Updated on 2022-05-17 GMT+08:00
Special Billing Scenarios
Lifecycle Rules
If you configure lifecycle rules to perform actions automatically, you will be billed. The following tables list billable items and their descriptions.
For detailed information about billing items, see Overview.
Table 1 Fees related to lifecycle management actions (during action execution)
Action
Billing Category
Delete after expiration
Requests
You are charged for the number of successfully deleted objects.
Storage space
If objects are deleted before they have been stored for the required minimum duration (30 days for Warm storage and 90 days for Cold storage), you will still be billed for a full 30 or 90 days.
Transition from Standard to Warm
Requests
You are charged for the number of successfully transitioned objects.
If N objects are successfully transitioned, you are billed for N requests.
Transition from Standard to Cold
Requests
Transition from Warm to Cold
Requests
Table 2 Fees related to lifecycle management actions (after action execution)
Action
Billing Category
None
None
Storage space
After the transition, object storage fees are calculated based on the Warm storage price.
Data retrieval
After the transition, retrieving Warm objects will be charged based on the object size.
Storage space
After the transition, object storage fees are calculated based on the Cold storage price.
Data retrieval
After the transition, retrieving Cold objects will be charged based on the object size and restoration speed.
Storage space
  1. After the transition, object storage fees are calculated based on the Cold storage price.
  2. If Warm objects are transitioned to Cold ones before they have been stored for the required minimum duration (30 days), you will still be charged for a full 30 days.
Data retrieval
