Days>
            </Transition>
         </Rule>
Deleting Fragments
The following lifecycle rule specifies prefix texta/ as the filter. It applies to objects with the texta/ prefix, such as texta/file1.txt and texta/file2.txt. This rule lets OBS delete object fragments 10 days after generation.
 3
 4
 5
 6
 7
 8
 9
10
   <Rule>
        <AbortIncompleteMultipartUpload>
            <DaysAfterInitiation>10</DaysAfterInitiation>
        </AbortIncompleteMultipartUpload>
    </Rule>
Specifying a Lifecycle Rule for a Versioning-Enabled/Suspended Bucket
Example 1: Periodically transitioning and deleting historical object versions
The following lifecycle rule specifies prefix prefix1/ as the filter. It applies to objects with the prefix1/ prefix, such as prefix1/file1.txt and prefix1/file2.txt.
This rule specifies two lifecycle actions: transitioning historical object versions to the Archive storage class 20 days after generation and deleting them 30 days after generation.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
     <Rule>
         <Prefix>prefix1/</Prefix>
         <NoncurrentVersionTransition>
             <NoncurrentDays>20</NoncurrentDays>
         </NoncurrentVersionTransition>
         <NoncurrentVersionExpiration>
             <NoncurrentDays>30</NoncurrentDays>
         </NoncurrentVersionExpiration>
     </Rule>
Example 2: Removing expired delete markers
If all versions of an object with the prefix1/ prefix have been deleted and only one expired delete marker remains, this rule lets OBS remove this expired delete marker.
 3
 4
 5
 6
 7
 8
 9
10
   <Rule>
        <Expiration>
            <ExpiredObjectDeleteMarker>true</ExpiredObjectDeleteMarker>
        </Expiration>
    </Rule>
Disabling a Lifecycle Rule
The following configuration disables a lifecycle rule. This rule applies to objects with the texta/ prefix and transitions objects to the Archive storage class 100 days after creation.
XML:
 3
 4
 5
 6
 7
 8
 9
10
11
    <Rule>
        <Status>Disabled</Status>
        <Transition>
            <Days>100</Days>
        </Transition>
    </Rule>
