Configuring Tags for a Bucket
You can add tags to a bucket when creating the bucket. For details, see Creating a Bucket. Also you can add tags to a bucket after it has been created. This topic describes how to add tags to a bucket after it has been created.
- In the bucket list, click the bucket to be operated. The Overview page of the bucket is displayed.
- In the right Basic Configurations area, click Tags. The Tags page is displayed.
Alternatively, you can choose Basic Configurations > Tags in the navigation pane on the left.
- Click Add Tag. The Add Tag dialog box is displayed.
- Set the key and value based on Table 1.
Table 1 Parameter description Parameter
Key
Specifies the key of the tag. Each tag of a bucket has a unique key. The value of the key can be self-defined or predefined by TMS.
A tag key must comply with the following naming rules:
- Must contain 1 to 36 characters.
- The value cannot start or end with a space or contain the following characters: =*<>\,|/
Value
Specifies the value of the tag. Tags of a bucket can have repetitive or blank values.
The tag value must comply with the following naming rules:
- It ranges from 0 to 43 characters.
- Cannot contain the following characters: =*<>\,|/
- Click OK.
It takes approximately 3 minutes for the tag to take effect.
Related Operations
To modify the tag configuration, edit Value of the tag. You can also click Delete next to a tag to delete the tag.
