Updated on 2026-11-02 GMT+08:00
Lifecycle Configuration Elements
The following uses an example to describe the elements of a lifecycle rule.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
<LifecycleConfiguration>
     <!-- First rule -->
     <Rule>
         <ID>Rule-1</ID>
         <Prefix>prefix1</Prefix>
         <Status>Enabled</Status>
         <!-- Delete the current version of an object whose last modification time was before May 20, 2023 and prefix is prefix1/. -->
         <Expiration>
             <Date>2023-05-20T00:00:00.000Z</Date>
         </Expiration>
     </Rule>
     <!-- Second rule -->
     <Rule>
         <ID>Rule-2</ID>
         <Filter>
             <Prefix>prefix2</Prefix>
             <Tag>
                 <Key>key1</Key>
                 <Value>value1</Value>
             </Tag>
         </Filter>
         <!-- Transition the current version of any object with the prefix prefix2/, tagged key1/value1, and last modified 30 days ago to the Archive storage class. -->
         <Transition>
             <Days>30</Days>
             <StorageClass>COLD</StorageClass>
         </Transition>
         <!-- Delete the current version of an object whose prefix is prefix2/, tag is key1/value1, and last modification time is 60 days ago. -->
         <Expiration>
             <Days>60</Days>
         </Expiration>
         <!-- Transition the historical versions of any object with the prefix prefix2/, tagged key1/value1, and last modified 30 days ago to the Archive storage class. -->
         <NoncurrentVersionTransition>
             <NoncurrentDays>30</NoncurrentDays>
         </NoncurrentVersionTransition>
         <!-- Delete the historical version of an object whose prefix is prefix2/, tag is key1/value1, and last modification time is 60 days ago. -->
         <NoncurrentVersionExpiration>
             <NoncurrentDays>60</NoncurrentDays>
         </NoncurrentVersionExpiration>
     </Rule>
 </LifecycleConfiguration>
Elements of a lifecycle rule
A complete lifecycle rule consists of a range of elements that fall into metadata, filters, and actions (execution time included).
Figure 1 Elements of a lifecycle rule
Metadata
Rule metadata describes the rule ID and rule status.
Table 1 Metadata elements
Element
Metadata
ID
Definition:
Rule ID, which uniquely identifies a rule.
Value range:
The value is a string ranging from 0 (exclusive) to 255 characters. It can contain only uppercase or lowercase letters, digits, periods (.), underscores (_), and hyphens (-).
Default value:
If the ID element is not used or is left blank, OBS automatically assigns a unique ID to the rule.
Status
Definition:
It indicates whether the rule is enabled or disabled. If the rule is disabled, OBS does not perform any actions defined in the rule.
Value range:
  • Enabled: The rule is enabled.
  • Disabled: The rule is disabled.
Default value:
N/A
Filters
The object filter criteria of a rule describe the objects to which a lifecycle rule is applied.
Table 2 Filter elements
Element
Filters
Prefix
Definition:
Object name prefix, which identifies the objects to which the lifecycle rule applies
If you leave the Prefix element blank, the rule applies to all objects in the bucket.
Constraints:
  • Each lifecycle rule must have only one prefix. If no prefix is required for filtering, use <Prefix></Prefix> to leave the Prefix element blank.
  • If you specify only the Prefix element and no Tag element, the parent node Filter is not required. In the example below, only the texta/ prefix is specified and no Tag elements are specified, so the Filter element is not required.
     3
     4
     5
     6
     7
     8
     9
    10
    11
        <Rule>
            <ID>sample-rule</ID>
            <Prefix>texta/</Prefix>
            <Transition>
                <Days>100</Days>
            </Transition>
        </Rule>
Value range:
The value is a string ranging from 0 to 1024 characters.
Default value:
If this element is not specified, it is left blank by default.
Tag
Definition:
Object tag, which identifies the objects to which the lifecycle rule applies.
Constraints:
  • Object tags cannot be used as filters for deleting fragments or deleting expired delete markers.
  • A lifecycle rule allows for zero or up to 10 object tags.
  • If there are multiple tags specified in a rule, each tag key must be unique.
  • A tag key:
    • Can be up to 128 characters long, including letters, digits, and spaces representable in UTF-8, and the following special characters: _ . : = + - @
    • Must be case sensitive. If there are multiple tags, each tag key must be unique.
    • Cannot be left blank.
  • A tag value:
    • Can be up to 255 characters long, including letters, digits, and spaces representable in UTF-8, and the following special characters: _ . : /= + - @
    • Can be left blank.
