Downloading a File
Through OBS Console, you can download files from OBS to your PC. You can specify a download path or use the system default path.
Limitations and Constraints
Objects in the Cold storage class can be downloaded only when they are in the Restored state.
- In the bucket list, click the bucket to be operated. The Overview page of the bucket is displayed.
 - In the navigation pane, click Objects.
 - Select the files you want to download, and then click Download or More > Download As to download the files.
     In the Download As dialog box, right-click the object and choose Copy Link Address from the shortcut menu to obtain the download link address of the object.
