Monitoring OBS
In the use of OBS, you may continuously send PUT and GET requests that generate upload and download traffic or receive error responses from the server. Huawei Cloud provides Cloud Eye to help you better understand the status of your OBS buckets. You can use Cloud Eye to monitor your OBS buckets, perform automatic real-time monitoring, and configure alarm reporting and notifications. This helps you track requests to your buckets, analyze bucket usage, and understand the workload trends of your buckets, enabling you to promptly identify and resolve issues.
You do not need to separately subscribe to Cloud Eye. It starts automatically once you create a resource (a bucket, for example) in OBS. For more information about Cloud Eye, see What Is Cloud Eye?
OBS monitoring metrics are classified into request metrics and storage metrics. For details, see OBS Monitoring Metrics. Monitored OBS Events describes the event types supported by OBS.
Important Notes
Bucket names are globally unique. If you delete a bucket and recreate one with the same name, the monitoring data and alarm rules of the deleted bucket will be applied to the new one. You are advised to clear the alarm rules associated with the deleted bucket or reconfigure monitoring and alarm rules after creating a bucket with the same name.
Monitoring OBS
You can use the following methods provided by Cloud Eye to comprehensively monitor OBS, as shown in Figure 1.
Monitoring Data Retention Policy
For details about the retention period of monitoring data, see How Long Is the Metric Data Retained.