In the example below, objects with the key1/value1 tag will be deleted 120 days after the last update.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
    <Rule>
        <Filter>
            <Tag>
                <Key>key1</Key>
            </Tag>
        </Filter>
        <Expiration>
            <Days>120</Days>
        </Expiration>
    </Rule>
Default value:
Combination of Prefix and Tag
You can filter objects by a combination of prefix and object tags. In this case, you need to use a logical And to combine the filters. A logical And must contain at least two filter conditions. Prefix is mandatory and only one prefix can be configured. Tag is optional and up to 10 tags can be configured.
In the example below, objects with the key1/value1 tag and the texta/ prefix will be deleted 120 days after the last modification.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
    <Rule>
        <Filter>
            <And>
                <Tag>
                    <Key>key1</Key>
                </Tag>
            </And>
        </Filter>
        <Expiration>
            <Days>120</Days>
        </Expiration>
    </Rule>
Actions
The following table describes actions that will be performed on objects and when the actions will be performed.
Table 3 Elements to describe lifecycle actions
Element
Sub-elements
Expiration
Used to delete objects
The Expiration action does not delete unassembled multipart uploads.
Days
(Use only one of the Days, Date, and ExpiredObjectDeleteMarker elements.)
Definition:
The number of days since the last object update, after which eligible objects will be expired and then deleted
Constraints:
  • Days applies only to the current version of an object.
  • For the same object, the time specified for Expiration must be later than that for Transition.
Value range:
A positive integer, in days
Default value:
N/A
Date
Definition:
The date, before which objects were last modified will be expired and then deleted
Constraints:
  • Date applies only to the current version of an object.
  • The date must comply with ISO 8601, and its time must be 00:00:00 in UTC. If Date is set to 2018-01-01T00:00:00.000Z, objects whose last modification time is earlier than 2018-01-01T00:00:00.000Z will be deleted.
  • OBS Console and OBS Browser+ do not support the deletion of objects on a specified date.
Default value:
N/A
Used to remove expired delete markers
Definition:
Whether to remove expired delete markers
Constraints:
Object tags cannot be used as filters.
Value range:
  • true: Expired delete markers are removed.
  • false: Expired delete markers are not removed.
Default value:
N/A
Transition
Used to transition objects between storage classes
Days
(Use either Days or Date.)
Definition:
The number of days since the last object update, after which eligible objects will be transitioned to another storage class
Constraints:
Value range:
Unit: day
  • If only one transition is configured, the time should be at least one day after the update.
  • If multiple transitions are configured, the transition to the Deep Archive storage class must be later than the transition to Archive, and the transition to Archive must be later than the transition to Infrequent Access.
Default value:
N/A
Date
Definition:
The date, before which objects were last modified will be transitioned to another storage class
Constraints:
  • The date must comply with ISO 8601, and its time must be 00:00:00 in UTC. If Date is set to 2018-01-01T00:00:00.000Z, objects whose last modification time is earlier than 2018-01-01T00:00:00.000Z will be transitioned to another storage class.
  • OBS Console and OBS Browser+ do not support the transition of objects on a specified date.
Default value:
N/A
StorageClass
Definition:
New storage class eligible objects will be transitioned to
Value range:
  • WARM: the Infrequent Access storage class
  • COLD: the Archive storage class
  • DEEP_ARCHIVE: the Deep Archive storage class
Default value:
N/A
AbortIncompleteMultipartUpload
Used to delete fragments
DaysAfterInitiation
Definition:
The number of days since fragment generation, after which fragments will be expired and then deleted
Constraints:
Value range:
Default value:
N/A
Used to delete historical object versions
NoncurrentDays
Definition:
The number of days since the objects became historical, after which historical object versions will be deleted
Constraints:
  • NoncurrentDays only applies to historical object versions.
  • NoncurrentDays can only be used for buckets that have versioning enabled or suspended.
  • For the same historical version of an object, the time specified for Expiration must be later than that for Transition.
Value range:
Default value:
N/A
Used to transition historical versions
NoncurrentDays
Definition:
The number of days since the objects became historical, after which historical object versions will be transitioned to another storage class
Constraints:
Value range:
Unit: day
  • If multiple transitions are involved, the latter transition should be at least one day later than the former transition.
Default value:
N/A
StorageClass
Definition:
New storage class eligible historical object versions will be transitioned to
Value range:
Default value:
N/A
In the same lifecycle rule, Days or Date must be consistently used. If you use Days for Expiration, you must also use Days (rather than Date) for Transition, and vice versa.
